Caterpillar Forklift EP18TBCB Europe Parts Catalog 13-P-2204-C-T
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar EP18TBCB Forklift
Region: Europe
Part Number: 13-P-2204-C-T
Number of Pages: 615 Pages
001_01-01-01 10100A FRAME
002_01-01-02 10100B FRAME Side loading
003_01-01-03 10110A COVER
004_01-01-04 10110B COVER Side loading
005_01-01-05 10111A PANEL
006_01-01-06 10111B PANEL Side loading
007_01-01-07 10112A PAD & FLOOR PLATE
008_01-01-08 10112B PAD & FLOOR PLATE Side loading
009_01-01-09 10113A BATTERY COVER 15TCB_350_390Ah,16TCB_18TCB_350-565Ah
010_01-01-10 10113B BATTERY COVER 15TCB_476-565Ah,16TCB_18TCB_645Ah,16TBCB_18TBCB
011_01-01-11 10113C BATTERY COVER Side loading, 15TCB_350_390Ah,16TCB_18TCB_350-565Ah
012_01-01-12 10113D BATTERY COVER Side loading, 15TCB_476-565Ah,16TCB_18TCB_645Ah,16TBCB_18TBCB
013_01-01-13 10114 SIDE COVER Side loading
014_01-01-14 10115A BATTERY PARTS 1 Side loading, 15TCB_350_390Ah,16TCB_18TCB_350-565Ah
015_01-01-15 10115B BATTERY PARTS 1 Side loading, 15TCB_476-565Ah,16TCB_18TCB_645Ah,16TBCB_18TBCB
016_01-01-16 10116 BATTERY PARTS 2 Side loading
017_01-01-17 10290 LAMP COVER
018_01-01-18 10400 COUNTER BALANCE WEIGHT
019_01-01-19 10500 SEAT
020_01-01-20 10600 OVERHEAD GUARD
021_01-01-21 10950A NAME PLATE FIT.
022_01-01-22 10951A NAME PLATE
023_01-01-23 10950B NAME PLATE FIT. Australia Spec
024_01-01-24 10951B NAME PLATE Australia Spec
025_01-01-25 10952 NAME PLATE FIT. [SF]
026_01-01-26 10953 NAME PLATE FIT. Side loading
027_01-01-27 10954 NAME PLATE FIT. LASER POINTER
028_01-01-28 10963 TABLE BATTERY Side loading
029_01-02-01 11300 FRONT AXLE 1
030_01-02-02 11301A1 FRONT AXLE 2 (-265E_,-266E_,-267E_)
031_01-02-03 11301A2 FRONT AXLE 2 (265E_-,266E_-,267E_-)
032_01-02-04 11400A FRONT WHEEL 15TCB
033_01-02-05 11400B FRONT WHEEL 16TCB_18TCB, 16TBCB_18TBCB
034_01-02-06 11400C FRONT WHEEL Snow tire
035_01-02-07 11400D FRONT WHEEL Color tire, Cushion tire
036_01-02-08 11500 FRONT AXLE FIT.
037_01-02-09 12300 REAR AXLE 1
038_01-02-10 12301 REAR AXLE 2
039_01-02-11 12400A REAR WHEEL
040_01-02-12 12400B REAR WHEEL Color tire
041_01-03-01 13100 STEERING LINKAGE 1 STEERING WHEEL
042_01-03-02 13101 STEERING LINKAGE 2
043_01-03-03 13102 STEERING LINKAGE 3
044_01-03-04 13103 STEERING LINKAGE 4
045_01-03-05 13210 FOOT BRAKE LINKAGE 1
046_01-03-06 13211 FOOT BRAKE LINKAGE 2 MASTER CYLINDER
047_01-03-07 13300 PARKING BRAKE LINKAGE 1
048_01-03-08 13301 PARKING BRAKE LINKAGE 2
049_01-03-09 13400A VALVE LINKAGE 1 2 SPOOLS
050_01-03-10 13400B VALVE LINKAGE 1 3 SPOOLS
051_01-03-11 13400C VALVE LINKAGE 1 4 SPOOLS
052_01-03-12 13401A VALVE LINKAGE 2 2 SPOOLS
053_01-03-13 13401B VALVE LINKAGE 2 3 SPOOLS
054_01-03-14 13401C VALVE LINKAGE 2 4 SPOOLS
055_01-03-15 13500 ACCELERATOR LINKAGE
056_01-04-01 15000A OIL TANK RESIN OIL TANK
057_01-04-02 15000B OIL TANK IRON OIL TANK
058_01-04-03 15100 OIL PUMP
059_01-04-04 15200A CONTROL VALVE 2 SPOOLS
060_01-04-05 15200B CONTROL VALVE 3 SPOOLS
061_01-04-06 15200C CONTROL VALVE 4 SPOOLS
062_01-04-07 15510A FRAME PIPING 2 SPOOLS
063_01-04-08 15510B FRAME PIPING 3,4 SPOOLS
064_01-04-09 15560 BRAKE PIPING
065_02-05-01 20520A1 LIFT CYLINDER [Pm] (-265E-_,-266E-_,-267E-_)
066_02-05-02 20520A2 LIFT CYLINDER [Pm] (265E-_-,266E-_-,267E-_-)
067_02-05-03 20520B LIFT CYLINDER [Pm] CS_RP
068_02-05-04 20540A TILT CYLINDER [Pm] (-265E00172_-266E00501_-267E00015)
069_02-05-05 20540B TILT CYLINDER [Pm] (265E00173-_266E00502-_267E00016-)
070_02-05-06 20560 MAST PIPING [Pm]
071_02-05-07 20580A MAST PIPING [Pm][SF] w.o_LASER POINTER
072_02-05-08 20580B MAST PIPING [Pm][SF] w_LASER POINTER
073_02-05-09 20610A OUTER MAST [Pm] w.o_LASER POINTER
074_02-05-10 20610B OUTER MAST [Pm] w_LASER POINTER
075_02-05-11 20630 INNER MAST [Pm]
076_02-05-12 20640 CHAIN WHEEL [Pm]
077_02-05-13 20900 WIRING MAST [Pm] LASER POINTER
078_02-06-01 21520A1 LIFT CYLINDER(1st) [Mm] (-265E-_,-266E-_,-267E-_)
079_02-06-02 21520A2 LIFT CYLINDER(1st) [Mm] (265E-_-,266E-_-,267E-_-)
080_02-06-03 21520B LIFT CYLINDER(1st) [Mm] CS_RP
081_02-06-04 21530A1 LIFT CYLINDER(2nd) [Mm] (-265E-_,-266E-_,-267E-_)
082_02-06-05 21530A2 LIFT CYLINDER(2nd) [Mm] (265E-_-,266E-_-,267E-_-)
083_02-06-06 21530B LIFT CYLINDER(2nd) [Mm] CS_RP
084_02-06-07 21540A TILT CYLINDER [Mm] (-265E00173_-266E00515_-267E00015)
085_02-06-08 21540B TILT CYLINDER [Mm] (265E00174-_266E00516-_267E00016-)
086_02-06-09 21560 MAST PIPING [Mm]
087_02-06-10 21580A MAST PIPING [Mm][SF] w.o_LASER POINTER
088_02-06-11 21580B MAST PIPING [Mm][SF] w_LASER POINTER
089_02-06-12 21610 OUTER MAST [Mm]
090_02-06-13 21620 MIDDLE MAST [Mm]
091_02-06-14 21630 INNER MAST [Mm]
092_02-06-15 21640 CHAIN WHEEL(MAST) [Mm]
093_02-06-16 21650 CHAIN WHEEL(LIFT) [Mm]
094_02-06-17 21900 WIRING MAST [Mm] LASER POINTER
095_02-07-01 22520A LIFT CYLINDER(1st) [Fm]
096_02-07-02 22520B LIFT CYLINDER(1st) [Fm] CS_RP
097_02-07-03 22530A LIFT CYLINDER(2nd) [Fm]
098_02-07-04 22530B LIFT CYLINDER(2nd) [Fm] CS_RP
099_02-07-05 22540A TILT CYLINDER [Fm] (-265E00180_-266E00521_-267E00051)
100_02-07-06 22540B TILT CYLINDER [Fm] (265E00181-_266E00522-_267E00052-)
101_02-07-07 22560 MAST PIPING [Fm]
102_02-07-08 22580A MAST PIPING [Fm][SF] w.o_LASER POINTER
103_02-07-09 22580B MAST PIPING [Fm][SF] w_LASER POINTER
104_02-07-10 22610 OUTER MAST [Fm]
105_02-07-11 22630 INNER MAST [Fm]
106_02-07-12 22640 CHAIN WHEEL [Fm]
107_02-07-13 22900 WIRING MAST LASER POINTER [Fm]
108_03-08-01 36200A LIFT BRACKET [Pm]
109_03-08-02 36200B LIFT BRACKET [Mm]
110_03-08-03 36200C LIFT BRACKET [Fm]
111_03-08-04 36201A LIFT BRACKET [Pm][SF] CASCADE SF
112_03-08-05 36201B LIFT BRACKET [Mm][SF] CASCADE SF
113_03-08-06 36201C LIFT BRACKET [Fm][SF] CASCADE SF
114_03-08-07 36300 FORK
115_03-08-08 36400 BACKREST
116_03-08-09 36500A SIDESHIFT [Pm][SF] INTEGRAL SF
117_03-08-10 36500B SIDESHIFT [Mm][SF] INTEGRAL SF
118_03-08-11 36500C SIDESHIFT [Fm][SF] INTEGRAL SF
119_03-08-12 36500D SIDESHIFT [Pm][SF] CASCADE SF
120_03-08-13 36500E SIDESHIFT [Mm][SF] CASCADE SF
121_03-08-14 36500F SIDESHIFT [Fm][SF] CASCADE SF
122_03-08-15 36900 SIDE CYLINDER BOOT[SF]
123_04-09-01 40710 TRACTION MOTOR
124_04-09-02 40720 HYDRAULIC MOTOR
125_04-09-03 40730A EPS MOTOR [EIKOU]
126_04-09-04 40730B EPS MOTOR [FUJII]
127_04-10-01 44000A CONTROL UNIT 1
128_04-10-02 44000B CONTROL UNIT 1 Australia Spec
129_04-10-03 44001A CONTROL UNIT 2
130_04-10-04 44001B CONTROL UNIT 2 Australia Spec
131_04-10-05 44002A CONTROL UNIT 3
132_04-10-06 44002B CONTROL UNIT 3 Australia Spec
133_04-10-07 44003A1 CONTROL UNIT 4 WIRE HARNESS,(-265E00290_-266E01291_-267E00054)
134_04-10-08 44003A2 CONTROL UNIT 4 WIRE HARNESS,(265E00291-_266E01292-_267E00055-)
135_04-10-09 44003B CONTROL UNIT 4 WIRE HARNESS, Australia Spec
136_04-10-10 44004A CONTROL UNIT 5 FAN
137_04-10-11 44004B CONTROL UNIT 5 FAN, Australia Spec
138_04-10-12 44300 DIRECTIONAL SWITCH
139_04-10-13 44760 FORK LEVELING
140_04-10-14 45000A EPS CONTROLLER
141_04-10-15 45000B EPS CONTROLLER Australia Spec
142_04-11-01 48000A BATTERY (48V)
143_04-11-02 48000B BATTERY (48V)
144_04-11-03 48000C BATTERY (48V) Side loading
145_04-11-04 48000D BATTERY (48V) Side loading
146_04-11-05 48100A CHARGER(BC) AC200V
147_04-11-06 48100B CHARGER(BC) AC400V
148_04-11-07 48110A TRANSFORMER AC200V
149_04-11-08 48110B TRANSFORMER AC400V
150_04-11-09 48250 DISPLAY PANEL
151_04-11-10 48430 PLUG(BC)
152_04-11-11 48510A WIRE HARNESS (BODY)
153_04-11-12 48510B WIRE HARNESS (BODY) Australia Spec
154_04-11-13 48511 WIRE HARNESS (BATTERY)
155_04-11-14 48512 WIRE HARNESS Australia Spec
156_04-11-15 48600 ELECTRIC PARTS 1
157_04-11-16 48601 ELECTRIC PARTS 2
158_04-11-17 48850 LASER POINTER 1 LASER
159_04-11-18 48851 LASER POINTER 2 SWITCH & NAME PLATE
160_04-11-19 48890 HEAD LAMP
161_05-12-01 50000A ACCESSORY REAR LAMP
162_05-12-02 50000B ACCESSORY REVOLVING LAMP
163_05-12-03 50000C ACCESSORY REVOLVING LAMP(LED)
164_05-12-04 50000D ACCESSORY WORKING LAMP
165_05-12-05 50000E ACCESSORY HEAD LAMP GUARD
166_05-12-06 50000F ACCESSORY EXTINGUISHER
167_05-12-07 50000G ACCESSORY EARTH CHAIN
168_05-12-08 50000H ACCESSORY BACK MIRROR
169_05-12-09 50000I ACCESSORY ROOM MIRROR
170_05-12-10 50000J ACCESSORY CHIME
171_05-12-11 50660 HEADGUARD ROOF
172_05-12-12 59160 PROTECTOR
