Caterpillar Forklift NR20N2H Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00032601
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar NR20N2H Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: DOC00032601
Number of Pages: 744 Pages
001_06-06-01 MAIN ASSEMBLY
002_06-06-02 OPERATOR COMPARTMENT, STANDARD CABIN
003_06-06-03 OPERATOR COMPARTMENT, DRIVE-IN CABIN
004_06-06-04 OPERATOR COMPARTMENT, COLD CABIN
005_06-06-05 OPERATOR COMPARTMENT, COLD CABIN (RL624641)
006_06-06-06 OPERATOR COMPARTMENT, COLD CABIN (RL624640)
007_06-06-07 OPERATOR COMPARTMENT, COLD CABIN - FRAME PARTS
008_06-06-08 OPERATOR COMPARTMENT, COLD CABIN - DOOR
009_06-06-09 CONTROL PANEL (STANDARD)
010_06-06-10 CONTROL PANEL (NARROW)
011_06-06-11 CONTROL PANEL (DUAL PEDAL)
012_06-06-12 DUAL PEDAL - 1
013_06-06-13 DUAL PEDAL - 2
014_06-06-14 DUAL PEDAL - 3
015_06-06-15 HEATER I (COLD CABIN)
016_06-06-16 HEATER II (COLD CABIN)
017_06-06-17 STEERING UNIT
018_06-06-18 STEERING WHEEL, ROCKING PART
019_06-06-19 STEERING WHEEL, ROCKING PART, COLD STORAGE
020_06-06-20 STEERING WHEEL, PRE-ASSEMBLY
021_06-06-21 STEERING WHEEL, PRE-ASSEMBLY, COLD STORAGE
022_06-06-22 STEERING WHEEL AND BRODIE KNOB
023_06-06-23 SWITCH
024_06-06-24 SWITCH, KEY, W_ PIN-CODE
025_06-06-25 DUAL JOYSTICK ASSEMBLY, WO_ FR
026_06-06-26 DUAL JOYSTICK, WO_ FR
027_06-06-27 DUAL JOYSTICK ASSEMBLY, W_ FR
028_06-06-28 DUAL JOYSTICK, W_ FR
029_06-06-29 DECALS
030_06-06-30 DECALS, COLD CABIN
031_02-02-01 EL-PANEL, W_ 500A CONTROLLER (STANDARD)
032_02-02-02 EL-PANEL, W_ 500A CONTROLLER (STANDARD) - EN1175
033_02-02-03 EL-PANEL, W_ 500A CONTROLLER (COLD CABIN)
034_02-02-04 EL-PANEL, W_ 500A CONTROLLER (COLD CABIN) - EN1175
035_02-02-05 EL-PANEL, W_ 400A CONTROLLER (NARROW)
036_02-02-06 EL-PANEL, W_ 400A CONTROLLER (NARROW) - EN1175
037_02-02-07 EL-PANEL, W_ 500A CONTROLLER (NARROW)
038_02-02-08 EL-PANEL, W_ 500A CONTROLLER (NARROW) - EN1175
039_02-02-09 CONVERTER EL-PANEL
040_02-02-10 AUDIO SYSTEM
041_02-02-11 BATTERY CABLE
042_02-02-12 BLUE SPOT LIGHT
043_02-02-13 DRIVING LIGHT
044_02-02-14 FUSE HOLDER
045_02-02-15 POWER OUTLET DC_DC 24V, 200W
046_02-02-16 READING LIGHT
047_02-02-17 VCM WITH SOFTWARE
048_02-02-18 VOLTAGE CONVERTER
049_04-04-01 CHASSIS ASSEMBLY - 1
050_04-04-04 CHASSIS (NR16N2(H)C)
051_04-04-05 CHASSIS (NR20N2H)
052_04-04-06 CHASSIS (NR20-252X)
053_04-04-07 ACTIVE SWAY CONTROL (RL624399)
054_04-04-08 ACTIVE SWAY CONTROL (RL624697)
055_04-04-09 BATTERY COVER, 465Ah, COMPACT
056_04-04-10 BATTERY COVER, 620Ah
057_04-04-11 BATTERY COVER, 620Ah, COMPACT
058_04-04-12 BATTERY COVER, 775Ah
059_04-04-13 BATTERY COVER, 930Ah
060_04-04-14 BATTERY COVER, 930Ah, COLD CABIN
061_04-04-15 BATTERY LATCH, STANDARD
062_04-04-16 BATTERY LATCH, OPTION
063_04-04-17 BATTERY ROLLER MAIN ASSEMBLY
064_04-04-18 BATTERY ROLLER
065_04-04-19 BATTERY ROLLER (RL465065)
066_04-04-20 EL-PANEL COVER, STANDARD
067_04-04-21 EL-PANEL COVER, LI-ION STANDARD
068_04-04-22 EL-PANEL COVER, COLD STORAGE
069_04-04-23 FASTENER, WIRE SET BRAKE
070_04-04-24 FASTENER, WIRE SET CONNECTOR
071_04-04-25 LATCH
072_04-04-26 LOWERING STOP 500mm
073_04-04-27 MACHINERY SHIELD (STANDARD)
074_04-04-28 MACHINERY SHIELD (NARROW)
075_04-04-29 PROTECTIVE COVER (STANDARD)
076_04-04-30 PROTECTIVE COVER (NARROW)
077_04-04-31 SEAT PLATE (STANDARD)
078_04-04-32 SEAT PLATE (NARROW)
079_04-04-33 CUSHION
080_04-04-34 SENSOR PLATE ASSEMBLY (RB16N2(H)C)
081_04-04-35 SENSOR PLATE ASSEMBLY (RB20N2H)
082_04-04-36 SENSOR PLATE ASSEMBLY (RB20-252X)
083_04-04-37 STEP (STANDARD) - 1
084_04-04-38 STEP (NARROW) - 1
085_04-04-39 STEP (STANDARD) - 2
086_04-04-40 STEP (NARROW) - 2
087_05-05-01 HYDRAULIC SYSTEM, 4-VALVE
088_05-05-02 HYDRAULIC SYSTEM, 5-VALVE
089_05-05-03 PRESSURE SENSOR
090_05-05-04 4-VALVE BLOCK
091_05-05-05 5-VALVE BLOCK
092_05-05-06 PUMP MOTOR ASSEMBLY
093_09-09-01 PUMP MOTOR 30V 10KW
094_09-09-02 PUMP MOTOR 30V 14KW
095_05-05-07 PUMP, 16cc & 19cc
096_05-05-08 GASKET KIT
097_05-05-09 OIL TANK
098_05-05-10 OIL TANK FILTER
099_05-05-11 FREE LIFT CYLINDER, i20TF
100_05-05-12 GASKET HOLDER, i20TF
101_05-05-13 GASKET HOLDER, Ø40
102_05-05-14 GASKET HOLDER, Ø45
103_05-05-15 REACH CYLINDER, SHORT
104_05-05-16 REACH CYLINDER, LONG
105_05-05-17 FRAME PRESSURE HOSE
106_09-09-01 DRIVE UNIT WITH MOTOR
107_09-09-02 TRACTION MOTOR 30V 7kW
108_09-09-03 TRACTION MOTOR 30V 7,5kW
109_09-09-04 GEAR (RL636920)
110_09-09-05 GEAR (RL618590)
111_09-09-06 GEAR (RL618235)
112_09-09-07 BRAKE
113_07-07-03 MAST ASSEMBLY i20TF (STANDARD)
114_07-07-04 MAST ASSEMBLY i20TF (COLD STORAGE)
115_07-07-05 AUX HOSE FASTENERS, i20TF (STANDARD)
116_07-07-06 AUX HOSE FASTENERS, i20TF (COLD STORAGE)
117_07-07-07 HOSES AND CHAINS i16TF (STANDARD)
118_07-07-08 HOSES AND CHAINS i16TF (COLD STORAGE)
119_07-07-09 CHAINS 16TF, INTERMEDIATE MAST
120_07-07-10 CHAINS 16TF, LIFTING CARRIAGE
121_07-07-11 HOSES AND CHAINS i20TF, 4800-7000 (STANDARD)
122_07-07-12 HOSES AND CHAINS i20TF, 7500-13000 (STANDARD)
123_07-07-13 HOSES AND CHAINS i20TF, 4800-7000 (COLD STORAGE)
124_07-07-14 HOSES AND CHAINS i20TF, 7500-13000 (COLD STORAGE)
125_07-07-15 PISTON & FREELIFT CYLINDER, i16TF
126_07-07-16 PISTON & FREELIFT CYLINDER, i20TF
127_07-07-17 HEIGHT SENSOR, i16TF_i20TF
128_07-07-18 SIDE SHIFT AND TILT SENSOR
129_07-07-19 SIDESHIFT AND TILT SENSOR CENTERING ASSEMBLY
130_07-07-20 SIDESHIFT AND TILT SENSOR WIRE SET
131_07-07-21 PALLET SENSOR
132_07-07-22 BEARING CLEARANCE ROLLER
133_07-07-23 HOSE ROLLER, WO_ MAST CABLE
134_07-07-24 HOSE ROLLER, WO_ MAST CABLE (COLD STORAGE)
135_07-07-25 HOSE ROLLER, W_ MAST CABLE
136_07-07-26 HOSE ROLLER, W_ MAST CABLE (COLD STORAGE)
137_03-03-01 LIFING CARRIAGE (STANDARD)
138_03-03-02 LIFTING CARRIAGE (RL484007-P)
139_03-03-03 LIFTING CARRIAGE (REINFORCED)
140_03-03-04 LIFING CARRIAGE (RL605831)
141_03-03-05 GASKET HOLDER
142_03-03-06 LIFTING CARRIAGE (SIDE SHIFTER)
143_03-03-07 LIFTING CARRIAGE (RL620814)
144_03-03-08 SIDE SHIFT FORK POSITIONER
145_03-03-09 TELESCOPIC FORK
146_03-03-10 FORK (RL624579)
147_03-03-11 LOAD SUPPORT
148_03-03-12 FORK ASSY
149_03-03-13 REACH CARRIAGE (WIDE FORK)
150_03-03-14 REACH CARRIAGE (NARROW FORK)
151_10-10-01 DRIVE WHEEL
152_10-10-02 LOAD WHEEL
153_10-10-03 LOAD WHEEL BRAKE
154_10-10-04 BRAKE ASSEMBLY
155_01-01-01 ACCESSORIES
156_01-01-02 ABBOT
157_01-01-03 ABBOT, GPRS
158_01-01-04 ABBOT, GPRS+iBUTTON
159_01-01-05 ABBOT, WLAN
160_01-01-06 ABBOT, WLAN+iBUTTON
161_01-01-07 ACCESSORY RACK, STANDARD
162_01-01-08 ACCESSORY RACK, DRIVE IN
163_01-01-09 ACCESSORY RACK, COLD CABIN
164_01-01-10 ARM REST
165_01-01-12 BATTERY CHANGING DEVICE, 620Ah
166_01-01-13 BATTERY CHANGING DEVICE, 775Ah
167_01-01-14 SIDE GUIDE ROLLER
168_01-01-15 BRACKET, MOUNTING
169_01-01-16 BRACKET, ONLY PROTECTIVE COVER
170_01-01-17 BRACKET, WITH ACCESSORIES
171_01-01-18 BUZZER
172_01-01-19 CABLE HOLDER CASE (FORK CAMERA)
173_01-01-20 CAMERA ASSY
174_01-01-21 COMPUTER RACK
175_01-01-22 DRIVING SEAT, MSG20
176_01-01-23 DRIVING SEAT, MSG20, ARM REST
177_01-01-24 DRIVING SEAT, MSG20, SAFETY BELT
178_01-01-25 DRIVING SEAT, MSG65
179_01-01-26 DRIVING SEAT, MSG65, W_ LEFT ARM REST
180_01-01-27 DRIVING SEAT, MSG65, W_ VINYL BACK REST
181_01-01-28 DRIVING SEAT, MSG75
182_01-01-29 FAN
183_01-01-30 CABIN FAN
184_01-01-31 FAN, 48V
185_01-01-32 FIRE EXTINGUISHER
186_01-01-33 FIRE EXTINGUISHER ASSEMBLY
187_01-01-34 HYDRAULIC SYSTEM, ADDITIONAL, 5-VALVE
188_01-01-35 INSULATOR
189_01-01-36 INTERCOM SYSTEM
190_01-01-37 MIRROR, WIDE ANGLE
191_01-01-38 OHG PROTECTIVE COVER
192_01-01-39 DRIVER SHOULDER SHIELD
193_01-01-40 WARNING LIGHT, RUBBER BASE
194_01-01-41 WARNING LIGHT, STROBE
195_01-01-42 WINDSHIELD WIPER
196_01-01-43 WORKING LIGHT (RLMX100144)
197_01-01-44 WORKING LIGHT (RLMX100130)
198_01-01-45 WRITING PAD
