Caterpillar Forklift NSP16N3R Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00048958
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar NSP16N3R Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: DOC00048958
Number of Pages: 549 Pages
001_01-01-01 ACCESSORIES
002_01-01-02 ACCUMULATOR PLUG
003_01-01-03 COMPUTER RACK
004_01-01-04 LIST BRACKET
005_01-01-05 ACCESSORY RACK
006_01-01-06 BUZZER
007_01-01-07 BATTERY CHANGING DEVICE
008_01-01-08 LI-ION KIT
009_01-01-09 MAST, LOOSE PARTS, STANDARD
010_01-01-10 MAST, LOOSE PARTS, INITIAL LIFT
011_01-01-11 MAST, LOOSE PARTS, STRADDLE
012_01-01-12 BATTERY SHIMMING
013_02-02-01 ELECTRIC PANEL
014_02-02-02 ELECTRIC PANEL, SWE
015_02-02-03 ELECTRIC PANEL, PLATFORM
016_02-02-04 ELECTRIC PANEL, PLATFORM, SWE
017_02-02-05 FAN
018_02-02-06 FAN (RL638286)
019_02-02-07 CHARGING CONNECTOR, 150Ah BATTERY
020_02-02-08 CHARGING CONNECTOR, 250_375_500Ah BATTERY
021_02-02-09 INTERNAL CHARGER POWER CABLE, LEAD ACID, EURO
022_02-02-10 INTERNAL CHARGER POWER CABLE, LEAD ACID, UK
023_02-02-11 INTERNAL CHARGER POWER CABLE, LEAD ACID, DK
024_02-02-12 INTERNAL CHARGER POWER CABLE, LEAD ACID, SUI
025_02-02-13 ON-BOARD CHARGER POWER CABLE, LI-ION, EURO
026_02-02-14 ON-BOARD CHARGER POWER CABLE, LI-ION, UK
027_02-02-15 ON-BOARD CHARGER POWER CABLE, LI-ION, DK
028_02-02-16 ON-BOARD CHARGER POWER CABLE, LI-ION, SUI
029_02-02-17 INTERNAL CHARGER, 30A
030_02-02-18 POWER SUPPLY, 12V 150W
031_03-03-01 FORK CARRIAGE
032_03-03-02 FORK CARRIAGE, W_ LOAD BACKREST
033_03-03-03 FORK CARRIAGE, INITIAL LIFT
034_03-03-04 FORK CARRIAGE, W_ LOAD BACKREST, INITIAL LIFT
035_03-03-05 LIFTING CARRIAGE, SIMPLEX, DUPLEX, DUPLEX W_ FREE LIFT, STRADDLE
036_03-03-06 LIFTING CARRIAGE, TRIPLEX, STRADDLE
037_03-03-07 LIFTING CARRIAGE, TRIPLEX W_ FREE LIFT
038_03-03-08 LEVERAGE, SIMPLEX & DUPLEX
039_03-03-09 LEVERAGE, TRIPLEX
040_03-03-10 LOAD SUPPORT, WO_ STRADDLE
041_03-03-11 LOAD SUPPORT, STRADDLE
042_04-04-01 MAIN ASSEMBLY
043_04-04-02 MAIN ASSEMBLY, INITIAL LIFT
044_04-04-03 MAIN ASSEMBLY, STRADDLE
045_04-04-04 TRACTOR UNIT
046_04-04-05 TRACTOR UNIT, SWE
047_04-04-06 TRACTOR UNIT, SIDE SUPPORT
048_04-04-07 TRACTOR UNIT, INITIAL LIFT
049_04-04-08 TRACTOR UNIT, INITIAL LIFT, SWE
050_04-04-09 TRACTOR UNIT, INITIAL LIFT + PLATFORM
051_04-04-10 TRACTOR UNIT, INITIAL LIFT + PLATFORM, SWE
052_04-04-11 TRACTOR UNIT, PLATFORM
053_04-04-12 TRACTOR UNIT, PLATFORM, SWE
054_04-04-13 TRACTOR UNIT, PLATFORM, SIDE SUPPORT
055_04-04-14 PLATFORM
056_04-04-15 PLATFORM SENSOR
057_04-04-16 SIDE SUPPORT SENSOR
058_04-04-17 BATTERY COVER ASSEMBLY
059_04-04-18 DECALS
060_04-04-19 HINGE, RIGHT
061_04-04-20 HINGE, LEFT
062_04-04-21 TILLER ARM
063_04-04-22 TILLER HEAD
064_04-04-23 TILLER, TILLER HEAD
065_04-04-24 TILLER ASSEMBLY
066_04-04-25 TILLER ASSEMBLY, PLATFORM
067_04-04-26 TILLER ASSEMBLY, Z-SHAPE
068_04-04-27 TILLER FOOT
069_04-04-28 TILLER FOOT, PLATFORM
070_04-04-29 JOINT, TILLER FASTENER
071_04-04-30 SWITCH, KEY, W_ PIN-CODE
072_04-04-31 KEYBOARD
073_04-04-32 KEYBOARD, PLATFORM
074_05-05-01 HYDRAULIC AGGREGATE, 1.0T
075_05-05-02 HYDRAULIC AGGREGATE, 1.2-1.4T
076_05-05-03 HYDRAULIC AGGREGATE, 1.6T
077_05-05-04 HYDRAULIC SIDE SUPPORT, RIGHT
078_05-05-05 HYDRAULIC SIDE SUPPORT, LEFT
079_05-05-06 CENTER CYLINDER, SIMPLEX & DUPLEX, 1.0T
080_05-05-07 FREE LIFT CYLLINDER, SIMPLEX & DUPLEX, 1.0T
081_05-05-08 CENTER CYLINDERS HYDRAULIC PIPE, DUPLEX W_ FREE LIFT
082_05-05-09 SIDE CYLINDERS, SIMPLEX
083_05-05-10 SIDE CYLINDERS, DUPLEX
084_05-05-11 SIDE CYLINDERS, DUPLEX W_ FREE LIFT
085_05-05-12 SIDE CYLINDERS, TRIPLEX
086_05-05-13 SIDE CYLINDERS, TRIPLEX W_ FREE LIFT
087_05-05-14 SIDE CYLINDERS HOSE, TRIPLEX W_ FREE LIFT
088_05-05-15 STANDARD LIFT CYLINDER (RL467826)
089_05-05-16 HYDRAULIC SYSTEM, VALVE ELEMENT + HOSES
090_05-05-17 VALVE BLOCK
091_07-07-01 MAST UNIT, SIMPLEX, 1.0T
092_07-07-02 MAST UNIT, SIMPLEX, 1.2-1.6T
093_07-07-03 MAST UNIT, DUPLEX, 1.0T
094_07-07-04 MAST UNIT, DUPLEX, 1.2T
095_07-07-05 MAST UNIT, DUPLEX, 1.4-1.6T
096_07-07-06 MAST UNIT, DUPLEX W_ FREE LIFT, 1.2T
097_07-07-07 MAST UNIT, DUPLEX W_ FREE LIFT, 1.4-1.6T
098_07-07-08 MAST UNIT, TRIPLEX, 1.2-1.6T
099_07-07-09 MAST UNIT, TRIPLEX W_ FREE LIFT, 1.2-1.6T
100_07-07-10 MAST UNIT, SIMPLEX, 1.2-1.6T INITIAL LIFT
101_07-07-11 MAST UNIT, DUPLEX, 1.2T INITIAL LIFT
102_07-07-14 MAST UNIT, DUPLEX W_ FREE LIFT, 1.4-1.6T INITIAL LIFT
103_07-07-15 MAST UNIT, TRIPLEX, 1.2-1.6T INITIAL LIFT
104_07-07-17 MAST UNIT, SIMPLEX, 1.6T STRADDLE
105_07-07-18 MAST UNIT, DUPLEX, 1.6T STRADDLE
106_07-07-22 MAST UNIT, TRIPLEX, 1.2-1.6T SIDE SUPPORT
107_07-07-23 MAST UNIT, TRIPLEX W_ FREE LIFT, 1.2-1.6T SIDE SUPPORT
108_07-07-24 MAST GUARD ASSEMBLY
109_07-07-25 SIDE CYLINDER CHAIN
110_07-07-26 LIFT CARRIAGE CHAIN, TRIPLEX
111_07-07-27 CENTER CYLINDER CHAIN, DUPLEX, 1.0T
112_07-07-28 FREE LIFT CYLINDER CHAIN
113_07-07-29 INTERMEDIATE MAST CHAIN, TRIPLEX, 1.2-1.6T
114_07-07-30 SPEED REDUCTION SENSOR, DUPLEX & TRIPLEX
115_07-07-31 SPEED REDUCTION SENSOR, DUPLEX W_ FREE LIFT
116_07-07-32 SPEED REDUCTION SENSOR, TRIPLEX W_ FREE LIFT
117_07-07-33 CHAIN YOKE, SIMPLEX
118_07-07-34 CHAIN YOKE, DUPLEX
119_07-07-35 CHAIN WHEEL, SIMPLEX
120_07-07-36 CHAIN WHEEL, TRIPLEX
121_07-07-37 CHAIN WHEEL, TRIPLEX & TRIPLEX W_ FREE LIFT
122_07-07-38 BRACKET, CHAIN WHEEL
123_07-07-39 SIDE GUIDE ROLLER
124_07-07-40 PLUG, LEFT, DUPLEX W_ FREE LIFT SIDE CYLINDER
125_07-07-41 PLUG, RIGHT, DUPLEX W_ FREE LIFT SIDE CYLINDER
126_08-08-01 DRIVING UNIT
127_08-08-02 DRIVING UNIT, COLD STORAGE
128_08-08-03 DRIVING UNIT (RL657226)
129_08-08-04 GEAR
130_09-09-01 DRIVE WHEEL
131_09-09-02 LOAD WHEEL, SINGLE
132_09-09-03 LOAD WHEEL, TANDEM
133_09-09-04 CASTER WHEEL, STANDARD
134_09-09-05 CASTER WHEEL, STRADDLE
