Caterpillar Forklift EP18NT Chassis Mast Options Internal Hosing Europe Parts Catalog 98753-36010
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar EP18NT Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: 98753-36010
Number of Pages: 398 Pages
001_01-04-01 ELECTRIC SYSTEM
002_01-04-02 LIGHTING SYSTEM
003_01-04-03 SENSING SYSTEM
004_01-05-01 HARNESS & POWER CABLES (PART-1)
005_01-05-02 HARNESS & POWER CABLES (PART-2)
006_01-11-01 FRAME
007_01-11-02 CHASSIS ACCESSORY (PART-1)
008_01-11-03 CHASSIS ACCESSORY (PART-2)
009_01-11-04 INTERIOR PARTS
010_01-12-01 CONTROLLER COVER
011_01-13-01 COUNTER WEIGHT
012_01-14-01 SEAT (FOR FC MODEL)
013_01-14-02 SEAT (FOR MC MODEL)
014_01-15-01 HEAD GUARD
015_01-20-01 MOTOR
016_01-20-02 TRACTION MOTOR
017_01-20-03 PUMP MOTOR
018_01-22-01 CONTROLLER ACCESSORY
019_01-27-01 TRANSFER & DIFF (L.H.)
020_01-27-02 TRANSFER & DIFF (R.H.)
021_01-33-01 FRONT AXLE
022_01-34-01 FRONT TIRE
023_01-43-01 REAR AXLE (PART-1)
024_01-43-02 REAR AXLE (PART-2)
025_01-44-01 REAR TIRE
026_01-46-01 BRAKE SYSTEM (PART-1)
027_01-46-02 BRAKE SYSTEM (PART-2)
028_01-46-03 CALIPER ASSY
029_01-51-01 BRAKE CONTROL (PART-1)
030_01-51-02 BRAKE CONTROL (PART-2)
031_01-51-03 BRAKE CONTROL (PART-3)
032_01-52-01 ACCELERATOR PEDAL
033_01-54-01 STEERING SYSTEM
034_01-54-02 STEERING WHEEL
035_01-70-01 CONTROLLER
036_01-70-02 LOGICS UNIT
037_01-70-03 INVERTER (PART-1)
038_01-70-04 INVERTER (PART-2)
039_01-70-05 CONTACTOR ASSY
040_01-70-06 CONTACTOR
041_01-71-01 HYDRAULIC PUMP
042_01-72-01 CONTROL VALVE (3 VALVES)PART-1 (FOR FC MODEL)
043_01-72-02 CONTROL VALVE (3 VALVES)PART-2 (FOR FC MODEL)
044_01-72-03 CONTROL VALVE (4 VALVES) (FOR FC MODEL)
045_01-72-04 CONTROL VALVE (3 VALVES)PART-1 (FOR MC MODEL)
046_01-72-05 CONTROL VALVE (3 VALVES)PART-2 (FOR MC MODEL)
047_01-72-06 CONTROL VALVE (4 VALVES) (FOR MC MODEL)
048_01-73-01 ADJUSTER ASSY (FOR FC MODEL)
049_01-73-02 LEVER (FOR FC MODEL)
050_01-73-03 HYDRAULIC LEVER (FOR MC MODEL)
051_01-74-01 HYDRAULIC TANK
052_01-75-01 HYDRAULIC LINE (PART-1)
053_01-75-02 HYDRAULIC LINE (PART-2)
054_01-75-03 HYDRAULIC LINE (PART-3)
055_01-75-04 FLOW REGULATOR VALVE
056_01-75-05 ATTACHMENT VALVE PIPING
057_01-81-01 NAME-PLATE
058_02-01-01 LIFT BRACKET COMMON PARTS
059_02-01-02 LIFT BRACKET
060_02-01-03 BACKREST
061_02-04-01A TILT CYLINDER (L.H.)(OLD) (FOR 6DEGREES-7DEGREES,-5DEGREES,-3DEGREES)
062_02-04-01B TILT CYLINDER (L.H.)(NEW) (FOR 6DEGREES-7DEGREES,-5DEGREES,-3DEGREES)
063_02-04-02A TILT CYLINDER (R.H.)(OLD) (FOR 6DEGREES-7DEGREES,-5DEGREES,-3DEGREES)
064_02-04-02B TILT CYLINDER (R.H.)(NEW) (FOR 6DEGREES-7DEGREES,-5DEGREES,-3DEGREES)
065_02-06-01 FORK
066_02-10-01 MAST COMMON PARTS (PART-1) (FOR 2G15A & 1G20A)
067_02-10-02 MAST COMMON PARTS (PART-2) (FOR 2G15A & 1G20A)
068_02-10-03 MAST COMMON PARTS (PART-1) (FOR 2J15A & 1J20A)
069_02-10-04 MAST COMMON PARTS (PART-2) (FOR 2J15A & 1J20A)
070_02-10-05 MAST COMMON PARTS (PART-3) (FOR 2J15A & 1J20A)
071_02-10-06 MAST COMMON PARTS (PART-4) (FOR 2J15A & 1J20A)
072_02-10-07 MAST COMMON PARTS (PART-1) (FOR 2H15A & 1H20A)
073_02-10-08 MAST COMMON PARTS (PART-2) (FOR 2H15A & 1H20A)
074_02-10-09 MAST COMMON PARTS (PART-3) (FOR 2H15A & 1H20A)
075_02-18-01 DUPLEX MAST MODEL 2H15A30-40
076_02-18-01A LIFT CYLINDER (1ST) (OLD) (FOR 2H15A & 1H20A)
077_02-18-01B LIFT CYLINDER (1ST) (NEW) (FOR 2H15A & 1H20A)
078_02-18-02 LIFT CYLINDER (2ND) (FOR 2H15A & 1H20A)
079_02-18-03 DUPLEX MAST MODEL 1H20A30-40
080_02-20-01 TRIPLEX MAST MODEL 2J15A37-70
081_02-20-01A LIFT CYLINDER (1ST) (OLD) (FOR 2J15A & 1J20A)
082_02-20-01B LIFT CYLINDER (1ST) (NEW) (FOR 2J15A & 1J20A)
083_02-20-02A LIFT CYLINDER (2ND) (OLD) (FOR 2J15A & 1J20A)
084_02-20-02B LIFT CYLINDER (2ND) (NEW) (FOR 2J15A & 1J20A)
085_02-20-02 TRIPLEX MAST MODEL 1J20A37-70
086_02-60-01 SIMPLEX MAST MODEL 2G15A20-60
087_02-60-01A LIFT CYLINDER (OLD) (FOR 2G15A & 1G20A)
088_02-60-01B LIFT CYLINDER (NEW) (FOR 2G15A & 1G20A)
089_02-60-02 SIMPLEX MAST MODEL 1G20A20-60
090_03-04-01 PUMP MOTOR FAN KIT
091_03-04-02 TRACTION MOTOR FAN KIT
092_03-04-03 ARMREST FNR SWITCH KIT (FC MODEL)
093_03-04-04 BATTERY BOX
094_03-04-05 CONNECTOR KIT
095_03-04-06 DC_DC CONVERTER KIT
096_03-04-07 FIRE EXTINGUISHER KIT
097_03-04-08 WORKING LAMP 12V KIT
098_03-04-09 AMBER STROBE KIT
099_03-04-10 ROAD LIGHT KIT
100_03-14-01 CLOTH SEAT (FOR FC MODEL)
101_03-14-02 CLOTH SEAT (FOR MC MODEL)
102_03-34-01 FRONT TIRE KIT (NONMARKING)
103_03-34-02 FRONT TIRE KIT (NONMARKING) (EP16NT, EP18NT)
104_03-34-03 FRONT TIRE KIT (NONMARKING) (EP20NT)
105_03-34-04 FRONT TIRE KIT (PNEUMATIC) (EP16NT, EP18NT)
106_03-34-05 FRONT TIRE KIT (CUSHION)
107_03-44-01 REAR TIRE KIT (NONMARKING)
108_03-44-02 REAR TIRE KIT (PNEUMATIC) (EP16NT, EP18NT)
109_03-44-03 REAR TIRE KIT (CUSHION)
110_03-51-01 BRAKE PEDAL ASSY (FOR FOOT DIRECTION KIT)
111_03-52-01 FOOT DIRECTION CONTROL KIT
112_03-91-01 FORK STOPPER (FOR BACKREST-LESS)
113_03-92-01 MAST HOOK KIT (2G15A,1G20A20-60)
114_03-92-02 MAST HOOK KIT (2J15A,1J20A37-70)
115_03-92-03 MAST HOOK KIT (2H15A,1H20A30-40)
116_04-23 MAST PIPING KIT(3-WAY SIMPLEX) (FOR 2G15CA20-60)
117_04-24 MAST PIPING KIT(4-WAY SIMPLEX) (FOR 2G15CA20-60)
118_04-25 MAST PIPING KIT(3-WAY DUPLEX) (FOR 2G15CA30-40)
119_04-26 MAST PIPING KIT (4-WAY DUPLEX) (FOR 2H15CA30-40)
120_04-27 MAST PIPING KIT(3-WAY TRIPLEX) (FOR 2J15CA37-70)
121_04-28 MAST PIPING KIT(4-WAY TRIPLEX) (FOR 2J15CA37-70)
122_04-41-01 MAST PIPING KIT(3-WAY SIMPLEX) INTEGRAL SIDESHIFTER
123_04-41-02 MAST PIPING KIT(4-WAY SIMPLEX) INTEGRAL SIDESHIFTER
124_04-42-01 MAST PIPING KIT(3-WAY DUPLEX) INTEGRAL SIDESHIFTER
125_04-42-02 MAST PIPING KIT(4-WAY DUPLEX) INTEGRAL SIDESHIFTER
126_04-43 MAST PIPING KIT(3-WAY TRIPLEX) INTEGRAL SIDESHIFTER
127_04-43 MAST PIPING KIT(4-WAY TRIPLEX) INTEGRAL SIDESHIFTER
128_04-43 MAST PIPING KIT(4-WAY TRIPLEX) INTEGRAL SIDESHIFTER_1
