Caterpillar Forklift NR16N2S Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00032600
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar NR16N2S Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: DOC00032600
Number of Pages: 532 Pages
001_06-06-01 MAIN ASSEMBLY
002_06-06-02 OPERATOR COMPARTMENT, STANDARD CABIN
003_06-06-03 OPERATOR COMPARTMENT, COLD CABIN
004_06-06-04 OPERATOR COMPARTMENT, COLD CABIN (RL624641)
005_06-06-05 OPERATOR COMPARTMENT, COLD CABIN (RL624640)
006_06-06-06 OPERATOR COMPARTMENT, COLD CABIN - FRAME PARTS
007_06-06-07 OPERATOR COMPARTMENT, COLD CABIN - DOOR
008_06-06-08 CONTROL PANEL (STANDARD)
009_06-06-09 CONTROL PANEL (DUAL PEDAL)
010_06-06-10 DUAL PEDAL - 1
011_06-06-11 DUAL PEDAL - 2
012_06-06-12 DUAL PEDAL - 3
013_06-06-13 HEATER I (COLD CABIN)
014_06-06-14 HEATER II (COLD CABIN)
015_06-06-15 STEERING UNIT
016_06-06-16 STEERING WHEEL, ROCKING PART
017_06-06-17 STEERING WHEEL, ROCKING PART, COLD STORAGE
018_06-06-18 STEERING WHEEL, PRE-ASSEMBLY
019_06-06-19 STEERING WHEEL, PRE-ASSEMBLY, COLD STORAGE
020_06-06-20 STEERING WHEEL AND BRODIE KNOB
021_06-06-21 SWITCH
022_06-06-22 SWITCH, KEY, W_ PIN-CODE
023_06-06-23 DUAL JOYSTICK ASSEMBLY, WO_ FR
024_06-06-24 DUAL JOYSTICK, WO_ FR
025_06-06-25 DUAL JOYSTICK ASSEMBLY, W_ FR
026_06-06-26 DUAL JOYSTICK, W_ FR
027_06-06-27 DECALS
028_06-06-28 DECALS, COLD CABIN
029_02-02-01 EL-PANEL, W_ 400A CONTROLLER (STANDARD)
030_02-02-02 EL-PANEL, W_ 400A CONTROLLER (STANDARD) - EN1175
031_02-02-03 EL-PANEL, W_ 400A CONTROLLER (COLD CABIN)
032_02-02-04 EL-PANEL, W_ 400A CONTROLLER (COLD CABIN) - EN1175
033_02-02-05 EL-PANEL, W_ 500A CONTROLLER (STANDARD)
034_02-02-06 EL-PANEL, W_ 500A CONTROLLER (STANDARD) - EN1175
035_02-02-07 EL-PANEL, W_ 500A CONTROLLER (COLD CABIN)
036_02-02-08 EL-PANEL, W_ 500A CONTROLLER (COLD CABIN) - EN1175
037_02-02-09 CONVERTER EL-PANEL
038_02-02-10 AUDIO SYSTEM
039_02-02-11 BATTERY CABLE
040_02-02-12 BLUE SPOT LIGHT
041_02-02-13 DRIVING LIGHT
042_02-02-14 FUSE HOLDER
043_02-02-15 POWER OUTLET DC_DC 24V, 200W
044_02-02-16 READING LIGHT
045_02-02-17 VCM WITH SOFTWARE
046_02-02-18 VOLTAGE CONVERTER
047_04-04-05 ACTIVE SWAY CONTROL
048_04-04-06 BATTERY COVER, 465Ah
049_04-04-07 BATTERY COVER, 620Ah
050_04-04-08 BATTERY COVER, 775Ah
051_04-04-09 BATTERY LATCH, STANDARD
052_04-04-10 BATTERY LATCH, OPTION
053_04-04-11 BATTERY ROLLER MAIN ASSEMBLY
054_04-04-12 BATTERY ROLLER
055_04-04-13 BATTERY ROLLER (RL465065)
056_04-04-14 EL-PANEL COVER, STANDARD
057_04-04-15 EL-PANEL COVER, LI-ION STANDARD
058_04-04-16 EL-PANEL COVER, COLD STORAGE
059_04-04-17 FASTENER, WIRE SET BRAKE
060_04-04-18 FASTENER, WIRE SET CONNECTOR
061_04-04-19 LATCH
062_04-04-20 LOWERING STOP 500mm
063_04-04-21 MACHINERY SHIELD
064_04-04-22 PROTECTIVE COVER
065_04-04-23 SEAT PLATE
066_04-04-24 CUSHION
067_04-04-25 SENSOR PLATE ASSEMBLY
068_04-04-26 STEP (RL618936)
069_04-04-27 STEP (RL618931)
070_05-05-01 HYDRAULIC SYSTEM, 4-VALVE
071_05-05-02 HYDRAULIC SYSTEM, 5-VALVE
072_05-05-03 PRESSURE SENSOR
073_05-05-05 5-VALVE BLOCK
074_05-05-06 PUMP MOTOR ASSEMBLY
075_09-09-01 PUMP MOTOR 30V 10KW
076_09-09-02 PUMP MOTOR 30V 14KW
077_05-05-07 PUMP, 16cc & 19cc
078_05-05-08 GASKET KIT
079_05-05-10 OIL TANK FILTER
080_05-05-11 FREE LIFT CYLINDER, i20TF
081_05-05-12 GASKET HOLDER, i20TF
082_05-05-13 GASKET HOLDER, Ø40
083_05-05-14 GASKET HOLDER, Ø45
084_05-05-15 REACH CYLINDER
085_05-05-16 FRAME PRESSURE HOSE
086_09-09-01 DRIVE UNIT WITH MOTOR
087_09-09-03 TRACTION MOTOR 30V 7,5kW
088_09-09-04 GEAR (RL636920)
089_09-09-05 GEAR (RL618590)
090_09-09-06 GEAR (RL618235)
091_09-09-07 BRAKE
092_07-07-05 AUX HOSE FASTENERS, i20TF (STANDARD)
093_07-07-06 AUX HOSE FASTENERS, i20TF (COLD STORAGE)
094_07-07-07 HOSES AND CHAINS i16TF (STANDARD)
095_07-07-08 HOSES AND CHAINS i16TF (COLD STORAGE)
096_07-07-09 CHAINS 16TF, INTERMEDIATE MAST
097_07-07-10 CHAINS 16TF, LIFTING CARRIAGE
098_07-07-11 HOSES AND CHAINS i20TF, 4800-7000 (STANDARD)
099_07-07-12 HOSES AND CHAINS i20TF, 7500-13000 (STANDARD)
100_07-07-13 HOSES AND CHAINS i20TF, 4800-7000 (COLD STORAGE)
101_07-07-14 HOSES AND CHAINS i20TF, 7500-13000 (COLD STORAGE)
102_07-07-16 PISTON & FREELIFT CYLINDER, i20TF
103_07-07-17 HEIGHT SENSOR, i16TF_i20TF
104_07-07-18 SIDE SHIFT AND TILT SENSOR
105_07-07-19 SIDESHIFT AND TILT SENSOR CENTERING ASSEMBLY
106_07-07-20 SIDESHIFT AND TILT SENSOR WIRE SET
107_07-07-21 PALLET SENSOR
108_07-07-23 HOSE ROLLER, WO_ MAST CABLE
109_07-07-24 HOSE ROLLER, WO_ MAST CABLE (COLD STORAGE)
110_07-07-25 HOSE ROLLER, W_ MAST CABLE
111_03-03-01 LIFING CARRIAGE (STANDARD)
112_03-03-02 LIFTING CARRIAGE (RL484007-P)
113_03-03-04 LIFING CARRIAGE (RL605831)
114_03-03-05 GASKET HOLDER
115_03-03-06 LIFTING CARRIAGE (SIDE SHIFTER)
116_03-03-07 LIFTING CARRIAGE (RL620814)
117_03-03-08 SIDE SHIFT FORK POSITIONER
118_03-03-09 TELESCOPIC FORK
119_03-03-10 FORK (RL624579)
120_03-03-11 LOAD SUPPORT
121_03-03-13 REACH CARRIAGE (WIDE FORK)
122_03-03-14 REACH CARRIAGE (NARROW FORK)
123_10-10-01 DRIVE WHEEL
124_10-10-02 LOAD WHEEL
125_10-10-03 LOAD WHEEL BRAKE
126_01-01-01 ACCESSORIES
127_01-01-02 ABBOT
128_01-01-03 ABBOT, GPRS
129_01-01-04 ABBOT, GPRS+iBUTTON
130_01-01-05 ABBOT, WLAN
131_01-01-07 ACCESSORY RACK, STANDARD
132_01-01-08 ACCESSORY RACK, DRIVE IN
133_01-01-09 ACCESSORY RACK, COLD CABIN
134_01-01-10 ARM REST
135_01-01-13 BATTERY CHANGING DEVICE, 775Ah
136_01-01-15 BRACKET, MOUNTING
137_01-01-16 BRACKET, ONLY PROTECTIVE COVER
138_01-01-17 BRACKET, WITH ACCESSORIES
139_01-01-18 BUZZER
140_01-01-19 CABLE HOLDER CASE (FORK CAMERA)
141_01-01-20 CAMERA ASSY
142_01-01-21 COMPUTER RACK
143_01-01-22 DRIVING SEAT, MSG20
144_01-01-23 DRIVING SEAT, MSG20, ARM REST
145_01-01-24 DRIVING SEAT, MSG20, SAFETY BELT
146_01-01-25 DRIVING SEAT, MSG65
147_01-01-26 DRIVING SEAT, MSG65, W_ LEFT ARM REST
148_01-01-27 DRIVING SEAT, MSG65, W_ VINYL BACK REST
149_01-01-28 DRIVING SEAT, MSG75
150_01-01-29 FAN
151_01-01-30 FIRE EXTINGUISHER
152_01-01-31 FIRE EXTINGUISHER ASSEMBLY
153_01-01-32 CABIN FAN
154_01-01-33 FAN, 48V
155_01-01-34 HYDRAULIC SYSTEM, ADDITIONAL, 5-VALVE
156_01-01-35 INSULATOR
157_01-01-36 INTERCOM SYSTEM
158_01-01-37 MIRROR, WIDE ANGLE
159_01-01-38 OHG PROTECTIVE COVER
160_01-01-39 DRIVER SHOULDER SHIELD
161_01-01-40 WARNING LIGHT, RUBBER BASE
162_01-01-41 WARNING LIGHT, STROBE
163_01-01-42 WINDSHIELD WIPER
164_01-01-43 WORKING LIGHT (RLMX100144)
165_01-01-44 WORKING LIGHT (RLMX100130)
166_01-01-45 WRITING PAD
Brand: Caterpillar
Region: Europe
021_06-06-21 SWITCH
027_06-06-27 DECALS
061_04-04-19 LATCH
091_09-09-07 BRAKE
127_01-01-02 ABBOT
139_01-01-18 BUZZER
150_01-01-29 FAN
- CAT 416D Parts Manual
- CAT 420D Parts Manual
