Caterpillar Forklift MC60D P Chassis Mast Europe Parts Catalog SEBN2661-02
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar MC60D P Chassis Mast Forklift
Region: Europe
Part Number: SEBN2661-02
Number of Pages: 823 Pages
001_HARNESS GP-WIRING M40DP, M50DP
002_HARNESS GP-WIRING MC60DP
003_PANEL GP-CONTROL-PART 1 OF 2 TYPE 1 923000-PAGE 4
004_PANEL GP-CONTROL-PART 2 OF 2 TYPE 1
005_PANEL GP-CONTROL-PART 1 OF 2 TYPE 2 6R8700-PAGE 6.01
006_PANEL GP-CONTROL-PART 2 OF 2 TYPE 2
007_PANEL GP-CONTROL-PART 1 OF 2 TYPE 3 8Q5694-PAGE 6.03.01
008_PANEL GP-CONTROL-PART 2 OF 2 TYPE 3
009_PANEL GP-CONTROL-PART 2 OF 3 835910-PAGE 9, 914052-PAGE 10, 914051-PAGE 11, 929317-PAGE 12 6R5535-PAGE 6
010_PANEL GP-CONTROL-PART 3 OF 3 913988-PAGE 8 6R5535-PAGE 6.04 IS AVAILABLE PART OF 970019 CONTROL PANEL
011_PANEL GP-CONTROL-PART 1 OF 3 929316-PAGE 7 6R5535-PAGE 6.04 IS AVAILABLE PART OF 970019 CONTROL PANEL
012_PANEL GP-CONTROL-PART 2 OF 3 914051-PAGE 11, 914052-PAGE 10, 835910 AND 6R5465-PAGE 9 6R5535-PAGE 6
013_PANEL GP-CONTROL-PART 3 OF 3 913988-PAGE 8 6R5535-PAGE 6.04 IS AVAILABLE PART OF 970019 CONTROL PANEL_1
014_PANEL GP-CONTROL-PART 2 OF 3_R 913988-PAGE 8 PART OF 970019 CONTROL PANEL
015_PANEL GP-CONTROL-PART 3 OF 3_R PART OF 970019 CONTROL PANEL
016_CABLE AS USED TO MODIFY AN SA PANEL TO USE A PUMP CONTACTOR FOR HEAVY HYDRAULIC APPLICaterpillarIONS FIELD _INSTALLATION
017_BOARD AS-DRIVER PART OF 923000, 6R8700, 8Q5694 PANELS-CONTROL
018_BOARD AS-CURRENT SENSOR PART OF 923000, 6R8700, 8Q5694 PANELS-CONTROL
019_CONTACTOR AS-BYPASS PART OF 923000, 6R8700, 8Q5694 PANELS-CONTROL
020_CONTROL GP-ELECTRONIC PART OF 6R8700 PANEL-CONTROL
021_CONTACTOR AS-FORWARD AND REVERSE-2 REQUIRED PART OF 923000, 6R8700, 8Q5694 PANELS-CONTROL
022_CONTACTOR AS-LINE, LIFT, BYPASS-3 REQUIRED PART OF 923000, 6R8700, 8Q5694 PANELS-CONTROL
023_LOGIC GP PART OF 923000 PANEL-CONTROL
024_CONNECTOR GP-BATTERY
025_CONNECTOR GP-BATTERY-SBE
026_CONNECTOR AS-SBE-48 VOLT (POLARIZED CHARGER HALF) TO COMPLY WITH EEC REGULATIONS
027_CONNECTOR AS-SBE 48 VOLT (POLARIZED BATTERY HALF) TO COMPLY WITH EEC REGULATIONS
028_HORN GP-ELECTRIC
029_INSTRUMENT GP M40DP8 M50DP
030_INSTRUMENT GP TYPE 1 MC60DP
031_INSTRUMENT GP TYPE 2 MC60DP
032_CONTROL GP-ACCELERATION 917486-PAGE 21
033_SWITCH GP-ACCELERATOR PART OF 913091 CONTROL-ACCELERATION
034_CONTROL GP-FORWARD AND REVERSE
035_LIGHTING GP FOR EUROPEAN USE ONLY
036_LIGHTING GP 835951-PAGE 41
037_LIGHTING GP-ROAD 12 VOLT FOR EUROPEAN USE ONLY
038_LIGHTING GP-FLOOD MAST MOUNTED FOR U.S. USE ONLY
039_LIGHTING GP-FLOOD OVERHEAD GUARD MOUNTED
040_LIGHTING GP-FLOOD HEADGUARD MOUNTED-LH
041_LIGHTING GP-SIGNAL AMBER FRONT AND REAR FACING SIGNAL LIGHTS
042_LIGHTING GP-STOP AND TAIL PRIMARY RED HEADGUARD MOUNTED-LH
043_LIGHTING GP-STOP AND TAIL SECONDARY-RED HEADGUARD MOUNTED-RH
044_LIGHTING GP-STROBE FLASHING RED REAR HEADGUARD MOUNTED
045_LIGHTING GP-STROBE FLASHING-AMBER REAR HEADGUARD MOUNTED
046_LIGHTING GP-STROBE FLASHING-AMBER REAR HEADGUARD OR TOP HEADGYARD MOUNTED FOR EUROPEAN USE ONY
047_LIGHTING GP-STROBE FLASHING-RED TOP HEADGUARD MOUNTED FOR 360 DEGREE VISIBILITY
048_LIGHTING GP-STROBE FLASHING-AMBER TOP HEADGUARD MOUNTED FOR 360 DEGREE VISIBILITY
049_LIGHTING GP-STROBE FLASHING AMBER OVERHEAD GUARD MOUNTED-REAR CENTER
050_WARNING GP-BACK-UP AUDIBLE HEADGUARD MOUNTED FOR EUROPEAN USE ONLY
051_WARNING GP-BACK-UP AUDIBLE REAR HEADGUARD MOUNTED
052_WARNING GP-BACKUP AUDIBLE OVERHEAD GUARD MOUNTED-REAR LH LEG
053_WARNING GP-BACK-UP FLASHING STROBE-RED REAR HEADGUARD MOUNTED
054_WARNING GP-BACK-UP FLASHING STROBE-AMBER REAR HEADGUARD MOUNTED
055_WIRING GP-LIGHTING-PART 1 OF 2 12 VOLT WIRING SYSTEM FOR OPTIONAL LIGHTING AND WARNING GPS FOR EUROPEAN USE _ONLY
056_WIRING GP-LIGHTING PART 2 OF 2 12 VOLT WIRING SYSTEM FOR OPTIONAL LIGHTING AND WARNING GPS 835951-PAGE 41 FOR _EUROPEAN
057_WIRING GP-LIGHTING CONVERTS 36_48 VOLT TO 12 VOLT 835951-PAGE 41 U.S. USAGE
058_CONVERTER GP-ELECTRICAL_R PART OF 6R5359 LIGHTING AND 929156, 925602 WIRING-LIGHTING
059_MOTOR GP-ELECTRIC MAIN DRIVE
060_MOTOR GP-ELECTRIC MAIN DRIVE_R TYPE 1 907404-PAGE 45 PART OF 975777 MOTOR-ELECTRIC MAIN DRIVE
061_MOTOR GP-ELECTRIC MAIN DRIVE_R TYPE 2 986715-PAGE 44.02 PART OF 975777 MOTOR-ELECTRIC MAIN DRIVE
062_THERMOSTAT AS PART OF 916100 ELECTRIC MAIN DRIVE MOTOR
063_THERMOSTAT AS PART OF 916100 MOTOR-ELECTRIC MAIN DRIVE
064_AXLE GP-DRIVE
065_TRANSAXLE AR
066_MOUNTING GP-TRANSMISSION PART OF 975780 TRANSAXLE AR
067_POWER TRANSFER GP PART OF 975780 TRANSAXLE AR
068_TIRE AR-WIDE
069_TIRE AR-WIDE_1
070_TIRE AR-WIDE_2
071_TIRE AR-WIDE_3
072_TIRE AR-WIDE M40DP - M50DP
073_TIRE AR-WIDE MC60DP
074_TIRE AR-WIDE MC60DP - DRIVE, STEER COMPOUND-ELECTRIC
075_TIRE AR-WIDE M40DP, M50DP, MC60DP
076_TIRE AR-NARROW
077_TIRE AR-NARROW_1
078_TIRE AR-NARROW DRIVE COMPOUND-POLYURETHANE, STEER COMPOUND-ELECTRIC M40DP, M50PD
079_TIRE AR-NARROW DRIVE, STEER COMPOUND-ELECTRIC M40DP, M50DP
080_TIRE AR-NARROW M40DP - M50DP
081_TIRE AR-NARROW MC60DP
082_TIRE AR-NARROW MC60DP - DRIVE, STEER COMPOUND-ELECTRIC
083_TIRE AR-NARROW M40DP, M50DP, MC60DP
084_WHEEL AND TIRE GP-DRIVE-2 REQUIRED ELECTRIC COMPOUND-WIDE PART OF 917815, 917819 AND 8Q7282 TIRE ARS
085_WHEEL AND TIRE GP-DRIVE-2 REQUIRED POLYURETHANE-WIDE PART OF 6R8005, 917823 AND 917827 TIRE ARS
086_WHEEL AND TIRE GP-DRIVE 2 REQUIRED ELECTRIC COMPOUND-NARROW PART OF 6R7983, 6R7985 AND 8Q7279 TIRE ARS
087_WHEEL AND TIRE GP-DRIVE-2 REQUIRED POLYURETHANE-NARROW PART OF 6R7987, 6R7989 AND 6R7991 TIRE ARS
088_WHEEL AND TIRE GP-DRIVE 2 REQUIRED NON-MARKING COMPOUND-WIDE PART OF 6R8007, 6R8009 AND 8Q7284 TIRE ARS
089_WHEEL AND TIRE GP-DRIVE 2 REQUIRED NON-MARKING COMPOUND-NARROW PART OF 6R7993, 6R7995 AND 8Q7281 TIRE ARS
090_WHEEL AND TIRE GP-DRIVE-2 REQUIRED MC60DP - WIDE PART OF 6R7998 AND 8Q7283 TIRE ARS
091_WHEEL AND TIRE GP-DRIVE-2 REQUIRED MC60DP - NARROW PART OF 6R7984 AND 8Q7280 TIRE ARS
092_MOUNTING GP-DRIVE WHEEL-2 REQUIRED WIDE AXLE PART OF 6R7998, 6R8005, 6R8007, 6R8009, 8Q7282, 8Q7283, 8Q7284, 917815, _91
093_MOUNTING GP-DRIVE WHEEL-2 REQUIRED NARROW AXLE PART OF 6R7983, 6R7984, 6R7985, 6R7987, 6R7989, 6R7991, 6R7993, _6R7995,
094_MOUNTING GP-DRIVE AXLE
095_AXLE GP-STEER 863450-PAGE 64
096_AXLE GP-STEER 863450-PAGE 64_1
097_KIT-STEER AXLE TAPERED ROLLER BEARING FIELD INSTALLATION
098_CYLINDER GP-STEER PART 3F 863464, 6R6955 AXLES-STEER
099_MOUNTING GP-STEER AXLE
100_LINES GP-POWER STEER TYPE 1
101_LINES GP-POWER STEER TYPE 2
102_STEERING WHEEL AND GEAR GP
103_STEERING WHEEL AND GEAR GP_1
104_WHEEL AND TIRE GP-STEER 2 REQUIRED POLYURETHANE COMPOUND PART OF 6R7985, 6R7987, 6R7995, 6R8009, 917819, AND _917823 TIR
105_WHEEL AND TIRE GP-STEER 2 REQUIRED ELECTRIC COMPOUND PART OF 6R7983, 6R7989, 917815 AND 917827 TIRE ARS.
106_WHEEL AND TIRE GP-STEER 2 REQUIRED ELECTRIC COMPOUND PART OF 6R7983, 6R7984, 6R7989, 6R7998, 917815 AND 917827 _TIRE ARS
107_WHEEL AND TIRE GP-STEER 2 REQUIRED NON-MARKING COMPOUND PART OF 6R7991, 6R7993, 6R8005 AND 6R8007 TIRE ARS.
108_WHEEL AND TIRE GP-STEER-2 REQUIRED PART OF 8Q7279, 8Q7280, 8Q7282 AND 8Q7283 TIRE ARS
109_WHEEL AND TIRE GP-STEER-2 REQUIRED PART OF 8Q7281, 8Q7284 TIRE ARS
110_WHEEL AND TIRE GP-STEER-2 REQUIRED PART OF 6R8074 WHEEL AND TIRE-STEER
111_MOUNTING GP-STEER WHEEL-2 REQUIRED
112_CONTROL GP-BRAKE
113_KIT-SERVICE REPAIR 987517-PAGE 73.02 USE ON TRUCKS REQUIRING DOUBLE ACTING MASTER CYLINDER FIELD INSTALLATION
114_CONTROL GP-BRAKE 909738-PAGE 73.03 PART OF 6R8017 KIT-SERVICE REPAIR
115_CYLINDER GP-MASTER PART OF 987517 CONTROL-BRAKE
116_CONTROL GP-BRAKE-PART 2 OF 2 TYPE 1
117_CONTROL GP-BRAKE-PART 1 OF 2 TYPE 2
118_CONTROL GP-BRAKE-PART 2 OF 2 TYPE 2
119_CONTROL GP-PARKING BRAKE-PART 1 OF 2
120_CONTROL GP-PARKING BRAKE-PART 2 OF 2
121_BRAKE GP-SERVICE 923663-PAGE 80 PART OF 975780 TRANSAXLE AR
122_BRAKE GP-SERVICE 6R8021-PAGE 80.01 PART OF 975780 TRANSAXLE AR
123_BRAKE GP-PARKING 923176-PAGE 78
124_BRAKE GP-PARKING PART OF 920330 BRAKE-PARKING
125_BRAKE GP-PARKING PART OF 970868, 6R5357, 1020072 CHANGEOVER ARS
126_BRAKE AS-2 REQUIRED PART OF 975808 BRAKE-SERVICE
127_BRAKE AS-SERVICE-2 REQUIRED PART OF 6R8097 BRAKE-SERVICE
128_LINES GP-BRAKE
129_LINES GP-SERVICE BRAKE
130_CHANGEOVER AR-FOOT BRAKE TO SEAT BRAKE-PART 1 OF 2 923177-PAGE 79
131_CHANGEOVER AR-FOOT BRAKE TO SEAT BRAKE-PART 2 OF 2 970827-PAGE 101
132_CHANGEOVER AR-FOOT BRAKE TO SEAT BRAKE-PART 1 OF 2 973177-PAGE 79
133_CHANGEOVER AR-SEAT PARK BRAKE 923177-PAGE 79
134_PANEL GP-TOP-PART 1 OF 2 M40D
135_PANEL GP-TOP-PART 2 OF 2 M40D
136_PANEL GP-TOP M40D
137_PANEL GP-TOP-PART 1 OF 2 M50D
138_PANEL GP-TOP-PART 2 OF 2 M50D
139_PANEL GP-TOP M50D
140_PANEL GP-TOP MC60DP
141_PANEL GP-TOP MC60DP_1
142_PANEL GP-SIDE
143_PANEL GP-SIDE_1
144_COWLING GP M40DP, M50DP
145_COWLING GP M40DP, M50DP, MC60DP
146_GUARD GP-OVERHEAD M40D
147_GUARD GP-OVERHEAD M40D_1
148_GUARD GP-OVERHEAD M50D
149_GUARD GP-OVERHEAD M50D_1
150_GUARD GP-OVERHEAD MC60DP
151_FLOORPLATE GP
152_FENDER GP PART OF 6R7998, 6R8005, 6R8007, 6R8009, 8Q7282, 8Q7283, 8Q72848 917815, 9178198 917823 AND 917827 TI
153_COUNTERWEIGHT GP M50D
154_COUNTERWEIGHT GP M40D
155_COUNTERWEIGHT GP MC60DP
156_COUNTERWEIGHT GP-AUXILIARY M40DP, M50DP PROVIDES ADDITIONAL COUNTERWEIGHT TO COMPENSATE FOR THE WEIGHT _OF A SMALL BATTE
157_COUNTERWEIGHT GP-AUXILIARY MC60DP PROVIDES ADDITIONAL COUNTERWEIGHT TO COMPENSATE FOR THE WEIGHT OF A _SMALL BATTERY
158_CONTAINER AS
159_CHANGEOVER AR-E TO ES
160_SEAT GP 970852-PAGE 100
161_SEAT GP 970827-PAGE 101
162_SEAT GP 970827-PAGE 101 PART OF 970853 AND 6R5355 SEATS
163_SEAT GP-SUSPENSION 6R7231-PAGE 104.07
164_SEAT GP-SUSPENSION TYPE 1 970917-PAGE 100.04
165_SEAT GP-SUSPENSION TYPE 2 970887-PAGE 104.04
166_SEAT GP-SUSPENSION TYPE 3 6R6634-PAGE 104.04.01
167_SEAT GP-SUSPENSION CLOTH CUSHION PART OF 1011468 SEAT
168_SET GP PART OF 970852 SEAT, 970868 AND 6R5327 CHANGEOVER ARS
169_SEAT GP 970848-PAGE 103
170_SEAT GP 970826-PAGE 104 PART OF 970855 SEAT GP
171_SEAT GP PART OF 970848 SEAT
172_SEAT GP-SUSPENSION TYPE 1 970917-PAGE 100.04_1
173_SEAT GP-SUSPENSION 970887-PAGE 104.03 PART OF 6R5356 SEAT
174_SEAT GP-SUSPENSION TYPE 2 970887-PAGE 104.04_1
175_SEAT GP-SUSPENSION VINYL PART OF 970634, 1011468, 6R5356 SEATS
176_SEAT GP (VINYL) SUSPENSION SEAT W_MICRO SWITCH PART 3 1011468
177_SEAT GP-SUSPENSION TYPE 1 6R7231-PAGE 104.07
178_SEAT GP-SUSPENSION TYPE 2 6R7182-PAGE 104.08
179_SEAT GP PART OF 8Q5562, 1011466 SEATS
180_SEAT GP PART OF 8Q5562 SEAT
181_SEAT GP TYPE 1 6R6625-PAGE 104.10
182_SEAT GP TYPE 2 1095584-PAGE 104.10.01
183_SEAT GP-CLOTH SUSPENSION PART OF 6R6636 SEAT AND 8Q5806 CONVERSION KIT
184_SEAT GP PART OF 6R6636 SEAT AND 8Q5806 CONVERSION KIT 36_48 VOLT
185_KIT-CONVERSION FIELD INSTALLATION
186_CONSOLE GP-CAB
187_CONSOLE GP-CAB_1
188_CONVERSION GP-RESTRICTOR PART OF 834468 MAST AR
189_CONVERSION GP-RESTRICTOR PART OF 834454 STD, 834466 FFL AND 834468 FFTL MAST ARS
190_VALVE AR-2-PART 1 OF 2 987292-PAGE 112, 916900-PAGE 115
191_VALVE AR-2-PART 2 OF 2 987500-PAGE 123
192_VALVE AR-2 WAY 916900-PAGE 115, 987293-PAGE 113, 987500-PAGE 123
193_VALVE AR-3-PART 1 OF 2 987500-PAGE 123
194_VALVE AR-3-PART 2 OF 2 987293-PAGE 113, 916900-PAGE 115
195_VALVE AR-4-PART 1 OF 2 TYPE 1 987500-PAGE 123
196_VALVE AR-4-PART 2 OF 2 TYPE 1 987294-PAGE 114, 916900-PAGE 115
197_VALVE AR-4-PART 1 OF 2 TYPE 2 987500-PAGE 123
198_VALVE AR-4-PART 2 OF 2 TYPE 2 6R6264-PAGE 122.02, 916900-PAGE 115
199_VALVE GP-CONTROL-2 WAY PART OF 970024 VALVE AR-2
200_VALVE GP-CONTROL-3 WAY 987296-PAGE 122 PART OF 970025, 8Q5542 VALVE ARS
201_VALVE GP-CONTROL-4 WAY 987295-PAGE 122.03, 987297-PAGE 122.04 PART OF 970026 VALVE AR-4
202_BOARD AS-VALVE CONTROL PART OF 970024, 970025, 970026, 8Q5542 VALVE ARS
203_CHANGEOVER AR-2 WAY TO 3 WAY-PART 1 OF 2 TYPE 1 987500-PAGE 123
204_CHANGEOVER AR-2 WAY TO 3 WAY-PART 2 OF 2 TYPE 1 987296-PAGE 122
205_CHANGEOVER AR-2 WAY TO 3 WAY-PART 1 OF 2 TYPE 2 987500-PAGE 123
206_CHANGEOVER AR-2 WAY TO 3 WAY-PART 2 OF 2 TYPE 2
207_CHANGEOVER AR-2 WAY TO 4 WAY-PART 1 OF 2 TYPE 1 987500-PAGE 123
208_CHANGEOVER AR-2 WAY TO 4 WAY-PART 2 OF 2 TYPE 1 987297-PAGE 122.04
209_CHANGEOVER AR-2 WAY TO 4 WAY-PART 1 OF 2 TYPE 2 987500-PAGE 123
210_CHANGEOVER AR-2 WAY TO 4 WAY-PART 2 OF 2 TYPE 2 6R6267-PAGE 122.01
211_CHANGEOVER AR-3 WAY TO 4 WAY-PART 1 OF 2 TYPE 1 987500-PAGE 123
212_CHANGEOVER AR-3 WAY TO 4 WAY-PART 2 OF 2 TYPE 1 987297-PAGE 122.04
213_CHANGEOVER AR-3 WAY TO 4 WAY-PART 1 OF 2 TYPE 2 987500-PAGE 123
214_CHANGEOVER AR-3 WAY TO 4 WAY-PART 2 OF 2 TYPE 2 6R6267-PAGE 122.01
215_VALVE GP OPTIONAL REPLACEMENT VALVES PART OF 987293 VALVE-CONTROL AND 970027 CHANGEOVER AR
216_VALVE GP-CONTROL PART OF 970028, 970029, AND 1069624 CHANGEOVER ARS
217_VALVE GP-CONTROL 987295-PAGE 122.03, 987297-PAGE 122.04 PART OF 970026 VALVE AR
218_VALVE GP PART OF 6R6264, 987292, 987293, 987294 VALVES-CONTROL VALVE AR
219_VALVE GP PART OF 6R6264, 987294 VALVES-CONTROL AND 970028, 970029 CHANGEOVER ARS
220_VALVE GP 3 TO 4 WAY VALVE CONVERSION ARS
221_SWITCH GP PART OF 970024, 970025, 970026, 8Q5542 VALVE ARS AND 970027, 970028, 970029, AND 1069624 CHANGEOVER
222_LINES GP-MAST OPERATING 917335-PAGE 125
223_FILTER GP-HYDRAULIC OIL PART OF 970021 LINES-MAST OPERATING
224_TANK GP-HYDRAULIC
225_MOTOR GP-ELECTRIC HYDRAULIC PUMP 913149-PAGE 128
226_MOTOR GP-ELECTRIC HYDRAULIC PUMP_R PART OF 975785 MOTOR-ELECTRIC HYDRAULIC PUMP
227_PUMP GP-GEAR
228_CYLINDER GP-TILT (CHG-00) FFTL-2 REQUIRED 80MM (3.1 IN.) BORE X (1.7 IN) STROKE 3 DEG. FORWARD X 3 DEG. BACKWARD _TILT
229_CYLINDER GP-TILT (CHG-01) STD, FFL, FFTL-2 REQUIRED 80MM (3.1 IN.) BORE X 58MM (2.3 IN.) STROKE 3 DEG. FORWARD X 5 _DEG
230_CYLINDER GP-TILT (CHG 01) STD, FFL-2 REQUIRED 80MM (3.1 IN.) BORE X 81MM (3.2 IN.) STROKE 3 DEG. FORWARD X 8 DEG
231_CYLINDER GP-TILT (CHG 01) STD-2 REQUIRED 80MM (3.1 IN.) BORE X 96MM (3.8 IN.) STROKE 3 DEG. FORWARD X 10 DEG
232_CYLINDER GP-TILT (CHG 00) FFTL-2 REQUIRED 80MM (3.1 IN.) BORE X 65MM (2.6 IN.) STROKE 6 DEG. FORWARD X 3 DEG
233_CYLINDER GP-TILT (CHG 03) STD FFL, FFTL-2 REQUIRED 80MM (3.1 IN.) BORE X 79.5MM (3.1 IN.) STROKE 6 DEG
234_CYLINDER GP-TILT (CHG 01) STD FFL, FFTL-2 REQUIRED 80MM (3.1 IN.) BORE X 102MM (4 IN.) STROKE 6 DEG. FORWARD X 8 DEG
235_CYLINDER GP-TILT (CHG 01) STD-2 REQUIRED 80MM (3.1 IN.) BORE X 117MM (4.6 IN.) STROKE 6 DEG. FORWARD X 10 DEG
236_CYLINDER GP-TILT (CHG 01) STD, FFL, FFTL-2 REQUIRED 80MM (3.1 IN.) BORE X 107MM (4.2 IN.) STROKE 10 DEG
237_CYLINDER GP-TILT (CHG 04) STD, FFL, FFTL-2 REQUIRED 80MM (3.1 IN.) BORE X 145MM (5.7 IN.) STROKE 10 DEG
238_CYLINDER GP-TILT PART OF 911510, 910876 AND 910835 CYLINDER-TILT
239_MOUNTING GP-LIFT AND TILT-FFTL MFH 3950MM (155 IN.) PART OF 834468 MAST AR
240_MOUNTING GP-LIFT AND TILT-FFTL MFH 4355MM (171 IN.) PART OF 834469 MAST AR
241_MOUNTING GP-LIFT AND TILT-FFTL MFH 4775MM (188 IN.) PART OF 834470 MAST AR
242_MOUNTING GP-LIFT AND TILT-FFTL MFH 5600MM (222 IN.) PART OF 834471 MAST AR
243_MOUNTING GP-LIFT AND TILT-FFTL MFH 6050MM (238 IN.) PART OF 834472 MAST AR
244_MOUNTING GP-LIFT AND TILT-FFL MFH 2625MM (103 IN.) PART OF 834464 MAST AR
245_MOUNTING GP-LIFT AND TILT-FFL MFH 2995MM (118 IN.) PART OF 834465 MAST AR
246_MOUNTING GP-LIFT AND TILT-FFL MFH 3275MM (129 IN.) PART OF 834466 MAST AR
247_MOUNTING GP-LIFT AND TILT-FFL MFH 3650MM (143 IN.) PART OF 834467 MAST AR
248_MOUNTING GP-LIFT AND TILT-STD PART OF 834454, 834456, 834457, 834458, 834459, 834460, 834461 AND 834462 MAST ARS
249_MOUNTING GP-LIFT AND TILT-FFL-PART 1 OF 2 PART OF 911474, 911479, 910866 AND 911484 MOUNTING-LIFT AND TILT
250_MOUNTING GP-LIFT AND TILT-FFL-PART 2 OF 2 PART OF 911474, 911479, 910866 AND 911484 MOUNTING-LIFT AND TILT
251_MOUNTING GP-LIFT AND TILT-FFTL-PART 2 OF 2 PART OF 911489, 911494, 910854, 911499 MOUNTING-LIFT AND TILT
252_LINES GP-ATTACHMENT-3 WAY-STD LIFT
253_LINES GP-ATTACHMENT-3 WAY-STD LIFT_1
254_LINES GP-ATTACHMENT-4 WAY-STD LIFT
255_LINES GP-ATTACHMENT-3 WAY-FFL
256_LINES GP-ATTACHMENT-4 WAY-FFL
257_LINES GP-SECONDARY ATTACHMENT-3 WAY-STD LIFT RH SIDE
258_LINES GP-SECONDARY ATTACHMENT-RH-3 WAY-STD LIFT MC60DP
259_LINES GP-SECONDARY ATTACHMENT-3 WAY-FFL, FFTL RH SIDE
260_LINES GP-SECONDARY ATTACHMENT-4 WAY-STD LIFT LH SIDE
261_LINES GP-SECONDARY ATTACHMENT-LH-4 WAY-STD LIFT MC60DP
262_LINES GP-SECONDARY ATTACHMENT-4 WAY-FFL, FFTL LH SIDE
263_LINES GP-SECONDARY ATTACHMENT-4 WAY-STD LIFT MC60DP
264_LINES GP-SECONDARY ATTACHMENT-4 WAY-STD LIFT
265_LINES GP-SECONDARY ATTACHMENT-4 WAY-FFL, FFTL
266_LINES GP-SIDESHIFTER-STD LIFT
267_LINES GP-SIDESHIFTER-4 WAY-STD LIFT M40DP, M50DP
268_LINES GP-SIDESHIFTER-4 WAY-FFL, FFTL M40DP, M50DP
269_LINES GP-SIDESHIFTER-STD LIFT MC60DP
270_LINES GP-SIDESHIFTER-FFL, FFTL
271_LINES GP-SIDESHIFTER-FFL, FFTL MC60DP
272_LINES GP-SIDESHIFTER-FFL, FFTL MC60DP_1
273_COUPLING GP FOR USE WITH 3 WAY AND 4 WAY HYDRAULICS
274_KIT-CONVERSION-TILT LIMIT PART OF 910887, 910841 CYLINDER-TILT
275_KIT-CONVERSION-TILT LIMIT PART OF 911517, 910869 AND 911509 CYLINDER-TILT
276_KIT-CONVERSION-TILT LIMIT PART OF 911511, 910885 CYLINDER-TILT
277_LIMIT GP-TILT PART OF 911510, 910876 AND 910835 CYLINDER-TILT
278_MAST AR-STD LIFT MFH 2075MM (81.7 IN.)
279_MAST AR-STD LIFT MFH 2995MM (117 IN.)
280_MAST AR-STD LIFT MFH 3275MM (129 IN.)
281_MAST AR-STD LIFT MFH 3350MM (139 IN.)
282_MAST AR-STD LIFT MFH 3850MM (151 IN.)
283_MAST AR-STD LIFT MFH 4000MM (158 IN.)
284_MAST AR-STD LIFT MFH 4400MM (173 IN.)
285_MAST AR-STD LIFT MFH 5000MM (197 IN.)
286_MAST AR-FFL MFH 2625MM (103 IN.)
287_MAST AR-FFL MFH 2995MM (118 IN.)
288_MAST AR-FFL MFH 3275MM (129 IN.)
289_MAST AR-FFL MFH 3650MM (143 IN.)
290_MAST AR-FFTL MFH 3950MM (155 IN.)
291_MAST AR-FFTL MFH 4355MM (171 IN.)
292_MAST AR-FFTL MFH 4775MM (188 IN.)
293_MAST AR-FFTL MFH 5600MM (222 IN.)
294_MAST AR-FFTL MFH 6050MM (238 IN.)
295_MAST GP-STD LIFT MFH 2075MM (81.7 IN.) PART OF 834454 MAST AR
296_MAST GP-STD LIFT MFH 2995MM (117 IN.) PART OF 834456 MAST AR
297_MAST GP-STD LIFT MFH 3275MM (129 IN.) PART OF 834457 MAST AR
298_MAST GP-STD LIFT MFH 3550MM (139 IN.) PART OF 834458 MAST AR
299_MAST GP-STD LIFT MFH 3850MM (151 IN.) PART OF 834459 MAST AR
300_MAST GP-STD LIFT MFH 4000MM (158 IN.) PART OF 834460 MAST AR
301_MAST GP-STD LIFT MFH 4400MM (174 IN.) PART OF 834461 MAST AR
302_MAST GP-STD LIFT MFH 5000MM (197 IN.) PART OF 834462 MAST AR
303_MAST GP-FFL PART OF 834465 MAST AR
304_MAST GP-FFL MFH 2625MM (103 IN.) PART OF 834464 MAST AR
305_MAST GP-FFL MFH 3275MM (129 IN.) PART OF 834466 MAST AR
306_MAST GP-FFL MFH 3650MM (143 IN.) PART OF 834467 MAST AR
307_MAST GP-FFTL MFH 3950MM (155 IN.) PART OF 834468 MAST AR
308_MAST GP-FFTL MFH 4355MM (171 IN.) PART OF 834469 MAST AR
309_MAST GP-FFTL MFH 4775MM (188 IN.) PART OF 834470 MAST AR
310_MAST GP-FFTL MFH 5600MM (222 IN.) PART OF 834471 MAST AR
311_MAST GP-FFTL MFH 6050MM (238 IN.) PART OF 834472 MAST AR
312_MAST GP-STD, FFL PART OF 834473, 834475, 834476, 834477, 834478, 834479, 834480, 834481, 910864, 911471, 911476, 9114
313_MAST GP-FFTL PART OF 910849, 910912, 911486, 911491 AND 911496 MASTS
314_MOUNTING GP-MAST
315_UPRIGHT AS-STATIONARY-FFTL 910972 UPRIGHT AS-INTERMEDIATE FFTL8 910978 UPRIGHT AS-INNER-FFTL PART OF 910965, _911376, 91
316_UPRIGHT AS-STATIONARY-STD LIFT PART OF 834489, 834490, 834491, 834492, 834493, 8344948 834495 AND 834496 UPRIGHTSSTATION
317_UPRIGHT AS-STATIONARY-FFL 911088 UPRIGHT AS-INNER-FFL PART OF 911078, 911531, 911533, 911535 UPRIGHTS-STATIONARY _PART O
318_UPRIGHT AS-INNER-STD LIFT PART OF 834500, 834502, 834503, 834504, 834505, 834506, 834507, 834499 UPRIGHTS-INNER
319_UPRIGHT AS-STATIONARY-STD LIFT PART OF 834488 UPRIGHT-STATIONARY
320_LIFT GP-STD-2 REQUIRED PART OF 834460 MAST AR
321_LIFT GP-STD-2 REQUIRED PART OF 834462 MAST AR
322_LIFT GP-STD-2 REQUIRED PART OF 834459 MAST AR
323_LIFT GP-STD-2 REQUIRED PART OF 834457 MAST AR
324_LIFT GP-STD-2 REQUIRED PART OF 834454 MAST AR
325_LIFT GP-STD-2 REQUIRED PART OF 834456 MAST AR
326_LIFT GP-STD-2 REQUIRED PART OF 834458 MAST AR
327_LIFT GP-STD-2 REQUIRED PART OF 834461 MAST AR
328_LIFT GP-PRIMARY-FFL PART OF 834465 MAST AR
329_LIFT GP-PRIMARY-FFL MFH 3950MM (143 IN.) PART OF 834467 MAST AR
330_LIFT GP-PRIMARY-FFL MFH 2625MM (103 IN.) PART OF 834464 MAST AR
331_LIFT GP-PRIMARY-FFL MFH 3275MM (129 IN.) PART OF 834466 MAST AR
332_LIFT GP-PRIMARY-FFTL MFH 3950MM (155 IN.) PART OF 834468 MAST AR
333_LIFT GP-PRIMARY-FFTL MFH 4355MM (171 IN.) PART OF 834469 MAST AR
334_LIFT GP-PRIMARY-FFTL MFH 4775MM (188 IN.) PART OF 834470 MAST AR
335_LIFT GP-PRIMARY-FFTL MFH 5600MM (222 IN.) PART OF 834471 MAST AR
336_LIFT GP-PRIMARY-FFTL MFH 6050MM (238 IN.) PART OF 834472 MAST AR
337_LIFT GP-SECONDARY-FFL-2 REQUIRED PART OF 834465 MAST AR
338_LIFT GP-SECONDARY-FFL-2 REQUIRED MFH 2625MM (103 IN.) PART OF 834464 MAST AR
339_LIFT GP-SECONDARY-FFL-2 REQUIRED MFH 3275MM (129 IN.) PART OF 834466 MAST AR
340_LIFT GP-SECONDARY-FFL-2 REQUIRED MFH 3650MM (143 IN.) PART OF 834467 MAST AR
341_LIFT GP-SECONDARY-FFTL-2 REQUIRED MFH 3950MM (155 IN.) PART OF 834468 MAST AR
342_LIFT GP-SECONDARY-FFTL-2 REQUIRED MFH 4355MM (171 IN.) PART OF 834469 MAST AR
343_LIFT GP-SECONDARY-FFTL-2 REQUIRED MFH 4775MM (188 IN.) PART OF 834470 MAST AR
344_LIFT GP-SECONDARY-FFTL-2 REQUIRED MFH 5600MM (222 IN.) PART OF 834471 MAST AR
345_LIFT GP-SECONDARY-FFTL-2 REQUIRED MFH 6050MM (238 IN.) PART OF 834472 MAST AR
346_LIFT GP-PRIMARY-FFTL PART OF 910851, 910913, 911487, 911492 AND 911497 LIFTS
347_LIFT GP-FFL PART OF 910852, 911472, 911477 AND 911482 LIFTS
348_LIFT GP-SECONDARY-STD, FFTL PART OF 910828, 910829, 910905, 910909, 910914, 911460, 911463, 911466, 911469, 911493, 9114
349_LIFT GP-SECONDARY-FFL PART OF 911038, 911473, 911478 AND 911483 LIFTS
350_RELAY GP-LIFT-STD PART OF 834454, 834456, 834457, 834458, 834459, 834460, 834461 AND 834462 MAST ARS
351_RELAY GP-LIFT-FFL PART OF 834464, 834465, 834466 AND 834467 MAST ARS
352_RELAY GP-LIFT-FFTL PART OF 834468, 834469, 834470, 834471 AND 834472 MAST ARS
353_CARRIAGE AR-STD CARRIAGE WIDTH 973MM (38 IN.) WIDE M40DP, M50DP
354_CARRIAGE AR-STD LIFT WIDTH 973MM (38 IN) M40DP, M50DP
355_CARRIAGE AR-STD CARRIAGE WIDTH 1025MM (40 IN.) WIDE MC60DP
356_CARRIAGE AR-FFL CARRIAGE WIDTH 973MM (38 IN.) WIDE M40DP, M50DP
357_CARRIAGE AR-FFTL WIDTH 973MM (38 IN.) M40DP, M50DP
358_CARRIAGE AR-FFL CARRIAGE WIDTH 1025MM (40 IN.) WIDE MC60DP
359_CARRIAGE AR-FFTL CARRIAGE WIDTH 973MM (38 IN.) WIDE M40DP, M50DP
360_CARRIAGE AR-FFTL WIDTH 973MM (38 IN. M40DP, M50DP
361_CARRIAGE AR-FFTL CARRIAGE WIDTH 1025MM (40 IN.) WIDE MC60DP
362_CARRIAGE AS-STD PART OF 908966 CARRIAGE AR M40DP, M50DP
363_CARRIAGE AS-STD LIFT PART OF 6R8718 CARRIAGE AR M40DP, M50DP
364_CARRIAGE AS-STD PART OF 910845 CARRIAGE AR MC60DP
365_CARRIAGE AS-FFL PART OF 908969 CARRIAGE AR M40DP, M50DP
366_CARRIAGE AS-FFL PART OF 6R8719 CARRIAGE AR M40DP, M50DP
367_CARRIAGE AS-FFL PART OF 910867 CARRIAGE AR MC60DP
368_CARRIAGE AS-FFTL PART OF 908971 CARRIAGE AR M40DP, M50DP
369_CARRIAGE AS-FFTL PART OF 6R8720 CARRIAGE AR M40DP, M50DP
370_CARRIAGE AS-FFTL PART OF 910859 CARRIAGE AR
371_MOUNTING GP-CARRIAGE-STD, FFL, FFTL PART OF 908966, 908969, 908971, 6R8718, 6R8719, 6R8720 CARRIAGE ARS M40DP, _M50DP
372_MOUNTING GP-CARRIAGE-STD, FFL, FFTL, PART OF 910845, 910867 AND 910859 CARRIAGE ARS MC60DP
373_SIDESHIFTER GP TYPE 1 911160-PAGE 218 M40DP, M50DP
374_SIDESHIFTER GP TYPE 2 911160-PAGE 218 M40DP, M50DP
375_SIDESHIFTER GP 911160-PAGE 218 MC60DP
376_SIDESHIFTER GP 6R7401-PAGE 217.05
377_CYLINDER GP-SIDESHIFTER (CHG 00-01) 41.6MM (1.6 IN) BORE X 204MM (8.0 IN) STROKE PART OF 6R8732, 6R8733 SIDESHIFTERS
378_CYLINDER GP-SIDESHIFTER PART OF 910873, 910879 SIDESHIFTERS
379_BACKREST AS-LOAD M40DP, M50DP
380_BACKREST AS-LOAD MC60DP
381_FORK GP-PALLET-HOOK TYPE-2 REQUIRED 100MM (4 IN.) WIDE, 45MM 1.8 IN.) THK, 900MM (35 IN.) LONG
382_FORK GP-PALLET HOOK TYPE-2 REQUIRED 130MM (5.1 IN.) WIDE, 45MM (1.8 IN.) THK, 1050MM (41 IN.) LONG
383_FORK GP-FULLY TAPERED AND POLISHED-HOOK TYPE 2 REQUIRED 130MM (5.1 IN.) WIDE, 45MM (1.8 IN.) THK, 1050MM (41 IN.) _LONG
384_FORK GP-PALLET-HOOK TYPE-2 REQUIRED 100MM (4 IN.) WIDE, 45MM (1.8 IN.) THK, 1050MM (42 IN.) LONG
385_FORK GP-FULLY TAPERED AND POLISHED-HOOK TYPE 2 REQUIRED 100MM (4 IN.) WIDE, 45MM (1.8 IN.) THK, 1050MM (42 IN.) LONG
386_FORK GP-PALLET-HOOK TYPE-2 REQUIRED 130MM (5.1 IN.), 45MM (1.8 IN.) THK, 1200MM (47 IN.) LONG
387_FORK GP-FULLY TAPERED AND POLISHED-HOOK TYPE 2 REQUIRED 130MM (5.1 IN.) WIDE, 45MM (1.8 IN.) THK, 1200 MM (47 IN
388_FORK GP-PALLET-HOOK TYPE-2 REQUIRED 100MM (4 IN.) WIDE, 45MM 1.8 IN.) THK, 1200MM (48 IN.) LONG
389_FORK GP-TAPERED AND POLISHED-HOOK TYPE 2 REQUIRED 100MM (4 IN.) WIDE, 45MM (1.8) THK, 1200MM (48 IN.) LONG
390_LUBRICANT AND PAINT GP TRANSFERS, DECALS AND PLATES
391_PAINT AND LUBRICANT GP-DANISH
392_PAINT AND LUBRICANT GP-DANISH_1
393_PAINT AND LUBRICANT GP-DUTCH
394_PAINT AND LUBRICANT GP-DUTCH_1
395_PAINT AND LUBRICANT GP-FRENCH
396_PAINT AND LUBRICANT GP-FRENCH_1
397_PAINT AND LUBRICANT GP-GERMAN
398_PAINT AND LUBRICANT GP-GERMAN_1
399_PAINT AND LUBRICANT GP-GREEK
400_PAINT AND LUBRICANT GP-GREEK_1
401_PAINT AND LUBRICANT GP-ITALIAN
402_PAINT AND LUBRICANT GP-ITALIAN_1
403_PAINT AND LUBRICANT GP-PORTUGUESE
