Caterpillar Forklift EP13T 48V Chassis Mast Europe Parts Catalog SEBN2729-01
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar EP13T 48V Chassis Mast Forklift
Region: Europe
Part Number: SEBN2729-01
Number of Pages: 377 Pages
001_HARNESS GP (WIRING)
002_PANEL GP CONTROL PART 1 OF 2
003_PANEL GP CONTROL PART 2 OF 2
004_PANEL GP CONTROL PART 1 OF 3
005_PANEL GP CONTROL PART 3 OF 3
006_PANEL GP CONTROL (BOARD GP DRIVER)
007_PANEL GP CONTROL (CONTACTOR ASSY.-DIRECTIONAL)
008_PANEL GP CONTROL (CONTACTOR ASSY.-LINE)
009_PANEL GP CONTROL (CONTACTOR ASSY.-BYPASS)
010_PANEL GP CONTROL (CONTACTOR ASSY.-PUMP)
011_CONNECTOR GP BATTERY (SBE - 36 VOLT)
012_CONNECTOR ASSY..BATTERY (36 VOLT)
013_CONNECTOR GP BATTERY (48 VOLT)
014_CONNECTOR ASSY. BATTERY (48 VOLT)
015_SWITCH GP ELECTRICAL
016_HORN GP ELECTRICAL
017_INSTRUMENT GP
018_INSTRUMENT - GP
019_MOTOR GP DRIVE (36 VOLT)
020_MOTOR GP MAIN DRIVE (36 VOLT)
021_MOTOR GP DRIVE (48 VOLT)
022_MOTOR GP DRIVE (48 VOLT)_1
023_MOTOR GP ELECTRIC POWER STEER PUMP (36 VOLT)
024_MOTOR GP ELECTRIC POWER STEER PUMP (36 VOLT)_1
025_MOTOR GP ELECTRIC POWER STEER PUMP (48 VOLT)
026_MOTOR GP ELECTRIC POWER STEER PUMP (48 VOLT)_1
027_MOTOR GP HYDRAULIC PUMP (36 VOLT)
028_MOTOR GP HYDRAULIC PUMP (36 VOLT)_1
029_MOTOR GP HYDRAULIC PUMP (48 VOLT)
030_MOTOR GP HYDRAULIC PUMP (48 VOLT)_1
031_AXLE GP DRIVE R.H
032_AXLE GP DRIVE L.H
033_MOUNTING GP DRIVE AXLE
034_TIRE GP SOLID PNEUMATIC
035_MOUNTING GP DRIVE WHEEL
036_AXLE GP STEER
037_MOUNTING GP STEER
038_PANEL GP TOP
039_PANEL GP SIDE
040_RESTRAINT GP BATTERY
041_RESTRAINT GP BATTERY_1
042_FLOOR PLATE GP
043_COUNTERWEIGHT GP
044_COUNTERWEIGHT GP_1
045_COUNTERWEIGHT GP_2
046_CONSOLE GP
047_GUARD GP OVERHEAD
048_GUARD GP OVERHEAD_1
049_PAINT AND LUBE GP
050_SEAT GP - SUSPENSION
051_CONTROL GP ACCELERATION
052_CONTROL GP ACCELERATION_1
053_CONTROL GP BRAKE
054_CONTROL GP SERVICE BRAKE
055_BRAKE GP SERVICE
056_BRAKE GP PARKING
057_LINES GP BRAKE
058_STEERING WHEEL AND GEAR GROUP
059_CONTROL GP FORWARD AND REVERSE
060_PUMP GP POWER STEERING PART 1 OF 2
061_PUMP GP POWER STEERING PART 2 OF 2
062_PUMP GROUP HYDRAULIC
063_LINES GROUP POWER STEER
064_FILTER GP HYDRAULIC OIL
065_TANK GP HYDRAULIC
066_TANK GP HYDRAULIC (LARGE)
067_LINES GP MAST OPERATING
068_CONTROL GP MAST OPERATING VALVE (3-WAY)
069_VALVE GP CONTROL (3-WAY)
070_VALVE GP CONTROL (3-WAY)_1
071_VALVE GP CONTROL (3-WAY)_2
072_VALVE GP CONTROL (3-WAY)_3
073_MOUNTING GP MAST OPERATING VALVE
074_CONTROL VALVE FLOW
075_1200791 CYLINDER GP TILT - SIMPLEX - DUPLEX - TRIPLEX 1 REQUIRED 89MM (3.5 In.) Bore X 96MM (3.8 In.) Stroke 10 Degrees
076_1200792 CYLINDER GP TILT - SIMPLEX - TRIPLEX 1 REQUIRED 89MM (3.5 In.) Bore X 84MM (3.3 In.) Stroke 6 Degrees Forward X
077_1200793 CYLINDER GP TILT - SIMPLEX - DUPLEX - TRIPLEX 1 REQUIRED 89MM (3.5 In.) Bore X 71MM (2.8 In.) Stroke 6 Degrees
078_1200796 CYLINDER GP TILT - SIMPLEX - TRIPLEX 1 REQUIRED 89MM (3.5 In.) Bore X 57MM (2.5 In.) Stroke 6 Degrees Forward X
079_1200794 CYLINDER GP TILT - SIMPLEX - DUPLEX - TRIPLEX 1 REQUIRED 89MM (3.5 In.) Bore X 52MM (2 In
080_1200795 CYLINDER GP TILT - SIMPLEX - TRIPLEX 1 REQUIRED 89MM (3.5 In.) Bore X 65MM (2.6 In.) Stroke 3 Degrees Forward X
081_CYLINDER GP - TILT
082_MOUNTING GP - CYLINDER - TILT REAR
083_FORKS
084_LIFT BRACKET
085_MAST COMMON PARTS (SIMPLEX) G15A20-60
086_MAST COMMON PARTS (SIMPLEX) G15A20-60_1
087_SIMPLEX MAST G15A20-60
088_LIFT CYLINDER (SIMPLEX) G15A20-60
089_MAST COMMON PARTS (DUPLEX) H15A27-40
090_MAST COMMON PARTS (DUPLEX) H15A27-40_1
091_DUPLEX MAST H15A27-40
092_LIFT CYLINDER (DUPLEX) H15A27-40(1ST)
093_LIFT CYLINDER (DUPLEX) H15A27-40 (2ND)
094_MAST COMMON PARTS (TRIPLEX) J15B37-70
095_MAST COMMON PARTS (TRIPLEX) J15B37-70_1
096_MAST COMMON PARTS (TRIPLEX) J15B37-70_2
097_TRIPLEX MAST J15B37-70
098_LIFT CYLINDER (TRIPLEX) - J15B37-70 (1ST)
099_LIFT CYLINDER (TRIPLEX) J15B37-70 (2ND)
100_LIFT TRUCK OPTIONS CHASSIS OPTION AR.
101_LIFT TRUCK OPTIONS CHASSIS OPTION AR. 4 WAY
102_LIFT TRUCK OPTIONS CHASSIS OPTION AR. VALVE GP
103_LIFT TRUCK OPTIONS MIRROR KIT
104_LIFT TRUCK OPTIONS DRAW BAR PIN KIT
105_LIFT TRUCK OPTIONS LIGHT GROUP ROAD
106_LIFT TRUCK OPTIONS BACKUP WARNING KIT
107_LIFT TRUCK OPTIONS WARNING LAMP KIT (AMBER)
108_LIFT TRUCK OPTIONS LIGHT GROUP 2F_1B (36V)
109_LIFT TRUCK OPTIONS LIGHT GROUP 2F_1B (48V)
110_LABEL KIT (FRENCH)
111_LABEL KIT (SPANISH)
112_LABEL KIT (ITALIAN)
113_LABEL KIT (GERMAN)
114_LABEL KIT (DUTCH)
115_LABEL KIT (PORTUGUESE)
116_LABEL KIT (DANISH)
117_LABEL KIT (GREEK)
118_LIFT TRUCK OPTIONS CONNECTOR AS - SBE (36 VOLT)
119_LIFT TRUCK OPTIONS CONNECTOR AS - SBE (48 VOLT)
120_LIFT TRUCK OPTIONS CONNECTOR AS - SBE (36 VOLT)_1
121_LIFT TRUCK OPTIONS CONNECTOR AS - SBE (48 VOLT)_1
122_LIFT TRUCK OPTIONS TIRE GROUP CUSHION
123_LIFT TRUCK OPTIONS SPARE WHEEL CUSHION
124_LIFT TRUCK OPTIONS SPARE WHEEL (SOLID PNEUMATIC)
125_LIFT TRUCK OPTIONS 3 - WAY SIMPLEX G15A20-60
126_LIFT TRUCK OPTIONS 4 - WAY SIMPLEX G15A20-60
127_LIFT TRUCK OPTIONS 3 - WAY DUPLEX H15A27-40
128_LIFT TRUCK OPTIONS 4 - WAY DUPLEX H15A27-40
129_LIFT TRUCK OPTIONS 3 - WAY TRIPLEX J15B37-70
130_LIFT TRUCK OPTIONS 4 - WAY TRIPLEX J15B37-70
Brand: Caterpillar
Region: Europe
017_INSTRUMENT GP
018_INSTRUMENT - GP
036_AXLE GP STEER
038_PANEL GP TOP
039_PANEL GP SIDE
042_FLOOR PLATE GP
046_CONSOLE GP
057_LINES GP BRAKE
083_FORKS
084_LIFT BRACKET
- CAT 416D Parts Manual
- CAT 420D Parts Manual
