Caterpillar Forklift NO20NEX Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00032553
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar NO20NEX Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: DOC00032553
Number of Pages: 256 Pages
001_01-01-01 ACCESSORIES
002_01-01-02 ACCESSORY RACK (NO10NEF, NO20NEX)
003_01-01-03 ACCESSORY RACK (NO10NEFP, NO20NEXP)
004_01-01-04 ADAPTER 465Ah, SCISSOR
005_01-01-05 ADAPTER 620Ah, SCISSOR
006_01-01-06 BRACKET, BOTTLE HOLDER
007_01-01-07 BRACKET, PENHOLDER
008_01-01-08 COMPUTER RACK
009_01-01-09 DISPLAY UNIT, PICKING ASSISTANT
010_01-01-10 IGNITION SWITCH
011_01-01-11 FAN, 24V
012_01-01-12 FAN, BUILT-UP
013_01-01-13 LIST BRACKET
014_01-01-14 SAFETY BAR
015_02-02-01 ABBOT, WLAN
016_02-02-02 ABBOT, WLAN iBUTTON
017_02-02-03 ABBOT, WLAN+GPRS
018_02-02-04 ABBOT, GPRS
019_02-02-05 ABBOT, GPRS iBUTTON
020_02-02-06 ABBOT, WLAN+GPRS iBUTTON
021_02-02-07 CONTROL PANEL, STANDARD PLATFORM (NO10NEF, NO20NEX)
022_02-02-08 CONTROL PANEL, RAISING PLATFORM (NO20NEXP)
023_02-02-09 CONTROL PANEL, RASING PLATFORM + MINI MAST (NO10NEFP)
024_02-02-10 EL-PANEL
025_02-02-11 EL-PANEL, COLD STORAGE
026_02-02-12 LIGHT, 24V, WHITE LED
027_02-02-13 PRESS KEY
028_02-02-14 SENSOR, PRESSURE MEASURE
029_02-02-15 SWITCH, WALK BESIDE LIFT BUTTONS
030_02-02-16 SWITCH, WALK BESIDE DRIVING BUTTONS
031_02-02-17 SWITCH, WALK BESIDE DRIVING+LIFT BUTTONS
032_02-02-18 DISPLAY UNIT, W_ CURRENT OUTPUT
033_02-02-19 VOLTAGE TRANSDUCER, AUDIOVISUAL PICKING DISPLAY MOUNT
034_02-02-20 VOLTAGE TRANSDUCER, OUTPUT 12V _ 12,5A - 1
035_02-02-21 VOLTAGE TRANSDUCER, OUTPUT 12V _ 12,5A - 2
036_02-02-22 VOLTAGE TRANSDUCER, OUTPUT 12V _ 12,5A - 3
037_02-02-23 VOLTAGE TRANSDUCER, OUTPUT 12V _ 12,5A + 24V _ 6,5A
038_02-02-24 VOLTAGE TRANSDUCER, OUTPUT 24V _ 6,5A
039_03-03-01 LEVERAGE, SCISSOR
040_03-03-02 LIFTING DEVICE, SCISSOR
041_03-03-03 LOAD SUPPORT, BASIC FORKS
042_03-03-04 LOAD SUPPORT, SCISSOR FORKS
043_03-03-05 ROLLER, PALLET ENTRY AND EXIT
044_03-03-06 ROLLER, CROSSWISE HANDLING
045_04-04-01 BATTERY COVER, 465Ah + HANDLE
046_04-04-02 BATTERY COVER, 620Ah
047_04-04-03 BATTERY ROLLER - 1
048_04-04-04 BATTERY ROLLER - 2
049_04-04-05 LIFTING CARRIAGE
050_04-04-06 BRACKET, GARBAGE BAG
051_04-04-07 BUMPER, STANDARD
052_04-04-08 BUMPER, BUILT-UP
053_04-04-09 BUZZER, 24V
054_04-04-10 BUZZER, 48V
055_04-04-11 BUZZER, 24V, US
056_04-04-12 LEVER
057_04-04-13 MACHINEY SHIELD
058_04-04-14 MESH
059_04-04-15 STEERING UNIT
060_04-04-16 SWITCH, IGNITION LOCK + KEY ASSEMBLY
061_04-04-17 SWITCH, EMERGENCY STOP
062_04-04-18 SWITCH, START BUTTON
063_04-04-19 TRACTOR UNIT, BASIC (NO10NEF, NO20NEX)
064_04-04-21 TRACTOR UNIT, RAISING PLATFORM (NO10NEFP, NO20NEXP)
065_04-04-22 TRACTOR UNIT, RAISING PLATFORM, COLD STORAGE (NO10NEFP, NO20NEXP)
066_05-05-01 CYLINDER
067_05-05-02 CYLINDER, LEFT, RAISING PLATFORM
068_05-05-03 CYLINDER, RIGHT, RAISING PLATFORM
069_05-05-04 LIFTING CYLINDER, H=800
070_05-05-05 LIFTING CYLINDER, H=800, RAISING PLATFORM
071_05-05-06 HYDRAULIC AGGREGATE - 1
072_05-05-07 HYDRAULIC AGGREGATE - 2
073_05-05-08 HYDRAULIC AGGREGATE - 3
074_05-05-09 HYDRAULIC AGGREGATE - 4
075_05-05-10 HYDRAULIC SYSTEM (NO10NEF, NO20NEX)
076_05-05-11 HYDRAULIC SYSTEM (NO10NEFP, NO20NEXP)
077_05-05-12 OIL TANK
078_05-05-13 PUMP
079_06-06-01 ADAPTER 465Ah, MINI MAST
080_06-06-02 ADAPTER 620Ah, MINI MAST
081_06-06-03 MAIN ASSEMBLY
082_06-06-04 PLATFORM ASSEMBLY (NO10NEF, NO20NEX)
083_06-06-06 PLATFORM (NO10NEF, NO20NEX)
084_06-06-07 PLATFORM (NO10NEFP, NO20NEXP)
085_06-06-08 STEERING WHEEL, B3-PANEL, BUILT-UP (NO10NEF, NO20NEX)
086_06-06-09 STEERING WHEEL, BUILT-UP (NO10NEF, NO20NEX)
087_06-06-10 STEERING WHEEL (NO10NEFP, NO20NEXP)
088_06-06-11 TRANSMISSION UNIT
089_07-07-01 MAST UNIT, MINI MAST
090_07-07-02 MAST UNIT, 520-550
091_07-07-03 MAST UNIT, 540
092_08-08-01 CHAIN YOKE
093_08-08-02 CHAIN YOKE, SCISSOR
094_09-09-01 BRAKE
095_09-09-02 DRIVE UNIT
096_09-09-03 DRIVING MOTOR
097_09-09-04 SWITCH, START-BUTTON
098_10-10-01 CASTER WHEEL
099_10-10-02 LOAD WHEEL, TANDEM
