Caterpillar Forklift NSP14N2IR Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00032664
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar NSP14N2IR Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: DOC00032664
Number of Pages: 339 Pages
001_01-01-01 ACCESSORIES
002_01-01-02 ABBOT MOUNTING BRACKET
003_01-01-03 ABBOT, GPRS
004_01-01-04 ABBOT, GPRS+iBUTTON
005_01-01-05 ABBOT, WLAN
006_01-01-06 ABBOT, WLAN+iBUTTON
007_01-01-07 ACCESSORY RACK
008_01-01-08 BRACKET, PEN HOLDER
009_01-01-09 BRACKET, BOTTLE HOLDER
010_01-01-10 COMPUTER RACK
011_01-01-11 DECAL, TILLER, SIDE-STABALIZER
012_01-01-12 LIST BRACKET
013_01-01-13 RACK, PLATFORM SENSOR
014_02-02-01 EL-PANEL, CENTER STEERING
015_02-02-02 EL-PANEL, CENTER STEERING, SWE
016_02-02-03 CHARGER
017_02-02-04 CHARGING CONNECTOR, 150Ah BATTERY
018_02-02-05 CHARGING CONNECTOR, 250_375_500Ah BATTERY
019_02-02-06 ELECTRICITY FROM GRID CABLE, EURO 30A
020_02-02-07 ELECTRICITY FROM GRID CABLE, UK 30A
021_02-02-08 ELECTRICITY FROM GRID CABLE, DK 30A
022_02-02-09 ELECTRICITY FROM GRID CABLE, SUI 30A
023_02-02-10 KEYBOARD, PIN CODE ASSEMBLY
024_02-02-11 OPTION RELAY PACKAGE
025_02-02-12 SENSOR, SPEED LIMIT, LIFT CUT
026_02-02-13 VOLTAGE TRANSDUCER
027_03-03-01 CHAIN WHEEL, TRIPLEX
028_03-03-02 LEVERAGE, SIMPLEX_DUPLEX
029_03-03-03 LEVERAGE, TRIPLEX
030_03-03-04 LIFTING CARRIAGE, DUPLEX, STRADDLE, FORK LENGTH 950-1500mm
031_03-03-05 LIFTING CARRIAGE, TRIPLEX, STRADDLE, FORK LENGTH 950-1500mm
032_03-03-06 LIFTING CARRIAGE, TRIPLEX W_ FULL FREE LIFT, STRADDLE, FORK LENGTH 950-1500mm
033_03-03-07 LOAD SUPPORT, BULL STRADDLE
034_03-03-08 LOAD SUPPORT, MOUNTING
035_04-04-01 DECALS
036_04-04-02 HYDRAULIC SIDE SUPPORT, RIGHT
037_04-04-03 HYDRAULIC SIDE SUPPORT, LEFT
038_04-04-04 TRACTOR UNIT, BASIC, RIDE-ON
039_04-04-05 TRACTOR UNIT, BASIC, RIDE-ON, SWE
040_04-04-06 TRACTOR UNIT, BASIC, RIDE-ON, SIDE SUPPORT - OPTION
041_04-04-07 TRACTOR UNIT, INITIAL LIFT, RIDE-ON
042_04-04-08 TRACTOR UNIT, INITIAL LIFT, RIDE-ON, SWE
043_05-05-01 HOSE, TRIPLEX W_ FREE LIFT, L=1730
044_05-05-02 HOSE, TRIPLEX W_ FREE LIFT, L=1800
045_05-05-03 HOSE, TRIPLEX W_ FREE LIFT, L=1900
046_05-05-04 HOSE, TRIPLEX W_ FREE LIFT, L=2170
047_05-05-05 HOSE, TRIPLEX W_ FREE LIFT, L=2330
048_05-05-06 HOSE, TRIPLEX W_ FREE LIFT, L=2530
049_05-05-07 HOSE, TRIPLEX W_ FREE LIFT, L=VARIABLE
050_05-05-08 HYDRAULIC AGGREGATE ASSY (NSP12-14N2IR)
051_05-05-09 HYDRAULIC AGGREGATE ASSY (NSP16N2IR, NSP16N2SR)
052_05-05-10 HYDRAULIC AGGREGATE (NSP12-14N2IR)
053_05-05-11 HYDRAULIC AGGREGATE (NSP16N2IR, NSP16N2SR)
054_05-05-12 HYDRAULIC AGGREGATE, SIDE SUPPORT (NSP12-14N2IR)
055_05-05-13 HYDRAULIC AGGREGATE, SIDE SUPPORT (NSP16N2IR, NSP16N2SR)
056_05-05-14 LIFTING CYLINDER, SIMPLEX, 1500
057_05-05-15 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 2500
058_05-05-16 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 2501-4299
059_05-05-17 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 2900
060_05-05-18 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 3300
061_05-05-19 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 3450
062_05-05-20 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 3600
063_05-05-21 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 3700
064_05-05-22 LIFTING CYLINDER, DUPLEX W_ FREE LIFT, 4300
065_05-05-23 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 4100
066_05-05-24 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 4101-6499
067_05-05-25 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 4300
068_05-05-26 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 4700
069_05-05-27 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 5400
070_05-05-28 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 5900
071_05-05-29 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT, 6500
072_05-05-30 LIFTING CYLINDER, TRIPLEX W_ FREE LIFT
073_05-05-31 SIDE CYLINDER, TRIPLEX W_ FREE LIFT
074_05-05-32 STANDARD LIFT CYLINDER
075_05-05-33 PLUG, RIGHT, DUPLEX W_ FREE LIFT SIDE CYLINDER
076_05-05-34 PLUG, LEFT, DUPLEX W_ FREE LIFT SIDE CYLINDER
077_06-06-01 MAIN ASSEMBLY (NSP12-16N2R)
078_06-06-02 MAIN ASSEMBLY (NSP16N2SR)
079_06-06-03 BATTERY COVER ASSEMBLY
080_06-06-04 PLATFORM
081_06-06-05 TILLER
082_06-06-06 CONNECTION PIECE (RL638281)
083_06-06-07 ASSEMBLY
084_06-06-08 CONNECTION PIECE (RL615094)
085_06-06-09 GAS SPRING (RL609963)
086_06-06-10 MANIPULATOR
087_06-06-11 MANIPULATOR, COLD STORAGE
088_06-06-12 MANIPULATOR, BIG LEVERS
089_06-06-13 MANIPULATOR, BIG LEVERS, COLD STORAGE
090_04-04-01 LIFTING CARRIAGE
091_07-07-01 MAST UNIT, SIMPLEX, 1.2-1.6T INITIAL LIFT
092_07-07-02 MAST UNIT, DUPLEX, 1.2T INITIAL LIFT
093_07-07-03 MAST UNIT, DUPLEX W_ FREE LIFT, 1.2T INITIAL LIFT
094_07-07-04 MAST UNIT, DUPLEX W_ FREE LIFT, 1.4-1.6T INITIAL LIFT
095_07-07-05 MAST UNIT, TRIPLEX, 1.2-1.6T INITIAL LIFT
096_07-07-07 MAST UNIT, SIMPLEX, STRADDLE (NSP16N2SR)
097_07-07-09 MAST UNIT, DUPLEX W_ FREE LIFT, STRADDLE (NSP16N2SR)
098_07-07-10 MAST UNIT, TRIPLEX, STRADDLE (NSP16N2SR)
099_07-07-11 MAST UNIT, TRIPLEX W_ FREE LIFT, STRADDLE (NSP16N2SR)
100_07-07-12 MAST UNIT, DUPLEX W_ FREE LIFT, SPEED LIMITING - OPTION
101_07-07-13 MAST UNIT, DUPLEX, TRIPLEX, SPEED LIMITING - OPTION
102_07-07-14 MAST UNIT, TRIPLEX W_ FREE LIFT, SPEED LIMITING - OPTION
103_07-07-15 MAST UNIT, DUPLEX W_ FREE LIFT, PIPE
104_08-08-01 CHAIN YOKE (NSP16N2SR)
105_08-08-02 CHAIN YOKE, DUPLEX
106_08-08-03 CHAIN YOKE, DUPLEX, COLD STORAGE
107_08-08-04 CHAIN WHEEL, TRIPLEX
108_08-08-05 CHAIN WHEEL, TRIPLEX, COLD STORAGE
109_08-08-06 SENSOR (LIFT CUT-OFF+RESET)
110_09-09-01 DRIVE UNIT, BASIC
111_09-09-02 DRIVE UNIT, COLD STORAGE
112_01-01-01 DRIVE UNIT (RL638262)
113_01-01-02 GEAR (RL605443)
114_10-10-01 CASTER WHEEL, BASIC
115_10-10-02 CASTER WHEEL, STRADDLE
116_10-10-03 LOAD WHEEL, SINGLE, VULKOLLAN
117_10-10-04 LOAD WHEEL, SINGLE, VULKOLLAN, COLD STORAGE
118_10-10-05 LOAD WHEEL, TANDEM, VULKOLLAN
119_10-10-06 LOAD WHEEL, TANDEM, VULKOLLAN, COLD STORAGE
120_10-10-07 WHEEL, NORMAL FLOOR, VULKOLLAN
121_10-10-08 WHEEL, SLIPPERY FLOOR, POWER FRICTION - OPTION
Brand: Caterpillar
Region: Europe
035_04-04-01 DECALS
081_06-06-05 TILLER
- CAT 416D Parts Manual
- CAT 420D Parts Manual
