Caterpillar Forklift NR16N2H Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00032601
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar NR16N2H Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: DOC00032601
Number of Pages: 666 Pages
001_06-06-01 MAIN ASSEMBLY
002_06-06-02 OPERATOR COMPARTMENT, STANDARD CABIN
003_06-06-03 OPERATOR COMPARTMENT, DRIVE-IN CABIN
004_06-06-05 OPERATOR COMPARTMENT, COLD CABIN (RL624641)
005_06-06-07 OPERATOR COMPARTMENT, COLD CABIN - FRAME PARTS
006_06-06-08 OPERATOR COMPARTMENT, COLD CABIN - DOOR
007_06-06-09 CONTROL PANEL (STANDARD)
008_06-06-10 CONTROL PANEL (NARROW)
009_06-06-11 CONTROL PANEL (DUAL PEDAL)
010_06-06-12 DUAL PEDAL - 1
011_06-06-13 DUAL PEDAL - 2
012_06-06-14 DUAL PEDAL - 3
013_06-06-15 HEATER I (COLD CABIN)
014_06-06-16 HEATER II (COLD CABIN)
015_06-06-17 STEERING UNIT
016_06-06-18 STEERING WHEEL, ROCKING PART
017_06-06-19 STEERING WHEEL, ROCKING PART, COLD STORAGE
018_06-06-20 STEERING WHEEL, PRE-ASSEMBLY
019_06-06-21 STEERING WHEEL, PRE-ASSEMBLY, COLD STORAGE
020_06-06-22 STEERING WHEEL AND BRODIE KNOB
021_06-06-23 SWITCH
022_06-06-24 SWITCH, KEY, W_ PIN-CODE
023_06-06-25 DUAL JOYSTICK ASSEMBLY, WO_ FR
024_06-06-26 DUAL JOYSTICK, WO_ FR
025_06-06-27 DUAL JOYSTICK ASSEMBLY, W_ FR
026_06-06-28 DUAL JOYSTICK, W_ FR
027_06-06-29 DECALS
028_06-06-30 DECALS, COLD CABIN
029_02-02-01 EL-PANEL, W_ 500A CONTROLLER (STANDARD)
030_02-02-02 EL-PANEL, W_ 500A CONTROLLER (STANDARD) - EN1175
031_02-02-03 EL-PANEL, W_ 500A CONTROLLER (COLD CABIN)
032_02-02-04 EL-PANEL, W_ 500A CONTROLLER (COLD CABIN) - EN1175
033_02-02-05 EL-PANEL, W_ 400A CONTROLLER (NARROW)
034_02-02-06 EL-PANEL, W_ 400A CONTROLLER (NARROW) - EN1175
035_02-02-07 EL-PANEL, W_ 500A CONTROLLER (NARROW)
036_02-02-08 EL-PANEL, W_ 500A CONTROLLER (NARROW) - EN1175
037_02-02-09 CONVERTER EL-PANEL
038_02-02-10 AUDIO SYSTEM
039_02-02-11 BATTERY CABLE
040_02-02-12 BLUE SPOT LIGHT
041_02-02-13 DRIVING LIGHT
042_02-02-14 FUSE HOLDER
043_02-02-15 POWER OUTLET DC_DC 24V, 200W
044_02-02-16 READING LIGHT
045_02-02-17 VCM WITH SOFTWARE
046_02-02-18 VOLTAGE CONVERTER
047_04-04-04 CHASSIS (NR16N2(H)C)
048_04-04-05 CHASSIS (NR20N2H)
049_04-04-06 CHASSIS (NR20-252X)
050_04-04-07 ACTIVE SWAY CONTROL (RL624399)
051_04-04-08 ACTIVE SWAY CONTROL (RL624697)
052_04-04-09 BATTERY COVER, 465Ah, COMPACT
053_04-04-10 BATTERY COVER, 620Ah
054_04-04-11 BATTERY COVER, 620Ah, COMPACT
055_04-04-12 BATTERY COVER, 775Ah
056_04-04-13 BATTERY COVER, 930Ah
057_04-04-14 BATTERY COVER, 930Ah, COLD CABIN
058_04-04-15 BATTERY LATCH, STANDARD
059_04-04-16 BATTERY LATCH, OPTION
060_04-04-17 BATTERY ROLLER MAIN ASSEMBLY
061_04-04-18 BATTERY ROLLER
062_04-04-19 BATTERY ROLLER (RL465065)
063_04-04-20 EL-PANEL COVER, STANDARD
064_04-04-21 EL-PANEL COVER, LI-ION STANDARD
065_04-04-22 EL-PANEL COVER, COLD STORAGE
066_04-04-23 FASTENER, WIRE SET BRAKE
067_04-04-24 FASTENER, WIRE SET CONNECTOR
068_04-04-25 LATCH
069_04-04-26 LOWERING STOP 500mm
070_04-04-27 MACHINERY SHIELD (STANDARD)
071_04-04-28 MACHINERY SHIELD (NARROW)
072_04-04-29 PROTECTIVE COVER (STANDARD)
073_04-04-30 PROTECTIVE COVER (NARROW)
074_04-04-31 SEAT PLATE (STANDARD)
075_04-04-32 SEAT PLATE (NARROW)
076_04-04-33 CUSHION
077_04-04-34 SENSOR PLATE ASSEMBLY (RB16N2(H)C)
078_04-04-35 SENSOR PLATE ASSEMBLY (RB20N2H)
079_04-04-36 SENSOR PLATE ASSEMBLY (RB20-252X)
080_04-04-37 STEP (STANDARD) - 1
081_04-04-38 STEP (NARROW) - 1
082_04-04-39 STEP (STANDARD) - 2
083_04-04-40 STEP (NARROW) - 2
084_05-05-01 HYDRAULIC SYSTEM, 4-VALVE
085_05-05-02 HYDRAULIC SYSTEM, 5-VALVE
086_05-05-03 PRESSURE SENSOR
087_05-05-04 4-VALVE BLOCK
088_05-05-05 5-VALVE BLOCK
089_05-05-06 PUMP MOTOR ASSEMBLY
090_09-09-01 PUMP MOTOR 30V 10KW
091_09-09-02 PUMP MOTOR 30V 14KW
092_05-05-07 PUMP, 16cc & 19cc
093_05-05-08 GASKET KIT
094_05-05-09 OIL TANK
095_05-05-10 OIL TANK FILTER
096_05-05-11 FREE LIFT CYLINDER, i20TF
097_05-05-12 GASKET HOLDER, i20TF
098_05-05-13 GASKET HOLDER, Ø40
099_05-05-14 GASKET HOLDER, Ø45
100_05-05-15 REACH CYLINDER, SHORT
101_05-05-16 REACH CYLINDER, LONG
102_05-05-17 FRAME PRESSURE HOSE
103_09-09-01 DRIVE UNIT WITH MOTOR
104_09-09-02 TRACTION MOTOR 30V 7kW
105_09-09-03 TRACTION MOTOR 30V 7,5kW
106_09-09-04 GEAR (RL636920)
107_09-09-05 GEAR (RL618590)
108_09-09-06 GEAR (RL618235)
109_09-09-07 BRAKE
110_07-07-05 AUX HOSE FASTENERS, i20TF (STANDARD)
111_07-07-06 AUX HOSE FASTENERS, i20TF (COLD STORAGE)
112_07-07-07 HOSES AND CHAINS i16TF (STANDARD)
113_07-07-08 HOSES AND CHAINS i16TF (COLD STORAGE)
114_07-07-09 CHAINS 16TF, INTERMEDIATE MAST
115_07-07-10 CHAINS 16TF, LIFTING CARRIAGE
116_07-07-11 HOSES AND CHAINS i20TF, 4800-7000 (STANDARD)
117_07-07-12 HOSES AND CHAINS i20TF, 7500-13000 (STANDARD)
118_07-07-13 HOSES AND CHAINS i20TF, 4800-7000 (COLD STORAGE)
119_07-07-14 HOSES AND CHAINS i20TF, 7500-13000 (COLD STORAGE)
120_07-07-15 PISTON & FREELIFT CYLINDER, i16TF
121_07-07-16 PISTON & FREELIFT CYLINDER, i20TF
122_07-07-17 HEIGHT SENSOR, i16TF_i20TF
123_07-07-18 SIDE SHIFT AND TILT SENSOR
124_07-07-19 SIDESHIFT AND TILT SENSOR CENTERING ASSEMBLY
125_07-07-20 SIDESHIFT AND TILT SENSOR WIRE SET
126_07-07-21 PALLET SENSOR
127_07-07-22 BEARING CLEARANCE ROLLER
128_07-07-23 HOSE ROLLER, WO_ MAST CABLE
129_07-07-24 HOSE ROLLER, WO_ MAST CABLE (COLD STORAGE)
130_07-07-25 HOSE ROLLER, W_ MAST CABLE
131_07-07-26 HOSE ROLLER, W_ MAST CABLE (COLD STORAGE)
132_03-03-01 LIFING CARRIAGE (STANDARD)
133_03-03-02 LIFTING CARRIAGE (RL484007-P)
134_03-03-03 LIFTING CARRIAGE (REINFORCED)
135_03-03-04 LIFING CARRIAGE (RL605831)
136_03-03-05 GASKET HOLDER
137_03-03-06 LIFTING CARRIAGE (SIDE SHIFTER)
138_03-03-07 LIFTING CARRIAGE (RL620814)
139_03-03-08 SIDE SHIFT FORK POSITIONER
140_03-03-09 TELESCOPIC FORK
141_03-03-10 FORK (RL624579)
142_03-03-11 LOAD SUPPORT
143_03-03-12 FORK ASSY
144_03-03-13 REACH CARRIAGE (WIDE FORK)
145_03-03-14 REACH CARRIAGE (NARROW FORK)
146_10-10-01 DRIVE WHEEL
147_10-10-02 LOAD WHEEL
148_10-10-03 LOAD WHEEL BRAKE
149_10-10-04 BRAKE ASSEMBLY
150_01-01-01 ACCESSORIES
151_01-01-02 ABBOT
152_01-01-03 ABBOT, GPRS
153_01-01-04 ABBOT, GPRS+iBUTTON
154_01-01-05 ABBOT, WLAN
155_01-01-06 ABBOT, WLAN+iBUTTON
156_01-01-07 ACCESSORY RACK, STANDARD
157_01-01-08 ACCESSORY RACK, DRIVE IN
158_01-01-09 ACCESSORY RACK, COLD CABIN
159_01-01-10 ARM REST
160_01-01-13 BATTERY CHANGING DEVICE, 775Ah
161_01-01-14 SIDE GUIDE ROLLER
162_01-01-15 BRACKET, MOUNTING
163_01-01-16 BRACKET, ONLY PROTECTIVE COVER
164_01-01-17 BRACKET, WITH ACCESSORIES
165_01-01-18 BUZZER
166_01-01-19 CABLE HOLDER CASE (FORK CAMERA)
167_01-01-20 CAMERA ASSY
168_01-01-21 COMPUTER RACK
169_01-01-22 DRIVING SEAT, MSG20
170_01-01-23 DRIVING SEAT, MSG20, ARM REST
171_01-01-24 DRIVING SEAT, MSG20, SAFETY BELT
172_01-01-25 DRIVING SEAT, MSG65
173_01-01-26 DRIVING SEAT, MSG65, W_ LEFT ARM REST
174_01-01-27 DRIVING SEAT, MSG65, W_ VINYL BACK REST
175_01-01-28 DRIVING SEAT, MSG75
176_01-01-29 FAN
177_01-01-30 CABIN FAN
178_01-01-31 FAN, 48V
179_01-01-32 FIRE EXTINGUISHER
180_01-01-33 FIRE EXTINGUISHER ASSEMBLY
181_01-01-34 HYDRAULIC SYSTEM, ADDITIONAL, 5-VALVE
182_01-01-35 INSULATOR
183_01-01-36 INTERCOM SYSTEM
184_01-01-37 MIRROR, WIDE ANGLE
185_01-01-38 OHG PROTECTIVE COVER
186_01-01-39 DRIVER SHOULDER SHIELD
187_01-01-40 WARNING LIGHT, RUBBER BASE
188_01-01-41 WARNING LIGHT, STROBE
189_01-01-42 WINDSHIELD WIPER
190_01-01-43 WORKING LIGHT (RLMX100144)
191_01-01-44 WORKING LIGHT (RLMX100130)
192_01-01-45 WRITING PAD
Brand: Caterpillar
Region: Europe
021_06-06-23 SWITCH
027_06-06-29 DECALS
068_04-04-25 LATCH
109_09-09-07 BRAKE
151_01-01-02 ABBOT
165_01-01-18 BUZZER
176_01-01-29 FAN
- CAT 416D Parts Manual
- CAT 420D Parts Manual
