Caterpillar Forklift NSP12N3 Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00048958
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar NSP12N3 Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: DOC00048958
Number of Pages: 347 Pages
001_01-01-01 ACCESSORIES
002_01-01-02 ACCUMULATOR PLUG
003_01-01-03 COMPUTER RACK
004_01-01-04 LIST BRACKET
005_01-01-05 ACCESSORY RACK
006_01-01-06 BUZZER
007_01-01-07 BATTERY CHANGING DEVICE
008_01-01-08 LI-ION KIT
009_01-01-09 MAST, LOOSE PARTS, STANDARD
010_01-01-10 MAST, LOOSE PARTS, INITIAL LIFT
011_01-01-11 MAST, LOOSE PARTS, STRADDLE
012_01-01-12 BATTERY SHIMMING
013_02-02-04 ELECTRIC PANEL, PLATFORM, SWE
014_02-02-05 FAN
015_02-02-06 FAN (RL638286)
016_02-02-07 CHARGING CONNECTOR, 150Ah BATTERY
017_02-02-08 CHARGING CONNECTOR, 250_375_500Ah BATTERY
018_02-02-09 INTERNAL CHARGER POWER CABLE, LEAD ACID, EURO
019_02-02-10 INTERNAL CHARGER POWER CABLE, LEAD ACID, UK
020_02-02-11 INTERNAL CHARGER POWER CABLE, LEAD ACID, DK
021_02-02-12 INTERNAL CHARGER POWER CABLE, LEAD ACID, SUI
022_02-02-13 ON-BOARD CHARGER POWER CABLE, LI-ION, EURO
023_02-02-14 ON-BOARD CHARGER POWER CABLE, LI-ION, UK
024_02-02-15 ON-BOARD CHARGER POWER CABLE, LI-ION, DK
025_02-02-16 ON-BOARD CHARGER POWER CABLE, LI-ION, SUI
026_02-02-17 INTERNAL CHARGER, 30A
027_02-02-18 POWER SUPPLY, 12V 150W
028_03-03-01 FORK CARRIAGE
029_03-03-02 FORK CARRIAGE, W_ LOAD BACKREST
030_03-03-03 FORK CARRIAGE, INITIAL LIFT
031_03-03-04 FORK CARRIAGE, W_ LOAD BACKREST, INITIAL LIFT
032_03-03-05 LIFTING CARRIAGE, SIMPLEX, DUPLEX, DUPLEX W_ FREE LIFT, STRADDLE
033_03-03-06 LIFTING CARRIAGE, TRIPLEX, STRADDLE
034_03-03-07 LIFTING CARRIAGE, TRIPLEX W_ FREE LIFT
035_03-03-08 LEVERAGE, SIMPLEX & DUPLEX
036_03-03-09 LEVERAGE, TRIPLEX
037_03-03-10 LOAD SUPPORT, WO_ STRADDLE
038_03-03-11 LOAD SUPPORT, STRADDLE
039_04-04-04 TRACTOR UNIT
040_04-04-11 TRACTOR UNIT, PLATFORM
041_04-04-14 PLATFORM
042_04-04-15 PLATFORM SENSOR
043_04-04-16 SIDE SUPPORT SENSOR
044_04-04-17 BATTERY COVER ASSEMBLY
045_04-04-18 DECALS
046_04-04-19 HINGE, RIGHT
047_04-04-20 HINGE, LEFT
048_04-04-21 TILLER ARM
049_04-04-22 TILLER HEAD
050_04-04-23 TILLER, TILLER HEAD
051_04-04-24 TILLER ASSEMBLY
052_04-04-25 TILLER ASSEMBLY, PLATFORM
053_04-04-26 TILLER ASSEMBLY, Z-SHAPE
054_04-04-27 TILLER FOOT
055_04-04-28 TILLER FOOT, PLATFORM
056_04-04-30 SWITCH, KEY, W_ PIN-CODE
057_04-04-31 KEYBOARD
058_04-04-32 KEYBOARD, PLATFORM
059_05-05-01 HYDRAULIC AGGREGATE, 1.0T
060_05-05-02 HYDRAULIC AGGREGATE, 1.2-1.4T
061_05-05-03 HYDRAULIC AGGREGATE, 1.6T
062_05-05-04 HYDRAULIC SIDE SUPPORT, RIGHT
063_05-05-05 HYDRAULIC SIDE SUPPORT, LEFT
064_05-05-06 CENTER CYLINDER, SIMPLEX & DUPLEX, 1.0T
065_05-05-07 FREE LIFT CYLLINDER, SIMPLEX & DUPLEX, 1.0T
066_05-05-08 CENTER CYLINDERS HYDRAULIC PIPE, DUPLEX W_ FREE LIFT
067_05-05-09 SIDE CYLINDERS, SIMPLEX
068_05-05-10 SIDE CYLINDERS, DUPLEX
069_05-05-11 SIDE CYLINDERS, DUPLEX W_ FREE LIFT
070_05-05-12 SIDE CYLINDERS, TRIPLEX
071_05-05-13 SIDE CYLINDERS, TRIPLEX W_ FREE LIFT
072_05-05-14 SIDE CYLINDERS HOSE, TRIPLEX W_ FREE LIFT
073_05-05-15 STANDARD LIFT CYLINDER (RL467826)
074_05-05-16 HYDRAULIC SYSTEM, VALVE ELEMENT + HOSES
075_05-05-17 VALVE BLOCK
076_07-07-01 MAST UNIT, SIMPLEX, 1.0T
077_07-07-02 MAST UNIT, SIMPLEX, 1.2-1.6T
078_07-07-04 MAST UNIT, DUPLEX, 1.2T
079_07-07-15 MAST UNIT, TRIPLEX, 1.2-1.6T INITIAL LIFT
080_07-07-16 MAST UNIT, TRIPLEX W_ FREE LIFT, 1.2-1.6T INITIAL LIFT
081_07-07-23 MAST UNIT, TRIPLEX W_ FREE LIFT, 1.2-1.6T SIDE SUPPORT
082_07-07-24 MAST GUARD ASSEMBLY
083_07-07-25 SIDE CYLINDER CHAIN
084_07-07-26 LIFT CARRIAGE CHAIN, TRIPLEX
085_07-07-27 CENTER CYLINDER CHAIN, DUPLEX, 1.0T
086_07-07-28 FREE LIFT CYLINDER CHAIN
087_07-07-29 INTERMEDIATE MAST CHAIN, TRIPLEX, 1.2-1.6T
088_07-07-30 SPEED REDUCTION SENSOR, DUPLEX & TRIPLEX
089_07-07-31 SPEED REDUCTION SENSOR, DUPLEX W_ FREE LIFT
090_07-07-32 SPEED REDUCTION SENSOR, TRIPLEX W_ FREE LIFT
091_07-07-33 CHAIN YOKE, SIMPLEX
092_07-07-34 CHAIN YOKE, DUPLEX
093_07-07-35 CHAIN WHEEL, SIMPLEX
094_07-07-36 CHAIN WHEEL, TRIPLEX
095_07-07-37 CHAIN WHEEL, TRIPLEX & TRIPLEX W_ FREE LIFT
096_07-07-38 BRACKET, CHAIN WHEEL
097_07-07-39 SIDE GUIDE ROLLER
098_07-07-40 PLUG, LEFT, DUPLEX W_ FREE LIFT SIDE CYLINDER
099_07-07-41 PLUG, RIGHT, DUPLEX W_ FREE LIFT SIDE CYLINDER
100_08-08-01 DRIVING UNIT
101_08-08-02 DRIVING UNIT, COLD STORAGE
102_08-08-03 DRIVING UNIT (RL657226)
103_08-08-04 GEAR
104_09-09-01 DRIVE WHEEL
105_09-09-02 LOAD WHEEL, SINGLE
106_09-09-03 LOAD WHEEL, TANDEM
107_09-09-04 CASTER WHEEL, STANDARD
108_09-09-05 CASTER WHEEL, STRADDLE
