Caterpillar Forklift EC20N Chassis Mast Options Europe Parts Catalog 98753-32210
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar EC20N Chassis Mast Options Forklift
Region: Europe
Part Number: 98753-32210
Number of Pages: 326 Pages
001_01-04-01 ELECTRICAL SYSTEM 36_48V
002_01-04-02 OPERATOR DISPLAY
003_01-04-03 POWER CABLES
004_01-11-01 FRAME & BODY (PART-1)
005_01-11-02 FRAME & BODY (PART-2)
006_01-11-03 FRAME & BODY (PART-3)
007_01-11-04 BATTERY RETAINER
008_01-11-05 DASH COVER
009_01-11-06 TILT CYLINDER PIN
010_01-11-07 BATTERY BOX
011_01-14-01 SEAT ASSEMBLY (PART-1)
012_01-14-02 SEAT ASSEMBLY (PART-2)
013_01-15-01 HEAD GUARD
014_01-20-01 TRACTION MOTOR 11_ (PART-1)
015_01-20-02 TRACTION MOTOR 11_ (PART-2)
016_01-20-03 HYDRAULIC PUMP MOTOR DC (PART-1) (FOR USE WITH CONTACTOR HYDRAULICS)
017_01-20-04 HYDRAULIC PUMP MOTOR DC (PART-2) (FOR USE WITH CONTACTOR HYDRAULICS)
018_01-20-05 HYDRAULIC PUMP MOTOR-AC (PART-1) (FOR USE WITH TRANSISTOR HYDRAULICS)
019_01-20-06 HYDRAULIC PUMP MOTOR-AC (PART-2) (FOR USE WITH TRANSISTOR HYDRAULICS)
020_01-20-07 POWER STEERING MOTOR (PART-1)
021_01-20-08 POWER STEERING MOTOR (PART-2)
022_01-22-01 TRACTION INVERTER (PART-1)
023_01-22-02 TRACTION INVERTER (PART-2)
024_01-22-03 PUMP INVERTER (PART-1) (FOR USE WITH TRANSISTOR HYDRAULICS)
025_01-22-04 PUMP INVERTER (PART-2) (FOR USE WITH TRANSISTOR HYDRAULICS)
026_01-22-05 LOGICS UNIT
027_01-22-06 CONTACTOR PANEL (PART-1) (FOR USE WITH CONTACTOR HYDRAULICS)
028_01-22-07 CONTACTOR PANEL (PART-2) (FOR USE WITH CONTACTOR HYDRAULICS)
029_01-22-08 CONTACTOR PANELS (PART-1) (FOR USE WITH TRANSISTOR HYDRAULICS)
030_01-22-09 CONTACTOR PANEL (PART-2) (FOR USE WITH TRANSISTOR HYDRAULICS)
031_01-22-10 STEERING CONTACTOR (FOR USE WITH CONTACTOR AND TRANSISTOR HYDRAULICS)
032_01-22-11 LINE CONTACTOR (FOR USE WITH CONTACTOR AND TRANSISTOR HYDRAULICS)
033_01-22-12 PUMP CONTACTOR (FOR USE WITH CONTACTOR HYDRAULICS)
034_01-32-01 TRANSFER ASSY
035_01-32-02 REDUCTION & DIFFERENTIAL
036_01-32-03 FRONT AXLE (PART-1)
037_01-32-04 FRONT AXLE (PART 2)
038_01-43-01 REAR AXLE
039_01-43-02 STEERING CYLINDER
040_01-45-01 REAR TIRE
041_01-47-01 WHEEL BRAKE PIPING
042_01-47-02 WHEEL BRAKE ASSEMBLY
043_01-47-03 MASTER CYLINDER
044_01-51-01 PARKING BRAKE
045_01-52-01 ACCELERATOR PEDAL
046_01-54-01 STEERING CONTROL
047_01-54-02 STEERING WHEEL ASSY
048_01-71-01 HYDRAULIC PUMPS
049_01-72-01 HYDRAULIC CONTROL - 3V
050_01-72-02 HYDRAULIC CONTROL VALVE-3V
051_01-72-03 HYDRAULIC LEVER ASSY -3V
052_01-74-01 HYDRAULIC TANK
053_01-75-01 HYDRAULIC LINES (PART-1)
054_01-75-02 HYDRAULIC LINES (PART-2)
055_01-75-03 HYDRAULIC LINES (PART-3)
056_01-81-01 NAME PLATE
057_02-01-01 LIFT BRACKET COMMON PARTS
058_02-01-02 LIFT BRACKET & BACKREST
059_02-04-01 TILT CYLINDER (L.H.)
060_02-04-02 TILT CYLINDER (R.H.)
061_02-06-01 FORK
062_02-10-01 MAST COMMON PARTS (PART-1) (FOR SIMPLEX MAST)
063_02-10-02 MAST COMMON PARTS (PART-2) (FOR SIMPLEX MAST)
064_02-10-03 MAST COMMON PARTS (PART-1) (FOR TRIPLEX MAST)
065_02-10-04 MAST COMMON PARTS (PART-2) (FOR TRIPLEX MAST)
066_02-10-05 MAST COMMON PARTS (PART-3) (FOR TRIPLEX MAST)
067_02-10-06 MAST COMMON PARTS (PART-4) (FOR TRIPLEX MAST)
068_02-10-07 MAST COMMON PARTS (PART-1) (FOR DUPLEX MAST)
069_02-10-08 MAST COMMON PARTS (PART-2) (FOR DUPLEX MAST)
070_02-10-09 MAST COMMON PARTS (PART-3) (FOR DUPLEX MAST)
071_02-18-01 DUPLEX MAST MODEL 3B30C28-40
072_02-18-02 LIFT CYLINDER (1ST) (FOR 3B30C28-40)
073_02-18-03 LIFT CYLINDER (2ND) (FOR 3B25C28-40)
074_02-20-01 TRIPLEX MAST MODEL 3C25C40-60
075_02-20-02 LIFT CYLINDER (1ST) (FOR 3C25C40-60)
076_02-20-03 LIFT CYLINDER (2ND) (FOR 3C25C40-60)
077_02-60-01 SIMPLEX MAST MODEL 3A25B20-41
078_02-60-02 LIFT CYLINDER (FOR 3A25B20-41)
079_03-04-01 HEADLIGHTS, 2 FWD (HALOGEN)
080_03-04-02 HEADLIGHTS, 2 FWD 1 REV (HALOGEN)
081_03-04-03 2 FWD_1 REAR LIGHTS WITH TAIL LIGHTS (HALOGEN)
082_03-04-04 12V LAMP
083_03-04-05 LIGHTS, 2 FORWARD (LED)
084_03-04-06 LIGHTS, 2 FORWARD _ 1 REVERSE (LED)
085_03-04-07 LIGHTS, 2 FORWARD _ 1 REVERSE & TAILLIGHTS (LED)
086_03-04-08 STROBE LAMPS
087_03-04-09 BACKUP BUZZER OPTION
088_03-04-10 DC_DC CONVERTER HI-OUTPUT (200 AMP)
089_03-11-01 BATTERY SLIDE OPTION
090_03-11-02 REAR VIEW MIRROR OPTION
091_03-11-03 DRAW BAR PIN OPTION
092_03-11-04 FIRE EXTINGUISHER OPTION
093_03-14-01 OPTIONAL SEATS
094_03-14-02 SEMI-SUSPENSION SEAT
095_03-15-01 CLIPBOARD HOLDER
096_03-20-01 COVERED MOTOR OPTION
097_03-20-02 SEAT OPERATED PARK BRAKE (SOPB)
098_03-20-03 TRACTION MOTOR 11_ (FOR USE WITH SEAT OPERATED PARK BRAKE)
099_03-20-04 ELECTRO MAGNETIC BRAKE
100_03-33-01 WIDE AXLE OPTION
101_03-33-02 SEMI-WIDE AXLE OPTION & OPTIONAL DRIVE TIRES
102_03-45-01 OPTIONAL STEER TIRES
103_03-51-01 FOOT DIRECTIONAL CONTROL
104_03-72-01 HYDRAULIC CONTROL VALVE-4V (CONVERSION KIT, 3V TO 4V)
105_03-72-02 HYDRAULIC CONTROL VALVE-4V
106_03-72-03 HYDRAULIC CONTROL VALVE-4V (CONVERSION KIT, 3V TO 4V)
107_03-76-01 TC1510 INSTALLATION GROUP - 1 FUNCTION CASCADE MAST 9040105013
108_03-76-02 TC1510 INSTALLATION GROUP - 2 FUNCTION MAST 9040105014
109_03-76-03 TC1520 INSTALLATION GROUP - 1 FUNCTION CASCADE MAST 9040105013
110_03-76-04 TC1520 INSTALLATION GROUP - 2 FUNCTION MAST 9040105014
111_03-76-05 TC1530 INSTALLATION GROUP - 1 FUNCTION CASCADE MAST 9040105013
112_03-76-06 TC1530 INSTALLATION GROUP - 2 FUNCTION MAST 9040105014
113_03-81-01 SPANISH LANGUAGE LABELS
114_03-81-02 FRENCH LANGUAGE LABELS
115_03-81-03 PORTUGUESE LANGUAGE LABELS
