Caterpillar Forklift EC55N Chassis Mast Options Internal Hosing Europe Parts Catalog SEBN8474-02
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar EC55N Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: SEBN8474-02
Number of Pages: 586 Pages
001_01-040-01 CHASSIS WIRE HARNESS - MAIN
002_01-042-01 CONSOLE BOX
003_01-042-02 DISPLAY
004_01-043-01 DC_DC CONVERTER
005_01-043-02 BACK-UP ALARM (SMART)
006_01-044-01 HORN ASSEMBLY
007_01-045-01 POWER CABLE
008_01-111-01 BATTERY COVER
009_01-111-02 BATTERY RETAINER
010_01-114-01 FLOOR PLATES
011_01-115-01 STANDARD CHASSIS PARTS
012_01-115-02 STANDARD EUROPEAN CHASSIS PARTS
013_01-116-01 PLASTIC PARTS
014_01-120-01 COUNTERWEIGHTS
015_01-140-01 SEAT
016_01-150-01 HEAD GUARD ASSEMBLY
017_01-200-01 TRACTION MOTOR (PART-1)
018_01-200-02 TRACTION MOTOR (PART-2)
019_01-201-01 PUMP MOTOR (PART-1)
020_01-201-02 PUMP MOTOR (PART-2)
021_01-202-01 POWER STEERING MOTOR (PART-1)
022_01-202-02 POWER STEERING MOTOR (PART-2)
023_01-220-01 TRACTION MOTOR CONTROLLER & CONTACTOR PANEL
024_01-221-02 HYDRAULIC PUMP MOTOR CONTROLLER
025_01-222-01 CONTACTOR PANEL
026_01-222-02 CONTACTOR HYD
027_01-222-03 CONTACTOR LINE
028_01-222-04 CONTACTOR POWER STEERING
029_01-270-01 TRANSFER CASE
030_01-310-01 REDUCTION & DIFFERENTIAL
031_01-330-01 FRONT AXLE
032_01-340-01 FRONT TIRES
033_01-430-01 REAR AXLE (PART-1)
034_01-430-02 REAR AXLE (PART-2)
035_01-430-03 STEERING CYLINDER
036_01-440-01 REAR AXLE MTG
037_01-450-01 REAR TIRE
038_01-460-01 WHEEL BRAKE ASSY (L.H.)
039_01-460-03 WHEEL BRAKE ASSY (R.H.)
040_01-470-01 BRAKE LINES
041_01-470-02 MASTER CYLINDER
042_01-510-01 BRAKE CONTROL
043_01-511-01 PARKING BRAKE
044_01-511-02 HAND BRAKE
045_01-520-01 ACCELERATOR PEDAL AND FNR LEVER
046_01-540-01 STEERING CONTROL
047_01-540-02 STEER GEAR ASSY
048_01-710-01 HYDRAULIC PUMP (PART-1)
049_01-710-02 HYDRAULIC PUMP (PART-2)
050_01-711-01 POWER STEERING PUMP (PART-1)
051_01-711-02 POWER STEERING PUMP (PART-2)
052_01-720-01 HYDRAULIC CONTROL - 3V
053_01-720-02 HYD HAND LEVER - 4V
054_01-720-03 HYDRAULIC CONTROL VALVE - 3V
055_01-720-04 HYD CONTROL VALVE - 4V
056_01-740-01 HYDRAULIC TANK
057_01-750-01 HYDRAULIC LINES-3V
058_01-750-02 HYDRAULIC LINES -4V
059_01-751-01 FLOW REGULATOR VALVE
060_01-811-01A LABELS
061_01-811-01B LABELS
062_02-01-01 LIFT BRACKET COMMON PARTS
063_02-01-02 LIFT BRACKET & BACKREST
064_02-04-01 TILT CYLINDER (L.H.)
065_02-04-02 TILT CYLINDER (R.H.)
066_02-06 FORK
067_02-10-01 MAST COMMON PARTS (PART-1) (FOR SIMPLEX MAST)
068_02-10-02 MAST COMMON PARTS (PART-2) (FOR SIMPLEX MAST)
069_02-10-03 MAST COMMON PARTS (PART-1) (FOR TRIPLEX MAST)
070_02-10-04 MAST COMMON PARTS (PART-2) (FOR TRIPLEX MAST)
071_02-10-05 MAST COMMON PARTS (PART-3) (FOR TRIPLEX MAST)
072_02-10-06 MAST COMMON PARTS (PART-1) (FOR DUPLEX MAST)
073_02-10-07 MAST COMMON PARTS (PART-2) (FOR DUPLEX MAST)
074_02-52-01 DUPLEX MAST MODEL B40A32 - B40A36
075_02-52-02 LIFT CYLINDER (1ST) (FOR B40A32-36)
076_02-52-03 LIFT CYLINDER (2ND) (FOR B40A32-36)
077_02-66-01 SIMPLEX MAST MODEL A40A33-45
078_02-66-02 LIFT CYLINDER (FOR A40A33-45)
079_02-66-05 SIMPLEX MAST MODEL A55A28-40
080_02-66-06 LIFT CYLINDER (FOR A55A28-40)
081_02-68-01 TRIPLEX MAST MODEL C40A50-55
082_02-68-02 LIFT CYLINDER (1ST) (FOR C40A50-55)
083_02-68-03 LIFT CYLINDER (2ND) (FOR C40A50-55)
084_02-68-04 TRIPLEX MAST MODEL C45A47-53
085_02-68-05 LIFT CYLINDER (1ST) (FOR C45A47-53)
086_02-68-06 LIFT CYLINDER (2ND) (FOR C45A47-53)
087_02-68-07 TRIPLEX MAST MODEL C55A47-53
088_02-68-08 LIFT CYLINDER (1ST) (FOR C55A47-53)
089_02-68-09 LIFT CYLINDER (2ND) (FOR C55A47-53)
090_MAST PIPING 3-WAY SIMPLEX (STD 3_8 IN) (A40A MAST MODEL)
091_MAST PIPING 3-WAY SIMPLEX (HIGH 1_2 IN) (A40A MAST MODEL)
092_MAST PIPING 4-WAY SIMPLEX (STD 3_8 IN) (A40A MAST MODEL)
093_MAST PIPING 4-WAY SIMPLEX (HIGH 1_2 IN) (A40A MAST MODEL)
094_MAST PIPING 3-WAY DUPLEX (STD 3_8 IN) (B40A MAST MODEL)
095_MAST PIPING 3-WAY DUPLEX (HIGH 1_2 IN) (B40A MAST MODEL)
096_MAST PIPING 4-WAY DUPLEX (STD 3_8 IN) (B40A MAST MODEL)
097_MAST PIPING 4-WAY DUPLEX (HIGH 1_2 IN) (B40A MAST MODEL)
098_MAST PIPING 3-WAY, 4-WAY DUPLEX (HIGH 1_2 IN, STD 3_8 IN) (B40A MAST MODEL)
099_MAST PIPING 3-WAY TRIPLEX (STD 3_8 IN) (C40A MAST MODEL)
100_MAST PIPING 3-WAY TRIPLEX (HIGH 1_2 IN) (C40A MAST MODEL)
101_MAST PIPING 4-WAY TRIPLEX (STD 3_8 IN) (C40A MAST MODEL)
102_MAST PIPING 4-WAY TRIPLEX (HIGH 1_2 IN) (C40A MAST MODEL)
103_MAST PIPING 3-WAY, 4-WAY TRIPLEX (HIGH 1_2 IN, STD 3_8 IN) (C40A MAST MODEL)
104_SINGLE FUNCTION STEEL SUPPLY LINES - 3-WAY VALVE
105_DUAL FUNCTION STEEL SUPPLY LINES WITH 1 (OR NO) HIGH FLOW FUNCTION - 4-WAY VALVE REQUIRED
106_DUAL FUNCTION STEEL SUPPLY LINES WITH 2 HIGH FLOW FUNCTIONS - 4-WAY VALVE REQUIRED
107_1 MAST PIPING KIT 3-WAY SIMPLEX (STD 3_8 IN)
108_3 MAST PIPING KIT 3-WAY SIMPLEX (HIGH 1_2 IN)
109_5 MAST PIPING KIT 4-WAY SIMPLEX (STD 3_8 IN)
110_7 MAST PIPING KIT 4-WAY SIMPLEX (HIGH 1_2 IN)
111_9 MAST PIPING KIT 3-WAY DUPLEX (STD 3_8 IN)
112_11 MAST PIPING KIT 3-WAY DUPLEX (HIGH 1_2 IN)
113_13 MAST PIPING KIT 4-WAY DUPLEX (STD 3_8 IN)
114_17 MAST PIPING KIT 4-WAY DUPLEX (HIGH 1_2 IN)
115_21 MAST PIPING KIT 3-WAY, 4-WAY DUPLEX (HIGH 1_2 IN, STD 3_8 IN)
116_25 MAST PIPING KIT 3-WAY TRIPLEX (STD 3_8 IN)
117_29 MAST PIPING KIT 3-WAY TRIPLEX (HIGH 1_2 IN)
118_33 MAST PIPING KIT 4-WAY TRIPLEX (STD 3_8 IN)
119_37 MAST PIPING KIT 4-WAY TRIPLEX (HIGH 1_2 IN)
120_41 MAST PIPING KIT 3-WAY, 4-WAY TRIPLEX (HIGH 1_2 IN, STD 3_8 IN)
121_47 SINGLE FUNCTION STEEL SUPPLY LINES -- 3-WAY VALVE
122_49 DUAL FUNCTION STEEL SUPPLY LINES WITH 1 (OR NO) HIGH FLOW FUNCTION -- 4-WAY VALVE REQUIRED
123_51 DUAL FUNCTION STEEL SUPPLY LINES WITH 2 HIGH FLOW FUNCTIONS -- 4-WAY VALVE REQUIRED
124_1 MAST PIPING KIT 3-WAY SIMPLEX (STD 3_8 IN)_1
125_3 MAST PIPING KIT 3-WAY SIMPLEX (HIGH 1_2 IN)_1
126_5 MAST PIPING KIT 4-WAY SIMPLEX (STD 3_8 IN)_1
127_7 MAST PIPING KIT 4-WAY SIMPLEX (HIGH 1_2 IN)_1
128_9 MAST PIPING KIT 3-WAY DUPLEX (STD 3_8 IN)_1
129_11 MAST PIPING KIT 3-WAY DUPLEX (HIGH 1_2 IN)_1
130_13 MAST PIPING KIT 4-WAY DUPLEX (STD 3_8 IN)_1
131_17 MAST PIPING KIT 4-WAY DUPLEX (HIGH 1_2 IN)_1
132_21 MAST PIPING KIT 3-WAY, 4-WAY DUPLEX (HIGH 1_2 IN, STD 3_8 IN)_1
133_25 MAST PIPING KIT 3-WAY TRIPLEX (STD 3_8 IN)_1
134_29 MAST PIPING KIT 3-WAY TRIPLEX (HIGH 1_2 IN)_1
135_33 MAST PIPING KIT 4-WAY TRIPLEX (STD 3_8 IN)_1
136_37 MAST PIPING KIT 4-WAY TRIPLEX (HIGH 1_2 IN)_1
137_41 MAST PIPING KIT 3-WAY, 4-WAY TRIPLEX (HIGH 1_2 IN, STD 3_8 IN)_1
138_47 SINGLE FUNCTION STEEL SUPPLY LINES -- 3-WAY VALVE_1
139_49 DUAL FUNCTION STEEL SUPPLY LINES WITH 1 (OR NO) HIGH FLOW FUNCTION -- 4-WAY VALVE REQUIRED_1
140_51 DUAL FUNCTION STEEL SUPPLY LINES WITH 2 HIGH FLOW FUNCTIONS -- 4-WAY VALVE REQUIRED_1
141_03-043-01 LIGHT KIT 2 FWD_1 REV & TAIL
142_03-043-02 LIGHT KIT 2 FWD_1 REV
143_03-043-03 12V LAMP
144_03-043-04 STROBE LAMP KIT
145_03-043-05 STROBE LAMP
146_03-114-01 BATTERY SLIDE KIT
147_03-115-01 REAR VIEW MIRROR KIT
148_03-115-02 DRAW BAR PIN KIT
149_03-115-03 FIRE EXTINGUISHER KIT
150_03-115-04 BATTERY BOX
151_03-140-01 CLOTH SEAT KIT
152_03-140-02 STATIC SEAT CLOTH
153_03-200-01 SEAT OPERATED PARK BRAKE
154_03-200-02 ELECTROMAGNETIC BRAKE
155_03-340-01 DRIVE TIRE, NON-MARKING
156_03-450-01 STEER TIRE KIT NON-MARKING
157_03-520-01 FOOT DIR CONTROL KIT
158_03-720-01 HYD HAND LEVER KIT - 4V
159_03-811-01A LABELS SPANISH
160_03-811-01B LABELS SPANISH
161_03-811-02A LABELS FRENCH
162_03-811-02B LABELS FRENCH
163_03-811-03A LABELS PORTUGUESE
164_03-811-03B LABELS PORTUGUESE
