Caterpillar Forklift M40B Chassis Mast Europe Parts Catalog HEBN2593-02
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar M40B Chassis Mast Forklift
Region: Europe
Part Number: HEBN2593-02
Number of Pages: 611 Pages
001_916616 WIRING HARNESS GROUP
002_916551 HARNESS ASSEMBLY--PART 1 OF 2
003_916551 HARNESS ASSEMBLY--PART 2 OF 2
004_910655 CONTROL PANEL GROUP-PART 1 OF 2 - TYPE 1
005_910655 CONTROL PANEL GROUP-PART 2 OF 2 - TYPE 1
006_910655 CONTROL PANEL GROUP-PART 1 OF 2 - TYPE 2
007_910655 CONTROL PANEL GROUP-PART 2 OF 2 - TYPE 2
008_903060 BASIC CONTROL PANEL GROUP-PART 1 OF 3-TYPE 1_R
009_903060 BASIC CONTROL PANEL GROUP-PART 3 OF 3-TYPE 1_R
010_903060 BASIC CONTROL PANEL GROUP-PART 1 OF 3-TYPE 2_R
011_903060 BASIC CONTROL PANEL GROUP-PART 3 OF 3-TYPE 2_R
012_917139 BASIC CONTROL PANEL GROUP-PART 1 OF 3
013_917139 BASIC CONTROL PANEL GROUP-PART 3 OF 3
014_918496 LOGIC ASSEMBLY
015_399262 HARNESS ASSEMBLY--PART 1 OF 2
016_399262 HARNESS ASSEMBLY--PART 2 OF 2
017_394437 BASIC CONTACTOR PANEL GROUP
018_917140 BASIC CONTACTOR PANEL GROUP
019_912528 SEAT SWITCH DELAY ASSEMBLY
020_392291 FUSE ASSEMBLY
021_388766 1-DRIVE HEATSINK ASSEMBLY
022_918776 1-DRIVE HEATSINK ASSEMBLY
023_388763 2-THYRISTOR DRIVE HEATSINK ASSEMBLY
024_394929 6-DIODE DRIVE HEATSINK ASSEMBLY
025_388760 3-THYRISTOR DRIVE HEATSINK ASSEMBLY
026_394925 5-DOIDE DRIVE HEATSINK ASSEMBLY
027_396989 1-PUMP HEATSINK ASSEMBLY
028_388821 3-THYRISTOR PUMP HEATSINK ASSEMBLY
029_396468 ZENER HEATSINK ASSEMBLY (NSS)
030_918764 ZENER HEATSINK ASSEMBLY
031_394614 REGENERATIVE CONTACTOR ASSEMBLY
032_376870 FORWARD AND REVERSE CONTACTOR ASSEMBLY
033_394391 FIELD SHUNT CONTACTOR ASSEMBLY
034_386641 BY-PASS CONTACTOR ASSEMBLY
035_389705 LINE CONTACTOR ASSEMBLY
036_389918 HARNESS ASSEMBLY
037_3C7683 SB BATTERY CONNECTOR GROUP (NSS)
038_916617 EC BATTERY CONNECTOR GROUP (NSS)--RIGHT OR LEFT SIDE
039_0918855 BACK-UP WARNING GROUP
040_0918856 BACK-UP WARNING GROUP
041_382484 HORN GROUP (NSS)
042_916609 INSTRUMENT PANEL GROUP
043_916610 INSTRUMENT PANEL GROUP
044_916608 INSTRUMENT PANEL GROUP
045_916615 INSTRUMENT PANEL GROUP
046_916611 BASIC INSTRUMENT WARNING PANEL GROUP
047_916612 BASIC INSTRUMENT WARNING PANEL GROUP (NSS)
048_916613 BASIC INSTRUMENT WARNING PANEL GROUP (NSS)
049_916614 BASIC INSTRUMENT WARNING PANEL GROUP (NSS)
050_916552 INSTRUMENT HARNESS ASSEMBLY
051_382561 ACCELERATOR CONTROL GROUP (NSS)
052_393975 ACCELERATOR CONTROL GROUP (NSS)
053_902574 BASIC ACCELERATOR SWITCH GROUP
054_910654 FORWARD AND REVERSE CONTROL GROUP
055_903753 FORWARD AND REVERSE CONTROL GROUP
056_907490 FOOT DIRECTIONAL CONTROL HARNESS ASSEMBLY
057_912594 ELECTRIC SWITCH GROUP (NSS)
058_912595 ELECTRIC SWITCH GROUP (NSS) FOR USE WITH SEAT OPERATED PARKING BRAKE AND COVERED U.S. BATTERY 610 MM _(24 IN
059_388744 HARNESS ASSEMBLY
060_912600 HARNESS ASSEMBLY
061_351992 SPECIAL PROTECTIVE DEVICES GROUP
062_399478 SPECIAL PROTECTIVE DEVICES GROUP (NSS) FOR USE WITH MOTORS EQUIPPED WITH _EE_ AND WITH BRUSH WEAR _INDICaterpillarORS
063_916572 MAIN DRIVE MOTOR GROUP
064_3C7613 BASIC MAIN DRIVE MOTOR GROUP
065_916573 MAIN DRIVE MOTOR GROUP
066_362374 NARROW DRIVE AXLE GROUP (NSS)
067_362375 WIDE DRIVE AXLE GROUP (NSS)
068_392593 DRIVE AXLE GROUP (NSS)
069_392594 DRIVE AXLE GROUP (NSS)
070_354384 DRIVE AXLE GROUP (NSS)
071_357659 DRIVE AXLE GROUP (NSS)
072_325307 BASIC DIFFERENTIAL GROUP (5_38-1)--PART 1 OF 2
073_325307 BASIC DIFFERENTIAL GROUP (5_38-1)--PART 2 OF 2
074_325308 BASIC DIFFERENTIAL GROUP (4_88-1)--PART 1 OF 2
075_325308 BASIC DIFFERENTIAL GROUP (4_88-1)--PART 2 OF 2
076_325309 BASIC DIFFERENTIAL GROUP--PART 1 OF 2
077_325309 BASIC DIFFERENTIAL GROUP--PART 2 OF 2
078_905741 DRIVE WHEEL AND TIRE GROUP (NSS)--2 REQUIRED ELECTRIC COMPOUND
079_905742 DRIVE WHEEL AND TIRE GROUP (NSS)--2 REQUIRED NON-MARKING TIRE
080_905743 DRIVE WHEEL AND TIRE GROUP (NSS)--2 REQUIRED BERGOUGNAN TIRE
081_93787 DRIVE WHEEL AND TIRE MOUNTING GROUP (NSS)--2 REQUIRED
082_300971 POWER TRANSFER GROUP (NSS)
083_93479 STEERING AXLE GROUP 93501 STEERING AXLE MOUNTING GROUP (NSS)
084_93477 STEERING AXLE LINKAGE GROUP (NSS)
085_382483 STEERING WHEEL AND GEAR GROUP
086_394408 STEERING GEAR GROUP--PART 1 OF 2
087_394408 STEERING GEAR GROUP--PART 2 OF 2
088_320177 STEERING SHAFT AND COLUMN ASSEMBLY
089_300605 STEER AXLE SPRING GROUP (NSS)
090_907422 POWER STEERING PUMP GROUP (NSS)
091_348428 BASIC POWER STEERING PUMP GROUP
092_905639 POWER STEERING PUMP MOTOR GROUP
093_907398 BASIC POWER STEERING PUMP MOTOR GROUP
094_336099 ARM AND LINK GROUP (NSS)
095_394435 POWER STEERING OIL LINES GROUP
096_3C5799 STEER WHEEL AND TIRE GROUP (NSS)--M40B 3C5800 STEER WHEEL AND TIRE GROUP (NSS)--M50B 93505 STEER WHEEL _AND TIRE
097_330925 STEER WHEEL AND TIRE GROUP (NSS)--M40B 386112 STEER WHEEL AND TIRE GROUP (NSS)--M50B 93505 STEER WHEEL _AND TIRE
098_O389450 STEER WHEEL AND TIRE GROUP (NSS)--M40B 389451 STEER WHEEL AND TIRE GROUP (NSS)--M50B 93505 STEER WHEEL _MOUNTING
099_903716 SERVICE BRAKE GROUP (NSS)
100_903712 BASIC SERVICE BRAKE GROUP--RIGHT HAND
101_903713 BASIC SERVICE BRAKE GROUP--LEFT HAND
102_903714 BASIC SERVICE BRAKE GROUP-RIGHT HAND
103_903715 BASIC SERVICE BRAKE GROUP-LEFT HAND
104_300886 BRAKE CONTROLS GROUP(NSS)
105_382585 PARKING BRAKE GROUP(NSS)
106_389849 SEAT OPERATED PARKING BRAKE GROUP(NSS)
107_369271 SEAT OPERATED PARKING BRAKE GROUP(NSS) FOR USE WITH UNCOVERED BATTERY 575MM (22 5_8 IN.) HIGH AND U.S
108_396260 FOOT COVERED PARKING BRAKE CONTROL GROUP(NSS)--PART 1 OF 2
109_396260 FOOT OPERATED PARKING BRAKE CONTROL GROUP(NSS)--PART 2 OF 2
110_394325 NARROW AXLE SERVICE BRAKE LINES GROUP(NSS)
111_399256 WIDE AXLE SERVICE BRAKE LINES GROUP(NSS)
112_93714 MASTER CYLINDER GROUP
113_398219 TOP PANEL GROUP(NSS)--PART 1 OF 2--M40B
114_398219 TOP PANEL GROUP(NSS)--PART 2 OF 2--M40B
115_398218 TOP PANEL GROUP(NSS)--PART 1 OF 2--M50B
116_398218 TOP PANEL GROUP(NSS)--PART 2 OF 2--M50B
117_385083 TOP PANEL GROUP (NSS)--PART 1 OF 2--M40B
118_385083 TOP PANEL GROUP (NSS)--PART 2 OF 2--M40B
119_382540 TOP PANEL GROUP (NSS)--PART 1 OF 2--M50B
120_382540 TOP PANEL GROUP (NSS)--PART 2 OF 2--M50B
121_396703 TOP PANEL GROUP-M40B
122_396704 TOP PANEL GROUP-M50B
123_382539 SIDE PANEL GROUP (NSS)
124_399480 BATTERY ENCLOSURE GROUP (NSS)--M40B
125_399481 BATTERY ENCLOSURE GROUP (NSS)--M50B
126_912585 SEAT GROUP (NSS)
127_912586 SEAT GROUP (NSS) FOR USE WITH FOOT OPERATED PARKING BRAKE SHEEL METAL AND U.S, COVERED BATTERY 610 _MM (24 IN.)
128_912590 SEAT GROUP (NSS) SEAT OPERATED PARKING BRAKE FOR USE WITH UNCOVERED BATTERY 575 MM (22 5_8 IN.)
129_912591 SEAT GROUP (NSS) SEAT OPERATED PARKING BRAKE FOR USE WITH COVERED U.S. BATTERY 610 MM (24 IN.) HIGH _EE_ _TYPE
130_912592 SEAT GROUP (NSS) SEAT OPERATED PARKING BRAKE FOR USE WITH UNCOVERED BATTERY 575 MM (22 5_8 IN
131_912601 BASIC SEAT GROUP
132_913664 BASIC SEAT GROUP
133_398211 COMPOMENT SUPPORT GROUP (NSS)
134_399897 COMPONENT SUPPORT GROUP
135_383889 COMPONENT SUPPORT GROUP (NSS) FOR USE WITH SEAT OPERATED PARKING BRAKE AND UNCOVERED BATTERY 575 _MM
136_399898 COMPONENT SUPPORT GROUP (NSS) FOR USE WITH SEAT OPERATED PARKING BRAKE AND U.S. COVERED BATTERY 610 _MM (24 IN
137_905802 OVERHEAD GUARD GROUP (NSS)--M40B
138_905801 OVERHEAD GUARD GROUP (NSS)--M50B
139_905805 OVERHEAD GUARD GROUP (NSS)--M40B 2210 MM (87 IN.) USED WITH FULL PROFILE SEAT
140_905804 OVERHEAD GUARD GROUP (NSS)--M50B 2210 MM (87 IN.) USED WITH FULL PROFILE SEAT
141_382485 FLOORPLATE GROUP (NSS)
142_394451 FLOORPLATE GROUP (NSS) FOR USE WITH FOOT DIRECTIONAL CONTROL
143_300874 BATTERY RETAINER GROUP (NSS)
144_319275 BATTERY RETAINER GROUP (NSS)
145_AUXILIARY COUNTERWEIGHT GROUPS
146_AUXILIARY COUNTERWEIGHT MOUNTING PLATES
147_385118 COUNTERWEIGHT GROUP (NSS)--M40B
148_382541 COUNTERWEIGHT GROUP (NSS)--M50B
149_300963 TOWING COUPLER GROUP (NSS)--M40B
150_300964 TOWING COUPLER GROUP (NSS)--M50B
151_903009 ELECTRIC HYDRAULIC PUMP MOTOR GROUP (NSS)
152_399857 BASIC ELECTRIC HYDRAULIC PUMP MOTOR GROUP
153_903011 ELECTRIC HYDRAULIC PUMP MOTOR GROUP (NSS)
154_399850 BASIC ELECTRIC HYDRAULIC PUMP MOTOR GROUP
155_382593 MAST OPERATING VALVE GROUP--2-WAY
156_382594 MAST OPERATING VALVE GROUP--4-WAY
157_903038 MAST OPERATING VALVE GROUP--3-WAY
158_903041 MAST OPERATING VALVE GROUP--4-WAY
159_329819 RELIEF VALVE GROUP
160_373094 MAST OPERATING VALVE MOUNTING GROUP (NSS)
161_384482 MAST OPERATING VALVE CONTROL GROUP (NSS)--2-WAY--PART 1 OF 2
162_384482 MAST OPERATING VALVE CONTROL GROUP (NSS)--2-WAY--PART 2 OF 2
163_3C7600 ROD GROUP-3-WAY
164_3C6838 MAST OPERATING VALVE CONTROL GROUP (NSS)--4-WAY--PART 1 OF 2
165_3C6838 MAST OPERATING VALVE CONTROL GROUP (NSS)--4-WAY--PART 2 OF 2
166_903039 MAST OPERATING VALVE CONTROL GROUP (NSS)--3-WAY--PART 1 OF 2 FOR USE WITH AUXILIARY HYDRAULIC SPEED _CONTROL
167_903039 MAST OPERATING VALVE CONTROL GROUP (NSS)--3-WAY--PART 2 OF 2 903053 POTENTIOMETER PARTS ARE SHOWN ON _PAGE 11
168_903042 MAST OPERATING VALVE CONTROL GROUP (NSS)--4-WAY--PART 1 OF 2 FOR USE WITH AUXILIARY HYDRAULIC SPEED _CONTROL
169_903042 MAST OPERATING VALVE CONTROL GROUP (NSS)--4-WAY--PART 2 OF 2 398394 POTENTIOMETER PARTS ARE SHOWN ON _PAGE 11
170_903053 POTENTIOMETER ASSEMBLY PART OF 903039 MAST OPERATING VALVE CONTROL GROUP AND 903150 FIELD _CONVERSION GROUP SHOWN
171_398394 POTENTIOMETER ASSEMBLY PART OF 903042 MAST OPERATING VALVE CONTROL GROUP AND 903151 FIELD _CONVERSION GROUP SHOWN
172_383836 MAST OPERATING GEAR PUMP GROUP (NSS)
173_392592 MAST OPERATING GEAR PUMP GROUP (NSS) FOR USE WITH HIGH EFFICIENCY LIFT MAST AND _EE_
174_336788 HYDRAULIC OIL TANK GROUP (NSS)
175_336860 HYDRAULIC OIL FILTER GROUP (NSS)
176_384334 MAST OPERATING OIL LINES GROUP -PART 1 OF 2
177_384334 MAST OPERATING OIL LINES GROUP-PART 2 OF 2
178_906678 LIFT AND TILT MOUNTING GROUP
179_3C7511 LIFT AND TILT MOUNTING GROUP
180_3C5299 LIFT AND TILT MOUNTING GROUP
181_366491 LIFT AND TILT MOUNTING GROUP (NSS) FULL FREE LIFT
182_3C7538 LIFT & TILT MOUNTING GROUP
183_3C7528 LIFT & TILT MOUNTING GROUP-NARROE
184_3C6137 BASIC TILT CYLINDER ASSEMBLY
185_3C7236 TILT CYLINDER ASSEMBLY
186_3C7782 TILT CYLINDER ASSEMBLY
187_3C7236 BASIC TILT CYLINDER ASSEMBLY (NSS)
188_3C7782 BASIC TILT CYLINDER ASSEMBLY (NSS)
189_906683 ATTACHMENT LINES GROUP -3-WAY
190_918624 ATTACHMENT LINES GROUP
191_917383 ATTACHMENT LINES GROUP
192_399998 ATTACHMENT LINES GROUP-3-WAY
193_901380 ATTACHMENT LINES GROUP-3-WAY
194_918626 ATTACHMENT LINES GROUP- 4 WAY
195_399999 ATTACHMENT LINES GROUP (NSS)--4-WAY
196_901381 ATTACHMENT LINES GROUP-4-WAY
197_397553 ATTACHMENT LINES GROUP (NSS)--3-WAY
198_901497 ATTACHMENT LINES GROUP-3-WAY
199_397554 ATTACHMENT LINES GROUP (NSS)--4-WAY
200_901491 ATTACHMENT LINES GROUP-4-WAY
201_906754 SECONDARY ATTACHMENT LINES GROUP
202_904408 SECONDARY ATTACHMENT LINES GROUP (NSS)--3-WAY
203_904409 SECONDARY ATTACHMENT LINES GROUP (NSS)--4-WAY
204_906417 SECONDARY ATTACHMENT LINES GROUP (NSS)--4-WAY
205_375530 COUPLER GROUP (NSS)
206_917917 MAST GROUP
207_917918 MAST GROUP
208_917919 MAST GROUP
209_917920 MAST GROUP
210_917921 MAST GROUP
211_917922 MAST GROUP
212_917923 MAST GROUP
213_917924 MAST GROUP
214_906601 BASIC MAST GROUP
215_399948 MAST GROUP
216_906359 BASIC MAST GROUP
217_397052 MAST GROUP
218_397053 MAST GROUP
219_397054 MAST GROUP
220_397056 MAST GROUP
221_906365 BASIC MAST GROUP
222_397058 MAST GROUP
223_397059 MAST GROUP
224_904424 BASIC MAST GROUP
225_382161 MAST MOUNTING GROUP (NSS)
226_917943 LIFT GROUP
227_917944 LIFT GROUP
228_917945 LIFT GROUP
229_917946 LIFT GROUP
230_917947 LIFT GROUP
231_917948 LIFT GROUP
232_917949 LIFT GROUP
233_917950 LIFT GROUP
234_366239 LIFT GROUP
235_397344 LIFT GROUP
236_397073 BASIC CYLINDER GROUP
237_397345 LIFT GROUP
238_397074 BASIC CYLINDER GROUP
239_397346 LIFT GROUP
240_397075 BASIC CYLINDER GROUP
241_397348 LIFT GROUP
242_397077 BASIC CYLINDER GROUP
243_917991 LIFT RELAY GROUP
244_397390 CROSSHEAD GROUP
245_901567 LIFT RELAY GROUP (NSS)
246_397494 LIFT RELAY GROUP (NSS)
247_397495 LIFT RELAY GROUP (NSS)
248_397496 LIFT RELAY GROUP (NSS)
249_397061 LIFT RELAY GROUP
250_397090 LIFT RELAY GROUP
251_397091 LIFT RELAY GROUP
252_906631 CARRIAGE ASSEMBLY
253_397112 CARRIAGE ASSEMBLY
254_397120 CARRIAGE ASSEMBLY
255_397137 CARRIAGE ASSEMBLY
256_917356 CARRIAGE ASSEMBLY
257_917424 CARRIAGE MOUNTING GROUP
258_906688 CARRIAGE MOUNTING GROUP TYPE - 1
259_906688 CARRIAGE MOUNTING GROUP TYPE - 2
260_904314 CARRIAGE MOUNTING GROUP
261_397178 SIDESHIFTER GROUP (NSS) STANDARD, FULL FREE AND FULL FREE TRIPLE LIFT
262_397191 CYLINDER GROUP
263_906751 SIDESHIFTER LINES GROUP (NSS) STANDARD LIFT
264_904407 SIDESHIFTER LINES GROUP (NSS) FULL FREE AND FULL FREE TRIPLE LIFT--NARROW
265_399918 SIDESHIFTER LINES GROUP (NSS) FULL FREE TRIPLE LIFT--WIDE
266_372346 FORK POSITIONER GROUP (NSS)
Brand: Caterpillar
Region: Europe
- CAT 416D Parts Manual
- CAT 420D Parts Manual
