705,263
Caterpillar CAT USA REGION DPL40 3CM13251 Spare Parts Catalog
Brand: Caterpillar
Type of Machine: Forklift
Model: DPL40
Serial Number: 3CM13251
Region: USA
List of Files:
CAT FORKLIFT CHASSIS, MAST AND OPTIONS 3CM-00001-99999 98735-71920 411 Pages
CAT FORKLIFT ENGINE S6E 3CM-00001-99999 98731-55900A 87 Pages
CAT FORKLIFT OPTIONS & INTERNAL HOSING 3CM-00001-99995 TEES0004 221 Pages
CAT FORKLIFT S6S DIESEL ENGINE 3CM-00001-99999 98705-56030 111 Pages
CONTENTS:
98735-71920 CAT CHASSIS, MAST AND OPTIONS
OcultarCHASSIS
+COOLING SYSTEM
+ELECTRICAL SYSTEM
+FRAME AND BODY
+POWER LINE
+AXLE
+DRIVING CONTROL
+INTAKE AND EXHAUST SYSTEM
+FUEL SYSTEM
+HYDRAULIC SYSTEM
+NAMEPLATE
OcultarMAST
+LIFT BRACKET
+TILT CYLINDER
+FORK
+MAST COMMON PARTS
+DUPLEX MAST
+TRIPLEX MAST
+SIMPLEX MAST
ExpandirOPTION
OcultarINTERNAL HOSING
03-75-01 INTERNAL HYDRAULICS KIT 3 WAY - SIMPLEX OPTION NUMBER: 3V40A20-60
03-75-02 INTERNAL HYDRAULICS KIT 4 WAY - SIMPLEX OPTION NUMBER: 3V40A20-60
03-75-03 INTERNAL HYDRAULICS KIT 3 WAY - SIMPLEX OPTION NUMBER: 3V45A20-60, 3V50A20-60
03-75-04 INTERNAL HYDRAULICS KIT 4 WAY - SIMPLEX OPTION NUMBER: 3V45A20-60, 3V50A20-60
03-75-05 MAST PIPING KIT 3-WAY SIMPLEX STD 3/8 IN
03-75-06 MAST PIPING KIT 4-WAY SIMPLEX STD 3/8 IN
03-75-07 INTERNAL HYDRAULICS KIT 3 WAY - DUPLEX OPTION NUMBER: 3F40A30-50
03-75-08 INTERNAL HYDRAULICS KIT 3 WAY - DUPLEX OPTION NUMBER: 3F45A26-50
03-75-09 INTERNAL HYDRAULICS KIT 3 WAY - DUPLEX OPTION NUMBER: 3F50A26-50
03-75-10 MAST PIPING KIT 3-WAY DUPLEX STD 3/8 IN MAST, OUTER
03-75-11 MAST PIPING KIT 4-WAY DUPLEX STD 3/8 IN MAST, OUTER
03-75-12 MAST PIPING KIT 3-WAY DUPLEX STD 3/8 IN (Copy)
03-75-13 MAST PIPING KIT 4-WAY DUPLEX STD 3/8 IN (Copy)
03-75-14 INTERNAL HYDRAULICS KIT 3 WAY - TRIPLEX OPTION NUMBER: 3M40A37-70
03-75-15 INTERNAL HYDRAULICS KIT 3 WAY - TRIPLEX OPTION NUMBER: 3M45A37-70
03-75-16 INTERNAL HYDRAULICS KIT 3 WAY - TRIPLEX OPTION NUMBER: 3M50A37-70
03-75-17 MAST PIPING KIT 3-WAY TRIPLEX STD 3/8 IN
03-75-18 MAST PIPING KIT 4-WAY TRIPLEX STD 3/8 IN
ENGINE BODY
01-01 CYLINDER HEAD
04-01 VALVE MECHANISM
04-02 ROCKER COVER and CAMSHAFT
07-01 CRANKCASE ASSY
07-02 CRANKCASE
11-01 TIMING GEAR CASE and TIMING GEAR
13-01 OIL PAN and ENGINE MOUNTING
17-01 PISTON and CONNECTING ROD
20-01 CRANKSHAFT and FLYWHEEL
25-01 AIR COMPRESSOR OP.
OcultarINLET AND EXHAUST SYSTEM
30-01 INLET & EXHAUST SYSTEM
OcultarOIL SYSTEM
35-01 OIL PUMP and OIL STRAINER
40-01 OIL FILTER and BREATHER
OcultarCOOLING SYSTEM
45-01 WATER PUMP
46-01 COOLING SYSTEM
OcultarFUEL SYSTEM
61-01 INJECTION PUMP GENERAL
61-02 FUEL SYSTEM
61-03 INJECTION PUMP
61-04 GOVERNOR
61-05 FEED PUMP (MODEL S6E)
61-06 NOZZLE
62-01 FUEL FILTER
OcultarREPAIR PARTS
94-01 OVERHAUL GASKET KIT
OcultarELECTRICAL SYSTEM
66-01 ELECTRICAL SYSTEM
66-02 STARTER (24V-5kW)
68-01 ALTERNATOR (24V-20A)
68-02 ALTERNATOR (24V-35A) (ENCLOSED)
68-03 ALTERNATOR (24V-50A)
Ocultar
Expandir
Ocultar
MUFFLER KIT CATALYTIC
ELEVATED EXHAUST KIT
EXTRA CONTROL VALVE KIT
INTERNAL HYDRAULICS KIT 3 WAY - SIMPLEX 3V40A20-60
INTERNAL HYDRAULICS KIT 4 WAY - SIMPLEX 3V40A20-60
INTERNAL HYDRAULICS KIT 3 WAY - SIMPLEX 3V45A20-60, 3V50A20-60
INTERNAL HYDRAULICS KIT 4 WAY - SIMPLEX 3V45A20-60, 3V50A20-60
INTERNAL HYDRAULICS KIT 3 WAY - DUPLEX 3F40A30-50
INTERNAL HYDRAULICS KIT 3 WAY - DUPLEX 3F45A26-50
INTERNAL HYDRAULICS KIT 3 WAY - DUPLEX 3F50A26-50
INTERNAL HYDRAULICS KIT 3 WAY - TRIPLEX 3M40A37-70
INTERNAL HYDRAULICS KIT 3 WAY - TRIPLEX 3M45A37-70
INTERNAL HYDRAULICS KIT 3 WAY - TRIPLEX 3M50A37-70
BACK-UP BUZZER KIT
WARNING LAMP KIT AMBER
WARNING LAMP KIT RED
REAR WORKING LIGHT KIT (FOR USE WITH HIGH AIR INTAKE)
DUST-PROOF BREATHER KIT FRONT AXLE
BOOT POWER STEERING KIT
TILT CYLINDER BOOT KIT 6° FORWARD/10° BACK
TILT CYLINDER BOOT KIT 6° FORWARD/6° BACK
DUST-PROOF SEAL KIT
DUST PROOF SEAL
ALTERNATOR KIT GAS SAFETY 35/40
ALTERNATOR KIT DIESEL SAFETY 35/40
ALTERNATOR KIT DIESEL SAFETY 45/50
OIL FILTER KIT
RADIATOR KIT FLUID WARNING LIGHT
DUST-PROOF RADIATOR KIT FOR STANDARD RADIATOR
DUST-PROOF RADIATOR KIT FOR OPTIONAL PLATE FIN RADIATOR
PLATE FIN-TYPE RADIATOR KIT
DUST INDICATOR KIT WARNING LIGHT
ELEVATED AIR INTAKE KIT
BATTERY DISCONNECT SWITCH KIT
LIFTING EYE KIT (CWT)
LIFTING EYE KIT (MAST)
REAR VIEW MIRROR KIT
UL FUEL CAP KIT
03-65-01 LPG FUEL SYSTEM (PART-1)
03-65-02 LPG FUEL SYSTEM (PART-2)
LABEL KIT FRENCH
LABEL KIT FRENCH
LABEL KIT SPANISH
LABEL KIT SPANISH
AIR CLEANER KIT 35/40
03-00-01 DUAL TIRE KIT (PNEUMATIC) 7.5-16 OPTION NUMBER: 91893-03400, 91893-03500, 91893-03600
03-00-02 DUAL TIRE KIT (UNIQUE) 7.50-16 OPTION NUMBER: 91893-03700
03-00-03 SPECIAL DUAL TIRE KIT (PNEUMATIC) 6.50TX15ER OPTION NUMBER: 91893-07100, 91893-07200, 91893-07300
AIR CLEANER KIT 45/50C
ENGINE BODY
01 CYLINDER HEAD
04-02 ROCKER COVER & CAMSHAFT
07-02 REAR PLATE & MAIN METAL
11 TIMING GEAR CASE & TIMING GEAR
13 OIL PAN & OIL LEVEL GAGE
17 PISTON & CONNECTING-ROD
20 CRANKSHAFT & FLYWHEEL
07-01 07-01 CRANKCASE
30 INLET & EXHAUST SYSTEM
OcultarOIL SYSTEM
36 OIL SYSTEM
45 WATER PUMP & THERMOSTAT
OcultarFUEL SYSTEM
61-01 FUEL SYSTEM
61-02 NOZZLE (FOR DP60, 70)
61-03 NOZZLE (FOR DP40, L40, 45, 50, 50C)
61-04 INJECTION PUMP (FOR DP60, 70)
61-05 INJECTION PUMP (FOR DP40, L40, 45, 50, 50C)
61-06 GOVERNOR (FOR DP60, 70)
61-07 GOVERNOR (FOR DP40, L40, 45, 50, 50C)
61-08 FEED PUMP
62 FUEL FILTER
OcultarENGINE ELECTRICAL
66-01 ELECTRIC PARTS
66-02 STARTER (24V-5KW) (FOR DP60, 70)
66-03 STARTER (24V-5KW) (FOR DP40, L40, 45, 50, 50C)
68-01 ALTERNATOR (24V-30A) (FOR STANDARD)
68-02 ALTERNATOR (24V-35A) OP B (FOR DUST PROOF TYPE
68-03 ALTERNATOR (24V-35A) (FOR STANDARD)
68-04 ALTERNATOR (24V-50A) OP A
68-05 ALTERNATOR (24V-35A) OP B (FOR DUST PROOF TYPE
68-06 ALTERNATOR (24V-35A) (FOR STANDARD)
68-07 ALTERNATOR (24V-50A) OP A
OcultarREPAIR PARTS
Ocultar
Expandir
Ocultar
