Caterpillar Excavators 314D CR LCR Parts Manual SEBP4950-01 2008
Brand: Caterpillar
Type of Machine: Excavators
Model: Caterpillar 314D CR ; 314D LCR Excavators
Serial Number: BYJ1-Up ; PDP1-Up
Engine: Caterpillar C4.2 Engine - JKH1-Up
Part Number: SEBP4950-01
Publication Date: 2008
Number of Pages: 905 Pages
Repair Alternatives
Supplemental Coolant Additives
Maintenance Parts
Index
Machine Arrangement
Chassis Ar
General Ar
Engine Arrangement
Engine Ar
Engine Ar-Complete
Installation Ar-Engine
Basic Engine
Camshaft Gp
Cover Gp-Sound Suppression
Cover Gp-Valve Mechanism
Crankshaft Gp
Cylinder Block Gp
Cylinder Head As
Cylinder Head Gp
Flywheel Gp
Gear Gp-Front
Housing Gp-Flywheel
Housing Gp-Front
Mounting Gp-Alternator
Mounting Gp-Engine
Mounting Gp-Starting Motor
Pan Gp-Oil
Piston & Rod Gp
Pulley As-Idler
Pulley Gp-Fan & Alt Drive
Pulley Gp-Idler
Valve Mechanism Gp
Lubrication System
Adapter Gp-Remote Oil Filter
Breather Gp
Filter & Mtg Gp-Engine Oil
Lines Gp-Engine Oil
Lines Gp-Turbocharger Oil
Cooler Gp-Engine Oil
Cooling Ar
Fan Gp-Suction
Lines Gp-Water
Pump Gp-Water
Radiator & Hyd Oil Cooler Gp
Air Inlet And Exhaust System
Air Cleaner Gp
Insulation Gp-Muffler
Lines Gp-Air
Lines Gp-Muffler Drain
Lines Gp-Turbocharger Air
Manifold Gp-Exhaust
Manifold Gp-Inlet
Muffler Gp
Turbocharger Gp
Fuel System
Cap Gp-Fuel Filler
Filter Gp-Fuel
Filter Gp-Water Sep & Fuel
Injector Gp-Fuel
Lines Gp-Fuel
Lines Gp-Fuel Injection
Pump & Mtg Gp-Fuel Transfer
Pump Ar-Fuel Transfer
Pump Gp-Fuel Transfer
Tank & Mtg Gp-Fuel
Tank Gp-Fuel
Valve Gp-Fuel Shutoff
Electrical And Starting System
Alarm Gp
Alarm Gp-Travel
Alternator Gp-Charging
Battery & Wiring Gp
Battery Gp
Block Gp-Junction
Camera Gp
Control & Mtg
Gp-Communication
Control & Mtg Gp-Engine Elek
Control & Mtg Gp-Machine
Control Gp-Communication
Electronics Gpcommunication
Electronics Gp-Machine
Electronics Gp-Monitor
Fastener Gp-Wiring Harness
Installation Ar-Communication
Installation Gp-Communication
Installation Gp-Security
Kit-Bracket
Lamp Gp-Flood
Lighting Gp-Flood
Mounting Gp-Camera
Panel Gp-Circuit Breaker
Panel Gp-Switch
Sensor & Mtg Gp-Position
Sensor Gp-Engine
Sensor Gp-Liquid Level
Sensor Gp-Position
Starting Ar-Cold Weather
Starting Motor Gp-Electric
Switch Gp-Disconnect
Switch Gp-Magnetic
Switch Gp-Position
Switch Gp-Refueling
Switch Gp-Rotary
Switch Gp-Start
Switch Gp-Toggle
Wiring Gp-Aux Start
Receptacle
Wiring Gp-Auxiliary Control
Wiring Gp-Boom
Wiring Gp-Cab
Wiring Gp-Camera
Wiring Gp-Communication
Wiring Gp-Console
Wiring Gp-Control
Wiring Gp-Electronic Control
Wiring Gp-Fan
Wiring Gp-Fine Swing
Wiring Gp-Fuel System
Wiring Gp-Heater
Wiring Gp-Medium Pressure
Wiring Gp-Overload Warning
Wiring Gp-Platform
Power Train
Final Drive Gp
Fastener Gp-Final Drive
Power Train Ar
Sprocket Gp
Frame And Body
Box & Mounting Gp
Box & Mtg Gp-Storage
Box Gp-Fuel Transfer
Box Gp-Storage
Counterweight Gp
Cover As-Access
Cover As-Sound Suppression
Cover Gp-Access
Door Gp-Access
Fender As-Sound Suppression
Fender Gp
Frame Gp-Upper
Gear & Bearing Gp-Swing
Guard Gp-Bottom
Guard Gp-Fender
Guard Gp-Front
Guard Gp-Swivel
Handrail Gp
Hood & Guard Gp
Hood Gp-Engine
Sheet As-Sound Suppression
Step Gp
Storage Gp-Vandalism Guard
Support As-Enclosure
Undercarriage
Frame Ar-Undercarriage
Frame As-Undercarriage
Guard Gp-Track Guide
Guard Gp-Travel Motor
Idler Gp-Front
Link As-Track
Roller Ar-Track
Roller Ar-Track & Carrier
Roller Gp-Track Carrier
Roller Gp-Track-Single Flange
Track Adjuster & Recoil Gp
Track Gp
Accumulator Gp-Hydraulic
Control Ar-Auxiliary
Control Ar-Coupler
Coupling Gp-Flexible
Coupling Gp-Pump
Cylinder & Lines Gp-Blade
Cylinder & Lines Gp-Boom
Cylinder & Lines Gp-Bucket
Cylinder & Lines Gp-Stick
Cylinder & Seal Gp-Blade
Cylinder & Seal Gp-Boom
Cylinder & Seal Gp-Bucket
Cylinder & Seal Gp-Stick
Cylinder Gp-Blade
Cylinder Gp-Boom
Cylinder Gp-Bucket
Cylinder Gp-Coupler
Cylinder Gp-Stick
Drive Gp-Swing
Filter & Lines Gp-Hydraulic
Filter & Valve Gp-Pilot
Filter Ar-Hydraulic
Filter Gp-Oil
Gauge Gp-Sight
Guard Gp-Cylinder
Head Gp-Pump
Hydraulic Ar
Lines Ar-Auxiliary Hydraulic
Lines Ar-Quick Coupler
Lines Gp-Auxiliary Hydraulic
Lines Gp-Blade Cylinder
Lines Gp-Boom
Lines Gp-Boom Cylinder
Lines Gp-Bucket Cylinder
Lines Gp-Control
Lines Gp-Coupler
Lines Gp-Front
Lines Gp-Hydraulic Oil Cooler
Lines Gp-Pilot
Lines Gp-Pump
Lines Gp-Return
Lines Gp-Return & Filter
Lines Gp-Stick
Lines Gp-Stick Cylinder
Lines Gp-Swing Motor
Lines Gp-Travel Motor
Manifold Gp-Control
Motor Gp-Hydraulic
Motor Gp-Piston
Mounting Gp-Lines
Mounting Gp-Valve
Pump & Mtg Gp-Auxiliary
Pump & Mtg Gp-Main Hydraulic
Pump Gp-Piston
Screen Gp-Hydraulic
Spool Gp-Control Valve
Swivel & Mounting Gp
Swivel Gp
Tank & Filter Gp-Hydraulic
Tank & Mtg Gp-Hydraulic
Valve & Mtg Gp-Control
Valve & Mtg Gp-Main Control
Valve Ar
Valve Ar-Alt Pattern Control
Valve Ar-Check & Relief
Valve Ar-Swing
Valve As-Manual
Valve Gp-Bank
Valve Gp-Check
Valve Gp-Control
Valve Gp-Load Control
Valve Gp-Main Control
Valve Gp-Pilot
Valve Gp-Pressure Reducing
Valve Gp-Relief
Valve Gp-Shuttle
Valve Gp-Solenoid
Valve Gp-Solenoid & Press
Redc
Valve Gp-Travel
Counterbalance
Implements
Boom Ar-1 Piece Long
Boom Gp
Installation Ar-Auxiliary
Lines Gp-Grease
Linkage Ar-Bucket
Linkage Gp-Bucket
Stick Ar
Stick Ar-Hoe
Stick Gp-Hoe
Work Tools
Adjuster Gp-Bucket
Blade & Mounting Gp
Blade Gp-Straight
Bucket & Adjuster Gp
Bucket As
Bucket As-Ditch Cleaning
Bucket As-General Purpose
Bucket As-Heavy Duty Rock
Bucket Gp
Bucket Gp-Ditch Cleaning
Coupler Ar-Quick
Coupler Gp-Quick
Edge Gp-Cutting
Pin Gp-Bucket
Pin Gp-Coupler
Sidecutter Gp
Tip Gp-Long
Operator Station
Air Conditioner & Mounting Gp
Air Conditioner Ar
Air Conditioner Gp
Armrest Gp
Bracket Gp-Mirror
Cab Gp
Cab Gp-Enclosed Rops
Compressor Gp-Refrigerant
Condenser & Mtg Gprefrigerant
Condenser Gp-Refrigerant
Console Gp-Operator
Control & Mtg Gp-Joystick
Control & Mtg Gp-Pedal
Control Gp-Blade
Control Gp-Foot
Control Gp-Handle
Control Gp-Hydraulic Pedal
Control Gp-Joystick
Control Gp-Pedal
Control Gp-Pilot Operated
Hyd
Control Gp-Unprgmed Monitor
Cover Gp-Platform
Distributor Gp-Air
Door Gp-Cab
Duct Gp-Cab Air
Floor Mat Gp
Guard Ar-Overhead
Guard Ar-Vandalism
Guard Gp-Front Window
Guard Gp-Overhead
Guard Gp-Vandalism
Guard Gp-Window
Hatch Gp-Roof
Heater & Mtg Gp-Cab
Heater Ar-Cab
Horn Gp-Electric
Installation Ar
Installation Gp-Radio
Lines Gp-Air Conditioner
Lines Gp-Heater
Literature Gp
Mirror Gp-Rear View
Monitor Gp-Operator
Mounting Gp-Platform
Operator Ar
Platform Gp-Operator
Seat Belt Gp
Seat Gp
Seat Gp-Suspension
Support Gp-Seat
Suspension Gp-Seat
Visor Gp-Protection
Washer Gp-Window
Window Gp-Cab
Window Gp-Front
Wiper Gp-Window
Service Equipment And Supplies
Film Gp
Plate & Film Gp
Part Number Index
Brand: Caterpillar
Repair Alternatives
Maintenance Parts
Index
Machine Arrangement
Chassis Ar
General Ar
Engine Arrangement
Engine Ar
Engine Ar-Complete
Basic Engine
Camshaft Gp
Crankshaft Gp
Cylinder Block Gp
Cylinder Head As
Cylinder Head Gp
Flywheel Gp
Gear Gp-Front
Housing Gp-Flywheel
Housing Gp-Front
Mounting Gp-Engine
Pan Gp-Oil
Piston & Rod Gp
Pulley As-Idler
Pulley Gp-Idler
Valve Mechanism Gp
Lubrication System
Breather Gp
Lines Gp-Engine Oil
Cooling Ar
Fan Gp-Suction
Lines Gp-Water
Pump Gp-Water
Air Cleaner Gp
Lines Gp-Air
Manifold Gp-Exhaust
Manifold Gp-Inlet
Muffler Gp
Turbocharger Gp
Fuel System
Cap Gp-Fuel Filler
Filter Gp-Fuel
Injector Gp-Fuel
Lines Gp-Fuel
Tank & Mtg Gp-Fuel
Tank Gp-Fuel
Alarm Gp
Alarm Gp-Travel
Battery & Wiring Gp
Battery Gp
Block Gp-Junction
Camera Gp
Control & Mtg
Gp-Communication
Kit-Bracket
Lamp Gp-Flood
Lighting Gp-Flood
Mounting Gp-Camera
Panel Gp-Switch
Sensor Gp-Engine
Sensor Gp-Position
Switch Gp-Magnetic
Switch Gp-Position
Switch Gp-Refueling
Switch Gp-Rotary
Switch Gp-Start
Switch Gp-Toggle
Wiring Gp-Aux Start
Receptacle
Wiring Gp-Boom
Wiring Gp-Cab
Wiring Gp-Camera
Wiring Gp-Console
Wiring Gp-Control
Wiring Gp-Fan
Wiring Gp-Heater
Wiring Gp-Platform
Power Train
Final Drive Gp
Power Train Ar
Sprocket Gp
Frame And Body
Box & Mounting Gp
Box Gp-Storage
Counterweight Gp
Cover As-Access
Cover Gp-Access
Door Gp-Access
Fender Gp
Frame Gp-Upper
Guard Gp-Bottom
Guard Gp-Fender
Guard Gp-Front
Guard Gp-Swivel
Handrail Gp
Hood & Guard Gp
Hood Gp-Engine
Step Gp
Undercarriage
Idler Gp-Front
Link As-Track
Roller Ar-Track
Track Gp
Control Ar-Coupler
Coupling Gp-Pump
Cylinder Gp-Blade
Cylinder Gp-Boom
Cylinder Gp-Bucket
Cylinder Gp-Coupler
Cylinder Gp-Stick
Drive Gp-Swing
Filter Ar-Hydraulic
Filter Gp-Oil
Gauge Gp-Sight
Guard Gp-Cylinder
Head Gp-Pump
Hydraulic Ar
Lines Gp-Boom
Lines Gp-Control
Lines Gp-Coupler
Lines Gp-Front
Lines Gp-Pilot
Lines Gp-Pump
Lines Gp-Return
Lines Gp-Stick
Manifold Gp-Control
Motor Gp-Hydraulic
Motor Gp-Piston
Mounting Gp-Lines
Mounting Gp-Valve
Pump Gp-Piston
Screen Gp-Hydraulic
Swivel Gp
Valve Ar
Valve Ar-Swing
Valve As-Manual
Valve Gp-Bank
Valve Gp-Check
Valve Gp-Control
Valve Gp-Pilot
Valve Gp-Relief
Valve Gp-Shuttle
Valve Gp-Solenoid
Redc
Valve Gp-Travel
Counterbalance
Implements
Boom Gp
Lines Gp-Grease
Linkage Ar-Bucket
Linkage Gp-Bucket
Stick Ar
Stick Ar-Hoe
Stick Gp-Hoe
Work Tools
Adjuster Gp-Bucket
Blade & Mounting Gp
Blade Gp-Straight
Bucket As
Bucket Gp
Coupler Ar-Quick
Coupler Gp-Quick
Edge Gp-Cutting
Pin Gp-Bucket
Pin Gp-Coupler
Sidecutter Gp
Tip Gp-Long
Operator Station
Air Conditioner Ar
Air Conditioner Gp
Armrest Gp
Bracket Gp-Mirror
Cab Gp
Console Gp-Operator
Control Gp-Blade
Control Gp-Foot
Control Gp-Handle
Control Gp-Joystick
Control Gp-Pedal
Hyd
Cover Gp-Platform
Distributor Gp-Air
Door Gp-Cab
Duct Gp-Cab Air
Floor Mat Gp
Guard Ar-Overhead
Guard Ar-Vandalism
Guard Gp-Overhead
Guard Gp-Vandalism
Guard Gp-Window
Hatch Gp-Roof
Heater & Mtg Gp-Cab
Heater Ar-Cab
Horn Gp-Electric
Installation Ar
Lines Gp-Heater
Literature Gp
Mirror Gp-Rear View
Monitor Gp-Operator
Operator Ar
Seat Belt Gp
Seat Gp
Seat Gp-Suspension
Support Gp-Seat
Suspension Gp-Seat
Visor Gp-Protection
Washer Gp-Window
Window Gp-Cab
Window Gp-Front
Wiper Gp-Window
Film Gp
Plate & Film Gp
Part Number Index
- CAT 416D Parts Manual
- CAT 420D Parts Manual
