Caterpillar Forklift EP18CN2T Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00050169
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar EP18CN2T Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: DOC00050169
Number of Pages: 828 Pages
001_01-01-01 ACCESSORIES
002_01-01-02 SMART BACK-UP ALARM
003_01-01-03 BUZZER
004_01-01-04 STORAGE UNIT
005_01-01-05 HYDRAULIC ACCUMULATOR
006_01-01-06 TILT ANGLE SENSOR
007_01-01-07 ROAD LIGHT KIT
008_01-01-08 ROAD LIGHT
009_01-01-09 ACCESSORY RACK
010_01-01-10 EXTERNAL MIRRORS, WITHOUT DOOR
011_01-01-11 AMBER STROBE, UP POSITION
012_01-01-12 AMBER STROBE, DOWN POSITION
013_01-01-13 WARNING LIGHT, BLUE LIGHT (FRONT AND REAR)
014_01-01-14 WARNING LIGHT, BLUE LIGHT (FRONT)
015_01-01-15 WARNING LIGHT, BLUE LIGHT (REAR)
016_01-01-16 WARNING LIGHT, RED LIGHT (FRONT AND REAR)
017_01-01-17 WARNING LIGHT, RED LIGHT (FRONT)
018_01-01-18 WARNING LIGHT, RED LIGHT (REAR)
019_01-01-19 WARNING LIGHT, RED STRIPES
020_01-01-20 BACK-UP HANDLE
021_01-01-21 BACK-UP NARROW OHG
022_01-01-22 WASHER TANK, FRONT WINDOW
023_01-01-23 WASHER TANK, FRONT+REAR WINDOW
024_01-01-24 DRIVING SEAT, MSG65, W_ VINYL BACK REST
025_01-01-25 DRIVING SEAT, MSG65, W_ CLOTH BACK REST
026_01-01-26 DRIVING SEAT, MSG65, W_ LEFT ARM REST
027_01-01-27 BRACKET D-SERIES
028_01-01-28 SCANNER HOLDER
029_01-01-29 A4 CLIPBOARD
030_01-01-30 SUN VISOR
031_01-01-31 MIRROR, REAR VIEW
032_01-01-32 MIRROR, WIDE VIEW
033_01-01-33 MIRROR, WIDE VIEW ANGLE
034_01-01-34 HOOK ON SIDE SHIFTER
035_01-01-35 HOOK ON SIDE SHIFTER, SPARE PART KIT
036_01-01-36 USB POWER SUPPLY, 5V
037_01-01-37 ATTACHMENT SET, 3V
038_01-01-38 ATTACHMENT SET, 4V
039_01-01-39 SWIVEL SEAT ASSEMBLY
040_01-01-40 WIRE HARNESS, CABIN HEATER
041_01-01-41 WIRE HARNESS, SUPPLY CABLE
042_01-01-42 BATTERY RACK (SWE)
043_01-01-43 BATTERY CHANGING DEVICE (SWE)
044_01-01-44 COMPUTER RACK
045_01-01-45 DUST COVER, FRONT
046_01-01-46 LI-ION KIT
047_01-01-47 READING LIGHT
048_01-01-48 FAN
049_01-01-49 FAN & READING LIGHT
050_01-01-50 FAN (RL652480)
051_01-01-51 FAN (RL637676)
052_02-02-01 EL-PANEL ASSEMBLY
053_02-02-02 ADDITIONAL FAN
054_02-02-03 VOLTAGE CONVERTER, 1 DC POS. 1
055_02-02-04 VOLTAGE CONVERTER, 1 DC POS. 2
056_02-02-05 VOLTAGE CONVERTER, 2 DC
057_02-02-06 VOLTAGE CONVERTER, RELAY BRACKET
058_02-02-07 BATTERY CONNECTOR, STANDARD _ DIN
059_02-02-08 CONTACTOR PANEL, BRACKET
060_02-02-09 CABLE HARNESS
061_03-03-01 FORK ASSEMBLY
062_03-03-02 LOAD SUPPORT
063_03-03-03 LOAD SUPPORT, IFP
064_03-03-04 LOAD SUPPORT, DELETION
065_04-04-02 COUNTERWEIGHT ASSEMBLY
066_04-04-03 PIN, DRAWBAR ASSY
067_04-04-04 REAR AXLE, 3W
068_04-04-06 CHASSIS ASSEMBLY, SWE
069_04-04-07 SIDE PLATE, BASIC
070_04-04-08 SIDE PLATE, COMPACT
071_04-04-09 SIDE PLATE, LI-ION, BASIC
072_04-04-10 SIDE PLATE, LI-ION, COMPACT
073_04-04-11 HATCH, WO_ SWITCH
074_04-04-12 BATTERY DOOR, BASIC (CRANE)
075_04-04-13 BATTERY DOOR, COMPACT (CRANE)
076_04-04-14 BATTERY DOOR, BASIC (SWE)
077_04-04-15 BATTERY DOOR, COMPACT (SWE)
078_04-04-16 FLOOR ASSEMBLY, BASIC
079_04-04-17 FLOOR ASSEMBLY, OPP PEDAL
080_04-04-18 FLOOR ASSEMBLY, DUAL PEDAL
081_04-04-20 COVER, FRONT
082_04-04-21 COVER, BACK
083_04-04-22 COVER, RIGHT SIDE, WO_ PVC DOORS
084_04-04-23 COVER, RIGHT SIDE, W_ PVC DOORS
085_04-04-24 COVER, FELT
086_04-04-25 COVER, NARROW REAR LIGHT
087_04-04-26 FENDER, WIDE
088_04-04-27 DECALS
089_04-04-28 DECAL, LIFTING POINTS
090_04-04-29 SIDE DECALS
091_04-04-30 DECAL, BATTERY COVER
092_04-04-31 VEHICLE LIGHT
093_04-04-32 MAST LIGHTS
094_04-04-33 CABIN HEATER, RELAY & WIRING
095_04-04-34 STEERING UNIT, W_ FNR
096_04-04-35 STEERING UNIT, W_ FNR-LEVER NON-LOCKING
097_04-04-36 STEERING UNIT, W_ LIGHTS
098_04-04-37 STEERING UNIT, W_ FNR + LIGHTS
099_04-04-38 STEERING UNIT, W_ FNR-LEVER NON-LOCKING AND ROAD LIGHT
100_04-04-39 STEERING UNIT, WO_ FNR + LIGHTS
101_04-04-41 STEERING WHEEL
102_04-04-42 STEERING UNIT, MINISTEERING W_ LIGHTS
103_04-04-44 MINI STEERING COLUMN
104_04-04-46 BATTERY COVER, MSG65-75 (FC)
105_04-04-47 BATTERY COVER, MSG20 (FC)
106_04-04-48 BATTERY COVER, MSG65-75 (MC)
107_04-04-49 BATTERY COVER, MSG20 (MC)
108_04-04-50 BATTERY COVER ASSEMBLY
109_04-04-51 BATTERY COVER WELDING ASSEMBLY
110_04-04-52 BATTERY COVER ASSEMBLY PARTS
111_04-04-53 BASE, MSG65-75 (FC)
112_04-04-54 BASE, MSG65-75 (MC)
113_04-04-55 BASE, MSG20 (FC)
114_04-04-56 BASE, MSG20 (MC)
115_04-04-57 SINGLE JOYSTICK ASSEMBLY
116_04-04-58 SINGLE JOYSTICK
117_04-04-59 SINGLE JOYSTICK, DECAL, HANDLE
118_04-04-60 SINGLE JOYSTICK, DECAL, TRIGGER
119_04-04-61 SINGLE JOYSTICK, DECAL, ROLLER
120_04-04-62 DUAL JOYSTICK ASSEMBLY, W_ FR
121_04-04-63 DUAL JOYSTICK, W_ FR
122_04-04-64 DUAL JOYSTICK ASSEMBLY, WO_ FR
123_04-04-65 DUAL JOYSTICK DECALS
124_04-04-66 DUAL JOYSTICK DECALS, Y AXIS RIGHT
125_04-04-67 DASHBOARD, STANDARD
126_04-04-68 DASHBOARD, LI-ION
127_04-04-69 DASHBOARD, ZAPI ECOSMART, STANDARD
128_04-04-70 DASHBOARD, ZAPI ECOSMART, LI-ION
129_04-04-71 DISPLAY UNIT, ZAPI ECOSMART
130_04-04-72 KNOB, LIFT
131_04-04-73 KNOB, TILT
132_04-04-74 KNOB, BLANCO
133_04-04-75 KNOB, SIDE SHIFT
134_04-04-76 KNOB, CLAMP
135_04-04-77 KNOB, SPREADER POSITIONER
136_04-04-78 KNOB, ROTATE
137_04-04-79 KNOB, EXTEND
138_04-04-80 LEVERS
139_04-04-81 SWITCHES
140_04-04-82 ARM REST (FC)
141_04-04-83 DRIVING SEAT, MSG20, VINYL, W_ SEAT BELT & SEAT BELT SWITCH
142_04-04-84 DRIVING SEAT, MSG65, VINYL, W_ FULL SUSPENSION & SEAT BELT SWITCH
143_04-04-85 DRIVING SEAT, MSG65, CLOTH, W_ FULL SUSPENSION & SEAT BELT SWITCH
144_04-04-86 DRIVING SEAT, MSG65, VINYL, W_ HEATER & SEAT BELT SWITCH
145_04-04-87 DRIVING SEAT, MSG65, CLOTH, W_ HEATER & SEAT BELT SWITCH
146_04-04-88 DRIVING SEAT, MSG75, VINYL, W_ AIR SUSPENSION & SEAT BELT SWITCH
147_04-04-89 DRIVING SEAT, MSG75, CLOTH, W_ AIR SUSPENSION & SEAT BELT SWITCH
148_04-04-90 DRIVING SEAT, MSG75, VINYL, W_ AIR SUSPENSION & HEATER & SEAT BELT SWITCH
149_04-04-91 DRIVING SEAT, MSG75, CLOTH, W_ AIR SUSPENSION & HEATER & SEAT BELT SWITCH
150_04-04-92 DRIVING SEAT, MSG75, VINYL, WO_ LEFT ARMREST (SPECIAL FOR LOW OHG)
151_04-04-93 DRIVING SEAT, MSG65, VINYL, W_ FULL SUSPENSION & SEAT BELT SWITCH & ORANGE SEAT BELT
152_04-04-94 DRIVING SEAT, MSG65, CLOTH, W_ FULL SUSPENSION & SEAT BELT SWITCH & ORANGE SEAT BELT
153_04-04-95 BASE, MSG65-75, FC, CE
154_04-04-96 BASE, MSG65-75, MC, CE
155_04-04-97 COVER, FOR MC LEVERS
156_04-04-98 BATTERY POSITIONER (CRANE)
157_04-04-99 BATTERY POSITIONER (SWE)
158_04-04-00 BATTERY LOCKING (CRANE)
159_04-04-01 BATTERY LOCKING (SWE)
160_04-04-02 BATTERY ROLLER PALLET, 500Ah DIN A
161_04-04-03 BATTERY ROLLER PALLET, 625Ah DIN A
162_04-04-04 BATTERY ROLLER PALLET, 625Ah WIDE
163_04-04-05 BATTERY ROLLER PALLET, 750Ah WIDE
164_04-04-06 BATTERY ROLLER BED, WIDE
165_04-04-07 BATTERY ROLLER BED, DIN A
166_04-04-08 BATTERY ROLLER BED, COLD STORAGE
167_04-04-09 SENSOR, BATTERY LOCK ASSEMBLY
168_04-04-10 SENSOR, BATTERY LOCK ASSEMBLY
169_05-05-01 TILTING CYLINDER (5-3,5°)
170_05-05-02 TILTING CYLINDER (5-5°)
171_05-05-03 TILTING CYLINDER (5-6°)
172_05-05-04 TILTING CYLINDER (5-7,5°)
173_05-05-05 TILTING CYLINDER (RIGHT)
174_05-05-06 TILTING CYLINDER (LEFT)
175_05-05-07 HOSE ASSEMBLY, 3V
176_05-05-08 HOSE ASSEMBLY, 4V
177_05-05-09 HOSE ASSEMBLY, CLAMP RELEASE 3V (MC)
178_05-05-10 HOSE ASSEMBLY, CLAMP RELEASE 4V (MC)
179_05-05-11 VALVE BLOCK ASSEMBLY, 3V (FC)
180_05-05-12 VALVE BLOCK, 3V (FC)
181_05-05-13 VALVE BLOCK ASSEMBLY, 4V (FC)
182_05-05-14 VALVE BLOCK, 4V (FC)
183_05-05-15 VALVE BLOCK ASSEMBLY, 3V (MC)
184_05-05-16 VALVE BLOCK, 3V (MC)
185_05-05-17 VALVE BLOCK ASSEMBLY, 4V (MC)
186_05-05-18 VALVE BLOCK, 4V (MC)
187_05-05-19 VALVE ASSEMBLY 5V, 1.4-1.8T STANDARD SIMPLEX
188_05-05-20 VALVE ASSEMBLY 5V, 1.4-1.8T STANDARD DUPLEX
189_05-05-21 VALVE ASSEMBLY 5V, 1.4-1.8T STANDARD TRIPLEX
190_05-05-22 VALVE ASSEMBLY 5V, 2.0T STANDARD SIMPLEX
191_05-05-23 VALVE ASSEMBLY 5V, 2.0T STANDARD DUPLEX
192_05-05-24 VALVE ASSEMBLY 5V, 2.0T STANDARD TRIPLEX
193_05-05-25 VALVE ASSEMBLY 5V, IFP SIMPLEX
194_05-05-26 VALVE ASSEMBLY 5V, IFP DUPLEX
195_05-05-27 VALVE ASSEMBLY 5V, IFP TRIPLEX
196_05-05-28 VALVE ASSEMBLY 5V, ISS SIMPLEX
197_05-05-29 VALVE ASSEMBLY 5V, ISS DUPLEX
198_05-05-30 VALVE ASSEMBLY 5V, ISS TRIPLEX
199_05-05-31 VALVE BLOCK (RL630579)
200_05-05-32 VALVE BLOCK (RL630580)
201_05-05-33 VALVE BLOCK (RL630581)
202_05-05-34 VALVE BLOCK (RL630582)
203_05-05-35 VALVE, POPPET VALVE
204_05-05-36 FREELIFT PIPE, DUPLEX
205_05-05-37 FREE LIFT CYLINDER, DUPLEX & TRIPLEX (SERVICE KITS)
206_05-05-38 LIFTING CYLINDER, SIMPLEX & TRIPLEX (SERVICE KITS)
207_05-05-39 LIFTING CYLINDER, DUPLEX (REPAIR KITS)
208_05-05-40 OIL TANK
209_05-05-41 OIL TANK FILTER
210_05-05-42 GASKET KIT
211_06-06-01 OPERATOR COMPARTMENT, BASIC OHG
212_06-06-02 OPERATOR COMPARTMENT, PLEXI ROOF
213_06-06-03 OPERATOR COMPARTMENT, OHG ROOF, W_ WINDSCRN
214_06-06-04 OPERATOR COMPARTMENT, OHG ROOF, W_ WINDSCRN, WIPER, BATTERY HATCH
215_06-06-05 OPERATOR COMPARTMENT, OHG ROOF, W_ WINDSCRN, WIPER, BATTERY HATCH, REAR SCREEN, REAR WIPER
216_06-06-06 OPERATOR COMPARTMENT, OHG ROOF, W_ ... , STEEL DOORS
217_06-06-07 OPERATOR COMPARTMENT, OHG ROOF, W_ ... , PVC DOORS
218_06-06-08 OPERATOR COMPARTMENT, OHG ROOF, W_ ... , STEEL DOORS, HEATER
219_06-06-09 OPERATOR COMPARTMENT, OHG ROOF, W_ ... , STEEL DOORS, INTERIOR PACK
220_06-06-10 OPERATOR COMPARTMENT, OHG ROOF, W_ ... , PVC DOORS, INTERIOR PACK
221_06-06-11 OPERATOR COMPARTMENT, OHG ROOF, W_ ... , STEEL DOORS, HEATER, INTERIOR PACK
222_06-06-12 OPERATOR COMPARTMENT, OHG ROOF, W_ ... , INTERIOR PACK
223_06-06-13 OPERATOR COMPARTMENT, NARROW OHG
224_06-06-14 OHG, SUMMER DOORS
225_06-06-15 OHG, SUMMER DOORS - NEW
226_06-06-16 OHG, SUMMER DOORS, PLEXI ROOF
227_06-06-17 OHG, SUMMER DOORS, PLEXI ROOF, WINDSCRN
228_06-06-18 OHG, SUMMER DOORS, PLEXI ROOF, WINDSCRN, WIPER
229_06-06-19 OHG, SUMMER DOORS, PLEXI ROOF, WINDSCRN, WIPER, REAR SCRN
230_06-06-20 OHG, SUMMER DOORS, PLEXI ROOF, WINDSCRN, WIPER, REAR SCRN, INTERIOR PACK
231_06-06-21 WINDSCREEN, ROOF, INSTALLATION
232_06-06-22 WINDSCREEN, ROOF
233_06-06-23 WINDSCREEN, ROOF, INSTALLATION, W_ WINDSHIELD WIPER
234_06-06-24 WINDSCREEN, ROOF
235_06-06-25 WINDSHIELD WIPER, 197x748x503
236_06-06-26 WINDSHIELD WIPER, 97x750x168
237_06-06-27 HATCH, INSTALLATION
238_06-06-28 HATCH, ASSEMBLY
239_06-06-29 REAR WINDOW, INSTALLATION
240_06-06-30 REAR WINDOW, ASSEMBLY
241_06-06-31 ROOF WINDOW, INSTALLATION
242_06-06-32 ROOF WINDOW, ASSEMBLY
243_06-06-33 DOOR, LEFT, INSTALLATION
244_06-06-34 DOOR, LEFT, ASSEMBLY
245_06-06-35 DOOR, RIGHT, INSTALLATION
246_06-06-36 DOOR, RIGHT, ASSEMBLY
247_06-06-37 STOPPER
248_06-06-38 DOOR, RIGHT, W_ HEATER, INSTALLATION
249_06-06-39 DOOR, RIGHT, W_ HEATER, ASSEMBLY
250_06-06-40 DOOR, SUMMER DOOR, LEFT, INSTALLATION
251_06-06-41 DOOR, SUMMER DOOR, LEFT, ASSEMBLY
252_06-06-42 DOOR, 139x1485x1314, LEFT, INSTALLATION
253_06-06-43 DOOR, 142x1485x1314, LEFT, ASSEMBLY
254_06-06-44 DOOR, SUMMER DOOR, RIGHT, INSTALLATION
255_06-06-45 DOOR, SUMMER DOOR, RIGHT, ASSEMBLY
256_06-06-46 DOOR, 326x1414x1300, RIGHT, W_ HEATER, INSTALLATION
257_06-06-47 DOOR, 326x1415x1300, RIGHT, W_ HEATER, ASSEMBLY
258_07-07-10 INSTALLATION KIT, RIGHT FORK
259_07-07-11 INSTALLATION KIT, LEFT FORK
260_07-07-12 LIFT CHAIN, SIMPLEX (1.5T)
261_07-07-13 LIFT CHAIN, SIMPLEX (2.0T)
262_07-07-14 LIFT CHAIN, DUPLEX, TRIPLEX (1.5T)
263_07-07-15 LIFT CHAIN, DUPLEX, TRIPLEX (2.0T)
264_07-07-16 LIFT CHAIN, DUPLEX W_ FREE LIFT, TRIPLEX W_ FREE LIFT (1.5T)
265_07-07-17 LIFT CHAIN, DUPLEX W_ FREE LIFT, TRIPLEX W_ FREE LIFT (2.0T)
266_07-07-18 PERFORMANCE REDUCTION SENSOR, SIMPLEX
267_07-07-19 PERFORMANCE REDUCTION SENSOR, SIMPLEX (FOR LH_3.5M)
268_07-07-20 PERFORMANCE REDUCTION SENSOR, DUPLEX & TRIPLEX
269_07-07-21 PERFORMANCE REDUCTION SENSOR, DUPLEX & TRIPLEX (FOR LH_3.5M)
270_07-07-22 CHAIN YOKE ASSEMBLY
271_07-07-23 HOSE HOLDER, 3V
272_07-07-24 HOSE HOLDER, 4V
273_07-07-25 HOSE HOLDER, 5V
274_07-07-26 PULLEY, 5V FREE-LIFT PULLEY
275_07-07-27 PULLEY, 5V CABLE PULLEY
276_07-07-28 PULLEY, 5V SIDE CYLINDER
277_08-08-01 DRIVE UNIT, LEFT
278_08-08-02 DRIVE UNIT, RIGHT
279_08-08-03 DRIVING MOTOR
280_08-08-04 TRANSMISSION UNIT, LEFT
281_08-08-05 TRANSMISSION UNIT, RIGHT
282_08-08-06 PUMP MOTOR ASSEMBLY (1.4T & 1.6T)
283_08-08-07 PUMP MOTOR ASSEMBLY (1.8T & 2.0T)
284_08-08-08 SEAL KIT (FOR PUMP RL639237)
285_09-09-01 WHEEL SETS, 3W
286_09-09-02 WHEEL, SOLID ELASTIC, FRONT (1.4-1.8T)
287_09-09-03 WHEEL, SOLID ELASTIC, FRONT (2.0T)
288_09-09-04 WHEEL, SOLID ELASTIC, REAR
289_09-09-05 WHEEL, NON-MARKING, FRONT (1.4-1.8T)
290_09-09-06 WHEEL, NON-MARKING, FRONT (2.0T)
291_09-09-07 WHEEL, NON-MARKING, REAR
