Caterpillar Forklift F60D P Chassis Mast Europe Parts Catalog SEBN2683-01
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar F60D P Chassis Mast Forklift
Region: Europe
Part Number: SEBN2683-01
Number of Pages: 649 Pages
001_HARNESS GP-WIRING
002_PANEL GP-CONTROL-PART 1 OF 2 TYPE 1
003_PANEL GP-CONTROL-PART 2 OF 2 TYPE 1
004_PANEL GP-CONTROL-PART 1 OF 2 TYPE 2
005_PANEL GP-CONTROL-PART 2 OF 2 TYPE 2
006_PANEL GP-CONTROL-PART 1 OF 3
007_PANEL GP-CONTROL-PART 3 OF 3
008_CABLE AS USED TO MODIFY AN SA PANEL TO USE A PUMP CONTACTOR FOR HEAVY HYDRAULIC APPLICaterpillarIONS FIELD
009_PANEL GP-CONTROL-PART 1 OF 3_1
010_BOARD AS-CURRENT (SENSOR) PART OF 6R8700, 8Q5694 PANELS-CONTROL
011_CONTACTOR AS-BYPASS PART OF 6R8700, 8Q5694 PANELS-CONTROL
012_CONTACTOR AS-3 REQUIRED LINE, LIFT, BYPASS PART OF 6R8700, 8Q5694 PANELS-CONTROL
013_CONTACTOR AS-FORWARD, REVERSE-2 REQUIRED PART OF 6R8700, 8Q5694 PANELS-CONTROL
014_CONTROL GP-ELECTRIC HAND PART OF 6R8700 PANEL-CONTROL
015_CONNECTOR GP-BATTERY-SBE
016_CONNECTOR GP-BATTERY-SB
017_CONNECTOR GP-SBX
018_CONNECTOR AS-BATTERY-SBX GRAY
019_CONNECTOR AS-SBE-48 VOLT POLARIZED CHARGER HALF
020_CONNECTOR AS-SBE-48 VOLT POLARIZED BATTERY HALF
021_HORN GP-ELECTRIC
022_INSTRUMENT GP
023_INSTRUMENT GP TYPE 1
024_INSTRUMENT GP TYPE 2
025_CONTROL GP-ACCELERATOR 917486-PAGE 20
026_SWITCH GP-ACCELERATOR PART OF 913091 CONTROL-ACCELERATOR
027_CONTROL GP-FORWARD AND REVERSE
028_LIGHTING GP-FLOODLIGHT ONE LIGHT MOUNTED ON RIGHT REAR ON HEADGUARD
029_LIGHTING GP-FLOODLIGHT HALOGEN 36_48 VOLT TWO FORWARD FACING AND ONE REARWARD FACING-HEADGUARD MOUNTED
030_LIGHTING GP-STOP AND TAIL SECONDARY-ONE LIGHT MOUNTED ON RIGHT SIDE OF HEADGUARD
031_LIGHTING GP-SIGNAL AMBER-FRONT AND REAR FACING DIRECTIONAL SIGNAL LIGHTS
032_LIGHTING GP FLASHING RED-MOUNTED ON REAR HEADGUARD
033_LIGHTING GP FLASHING AMBER-MOUNTED ON REAR OF HEADGUARD
034_LIGHTING GP RED-TOP HEADGUARD MOUNTED FOR 360 DEGREE VISIBILITY
035_LIGHTING GP AMBER-TOP HEADGUARD MOUNTED FOR 360 DEGREE VISIBILITY
036_LIGHTING GP-36_48 VOLT (COSA) 12 VOLT LIGHTING AND WIRING SYSTEM
037_LIGHTING GP-72_80 VOLT (COSA) 12 VOLT LIGHTING AND WIRING SYSTEM
038_LIGHTING GP-STROBE FLASHING AMBER-REAR HEADGUARD OR TOP HEADGUARD MOUNTED
039_LIGHTING GP-STOBE-AMBER
040_LIGHTING GP-STROBE FLASHING AMBER-REAR HEADGUARD MOUNTED
041_WIRING AND LIGHTING GP WIRING SYSTEM FOR OPERATION OF OPTIONAL LIGHTING AND WIRING GPS CONVERTS 36_48 TO 12
042_WIRING AND LIGHTING GP-PART 1 OF 2 CONVERTS 36_48 VOLTS TO 12 VOLTS FOR OPTIONAL LIGHTING AND WARNING GPS PART
043_WIRING AND LIGHTING GP-PART 2 OF 2 CONVERTS 36_48 VOLTS TO 12 VOLTS FOR OPTIONAL LIGHTING AND WARNING GPS
044_WIRING GP-LIGHTING-PART 1 OF 2 CONVERTS 72_80 VOLTS TO 12 VOLTS FOR OPTIONAL LIGHTING AND WARNING GPS PART OF
045_WIRING GP-LIGHTING-PART 2 OF 2 CONVERTS 72_80 VOLTS TO 12 VOLTS FOR OPTIONAL LIGHTING AND WARNING GPS 912654-
046_CONVERTER GP-ELECTRICAL PART OF 923402, 923406, 6R5399 WIRING AND LIGHTINGS
047_CONVERTER GP-ELECTRICAL PART OF 923407 WIRING-LIGHTING
048_WARNING GP-BACK-UP AUDIBLE-MOUNTED ON REAR OF HEADGUARD
049_WARNING GP-BACK-UP RED FLASHING STROBE-REAR HEADGUARD MOUNTED
050_WARNING GP-BACK-UP AMBER FLASHING STROBE-REAR HEADGUARD MOUNTED
051_WARNING GP-BACK-UP AUDIBLE-HEADGUARD MOUNTED
052_WARNING GP-BACK-UP-AUDIBLE HEADGUARD MOUNTED
053_ALARM GP-BACKUP
054_MOTOR GP-ELECTRIC MAIN DRIVE 916100-PAGE 47
055_MOTOR GP-ELECTRIC MAIN DRIVE_R TYPE 1 907404-PAGE 47.02 PART OF 975777 MOTOR-MAIN DRIVE
056_MOTOR GP-ELECTRIC MAIN DRIVE_R TYPE 2 986175-PAGE 48 PART OF 975777 MOTOR-MAIN DRIVE
057_THERMOSTAT AS PART OF 916100 MOTOR-MAIN DRIVE
058_THERMOSTAT AS PART OF 916100 MOTOR-MAIN DRIVE_1
059_TRANSAXLE AR
060_AXLE GP-DRIVE PART OF 975780 TRANSAXLE AR
061_MOUNTING GP-DRIVE AXLE
062_MOUNTING GP-TRANSMISSION PART OF 975780 TRANSAXLE AR
063_TIRE AR PROVIDES EXTRA SOFT TIRE (DRIVE AND STEER) FOR NARROW DRIVE AXLE
064_TIRE AR PROVIDES CUSHION TIRE (DRIVE AND STEER) FOR NARROW DRIVE AXLE
065_TIRE AR PROVIDES EXTRA SOFT TIRE (DRIVE AND STEER) FOR WIDE DRIVE AXLE
066_TIRE AR PROVIDES PNEUMATIC TIRE (DRIVE AND STEER) FOR WIDE DRIVE AXLE
067_WHEEL AND TIRE GP-DRIVE-2 REQUIRED PART OF 914495 TIRE AR
068_WHEEL AND TIRE GP-DRIVE-2 REQUIRED PART OF 914497 TIRE AR
069_WHEEL AND TIRE GP-DRIVE-2 REQUIRED PART OF 919056 TIRE AR
070_WHEEL AND TIRE GP-DRIVE-2 REQUIRED PART OF 919057 TIRE AR
071_MOUNTING GP-DRIVE WHEEL-2 REQUIRED PART OF 914495, 919056 AND 919057 TIRE ARS
072_MOUNTING GP-DRIVE WHEEL-2 REQUIRED PART OF 914497 TIRE AR
073_CYLINDER GP-STEER AXLE PART OF 6R6956 AXLE-STEER
074_MOUNTING GP-STEER AXLE
075_STEERING WHEEL AND GEAR GP
076_WHEEL AND TIRE GP-STEER-2 REQUIRED PART OF 914497 TIRE AR
077_WHEEL AND TIRE GP-STEER-2 REQUIRED PART OF 919057 TIRE AR
078_WHEEL AND TIRE GP-STEER-2 REQUIRED PART OF 914495 AND 919056 TIRE ARS
079_MOUNTING GP-STEER WHEEL-2 REQUIRED PART OF 914495, 919056 AND 919057 TIRE ARS
080_MOUNTING GP-STEER WHEEL-2 REQUIRED PART OF 914497 TIRE AR
081_CONTROL GP-PARKING BRAKE-PART 2 OF 2
082_CONTROL GP-SERVICE BRAKE 909738-PAGE 77
083_CYLINDER GP-MASTER PART OF 6R8032 CONTROL-BRAKE
084_BRAKE GP-SERVICE 6R8021-PAGE 79 PART OF 975780 TRANSAXLE AR
085_BRAKE AS-SERVICE-2 REQUIRED PART OF 6R8097 BRAKE-SERVICE
086_BRAKE GP-PARKING 923176-PAGE 81
087_BRAKE GP-PARKING PART OF 920330 BRAKE-PARKING
088_BRAKE GP-PARKING PART OF 970869 AND 970870 CHANGEOVER ARS
089_DRUM AS-BRAKE-2 REQUIRED PART OF 914495, 919056 AND 919057 TIRE ARS
090_LINES GP-SERVICE BRAKE
091_CHANGEOVER AR-FOOT TO SEAT BRAKE-PART 1 OF 2 923177-PAGE 82
092_CHANGEOVER AR-FOOT TO SEAT BRAKE-PART 2 OF 2 970826-PAGE 110
093_CHANGEOVER AR-FOOT TO SEAT BRAKE-PART 1 OF 2 F50DP-F60DP 923177-PAGE 82
094_CHANGEOVER AR-FOOT TO SEAT BRAKE-PART 2 OF 2 F50DP-F60DP 970826-PAGE 110
095_PANEL GP-TOP-PART 1 OF 2 F40DP, F50DP
096_PANEL GP-TOP-PART 2 OF 2 F40DP, F50DP
097_PANEL GP-TOP-PART 1 OF 2 F60DP
098_PANEL GP-TOP-PART 2 OF 2 F60DP
099_PANEL GP-SIDE
100_COWLING GP
101_COWLING GP_1
102_GUARD GP-OVERHEAD F40DP, F50DP
103_GUARD GP-OVERHEAD F40DP, F50DP_1
104_GUARD GP-OVERHEAD F60DP
105_GUARD GP-OVERHEAD F60DP_1
106_FLOORPLATE GP
107_COUNTERWEIGHT GP F40DP
108_COUNTERWEIGHT GP F50DP, F60DP
109_COUNTERWEIGHT GP-AUXILIARY FOR USE WITH SELECTED BATTERY SIZES
110_CONTAINERS-BATTERY
111_RETAINER GP-BATTERY USED WITH ALL BATTERY SIZES
112_CHANGEOVER AR-STANDARD TO HIGH PROFILE BATTERY F50DP
113_CHANGEOVER AR-STANDARD TO HIGH PROFILE BATTERY F60DP
114_CHANGEOVER AR-STANDARD TO LOW PROFILE BATTERY F40DP-F50DP
115_CHANGEOVER AR-STANDARD TO LOW PROFILE BATTERY F60DP
116_FRAME AS-F40DP, F50DP
117_FRAME AS-F60DP
118_FRAME AS-F60DP_1
119_SEAT GP 970848-PAGE 109
120_SEAT GP-SUSPENSION 6R7231-PAGE 109.01
121_SEAT GP-SUSPENSION 970826-PAGE 110
122_SEAT GP 970826-PAGE 110 PART OF 970856 SEAT
123_SEAT GP PART OF 1011469 SEAT
124_SEAT GP PART OF 970848, 1011471 SEATS AND 970869, 970870 CHANGEOVER ARS
125_SEAT GP-SUSPENSION-VINYL COVERED 970634-PAGE 112
126_SEAT GP-SUSPENSION 970887-PAGE 113
127_SEAT GP-SUSPENSION TYPE 2 6R6634-PAGE 113.01
128_SEAT GP-SUSPENSION-VINYL COVERED 970887-PAGE 113 PART OF 970638 SEAT
129_SEAT GP-SUSPENSION-VINYL COVERED PART OF 970634, 1011473 SEATS
130_SEAT GP-SUSPENSION-VINYL PART OF 1011473 SEAT
131_CONSOLE GP-CAB
132_CONVERSION GP-RESTRICTOR PART OF 834466 AND 834468 MAST ARS
133_VALVE AR-2 WAY-PART 1 OF 2 987292-PAGE 128, 916900-PAGE 133
134_VALVE AR-2 WAY-PART 2 OF 2 987500-PAGE 132
135_VALVE AR-3 WAY-PART 1 OF 2 987293-PAGE 129, 916900-PAGE 133
136_VALVE AR-4 WAY-PART 1 OF 2 6R6264-PAGE 131.01, 916900-PAGE 133
137_VALVE AR-4 WAY-PART 2 OF 2 987500-PAGE 132
138_CHANGEOVER AR-2 WAY TO 3 WAY-PART 1 OF 2 TYPE 1 987296-PAGE 130
139_CHANGEOVER AR-2 WAY TO 3 WAY-PART 2 OF 2 TYPE 1 987500-PAGE 132
140_CHANGEOVER AR-2 WAY TO 3 WAY-PART 1 OF 2 TYPE 2
141_CHANGEOVER AR-2 WAY TO 3 WAY-PART 2 OF 2 TYPE 2 987500-PAGE 132
142_CHANGEOVER AR-2 WAY TO 4 WAY-PART 1 OF 2 987500-PAGE 132
143_CHANGEOVER AR-2 WAY TO 4 WAY-PART 2 OF 2 6R6267-PAGE 131.02
144_CHANGEOVER AR-3 WAY TO 4 WAY-PART 1 OF 2 987500-PAGE 132
145_CHANGEOVER AR-3 WAY TO 4 WAY-PART 2 OF 2 6R6267-PAGE 131.02
146_VALVE GP-CONTROL-2 WAY 987295-PAGE 131.03 PART OF 970046 VALVE AR
147_VALVE GP-CONTROL-3 WAY 987296-PAGE 130, 987295-PAGE 131.03 PART OF 970047, 8Q5545 VALVE ARS
148_VALVE GP OPTIONAL REPLACEMENT VALVES PART OF 987293 VALVE-CONTROL AND 970049 CHANGEOVER AR
149_VALVE GP-CONTROL 987295-PAGE 131.03, 987297-PAGE 131.04 PART OF 970048 VALVE AR-4
150_VALVE GP-CONTROL 970050, 970051, 1069624 CHANGEOVER ARS
151_VALVE GP PART OF 987292, 987293, 6R6264 VALVES-CONTROL
152_VALVE GP PART OF 6R6264 VALVE-CONTROL
153_VALVE GP 3 TO 4 WAY CONVERSION
154_SWITCH GP PART OF 970046, 970047, 970048, 8Q5545 VALVE ARS AND 970049, 970050, 970051 AND 1069624 CHANGEOVER ARS
155_BOARD AS-VALVE CONTROL PART OF 970046, 970047, 970048, 8Q5545 VALVE ARS
156_FILTER GP-HYDRAULIC OIL PART OF 923235 LINES-MAST
157_TANK GP-HYDRAULIC
158_PUMP GP-HYDRAULIC GEAR
159_MOTOR GP-ELECTRIC HYDRAULIC PUMP 913149-PAGE 139
160_MOTOR GP-ELECTRIC HYDRAULIC PUMP_R PART OF 914269 MOTOR-ELECTRIC HYDRAULIC PUMP
161_CYLINDER GP-TILT-STD LIFT-2 REQUIRED 6 DEGREES FORWARD, 10 DEGREES BACKWARD
162_CYLINDER GP-TILT-STD LIFT-2 REQUIRED 3 DEGREES FORWARD, 10 DEGREES BACKWARD
163_CYLINDER GP-TILT-STD, FFL-2 REQUIRED 6 DEGREES FORWARD, 8 DEGREES BACKWARD
164_CYLINDER GP-TILT-STD, FFL-2 REQUIRED 3 DEGREES FORWARD, 8 DEGREES BACKWARD
165_CYLINDER GP-TILT-FFTL-2 REQUIRED 6 DEGREES FORWARD, 3 DEGREES BACKWARD
166_CYLINDER GP-TILT-FFTL-2 REQUIRED 3 DEGREES FORWARD, 3 DEGREES BACKWARD
167_CYLINDER GP-TILT-STD, FFL, FFTL-2 REQUIRED 10 DEGREES FORWARD, 5 DEGREES BACKWARD
168_CYLINDER GP-TILT-STD, FFL, FFTL-2 REQUIRED 6 DEGREES FORWARD, 5 DEGREES BACKWARD
169_CYLINDER GP-TILT-STD, FFL, FFTL-2 REQUIRED 10 DEGREES FORWARD, 5 DEGREES BACKWARD_1
170_CYLINDER GP-TILT-STD, FFL, FFTL-2 REQUIRED 3 DEGREES FORWARD, 5 DEGREES BACKWARD
171_CYLINDER GP-TILT-(CHG 01-06) PART OF 910876, 911510, 910835 CYLINDERS-TILT
172_LIMIT GP-TILT PART OF 910835, 910876, 911510 CYLINDERS-TILT
173_KIT-CONVERSION-TILT LIMIT PART OF 910887, 910841 CYLINDERS-TILT
174_KIT-CONVERSION-TILT LIMIT PART OF 911517, 910869 AND 911509 CYLINDERS-TILT
175_KIT-CONVERSION-TILT LIMIT PART OF 911511, 910885 CYLINDERS-TILT
176_MOUNTING GP-LIFT AND TILT-FFL MFH 3650MM (143 IN.) PART OF 834467 MAST AR
177_MOUNTING GP-LIFT AND TILT-FFL MFH 2995MM (118 IN.) PART OF 834465 MAST AR
178_MOUNTING GP-LIFT AND TILT-FFL MFH 2625MM (103 IN.) PART OF 834464 MAST AR
179_MOUNTING GP-LIFT AND TILT-FFL MFH 3275MM (129 IN.) PART OF 834466 MAST AR
180_MOUNTING GP-LIFT AND TILT-FFTL MFH 6050MM (238 IN.) PART OF 834472 MAST AR
181_MOUNTING GP-LIFT AND TILT-FFTL MFH 5600MM (222 IN.) PART OF 834471 MAST AR
182_MOUNTING GP-LIFT AND TILT-FFTL MFH 4775MM (188 IN.) PART OF 834470 MAST AR
183_MOUNTING GP-LIFT AND TILT-FFTL MFH 4355MM (171 IN.) PART OF 834469 MAST AR
184_MOUNTING GP-LIFT AND TILT-FFTL MFH 3950MM (155 IN.) PART OF 834468 MAST AR
185_MOUNTING GP-LIFT AND TILT-FFL -PART 2 OF 2 PART OF 911474, 911479, 910866 AND 911484 MOUNTING-LIFT AND TILT
186_MOUNTING GP-LIFT AND TILT-FFTL -PART 2 OR 2 PART OF 911489, 911494, 910854, 910921 AND 911499 MOUNTING-LIFT AND TILT
187_LINES GP-ATTACHMENT-3 WAY-STD LIFT
188_LINES GP-ATTACHMENT-4 WAY-STD LIFT
189_LINES GP-SECONDARY ATTACHMENT-LH-3 WAY-STD LIFT
190_LINES GP-SECONDARY ATTACHMENT-RH-3 WAY-STD LIFT
191_LINES GP-SECONDARY ATTACHMENT-3 WAY-FFL, FFTL
192_LINES GP-SECONDARY ATTACHMENT-3 WAY-FFL AND FFTL
193_LINES GP-SECONDARY ATTACHMENT-4 WAY-FFL AND FFTL
194_LINES GP-SIDESHIFTER-STD LIFT
195_LINES GP-SIDESHIFTER-STD LIFT F40D P, F50D P
196_LINES GP-SIDESHIFTER-STD LIFT F60D P
197_LINES GP-SIDESHIFTER-FFL AND FFTL
198_LINES GP-SIDESHIFTER-4 WAY-FFL, FFTL
199_LINES GP-SIDESHIFTER-FFL, FFTL
200_COUPLING GP FOR USE WITH 3 WAY AND 4 WAY HYDRAULICS
201_MAST AR-STD LIFT MFH 2625MM (103 IN.)
202_MAST AR-STD LIFT MFH 2995MM (117 IN.)
203_MAST AR-STD LIFT MFH 3275MM (129 IN.)
204_MAST AR-STD LIFT MFH 3350MM (139 IN.)
205_MAST AR-STD LIFT MFH 3850MM (151 IN.)
206_MAST AR-STD LIFT MFH 4000MM (158 IN.)
207_MAST AR-STD LIFT MFH 4400MM (173 IN.)
208_MAST AR-STD LIFT MFH 5000MM (197 IN.)
209_MAST AR-FFL MFH 2625MM (103 IN.)
210_MAST AR-FFL MFH 2995MM (118 IN.)
211_MAST AR-FFL MFH 3275MM (129 IN.)
212_MAST AR-FFL MFH 3650MM (143 IN.)
213_MAST AR-FFTL MFH 3950MM (155 IN.)
214_MAST AR-FFTL MFH 4355MM (171 IN.)
215_MAST AR-FFTL MFH 4775MM (188 IN.)
216_MAST AR-FFTL MFH 5600MM (222 IN.)
217_MAST GP-STD LIFT MFH 2625MM (103 IN.) PART OF 834455 MAST AR
218_MAST GP-STD LIFT MFH 2625MM (103 IN.) PART OF 834455 MAST AR_1
219_MAST GP-STD LIFT MFH 2995MM (117 IN.) PART OF 834456 MAST AR
220_MAST GP-STD LIFT MFH 3275MM (129 IN.) PART OF 834457 MAST AR
221_MAST GP-STD LIFT MFH 3550MM (139 IN.) PART OF 834458 MAST AR
222_MAST GP-STD LIFT MFH 3850MM (151 IN.) PART OF 834459 MAST AR
223_MAST GP-STD LIFT MFH 4000MM (158 IN.) PART OF 834460 MAST AR
224_MAST GP-STD LIFT MFH 4400MM (174 IN.) PART OF 834461 MAST AR
225_MAST GP-STD LIFT MFH 5000MM (197 IN.) PART OF 834462 MAST AR
226_MAST GP-FFL PART OF 834465 MAST AR
227_MFH 2625MM (103 IN.) PART OF 834464 MAST AR
228_MAST GP-FFL MFH 3275MM (129 IN.) PART OF 834466 MAST AR
229_MAST GP-FFL MFH 3650MM (143 IN.) PART OF 834467 MAST AR
230_MAST GP-FFTL MFH 395077 (155 IN.) PART OF 834468 MAST AR
231_MAST GP-FFTL MFH 4355MM (171 IN.) PART OF 834469 MAST AR
232_MAST GP-FFTL MFH 4775MM (188 IN.) PART OF 834470 MAST AR
233_MAST GP-FFTL MFH 5600MM (222 IN.) PART OF 834471 MAST AR
234_MAST GP-FFTL MFH 6050MM (238 IN.) PART OF 834472 MAST AR
235_MAST GP-STD AND FFL PART OF 834474, 834475, 834476, 834477, 834478, 834479, 834480, 834481, 910864, 911471, 911476, 9114
236_MAST GP-FFTL PART OF 910849, 910912, 911486, 911491 AND 911496 MASTS
237_MOUNTING GP-MAST
238_UPRIGHT AS-STATIONARY-FFTL 910972 UPRIGHT AS-INTERMEDIATE FFTL, 910978 UPRIGHT AS-INNER-FFTL PART OF 910965,
239_UPRIGHT AS-STATIONARY-STD LIFT PART OF 834489, 834490, 834491, 834492, 834493, 834494, 834495 AND 834496 UPRIGHTSSTATION
240_UPRIGHT AS-STATIONARY-FFL 911088 UPRIGHT AS-INNER-FFL PART OF 911078, 911531, 911533, 911535 UPRIGHTS-STATIONARY
241_UPRIGHT AS-INNER-STD LIFT PART OF 834500, 834501, 834502, 834503, 834504, 834505, 834506, 834507 UPRIGHTS-INNER
242_LIFT GP-STD-2 REQUIRED PART OF 834460 MAST AR
243_LIFT GP-STD-2 REQUIRED PART OF 834462 MAST AR
244_LIFT GP-STD-2 REQUIRED PART OF 834459 MAST AR
245_LIFT GP-STD-2 REQUIRED PART OF 834457 MAST AR
246_LIFT GP-STD-2 REQUIRED PART OF 834455 MAST AR
247_LIFT GP-STD-2 REQUIRED PART OF 834456 MAST AR
248_LIFT GP-STD-2 REQUIRED PART OF 834458 MAST AR
249_LIFT GP-STD-2 REQUIRED PART OF 834461 MAST AR
250_LIFT GP-PRIMARY-FFL PART OF 834465 MAST AR
251_LIFT GP-PRIMARY-FFL MFH 3950MM (143 IN.) PART OF 834467 MAST AR
252_LIFT GP-PRIMARY-FFL MFH 2625MM (103 IN.) PART OF 834464 MAST AR
253_LIFT GP-PRIMARY-FFL MFH 3275MM (129 IN.) PART OF 834466 MAST AR
254_LIFT GP-PRIMARY-FFTL MFH 3950MM (155 IN.) PART OF 834468 MAST AR
255_LIFT GP-PRIMARY-FFTL MFH 4355MM (171 IN.) PART OF 834469 MAST AR
256_LIFT GP-PRIMARY-FFTL MFH 4775MM (188 IN.) PART OF 834470 MAST AR
257_LIFT GP-PRIMARY-FFTL MFH 5600MM (222 IN.) PART OF 834471 MAST AR
258_LIFT GP-PRIMARY-FFTL MFH 6050MM (238 IN.) PART OF 834472 MAST AR
259_LIFT GP-SECONDARY-FFL-2 REQUIRED PART OF 834465 MAST AR
260_LIFT GP-SECONDARY-FFL-2 REQUIRED MFH 2625MM (103 IN.) PART OF 834464 MAST AR
261_LIFT GP-SECONDARY-FFL-2 REQUIRED MFH 3275MM (129 IN.) PART OF 834466 MAST AR
262_LIFT GP-SECONDARY-FFL-2 REQUIRED MFH 3650MM (143 IN.) PART OF 834467 MAST AR
263_LIFT GP-SECONDARY-FFL-2 REQUIRED MFH 3950MM (155 IN.) PART OF 834468 MAST AR
264_LIFT GP-SECONDARY-FFTL-2 REQUIRED MFH 4355MM (171 IN.) PART OF 834469 MAST AR
265_LIFT GP-SECONDARY-FFTL-2 REQUIRED MFH 4775MM (188 IN.) PART OF 834470 MAST AR
266_LIFT GP-SECONDARY-FFTL-2 REQUIRED MFH 5600MM (222 IN.) PART OF 834471 MAST AR
267_LIFT GP-SECONDARY-FFTL-2 REQUIRED MFH 6050MM (238 IN.) PART OF 834472 MAST AR
268_LIFT GP-PRIMARY-FFTL PART OF 910851, 910913, 911487, 911492 AND 911497 LIFTS
269_LIFT GP-FFL PART OF 910852, 911472, 911477 AND 911482 LIFTS
270_LIFT GP-SECONDARY-STD, FFTL PART OF 910828, 910829, 910905, 910909, 910914, 911457, 911460, 911463, 911466, 911469, 9114
271_LIFT GP-SECONDARY-FFL PART OF 911038, 911473, 911478 AND 911483 LIFTS
272_RELAY GP-LIFT-STD PART OF 834455, 834456, 834457, 834458, 834459, 834460, 834461, 834462 MAS ARS
273_RELAY GP-LIFT-FFTL PART OF 834468, 834469, 834470, 834471 AND 834472 MAST ARS
274_CARRIAGE AR-FFL WIDTH 1150MM (45 IN) F60DP
275_CARRIAGE AR-FFL WIDTH 1115MM (44 IN) F60DP
276_CARRIAGE AR-FFTL WIDTH 1150MM (45 IN) FL60DP
277_CARRIAGE AR-FFTL WIDTH 1115MM (44 IN) F60DP
278_CARRIAGE AR-FFTL WIDTH 1103MM (43.5 IN) F40DP, F50DP
279_CARRIAGE AR-STD LIFT WIDTH 1150MM (45 IN) F60DP
280_CARRIAGE AR-STD LIFT WIDTH 1115MM (44 IN) F60DP
281_CARRIAGE AR-STD LIFT WIDTH 1103MM (43.5 IN) F40DP, F50DP
282_CARRIAGE AR-FFL WIDTH 1103MM (43.5 IN) F40DP, F50DP
283_CARRIAGE AS-STD LIFT PART OF 911110 CARRIAGE AR F40DP, F50DP
284_CARRIAGE AS-STD LIFT PART OF 911043 CARRIAGE AR FL60DP
285_CARRIAGE AS-STD LIFT PART OF 6R7457 CARRIAGE AR F40DP, F50DP
286_CARRIAGE AS-STD LIFT PART OF 6R7460 CARRIAGE AR F60DP
287_CARRIAGE AS-FFL PART OF 911041 CARRIAGE AR F40DP, F50DP
288_CARRIAGE AS-FFL PART OF 911112 CARRIAGE AR F60DP
289_CARRIAGE AS-FFL PART OF 6R7461 CARRIAGE AR F60DP
290_CARRIAGE AS-FFL PART OF 6R7458 CARRIAGE AR F40DP, F50DP
291_CARRIAGE AS-FFTL PART OF 911060 CARRIAGE AR F40DP, F50DP
292_CARRIAGE AS-FFTL PART OF 911114 CARRIAGE AR F60DP
293_CARRIAGE AS-FFTL PART OF 6R7459 CARRIAGE AR F40DP, F50DP
294_CARRIAGE AS -FFTLPART OF 6R7462 CARRIAGE AR F60DP
295_MOUNTING GP-CARRIAGE PART OF ALL CARRIAGE ARS
296_SIDESHIFTER GP-STD, FFL, FFTL 911160-PAGE 230 F40DP, F50DP
297_SIDESHIFTER GP-STD, FFL, FFTL 9111L0-PAGE 230 F60DP
298_SIDESHIFTER GP 6R7420-PAGE 229.02
299_CYLINDER GP-SIDESHIFTER-(CHG 00-01)-2 REQUIRED 41.6MM (1.6 IN) BORE X 204MM (8.0 IN) STROKE PART OF 6R7378
300_CYLINDER GP-SIDESHIFTER PART OF 910894 AND 910901 SIDESHIFTERS
301_FORK GP-PALLET-HOOK TYPE-2 REQUIRED 100MM (4 IN.) WIDE, 45MM 1.8 IN.) THK, 900MM (35 IN.) LONG
302_BACKREST AS-LOAD-STD, FFL, FFTL F40DP, F50DP
303_BACKREST AS-LOAD-STD, FFL, FFTL F60DP
304_FORK GP-PALLET HOOK TYPE-2 REQUIRED 130MM (5.1 IN.) WIDE, 45MM 1.8 IN.) THK, 1050MM (41 IN.) LONG
305_FORK GP-FULLY TAPERED AND POLISHED-HOOK TYPE-2 REQUIRED 130MM (5.1 IN.) WIDE, 45MM (1.8 IN.) THK, 1050MM (41 IN.)
306_FORK GP-PALLET-HOOK TYPE-2 REQUIRED 100MM (4 IN.) WIDE, 45MM (1.8 IN.) THK, 1050MM (42 IN.) LONG
307_FORK GP-FULLY TAPERED AND POLISHED-HOOK TYPE-2 REQUIRED 100MM (4 IN.) WIDE, 45MM (1.8 IN.) THK, 1050MM (42 IN.) LONG
308_FORK GP-PALLET-HOOK TYPE-2 REQUIRED 130MM (5.1 IN.) WIDE, 45MM (1.8 IN.) TNK, 1200MM (47 IN.) LONG
309_FORK GP-FULLY TAPERED AND POLISHED-HOOK TYPE-2 REQUIRED 130MM (5.1 IN.) WIDE, 45MM (1.8 IN.) THK, 1200MM (47 IN.)
310_FORK GP-PALLET-HOOK TYPE-2 REQUIRED 100MM (4 IN.) WIDE, 45MM 1.8 IN.) THK, 1200MM (48 IN.) LONG
311_FORK GP-TAPERED AND POLISHED-HOOK TYPE-2 REQUIRED 100MM (4 IN.) WIDE, 45MM (1.8) THK, 1200MM (48 IN.) LONG
312_PAINT AND LUBRICANT GP
313_PAINT AND LUBRICANT GP-FRENCH
314_PAINT AND LUBRICANT GP-SPANISH
315_PAINT AND LUBRICANT GP-GERMAN
316_PAINT AND LUBRICANT GP-ITALIAN
317_PAINT AND LUBRICANT GP-PORTUGUESE
318_PAINT AND LUBRICANT GP-DANISH
319_PAINT AND LUBRICANT GP-GREEK
320_PAINT AND LUBRICANT GP-DUTCH
321_CHANGEOVER AR-E TO ES
