Caterpillar Forklift ES3000 Chassis Mast Options Europe Parts Catalog 98755-38910
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar ES3000 Chassis Mast Options Forklift
Region: Europe
Part Number: 98755-38910
Number of Pages: 312 Pages
001_01-04-01 ELECTRICAL SYSTEM (PART-1)
002_01-04-02 ELECTRICAL SYSTEM (PART-2)
003_01-04-03 ELECTRICAL SYSTEM (PART-3)
004_01-05-01 POWER CABLES (PART-1)
005_01-05-02 POWER CABLES (PART-2)
006_01-11-01 FRAME & BODY
007_01-11-02 BATTERY BOX
008_01-11-03 GROUND STRAP
009_01-12-01 COUNTERWEIGHT
010_01-15-01 HEAD GUARD
011_01-20-01 TRACTION MOTOR ASSEMBLY
012_01-20-02 TRACTION MOTOR (AC)
013_01-20-03 HYDRAULIC MOTOR ASSEMBLY
014_01-20-04 HYDRAULIC MOTOR (AC)
015_01-20-05 STEER MOTOR ASSEMBLY
016_01-20-06 STEER MOTOR
017_01-22-01 CONTROL ASSEMBLY - TRANSISTOR HYDRAULICS
018_01-22-02 TRACTION CONTROL
019_01-22-03 TRACTION INVERTER
020_01-22-04 PUMP CONTROL
021_01-22-05 PUMP INVERTER
022_01-22-06 STEER CARD (STEERING CONTROLLER)
023_01-22-07 LOGICS UNIT
024_01-22-08 OUTPUT UNIT, HYDRAULIC
025_01-22-09 CONTACTOR PANEL ASSY, CHOPPER
026_01-22-10 LINE CONTACTOR
027_01-33-01 FRONT DRIVE ASSEMBLY
028_01-33-02 FRONT DRIVE AXLE
029_01-33-03 FRONT TIRE ASSEMBLY
030_01-43-01 REAR AXLE ASSEMBLY
031_01-43-02 STEER YOKE ASSEMBLY
032_01-44-01 REAR TIRE ASSEMBLY
033_01-46-01 ELECTROMAGNETIC BRAKE ASSEMBLY
034_01-51-01 PEDAL ASSEMBLY (UPTO 2009-07)
035_01-51-02 PEDAL ASSEMBLY (FROM 2009-08) (PART-1)
036_01-51-03 PEDAL ASSEMBLY (FROM 2009-08) (PART-2)
037_01-54-01 CONTROL HANDLE (JOY STICK)
038_01-54-02 CONTROL HANDLE BASE ASSEMBLY
039_01-54-03 STEER GEAR ASSEMBLY
040_01-71-01 HYDRAULIC PUMP ASSEMBLY
041_01-71-02 HYDRAULIC PUMP
042_01-72-01 HYDRAULIC CONTROL VALVE ASSEMBLY (3V)
043_01-72-02 HYDRAULIC CONTROL VALVE (3V)
044_01-75-01 HYDRAULIC TANK
045_01-75-02 HYDRAULIC FILTER ASSEMBLY
046_01-75-03 HYDRAULIC PUMP PIPING
047_01-75-04 HYDRAULIC RETURN PIPING
048_01-75-05 HYDRAULIC LIFT LINE PIPING (DUPLEX & TRIPLEX)
049_01-75-06 HYDRAULIC LIFT LINE PIPING (QUAD)
050_01-75-07 HYDRAULIC TILT PIPING
051_01-75-08 HYDRAULIC AUXILIARY PIPING (DUPLEX & TRIPLEX)
052_01-75-09 HYDRAULIC AUXILIARY PIPING (QUAD) (3V)
053_01-81-01 LABELS
054_02-01-01 LIFT BRACKET COMMON PARTS
055_02-01-02 LIFT BRACKET
056_02-01-03 BACKREST
057_02-04-01 TILT CYLINDER (3DEGREE-5DEGREE) (FOR BS15C, BS20C, CS15C, CS20C)
058_02-04-02 TILT CYLINDER (10DEGREE-5DEGREE) (FOR BS15C, BS20C, CS15C, CS20C)
059_02-04-03 TILT CYLINDER (5DEGREE-3DEGREE) (FOR BS15C, BS20C, CS15C, CS20C)
060_02-06-01 FORK (FOR BS15C, CS15C)
061_02-06-02 FORK (FOR BS20C, CS20C)
062_02-10-01 MAST COMMON PARTS (PART-1) (FOR CS15C, 20C37-70)
063_02-10-02 MAST COMMON PARTS (PART-2) (FOR CS15C, 20C37-70)
064_02-10-03 MAST COMMON PARTS (PART-3) (FOR CS15C, 20C37-70)
065_02-10-04 MAST COMMON PARTS (PART-4) (FOR CS15C, 20C37-70)
066_02-10-05 MAST COMMON PARTS (PART-1) (FOR BS15C, 20C28-40)
067_02-10-06 MAST COMMON PARTS (PART-2) (FOR BS15C, 20C28-40)
068_02-10-07 MAST COMMON PARTS (PART-3) (FOR BS15C, 20C28-40)
069_02-18 DUPLEX MAST MODEL (FOR BS15C, 20C28-40)
070_02-18 LIFT CYLINDER (1ST) (FOR BS15C, 20C28-40)
071_02-18 LIFT CYLINDER (2ND) (FOR BS15C, 20C28-40)
072_02-20-01 TRIPLEX MAST (FOR CS15C, 20C37-70)
073_02-20-02 LIFT CYLINDER (1ST) (FOR CS15C, 20C37-70)
074_02-20-03 LIFT CYLINDER (2ND) (FOR CS15C, 20C37-70)
075_02-22 LIFT BRACKET W_ COMMON PARTS (FOR QS20C56-70)
076_02-22 BACKREST (FOR QS20C56-70)
077_02-22 TILT CYLINDER (3DEGREE-5DEGREE) (FOR QS20C56-70)
078_02-22 FORK (FOR QS20C56-70)
079_02-22 MAST COMMON PARTS - (PART-1) (FOR QS20C56-70)
080_02-22 MAST COMMON PARTS - (PART-2) (FOR QS20C56-70)
081_02-22 MAST COMMON PARTS - (PART-3) (FOR QS20C56-70)
082_02-22 MAST COMMON PARTS - (PART-4) (FOR QS20C56-70)
083_02-22 MAST CHAINS & PRIMARY HOSE (FOR QS20C56-70)
084_02-22 LOWERING CONTROL VALVE (FOR QS20C56-70)
085_02-22 PRIMARY LIFT CYLINDER (FOR QS20C56-70)
086_02-22 SECONDARY LIFT CYLINDER (R.H.) (FOR QS20C56-70)
087_02-22 SECONDARY LIFT CYLINDER (L.H.) (FOR QS20C56-70)
088_02-22 SINGLE FUNCTION HI-VIS INTERNAL HOSE REEVING (FOR QS20C56-70)
089_02-22 DUAL FUNCTION HI-VIS INTERNAL HOSE FUNCTION (FOR QS20C56-70)
090_03-04-01 MAST MOUNTED LIGHTS KIT
091_03-04-02 REAR FLOOD LIGHT KIT
092_03-04-03 LED LAMP ASSEMBLY
093_03-04-04 OPERATOR COMPARTMENT LIGHT KIT
094_03-04-05 TOP MOUNT STROBE KIT
095_03-04-06 BOTTOM MOUNT STROBE KIT
096_03-04-07 OPERATOR FAN KIT
097_03-04-08 AUXILIARY POWER KIT
098_03-04-09 REVERSE TRAVEL ALARM KIT
099_03-04-10 OPTION BOX A KIT
100_03-04-11 HARNESS OPTION KIT
101_03-04-12 LOAD WEIGHT KIT
102_03-04-13 KEYLESS ENTRY
103_03-04-14 BLUE SPOT LIGHT, FORWARD ACTIVATED
104_03-04-15 BLUE SPOT LIGHT, REAR ACTIVATED
105_03-11-01 FIRE EXTINGUISHER KIT
106_03-11-02 REAR DOOR (OPTION)
107_03-11-03 EXTENDED BACKREST (OPTION)
108_03-15-01 HEAD GUARD (OPTION)
109_03-72-01 HYDRAULIC CONTROL VALVE ASSEMBLY (4V)
110_03-72-02 HYDRAULIC CONTROL VALVE (4V)
111_03-75-01 PIPING, AUXILIARY (4V) (DUPLEX & TRIPLEX)
112_03-75-02 PIPING, AUXILIARY (4V) (QUAD)
113_03-81-01 LABELS, SPANISH
114_03-81-02 LABELS, FRENCH
115_03-81-03 LABELS, PORTUGUESE
116_04-25 MAST PIPING KIT (3-WAY DUPLEX) (FOR BS15C, BS20C28-40)
117_04-26 MAST PIPING KIT (4-WAY DUPLEX) (FOR BS15C, BS20C28-40)
118_04-27 MAST PIPING KIT (3-WAY TRIPLEX) (FOR CS15C, CS20C37-70)
119_04-28 MAST PIPING KIT (4-WAY TRIPLEX) (FOR CS15C, CS20C37-70)
120_04-22-01 INTEGRAL SIDESHIFTER (FOR USE WITH BS20C MAST)
121_04-22-02 INTEGRAL SIDESHIFTER (FOR USE WITH CS15C, CS20C MAST)
122_INTEGRAL SIDE SHIFTER (FOR USE WITH ALL MAST)
