Caterpillar Forklift EP15KRT PAC Chassis Mast Options Internal Hosing Europe Parts Catalog 98753-37010
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar EP15KRT PAC Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: 98753-37010
Number of Pages: 337 Pages
001_01-04-01 ELECTRIC SYSTEM
002_01-04-02 COOLING FAN KIT - OPTION
003_01-04-03 WORKING LAMP KIT - OPTION
004_01-04-04 AMBER STROBE KIT - OPTION
005_01-04-05 REAR WORKING LAMP HARNESS KIT - OPTION
006_01-04-06 ROAD LIGHT KIT - OPTION
007_01-04-07 BATTERY BOX KIT - OPTION
008_01-04-08 CONNECTOR KIT - OPTION
009_01-05-01 HARNESS
010_01-05-02 POWER CABLE
011_01-11-01 FRAME
012_01-11-02 CHASSIS ACCESSORY
013_01-11-03 INTERIOR PARTS
014_01-12-01 CONTROLLER COVER
015_01-13-01 COUNTERWEIGHT
016_01-14-01 SEAT
017_01-14-02 VINYL SUSPENSION SEAT KIT - OPTION
018_01-14-03 CLOTH SUSPENSION SEAT KIT - OPTION
019_01-15-01 HEAD GUARD
020_01-15-02 OPTIONAL HEAD GUARD - OPTION
021_01-20-01 MOTOR
022_01-20-02 TRACTION MOTOR
023_01-20-03 PUMP MOTOR
024_01-22-01 CONTROLLER CHASSIS PARTS
025_01-33-01 FRONT AXLE
026_01-34-01 FRONT TIRE
027_01-34-02 NONMARKING TIRE KIT - OPTION
028_01-34-03 WIDE AXLE SOLID TIRE KIT - OPTION
029_01-34-04 WIDE AXLE NONMARKING TIRE KIT - OPTION
030_01-43-01 REAR AXLE
031_01-43-02 REAR AXLE ASSY (OLD) UPTO 2011-04
032_01-44-01 REAR TIRE
033_01-44-02 REAR NONMARKING TIRE KIT - OPTION
034_01-46-01 WHEEL BRAKE PIPING
035_01-46-02 WHEEL BRAKE (L.H.)
036_01-46-03 WHEEL BRAKE (R.H.)
037_01-51-01 PEDAL ASSY
038_01-51-02 HAND BRAKE
039_01-52-01 ACCELERATOR CONTROL
040_01-52-02 FOOT DIRECTION KIT - OPTION
041_01-54-01 STEERING SYSTEM
042_01-54-02 STEERING VALVE
043_01-54-03 HYDRAULIC MOTOR
044_01-54-04 STEERING WHEEL
045_01-70-01 MAIN CONTROLLER
046_01-70-02 TRACTION INVERTER (BACK ROW)
047_01-70-03 PUMP INVERTER (FRONT ROW)
048_01-71-01 HYDRAULIC PUMP
049_01-72-01 CONTROL VALVE (2-BLOCK)
050_01-72-02 CONTROL VALVE (3-BLOCK)
051_01-72-03 CONTROL VALVE (4-BLOCK)
052_01-72-04 INLET COVER, LIFT VALVE & TILT VALVE
053_01-72-05 ATTACHMENT VALVE (3-WAY, 4-WAY)
054_01-73-01 HYDRAULIC CONTROL (2-WAY)
055_01-73-02 HYDRAULIC CONTROL (3-WAY)
056_01-73-03 HYDRAULIC CONTROL (4-WAY)
057_01-74-01 HYDRAULIC TANK
058_01-75-01 HYDRAULIC LINE
059_01-75-02 ATTACHMENT VALVE PIPING
060_01-75-03 FLOW REGULATOR VALVE
061_01-81-01 NAME-PLATE
062_01-91-01 FORK STOPPER (FOR BACKREST-LESS) - OPTION
063_01-92-01 MAST HOOK KIT (FOR 2G15CA20-60) - OPTION
064_01-92-02 MAST HOOK KIT (FOR 2J15CA37-70) - OPTION
065_01-92-03 MAST HOOK KIT (FOR 2H15CA28-40) - OPTION
066_01-95-01 HIGH LOAD SIDE ROLLER - OPTION
067_02-01-01 LIFT BRACKET COMMON PARTS (OLD) (UPTO 2012-02)
068_02-01-02 LIFT BRACKET (OLD) (UP TO 2012-02)
069_02-01-03 BACKREST
070_02-01-04 LIFT BRACKET COMMON PARTS (NEW) (FROM 2012-03)
071_02-01-05 LIFT BRACKET (NEW) (FROM 2012-03)
072_02-04-01 TILT CYLINDER (OLD)
073_02-04-02 TILT CYLINDER (NEW)
074_02-06-01 FORK
075_02-10-01 MAST COMMON PARTS (PART-1) (FOR 2G15CA20-60)
076_02-10-02 MAST COMMON PARTS (PART-2) (FOR 2G15CA20-60)
077_02-10-03 MAST COMMON PARTS (PART-1) (FOR 2J15CA37-70)
078_02-10-04 MAST COMMON PARTS (PART-2) (FOR 2J15CA37-70)
079_02-10-05 MAST COMMON PARTS (PART-3) (FOR 2J15CA37-70)
080_02-10-06 MAST COMMON PARTS (PART-4) (FOR 2J15CA37-70)
081_02-10-07 MAST COMMON PARTS (PART-1) (FOR 2H15CA28-40)
082_02-10-08 MAST COMMON PARTS (PART-2) (FOR 2H15CA28-40)
083_02-10-09 MAST COMMON PARTS (PART-2) (FOR 2H15CA28-40)
084_02-18-01 DUPLEX MAST MODEL 2H15CA28-40
085_02-18-02 LIFT CYLINDER (1ST) (FOR 2H15CA28-40)
086_02-18-03 LIFT CYLINDER (2ND) (FOR 2H15CA28-40)
087_02-20-01 TRIPLEX MAST MODEL 2J15CA37-70
088_02-20-02 LIFT CYLINDER (1ST) (FOR 2J15CA37-70)
089_02-20-03 LIFT CYLINDER (2ND) (FOR 2J15CA37-70)
090_02-60-01 SIMPLEX MAST MODEL 2G15CA20-60
091_02-60-02 LIFT CYLINDER (FOR 2G15CA20-60)
092_04-23 MAST PIPING KIT(3-WAY SIMPLEX) (FOR 2G15CA20-60)
093_04-24 MAST PIPING KIT(4-WAY SIMPLEX) (FOR 2G15CA20-60)
094_04-25 MAST PIPING KIT(3-WAY DUPLEX) (FOR 2H15CA28-40)
095_04-26-01 MAST PIPING KIT (4-WAY DUPLEX) (FOR 2H15CA28-40) (UPTO 2011-10)
096_04-26-02 MAST PIPING KIT (4-WAY DUPLEX) (FOR 2H15CA28-40) (FROM 2011-11)
097_04-27 MAST PIPING KIT(3-WAY TRIPLEX) (FOR 2J15CA37-70)
098_04-28 MAST PIPING KIT(4-WAY TRIPLEX) (FOR 2J15CA37-70)
099_04-41-01 MAST PIPING KIT(3-WAY SIMPLEX) INTEGRAL SIDESHIFTER
100_04-41-02 MAST PIPING KIT(4-WAY SIMPLEX) INTEGRAL SIDESHIFTER
101_04-42-01 MAST PIPING KIT (3-WAY DUPLEX) INTEGRAL SIDESHIFTER
102_04-42-02 MAST PIPING KIT (4-WAY DUPLEX) INTEGRAL SIDESHIFTER (UPTO 2011-10)
103_04-42-03 MAST PIPING KIT (4-WAY DUPLEX) INTEGRAL SIDESHIFTER (FROM 2011-11)
104_04-42-03 MAST PIPING KIT (4-WAY DUPLEX) INTEGRAL SIDESHIFTER (FROM 2011-11)_1
105_04-43-01 MAST PIPING KIT(3-WAY TRIPLEX) INTEGRAL SIDESHIFTER
106_04-43-02 MAST PIPING KIT(4-WAY TRIPLEX) INTEGRAL SIDESHIFTER
