Caterpillar Forklift NRM20N2 Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00032277
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar NRM20N2 Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: DOC00032277
Number of Pages: 226 Pages
001_01-01-01 ACCESSORIES
002_01-01-02 ABBOT
003_01-01-03 ABBOT, GPRS
004_01-01-04 ABBOT, GPRS+iBUTTON
005_01-01-05 ABBOT, WLAN
006_01-01-06 ABBOT, WLAN+iBUTTON
007_01-01-07 ACCESSORY RACK
008_01-01-08 ARM REST
009_01-01-10 SIDE GUIDE ROLLER
010_01-01-11 BRACKET, MOUNTING
011_01-01-12 BRACKET, ONLY PROTECTIVE COVER
012_01-01-13 BRACKET, WITH ACCESSORIES
013_01-01-14 BUZZER
014_01-01-15 COMPUTER RACK
015_01-01-16 DRIVING SEAT, MSG20
016_01-01-17 DRIVING SEAT, MSG20, ARM REST
017_01-01-18 DRIVING SEAT, MSG20, SAFETY BELT
018_01-01-19 DRIVING SEAT, MSG65
019_01-01-20 DRIVING SEAT, MSG65, W_ LEFT ARM REST
020_01-01-21 DRIVING SEAT, MSG65, W_ VINYL BACK REST
021_01-01-22 DRIVING SEAT, MSG65, W_ CLOTH BACK REST
022_01-01-23 DRIVING SEAT, MSG75
023_01-01-24 FAN (RL618660)
024_01-01-25 FAN (RL619589)
025_01-01-26 FAN, 48V
026_01-01-27 FIRE EXTINGUISHER
027_01-01-28 MIRROR, WIDE ANGLE
028_01-01-29 OHG PROTECTIVE COVER
029_01-01-30 DRIVER SHOULDER SHIELD
030_01-01-31 WARNING LIGHT, RUBBER BASE
031_01-01-32 WARNING LIGHT, STROBE
032_01-01-33 WRITING PAD
033_01-01-34 WORKING LIGHT
034_02-02-01 EL-PANEL, W_ 500A CONTROLLER
035_02-02-02 EL-PANEL, W_ 500A CONTROLLER - EN1175
036_02-02-03 AUDIO SYSTEM
037_02-02-04 BATTERY CABLE
038_02-02-05 BLUE SPOT LIGHT
039_02-02-06 DRIVING LIGHT
040_02-02-07 FUSE HOLDER
041_02-02-08 READING LIGHT
042_02-02-09 VCM WITH SOFTWARE
043_02-02-10 VOLTAGE CONVERTER
044_03-03-01 LIFTING FORK, WIDTH 1700mm
045_03-03-02 LIFTING FORK, WIDTH 2200mm
046_03-03-03 FORK (RL627664)
047_03-03-04 FORK (RL627662)
048_04-04-02 CHASSIS ASSEMBLY - 2
049_04-04-03 CHASSIS (RL623611)
050_04-04-04 CHASSIS (RL626696)
051_04-04-05 CARRIAGE
052_04-04-06 ACTIVE SWAY CONTROL
053_04-04-07 BATTERY COVER, 465Ah
054_04-04-08 BATTERY ROLLER MAIN ASSEMBLY
055_04-04-09 BATTERY ROLLER (9791220010)
056_04-04-10 BATTERY ROLLER (RL465065)
057_04-04-11 BATTERY LATCH, STANDARD
058_04-04-12 BATTERY LATCH, OPTION
059_04-04-13 BRAKE
060_04-04-14 BRAKE - EN1175
061_04-04-15 EL-PANEL COVER
062_04-04-16 LATCH
063_04-04-17 MACHINERY SHIELD
064_04-04-18 PROTECTIVE COVER
065_04-04-19 SEAT PLATE
066_04-04-20 STEP (RL618936)
067_04-04-21 STEP (RL618931)
068_05-05-01 HYDRAULIC SYSTEM, 4-VALVE
069_05-05-02 VALVE
070_05-05-03 PUMP MOTOR ASSEMBLY
071_09-09-01 PUMP MOTOR 30V 14kW
072_05-05-04 PUMP 19cc
073_05-05-05 OIL TANK
074_05-05-06 OIL TANK FILTER
075_05-05-07 GASKET KIT
076_05-05-08 FREE LIFT CYLINDER
077_05-05-09 SIDE CYLINDER
078_05-05-10 REACH CYLINDER
079_05-05-11 CYLINDER (RL627675)
080_05-05-12 CYLINDER (RL627684)
081_05-05-13 CYLINDER (RL627698)
082_06-06-02 FLOOR AND PEDAL ASSEMBLY
083_06-06-03 DECALS
084_06-06-05 STEERING UNIT
085_06-06-06 STEERING WHEEL, ROCKING PART
086_06-06-07 STEERING WHEEL, PRE-ASSEMBLY
087_06-06-08 STEERING WHEEL AND BRODIE KNOB
088_06-06-09 SWITCH
089_06-06-10 DUAL JOYSTICK ASSEMBLY, W_ FR
090_06-06-11 DUAL JOYSTICK, W_ FR
091_07-07-01 MAST MAIN ASSEMBLY
092_07-07-03 HEIGHT SENSOR
093_08-08-01 CHAIN YOKE (RL472540)
094_08-08-02 CHAIN YOKE (RL472541)
095_09-09-01 DRIVE UNIT
096_09-09-02 TRACTION MOTOR 30V 7kW
097_09-09-03 TRACTION MOTOR 30V 7,5kW
098_09-09-04 GEAR (RL636920)
099_09-09-05 GEAR (RL618590)
100_09-09-06 GEAR (RL618235)
101_09-09-07 BRAKE
102_09-09-08 STEERING UNIT (RL626162)
103_09-09-09 STEERING MOTOR (RL631223)
104_09-09-10 STEERING MOTOR (RL625982)
105_10-10-01 DRIVE WHEEL
106_10-10-02 LOAD WHEEL
Brand: Caterpillar
Region: Europe
002_01-01-02 ABBOT
013_01-01-14 BUZZER
059_04-04-13 BRAKE
062_04-04-16 LATCH
069_05-05-02 VALVE
083_06-06-03 DECALS
088_06-06-09 SWITCH
101_09-09-07 BRAKE
- CAT 416D Parts Manual
- CAT 420D Parts Manual
