Caterpillar Forklift DP20 Chassis Mast Options Europe Parts Catalog 98725-24940
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar DP20 Chassis Mast Options Forklift
Region: Europe
Part Number: 98725-24940
Number of Pages: 797 Pages
001_01-01-01 COOLING SYSTEM (PART-1)
002_01-01-02 COOLING SYSTEM (PART-2)
003_01-04-01 ELECTRIC EQUIPMENT
004_01-04-02 CONSOLE BOX (PART-1) (UP TO 1996-07)
005_01-04-03 CONSOLE BOX (PART-2) (UP TO 1996-07)
006_01-04-04 ELECTRIC WIRING
007_01-04-05 CONSOLE BOX (PART-1) (FROM 1996-08)
008_01-04-06 CONSOLE BOX (PART-2) (FROM 1996-08)
009_01-11-01 FRAME
010_01-11-02 BODY (PART-1)
011_01-11-03 BODY (PART-2)
012_01-11-04 SEAT (UP TO 1993-08)
013_01-11-05 SEAT (FROM 1993-09)
014_01-15-01 HEAD GUARD
015_01-23-01 TORQUE-CONVERTER ASSEMBLY
016_01-24-01 TRANSMISSION (PART-1)
017_01-24-02 TRANSMISSION (PART-2)
018_01-24-03 TRANSMISSION (PART-3)
019_01-28-01 CONTROL VALVE
020_01-31-01 REDUCTION AND DIFFERENTIAL
021_01-33-01 FRONT AXLE
022_01-43-01 REAR AXLE (PART-1)
023_01-43-02 REAR AXLE (PART-2)
024_01-46-01 WHEEL BRAKE PIPING
025_01-46-02 WHEEL BRAKE ASSEMBLY (LEFT-HAND) (UP TO 1994-04) (FOR DP20_25_30_35)
026_01-46-03 WHEEL BRAKE ASSEMBLY (RIGHT-HAND) (UP TO 1994-04) (FOR DP20_25_30_35)
027_01-46-04 WHEEL BRAKE ASSEMBLY (LEFT-HAND) (FROM 1994-05) (FOR DP20 AND DP25)
028_01-46-05 WHEEL BRAKE ASSEMBLY (RIGHT-HAND) (FROM 1994-05) (FOR DP20 AND DP25)
029_01-46-06 WHEEL BRAKE ASSEMBLY (LEFT-HAND) (FROM 1996-01) (FOR DP30 AND DP35)
030_01-46-07 WHEEL BRAKE ASSEMBLY (RIGHT-HAND) (FROM 1996-01) (FOR DP30 AND DP35)
031_01-51-01 PEDAL ASSEMBLY
032_01-51-02 HAND BRAKE
033_01-51-03 ACCEL PEDAL
034_01-51-04 DRIVING CONTROL
035_01-54-01 STEERING LINK (PART-1)
036_01-54-02 STEERING LINK (PART-2)
037_01-54-03 STEERING GEAR
038_01-54-04 STEERING WHEEL
039_01-61-01 AIR INTAKE SYSTEM
040_01-62-01 EXHAUST SYSTEM
041_01-64-01 FUEL SYSTEM
042_01-71-01 PUMP AND JOINT
043_01-72-01 HYDRAULIC CONTROL
044_01-72-02 CONTROL VALVE (3 VALVES) (UP TO 1997-06) (FOR DP20, DP25, AND DP30)
045_01-72-03 CONTROL VALVE (3 VALVES) (UP TO 1994-09) (FOR DP35 ONLY)
046_01-72-04 CONTROL VALVE (3 VALVES) (FROM 1997-07) (FOR DP20, DP25, AND DP30)
047_01-72-05 CONTROL VALVE (3 VALVES) (FROM 1994-10) (FOR DP35 ONLY)
048_01-75-01 HYDRAULIC LINE (PART-1)
049_01-75-02 HYDRAULIC LINE (PART-2)
050_01-75-03 HYDRAULIC LINE (PART-3)
051_01-81-01 NAMEPLATE
052_02-00-01 BACKREST
053_02-01-01 LIFT BRACKET (FOR DP20 AND DP25)
054_02-01-02 LIFT BRACKET COMMON PARTS (FOR DP30 AND DP35)
055_02-01-03 LIFT BRACKET (FOR DP30 AND DP35)
056_02-04-01 TILT CYLINDER (FOR DP20 AND DP25)
057_02-04-02 TILT CYLINDER (FOR DP30 AND DP35)
058_02-06-01 FORK (FOR DP20 AND DP25)
059_02-06-02 FORK (FOR DP30 AND DP35)
060_02-10-01 MAST COMMON PARTS (FOR 4V25A20-60)
061_02-10-02 MAST COMMON PARTS (PART-1) (UP TO 1995-12) (FOR 4M25A37-70)
062_02-10-03 MAST COMMON PARTS (PART-2) (UP TO 1995-12) (FOR 4M25A37-70)
063_02-10-04 MAST COMMON PARTS (PART-3) (UP TO 1995-12) (FOR 4M25A37-70)
064_02-10-05 MAST COMMON PARTS (PART-1) (FOR 4F25A27-40)
065_02-10-06 MAST COMMON PARTS (PART-2) (FOR 4F25A27-40)
066_02-10-07 MAST COMMON PARTS (FOR 4V30A AND 4V35A)
067_02-10-08 MAST COMMON PARTS (PART-1) (UP TO 1995-12) (FOR 4M30A AND 4M35A)
068_02-10-09 MAST COMMON PARTS (PART-2) (UP TO 1995-12) (FOR 4M30A AND 4M35A)
069_02-10-10 MAST COMMON PARTS (PART-3) (UP TO 1995-12) (FOR 4M30A AND 4M35A)
070_02-10-11 MAST COMMON PARTS (PART-1) (FOR 4F30A AND 4F35A)
071_02-10-12 MAST COMMON PARTS (PART-2) (FOR 4F30A AND 4F35A)
072_02-10-13 MAST COMMON PARTS (PART-1) (FROM 1996-01) (FOR 4M25B_30B_35B)
073_02-10-14 MAST COMMON PARTS (PART-2) (FROM 1996-01) (FOR 4M25B_30B_35B)
074_02-10-15 MAST COMMON PARTS (PART-3) (FROM 1996-01) (FOR 4M25B_30B_35B)
075_02-10-16 MAST COMMON PARTS (PART-4) (FROM 1996-01) (FOR 4M25B_30B_35B)
076_02-18-01 DUPLEX MAST MODEL 4F25A27-40
077_02-18-02 LIFT CYLINDER (1ST) (FOR 4F25A27-40)
078_02-18-03 LIFT CYLINDER (2ND) (FOR 4F25A27-40)
079_02-18-04 DUPLEX MAST MODEL 4F30A27-40
080_02-18-05 LIFT CYLINDER (1ST) (FOR 4F30A27-40)
081_02-18-06 LIFT CYLINDER (2ND) (FOR 4F30A27-40)
082_02-18-07 DUPLEX MAST MODEL 4F35A27-40
083_02-18-08 LIFT CYLINDER (1ST) (FOR 4F35A27-40)
084_02-18-09 LIFT CYLINDER (2ND) (FOR 4F35A27-40)
085_02-20-01 TRIPLEX MAST (UP TO 1995-12) MODEL 4M25A37-70
086_02-20-02 LIFT CYLINDER (1ST) (UP TO 1995-12) (FOR 4M25A37-70)
087_02-20-03 LIFT CYLINDER (2ND) (UP TO 1995-12) (FOR 4M25A37-70)
088_02-20-04 TRIPLEX MAST (UP TO 1995-12) MODEL 4M30A37-70
089_02-20-05 LIFT CYLINDER (1ST) (UP TO 1995-12) (FOR 4M30A37-70)
090_02-20-06 LIFT CYLINDER (2ND) (UP TO 1995-12) (FOR 4M30A37-70)
091_02-20-07 TRIPLEX MAST (UP TO 1995-12) MODEL 4M35A37-70
092_02-20-08 LIFT CYLINDER (1ST) (UP TO 1995-12) (FOR 4M35A37-70)
093_02-20-09 LIFT CYLINDER (2ND) (UP TO 1995-12) (FOR 4M35A37-70)
094_02-20-10 TRIPLEX MAST (FROM 1996-01) MODEL 4M25B37-70
095_02-20-11 LIFT CYLINDER (1ST) (FROM 1996-01) (FOR 4M25B37-70)
096_02-20-12 LIFT CYLINDER (2ND) (FROM 1996-01) (FOR 4M25B37-70)
097_02-20-13 TRIPLEX MAST (FROM 1996-01) MODEL 4M30B37-70
098_02-20-14 LIFT CYLINDER (1ST) (FROM 1996-01) (FOR 4M30B37-70)
099_02-20-15 LIFT CYLINDER (2ND) (FROM 1996-01) (FOR 4M30B37-70)
100_02-20-16 TRIPLEX MAST (FROM 1996-01) MODEL 4M35B37-70
101_02-20-17 LIFT CYLINDER (1ST) (FROM 1996-01) (FOR 4M35B37-70)
102_02-20-18 LIFT CYLINDER (2ND) (FROM 1996-01) (FOR 4M35B37-70)
103_02-60-01 SIMPLEX MAST MODEL 4V25A20-60
104_02-60-02 LIFT CYLINDER (FOR 4V25A20-60)
105_02-60-03 SIMPLEX MAST MODEL 4V30A20-60
106_02-60-04 LIFT CYLINDER (FOR 4V30A20-60)
107_02-60-05 SIMPLEX MAST MODEL 4V35A20-60
108_02-60-06 LIFT CYLINDER (FOR 4V35A20-60)
109_03-02-01 RADIATOR KIT PLATE FIN TYPE
110_03-02-02 DUST-PROOF RADIATOR KIT
111_03-02-03 RAD. FLUID PILOT KIT
112_03-02-04 HIGH SPEED FAN, 1.2 RATIO
113_03-05-01 RADIATOR KIT FLUID WARNING LIGHT
114_03-05-02 DUST INDICaterpillarOR KIT WARNING LIGHT
115_03-05-03 FRONT TURN SIGNAL KIT
116_03-05-04 REAR WORKING LIGHT KIT
117_03-05-05 WARNING LAMP KIT
118_03-05-06 AMBER STROBE LIGHT KIT
119_03-05-07 BACK-UP BUZZER KIT
120_03-05-08 ALTERNATOR KIT
121_03-11-01 LIFTING EYE KIT
122_03-11-02 HOOK KIT
123_03-11-03 REAR VIEW MIRROR KIT
124_03-24-01 TORQUE CONVERTER FILTER KIT
125_03-34-01 DUST-PROOF BREATHER KIT FRONT AXLE
126_03-34-01P 4 PIECE HEAVY DUTY RIMS-DRIVE TIRES
127_03-34-02P 4 PIECE HEAVY DUTY RIMS-STEER TIRES
128_03-34-02 OPTIONAL DUAL DRIVE TIRE (STANDARD)
129_03-34-03 OPTIONAL DUAL DRIVE TIRE (SOLID SOFT)
130_03-34-04 OPTIONAL DUAL DRIVE TIRE (STANDARD)
131_03-34-05 OPTIONAL DUAL DRIVE TIRE (SOLID SOFT)
132_03-55-01 POWER STEERING CYLINDER BOOT KIT
133_03-62-01 MUFFLER KIT CaterpillarALYTIC
134_03-65-01 UL FUEL CAP KIT
135_03-76-01 DUST-PROOF SEAL KIT GEAR PUMP
136_03-76-02 EXTRA CONTROL VALVE KIT (GP15_35)
137_03-76-03 EXTRA CONTROL VALVE KIT (DP35 ONLY)
138_03-76-04 TILT CYLINDER BOOT KIT 6 DEGREES FORWARD _ 6 DEGREES BACK
139_03-76-05 BOTTLERS TILT CYLINDER KIT - 9 DEGREES FORWARD _ 9 DEGREES BACK
140_03-76-06 TILT CYLINDER BOOT KIT 6 DEGREES FORWARD _ 10 DEGREES BACK
141_03-76-07 DUST-PROOF BREATHER KIT
142_04-42-01 INTERNAL HOSING 3 AND 4 WAY WELDMENTS - SIMPLEX (4V25A20-60)
143_04-42-02 INTERNAL HOSING 4 WAY - SIMPLEX (4V25A20-60)
144_04-42-03 INTERNAL HOSING 3 AND 4 WAY WELDMENTS - SIMPLEX (4V30A20-60)
145_04-42-04 INTERNAL HOSING 4 WAY - SIMPLEX (4V30A20-60)
146_04-42-05 INTERNAL HOSING 4 WAY - SIMPLEX (4V35A20-60)
147_04-22-01 INTERNAL HOSING 3 AND 4 WAY WELDMENTS AND 3 WAY INTERNAL HOSING - DUPLEX (4F25A27-40)
148_04-22-02 INTERNAL HOSING 4 WAY - DUPLEX (4F25A27-40)
149_04-22-03 INTERNAL HOSING 3 AND 4 WAY WELDMENTS AND 3 WAY INTERNAL HOSING - DUPLEX (4F30A27-40)
150_04-22-04 INTERNAL HOSING 4 WAY - DUPLEX (4F30A27-40)
151_04-22-05 INTERNAL HOSING 3 AND 4 WAY WELDMENTS AND 3 WAY INTERNAL HOSING - DUPLEX (4F35A27-40)
152_04-22-06 INTERNAL HOSING 4 WAY - DUPLEX (4F35A27-40)
153_04-62-01 INTERNAL HOSING 3 AND 4-WAY WELDMENTS AND 3-WAY INTERNAL HOSING - TRIPLEX (4M25A37-70)
154_04-62-02 INTERNAL HOSING 4 WAY - TRIPLEX (4M24A37-70)
155_04-62-03 INTERNAL HOSING 3 WAY TRIPLEX B-SERIES (4M25B37-70)
156_04-62-04 INTERNAL HOSING 4 WAY TRIPLEX B-SERIES (4M25B37-70)
157_04-62-05 INTERNAL HOSING 3 AND 4 WAY WELDMENTS AND 3 WAY INTERNAL HOSING - TRIPLEX (4M30A37-70)
158_04-62-06 INTERNAL HOSING 4 WAY - TRIPLEX (4M30A37-70)
159_04-62-07 INTERNAL HOSING 3 WAY TRIPLEX B-SERIES (4M30B37-70)
160_04-62-08 INTERNAL HOSING 4 WAY TRIPLEX B-SERIES (4M30B37-70)
161_04-62-09 INTERNAL HOSING 3 WAY AND 4 WAY WELDMENTS AND 3 WAY INTERNAL HOSING - TRIPLEX (4M35A37-70)
162_04-62-10 INTERNAL HOSING 4 WAY TRIPLEX (4M35A37-70)
163_04-62-11 INTERNAL HOSING 3 WAY TRIPLEX B-SERIES (4M35B37-70)
164_04-62-12 INTERNAL HOSING 4 WAY TRIPLEX B-SERIES (4M35B37-70)
