Caterpillar Forklift EC15K Chassis Mast Options (MC) Europe Parts Catalog 98755-33120
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar EC15K Chassis Mast Options (MC) Forklift
Region: Europe
Part Number: 98755-33120
Number of Pages: 240 Pages
001_01-04-01 ELECTRICAL SYSTEM
002_01-04-02 DISPLAY ASSEMBLY
003_01-05-01 POWER CABLES
004_01-11-01 FRAME & BODY (PART-1)
005_01-11-02 FRAME & BODY (PART-2)
006_01-11-03 FRAME & BODY (PART-3)
007_01-11-04 FRAME & BODY (PART-4)(BATTERY SIDE COVERS)
008_01-11-05 PLUGS NO LIGHTS
009_01-11-06 NO DRAW PIN
010_01-14-01 SEAT ASSEMBLY
011_01-14-02 SEAT ASSEMBLY
012_01-15-01 HEAD GUARD
013_01-20-01 MOTORS
014_01-20-02 9” TRACTION MOTOR
015_01-20-03 8” PUMP MOTOR
016_01-20-04 POWER STEERING MOTOR
017_01-22-01 MOTOR CONTROL
018_01-22-02 TRACTION CONTROL
019_01-23-01 CONTACTOR PANEL
020_01-23-02 CONTACTOR LINE
021_01-23-03 CONTACTOR POWER STEERING
022_01-27-01 TRANSFER ASSY
023_01-31-01 REDUCTION & DIFFERENTIAL
024_01-33-01 FRONT AXLE
025_01-34-01 FRONT AXLE, WHEEL
026_01-43-01 REAR AXLE
027_01-43-02 STEERING CYLINDER
028_01-44-01 REAR TIRE
029_01-46-01 WHEEL BRAKE PIPING
030_01-46-02 WHEEL BRAKE ASSEMBLY
031_01-46-03 MASTER CYLINDER
032_01-51-01 HAND BRAKE
033_01-51-02 ACCELERATOR PEDAL
034_01-51-03 PEDAL ASSY
035_01-54-01 STEERING LINK (CONSOLE)
036_01-54-02 STEERING WHEEL
037_01-54-03 STEER GEAR ASSY
038_01-71-01 PUMP & JOINT
039_01-71-02 HYDRAULIC PUMP
040_01-71-03 POWER STEERING PUMP
041_01-72-01 HYDRAULIC CONTROL HAND LEVER
042_01-72-02 HYDRAULIC CONTROL VALVE-3V
043_01-75-01 HYDRAULIC LINE (PART-1)
044_01-75-02 HYDRAULIC LINE (PART-2)
045_01-75-03 HYDRAULIC LINE (PART-3)
046_01-75-04 HYDRAULIC LINE (PART-4)
047_01-75-05 FLOW REGULATOR VALVE
048_01-81-01 NAME PLATE
049_02-01-01 LIFT BRACKET COMMON PARTS
050_02-01-02 LIFT BRACKET & BACKREST
051_02-04-01 TILT CYLINDERS (FOR 3A15B, 3B15C, 3C15C)
052_02-04-02 WEBER TILT CYLINDERS (FOR 3A15B, 3B15C, 3C15C)
053_02-06-01 FORK (FOR 3A15B, 3B15C, 3C15C)
054_02-10-01 MAST COMMON PARTS (PART-1) (FOR SIMPLEX MAST)
055_02-10-02 MAST COMMON PARTS (PART-2) (FOR SIMPLEX MAST)
056_02-10-03 MAST COMMON PARTS (PART-1) (FOR TRIPLEX MAST)
057_02-10-04 MAST COMMON PARTS (PART-2) (FOR TRIPLEX MAST)
058_02-10-05 MAST COMMON PARTS (PART-3) (FOR TRIPLEX MAST)
059_02-10-06 MAST COMMON PARTS (PART-4) (FOR TRIPLEX MAST)
060_02-10-07 MAST COMMON PARTS (PART-1) (FOR DUPLEX MAST)
061_02-10-08 MAST COMMON PARTS (PART-2) (FOR DUPLEX MAST)
062_02-10-09 MAST COMMON PARTS (PART-3) (FOR DUPLEX MAST)
063_02-18-01 DUPLEX MAST MODEL 3B15C25-40
064_02-18-02 LIFT CYLINDER (2ND) (FOR 3B15C28-40)
065_02-18-03 LIFT CYLINDER (1ST) (FOR 3B15C28-40)
066_02-20-01 TRIPLEX MAST MODEL 3C15C37-70
067_02-20-02 LIFT CYLINDER (1ST) (FOR 3C15C37-70)
068_02-20-03 LIFT CYLINDER (2ND) (FOR 3C15C37-70)
069_02-60-01 SIMPLEX MAST MODEL 3A15B20-60
070_02-60-02 LIFT CYLINDER (FOR 3A15B20-60)
071_03-04-01 LIGHT KIT 2 FWD
072_03-04-02 LIGHT KIT 2 FWD 1 REV
073_03-04-03 12V LAMP
074_03-04-04 STROBE LAMP KIT
075_03-04-05 BACKUP BUZZER KIT
076_03-04-06 DC_DC CONV.
077_03-11-01 REAR VIEW MIRROR KIT
078_03-05-01 TC1350 LIGHT GROUP STOP_TAIL_BACKUP 9040106779
079_03-05-02 TC1350 LIGHT GROUP STOP_TAIL_BACKUP (FOR USE W_O FLOODS) 9040106801
080_03-11-02 DRAW PIN KIT
081_03-11-03 TC1250 GROUP, DRIVE-IN-RACK OVERHEAD GUARD (E6000) 9040110635
082_03-11-04 TC1250 KIT, DRIVE-IN-RACK OVERHEAD GUARD (E6000) 9040110636
083_03-11-05 TC1250 GROUP, DRIVE-IN-RACK OVERHEAD GUARD (E3000) 9040110637
084_03-11-06 TC1250 KIT, DRIVE-IN-RACK OVERHEAD GUARD (E3000) 9040110638
085_03-11-07 TC1250 GROUP, DRIVE-IN-RACK OVERHEAD GUARD (E4000) 9040110639
086_03-11-08 TC1250 KIT, DRIVE-IN-RACK OVERHEAD GUARD (E4000) 9040110640
087_03-11-09 TC1250 GROUP, 4_ LWR D-I-R OHG (E4000) 9040113087
088_03-11-10 TC1250 KIT, 4_ LWR D-I-R OHG (E4000) 9040113088
089_03-11-11 TC3360 60_ HIGH LOAD BACKREST EXTENSION P941D01211
090_03-20-01 MOTORS COVERED
091_03-34-01 KIT, SEMI-WIDE AXLE, ELEC.
092_03-34-02 KIT, SEMI-WIDE AXLE, NON MARKING
093_03-34-03 KIT, DRIVE TIRE, NON-MARKING
094_03-34-04 KIT, DRIVE TIRE SMOOTH
095_03-44-01 STEER TIRE KIT, NON MARKING
096_03-51-01 FOOT DIR CONTROL
097_03-72-01 HYDRAULIC CONTROL VALVE-4V
098_03-75-01 HYDRAULIC CONTROL HAND LEVER-4V
099_SIDE SHIFTER INSTALLATION KIT (OPTION NUMBER_ 93080-00060; 93080-00070)
100_03-76-01 TC3330 INSTALLATION GROUP - 1 FUNCTION CASCADE MAST 9040105013
101_03-76-02 TC3330 INSTALLATION GROUP - 2 FUNCTION MAST 9040105014
102_03-76-03 TC3330 TILT GROUP - 5° F_3° B 9040106674
103_03-76-04 TC3330 TILT GROUP FOR USE WITH QUAD 9040112447
104_MAST PIPING KIT (3-WAY SIMPLEX) (3A15B; 2G15A)
105_Mast piping kit (4-WAY SIMPLEX) MAST MODELS 3A15B20 - 60; 2G15A
106_MAST PIPING KIT (3-WAY DUPLEX) Mast Models 3B15C28 - 40; 2H15A
107_Mast piping kit (4-WAY DUPLEX) (PART-1) Mast Models 3B15C28 - 40; 2H15A
108_Mast piping kit (4-WAY DUPLEX) (PART-2) Mast Models 3B15C28 - 40; 2H15A
109_Mast piping kit (3 & 4-WAY TRIPLEX) (MAST) MAST MODELS 3C15C37 - 70
110_Mast piping kit (4-WAY TRIPLEX) (PART-1) MAST MODELS 3C15C37 - 70; 2J15A
111_Mast piping kit (4-WAY TRIPLEX) (PART-2)
112_STEEL SUPPLY LINES (SIMPLEX MAST) CARRIAGE TO ATTACHMENT MAST MODELS; 3A158
113_STEEL SUPPLY LINES (DUPLEX_TRIPLEX MAST) CARRIAGE TO ATTACHMENT MAST MODELS; 3815C,3C15C
114_QUICK DISCONNECT COUPLER FOR USE WITH STEEL LINES ORDER 1 FOR USE WITH SINGLE FUNCTION OR 2 FOR USE WITH _DUAL FUNCTION
