Caterpillar Forklift NSP16N2I Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00032659
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar NSP16N2I Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: DOC00032659
Number of Pages: 336 Pages
001_01-01-01 ACCESSORIES
002_01-01-02 ABBOT MOUNTING BRACKET
003_01-01-03 ABBOT, GPRS
004_01-01-04 ABBOT, GPRS+iBUTTON
005_01-01-05 ABBOT, WLAN
006_01-01-06 ABBOT, WLAN+iBUTTON
007_01-01-07 ACCESSORY RACK
008_01-01-08 BRACKET, PEN HOLDER
009_01-01-09 BRACKET, BOTTLE HOLDER
010_01-01-10 COMPUTER RACK
011_01-01-11 DECAL, TILLER, SIDE-STABALIZER
012_01-01-12 LIST BRACKET
013_02-02-01 EL-PANEL, STANDARD (RL613157)
014_02-02-02 EL-PANEL, STANDARD (RL638317)
015_02-02-03 EL-PANEL, STANDARD, SWE (RL617799)
016_02-02-04 EL-PANEL, STANDARD, SWE (RL638318)
017_02-02-05 CHARGER
018_02-02-06 CHARGING CONNECTOR, 150Ah BATTERY
019_02-02-07 CHARGING CONNECTOR, 250_375_500Ah BATTERY
020_02-02-08 ELECTRICITY FROM GRID CABLE, EURO 30A
021_02-02-09 ELECTRICITY FROM GRID CABLE, UK 30A
022_02-02-10 ELECTRICITY FROM GRID CABLE, DK 30A
023_02-02-11 ELECTRICITY FROM GRID CABLE, SUI 30A
024_02-02-12 KEYBOARD, PIN CODE ASSEMBLY
025_02-02-13 OPTION RELAY PACKAGE
026_02-02-14 SENSOR, SPEED LIMIT, LIFT CUT
027_02-02-15 VOLTAGE TRANSDUCER
028_03-03-01 CHAIN WHEEL, TRIPLEX
029_03-03-02 LEVERAGE, SIMPLEX_DUPLEX
030_03-03-03 LEVERAGE, TRIPLEX
031_03-03-04 LIFTING CARRIAGE, DUPLEX, STRADDLE, FORK LENGTH 950-1500mm
032_03-03-05 LIFTING CARRIAGE, TRIPLEX, STRADDLE, FORK LENGTH 950-1500mm
033_03-03-06 LIFTING CARRIAGE, TRIPLEX W_ FULL FREE LIFT, STRADDLE, FORK LENGTH 950-1500mm
034_03-03-07 LOAD SUPPORT, MOUNTING
035_03-03-08 LOAD SUPPORT, BULL STRADDLE
036_04-04-01 DECALS
037_04-04-02 HYDRAULIC SIDE SUPPORT, RIGHT
038_04-04-03 HYDRAULIC SIDE SUPPORT, LEFT
039_04-04-04 TRACTOR UNIT, BASIC
040_04-04-05 TRACTOR UNIT, BASIC, SWE
041_04-04-06 TRACTOR UNIT, BASIC, SIDE-SUPPORT - OPTION
042_04-04-07 TRACTOR UNIT, INITIAL LIFT
043_04-04-08 TRACTOR UNIT, INITIAL LIFT, SWE
044_05-05-01 HOSE, TRIPLEX W_ FREE LIFT, L=1730
045_05-05-02 HOSE, TRIPLEX W_ FREE LIFT, L=1800
046_05-05-03 HOSE, TRIPLEX W_ FREE LIFT, L=1900
047_05-05-04 HOSE, TRIPLEX W_ FREE LIFT, L=2170
048_05-05-05 HOSE, TRIPLEX W_ FREE LIFT, L=2330
049_05-05-06 HOSE, TRIPLEX W_ FREE LIFT, L=2530
050_05-05-07 HOSE, TRIPLEX W_ FREE LIFT, L=VARIABLE
051_05-05-08 HYDRAULIC AGGREGATE ASSY (NSP12-14N2I)
052_05-05-09 HYDRAULIC AGGREGATE ASSY (NSP16N2I, NSP16N2S)
053_05-05-10 HYDRAULIC AGGREGATE (NSP12-14N2I)
054_05-05-11 HYDRAULIC AGGREGATE (NSP16N2I, NSP16N2S)
055_05-05-12 HYDRAULIC AGGREGATE, SIDE SUPPORT (NSP12-14NI)
056_05-05-13 HYDRAULIC AGGREGATE, SIDE SUPPORT (NSP16N2I, NSP16N2S)
057_05-05-14 LIFTING CYLINDER, SIMPLEX, 1500
058_05-05-15 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 2500
059_05-05-16 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 2501-4299
060_05-05-17 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 2900
061_05-05-18 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 3300
062_05-05-19 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 3450
063_05-05-20 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 3600
064_05-05-21 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 3700
065_05-05-22 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 4300
066_05-05-23 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 4100
067_05-05-24 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 4101-6499
068_05-05-25 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 4300
069_05-05-26 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 4700
070_05-05-27 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 5400
071_05-05-28 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 5900
072_05-05-29 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 6500
073_05-05-30 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT
074_05-05-31 SIDE CYLINDER, TRIPLEX W_ FREE LIFT
075_05-05-32 STANDARD LIFT CYLINDER
076_05-05-33 PLUG, RIGHT, DUPLEX W_ FREE LIFT SIDE CYLINDER
077_05-05-34 PLUG, LEFT, DUPLEX W_ FREE LIFT SIDE CYLINDER
078_06-06-01 MAIN ASSEMBLY (NSP12-16N2I)
079_06-06-02 MAIN ASSEMBLY (NSP16N2S)
080_06-06-03 BATTERY COVER ASSEMBLY
081_06-06-04 TILLER
082_06-06-05 CONNECTION PIECE (RL638282)
083_06-06-06 CONNECTION PIECE (RL615094)
084_06-06-07 GAS SPRING (RL609963)
085_06-06-08 MANIPULATOR
086_06-06-09 MANIPULATOR, COLD STORAGE
087_06-06-10 MANIPULATOR, BIG LEVERS
088_06-06-11 MANIPULATOR, BIG LEVERS, COLD STORAGE
089_04-04-01 LIFTING CARRIAGE
090_07-07-01 MAST UNIT, SIMPLEX, 1.2-1.6T INITIAL LIFT
091_07-07-03 MAST UNIT, DUPLEX W_ FREE LIFT, 1.2T INITIAL LIFT
092_07-07-04 MAST UNIT, DUPLEX, 1.4-1.6T INITIAL LIFT
093_07-07-05 MAST UNIT, DUPLEX W_ FREE LIFT, 1.4-1.6T INITIAL LIFT
094_07-07-06 MAST UNIT, TRIPLEX, 1.2-1.6T INITIAL LIFT
095_07-07-08 MAST UNIT, SIMPLEX, STRADDLE (NSP16N2S)
096_07-07-09 MAST UNIT, DUPLEX, STRADDLE (NSP16N2S)
097_07-07-10 MAST UNIT, DUPLEX W_ FREE LIFT, STRADDLE (NSP16N2S)
098_07-07-11 MAST UNIT, TRIPLEX, STRADDLE (NSP16N2S)
099_07-07-13 MAST UNIT, DUPLEX W_ FREE LIFT, SPEED LIMITING - OPTION
100_07-07-14 MAST UNIT, DUPLEX, TRIPLEX, SPEED LIMITING - OPTION
101_07-07-15 MAST UNIT, TRIPLEX W_ FREE LIFT, SPEED LIMITING - OPTION
102_07-07-16 MAST UNIT, DUPLEX W_ FREE LIFT, PIPE
103_08-08-01 CHAIN WHEEL, TRIPLEX
104_08-08-02 CHAIN WHEEL, TRIPLEX, COLD STORAGE
105_08-08-03 CHAIN YOKE (NSP16N2S)
106_08-08-04 CHAIN YOKE, DUPLEX
107_08-08-05 CHAIN YOKE, DUPLEX, COLD STORAGE
108_08-08-06 SENSOR (LIFT CUT-OFF+RESET)
109_09-09-01 DRIVE UNIT, BASIC
110_09-09-02 DRIVE UNIT, COLD STORAGE
111_01-01-01 DRIVE UNIT (RL638262)
112_01-01-02 GEAR (RL605443)
113_10-10-01 CASTER WHEEL, BASIC
114_10-10-02 CASTER WHEEL, STRADDLE
115_10-10-03 LOAD WHEEL, SINGLE, VULKOLLAN
116_10-10-04 LOAD WHEEL, SINGLE, VULKOLLAN, COLD STORAGE
117_10-10-05 LOAD WHEEL, TANDEM, VULKOLLAN
118_10-10-06 LOAD WHEEL, TANDEM, VULKOLLAN, COLD STORAGE
119_10-10-07 WHEEL, NORMAL FLOOR, VULKOLLAN
Brand: Caterpillar
Region: Europe
036_04-04-01 DECALS
081_06-06-04 TILLER
- CAT 416D Parts Manual
- CAT 420D Parts Manual
