Hyundai
86
176,834
Caterpillar Backhoe Loader 416F Parts Manual SEBP5963-03 2013
Brand: Caterpillar
Model: Caterpillar 416F Backhoe Loader
Engine: C4.4 3054C Engine
Serial Number: LWT1-Up(Machine), C4Z1-Up(Engine), CRS1-Up(Engine)
Part Number: SEBP5963-03
Publication Date: 2013
Number of Pages: 770 Pages
Repair Alternatives
Supplemental Coolant Additives
Maintenance Parts
Index
Machine Arrangement
Backhoe Ar-Extendable Stick​
Backhoe Ar-Standard Stick​
Chassis Ar​
Cold Weather Ar​
Common Ar​
Drive Ar-Backhoe Loader​
Loader Ar​
Option Ar-Backhoe​
Engine Arrangement
Engine Ar-Complete​
Engine Ar-Primary​
Basic Engine
Camshaft GP​
Cover GP-Valve Mechanism​
Crankshaft GP​
Cylinder Block GP​
Cylinder Head GP​
Drive GP-Fan​
Flywheel GP​
Housing GP-Flywheel​
Housing GP-Front​
Lifting GP-Engine​
Mounting GP-Engine​
Mounting GP-Engine - Xmsn​
Pan GP-Oil​
Piston - Rod GP​
Plug GP-Cylinder Head​
Plug GP-Engine​
Pulley GP-Crankshaft​
Rocker Arm GP​
Valve Mechanism GP​
Lubrication System
Breather GP​
Filler GP-Engine Oil​
Gauge GP-Oil Level - Filler​
Gauge GP-Oil Level (Dipstick)​
Pump GP-Engine Oil​
Connection GP-Water​
Cooler GP-Engine Oil​
Cooler GP-Fltr Base - Eng Oil​
Cooling GP-Supplemental​
Fan GP-Suction​
Lines GP-Power Train Cooler​
Pump GP-Water​
Radiator - Hyd Oil Cooler GP​
Tank - Lines GP-Coolant​
Air Inlet And Exhaust System
Air Cleaner GP​
Cover GP-Inlet Manifold​
Extension GP-Exhaust​
Lines GP-Air​
Muffler GP​
Turbocharger GP​
Fuel System
Control GP-Governor​
Filter GP-Water Sep - Fuel​
Lines GP-Fuel​
Lines GP-Fuel Filter​
Mounting GP-Governor Control​
Pump GP-Fuel Injection​
Pump GP-Fuel Prm - Prim Filter​
Tank GP-Fuel​
Electrical And Starting System
Alternator GP-Charging​
Battery - Wiring GP​
Battery GP​
Electronics GP-Machine​
Glow Plug GP​
Harness As-Alarm​
Harness As-Engine​
Harness As-Platform​
Harness As-Quick Coupler​
Harness As-Wiring​
Heater GP-Jacket Water​
Lamp GP-Flood​
Lamp GP-Warning Beacon​
Lighting GP-Flood - Signal​
Lighting GP-Warning Beacon​
Radio GP-Communication​
Relay GP​
Starting Motor GP-Electric​
Switch GP-All Wheel Drive​
Switch GP-Differential Lock​
Switch GP-Disconnect​
Switch GP-Pressure​
Wiring GP-Air Conditioner​
Wiring GP-Auxiliary​
Wiring GP-Communication​
Wiring GP-Console​
Wiring GP-Engine​
Wiring GP-Heater​
Wiring GP-Kickout - Positioner​
Wiring GP-Platform​
Wiring GP-Quick Coupler​
Wiring GP-Rear​
Wiring GP-Ride Control​
Wiring GP-Transmission Control​
Power Train
Axle GP-Drive - Steering​
Axle GP-Rear​
Case As-Transmission​
Case GP-Transmission​
Differential - Bevel Gear GP​
Differential GP​
Drive GP-Flexible Coupling​
Filler GP-Power Train Oil​
Flange GP-Wheel​
Housing - Flange GP-Axle​
Housing GP-Axle​
Lines GP-Power Train Oil​
Mounting GP-Axle​
Mounting GP-Transmission​
Planetary GP-Final Drive​
Power Train Ar​
Shaft GP-Drive​
Shaft GP-Input​
Shaft GP-Output​
Torque Converter Ar​
Transmission Ar-Direct Drive​
Transmission GP-Direct Drive​
Valve GP-Relief​
Valve GP-Tire​
Wheel - Tire Ar​
Wheel - Tire GP​
Braking System
Control GP-Parking Brake​
Control GP-Service Brake​
Cylinder GP-Brake​
Lever GP-Hand Control​
Axle GP-Front​
Lines GP-Steering​
Pump GP-Metering​
Steering Column GP​
Frame And Body
Box GP-Storage​
Counterweight GP​
Extension GP-Fender​
Fender GP-Front​
Fender GP-Rear​
Floorplate GP​
Frame GP-Loader​
Frame GP-Swing​
Grill GP-Radiator​
Guard GP-Cylinder​
Guard GP-Debris​
Guard GP-Drive Shaft​
Guard GP-Fuel Tank​
Hood - Guard GP​
Hood GP-Engine​
Kit-Fender​
Kit-Guard​
Liner GP-Sound Suppression​
Accumulator GP-Hydraulic​
Accumulator GP-Ride Control​
Control Ar-Coupler​
Control Ar-Ride​
Cylinder - Lines GP-Thumb​
Cylinder GP-Backhoe Bucket​
Cylinder GP-Boom​
Cylinder GP-Coupler​
Cylinder GP-Hydraulic​
Cylinder GP-Lift​
Cylinder GP-Multipurpose Bukt​
Cylinder GP-Stabilizer​
Cylinder GP-Stick​
Cylinder GP-Thumb​
Cylinder GP-Tilt​
Drive - Mtg GP-Pump​
Filter GP-Oil​
Fitting GP-Hydraulic​
Hydraulic Ar​
Kickout - Positioner GP​
Kit-Auxiliary Lines​
Kit-Control Valve​
Kit-Cylinder Cushion​
Kit-Ride Control​
Lines GP-Auxiliary Hydraulic​
Lines GP-Boom Cylinder​
Lines GP-Bucket​
Lines GP-Bucket Cylinder​
Lines GP-Coupler​
Lines GP-Extendable Stick​
Lines GP-Lift - Tilt Cylinder​
Lines GP-Multipurpose Bucket​
Lines GP-Pilot​
Lines GP-Pump​
Lines GP-Quick Coupler​
Lines GP-Return​
Lines GP-Ride Control​
Lines GP-Stabilizer​
Lines GP-Stick​
Lines GP-Swing Cylinder​
Manifold GP-Control​
Manifold GP-Ride Control​
Mounting GP-Cylinder​
Mounting GP-Lines​
Pump - Mtg GP-Hydraulic​
Pump GP-Piston​
Rotating GP-Pump​
Shaft GP-Pump Drive​
Tank - Mtg GP-Hydraulic​
Valve - Mtg GP-Bank​
Valve - Mtg GP-Coupler​
Valve Ar-Bank 2​
Valve Ar-Bank 3​
Valve GP-Bank 2​
Valve GP-Bank 3​
Valve GP-Bank 6​
Valve GP-Bank 7​
Valve GP-Bank 8​
Valve GP-Control​
Valve GP-Pump Control​
Valve GP-Solenoid - Manifold​
Implements
Arm GP-Lift​
Boom GP​
Brace GP-Lift Cylinder​
Guard GP-Boom​
Linkage GP-Backhoe Bucket​
Lock GP-Transport​
Pad - Mtg GP-Stabilizer​
Pad GP-Stabilizer​
Stabilizer GP-Backhoe​
Stick As​
Stick GP​
Stick GP-Hoe​
Work Tools
Adjuster GP-Manual​
Bucket Ar-General Purpose​
Bucket Ar-Multipurpose​
Bucket As-General Purpose​
Bucket As-Hoe​
Bucket GP-General Purpose​
Bucket GP-Hoe​
Bucket GP-Multipurpose​
Bulldozer As​
Clam As-Multipurpose Bucket​
Coupler Ar-Quick​
Coupler GP-Quick​
Edge GP-Cutting​
Fork GP​
Lock GP-Quick Coupler​
Mounting GP-Bucket​
Mounting GP-Fork​
Pin GP-Coupler​
Thumb Ar​
Thumb GP​
Tooth GP-Uni​
Operator Station
Air Conditioner - Mounting GP​
Cab Ar​
Cab Ar-Enclosed Rops​
Cab GP​
Canopy Ar​
Canopy Ar-Open Rops​
Canopy GP-Open Rops​
Compartment GP-Literature​
Compressor GP-Refrigerant​
Condenser - Mtg GP-Refrigerant​
Console GP-Operator​
Control - Mtg GP-Stabilizer​
Control GP-Hydraulic Hand​
Control GP-Hydraulic Pedal​
Control GP-Steering​
Control GP-Transmission​
Cover GP-Wiper Motor​
Door GP-Cab​
Duct GP-Cab Air​
Floor Mat GP​
Heater - Air Conditioner Ar​
Heater - Air Conditioner GP​
Heater Ar-Cab​
Heater GP-Cab​
Installation GP-Radio​
Kit-Cab Window​
Kit-Hydraulic Hand Control​
Latch GP​
Latch GP-Cab Door - Window​
Lever GP-Governor​
Liner GP-Cab​
Lines GP-Heater​
Lines GP-Heater - Air Cond​
Mirror GP-Rear View​
Motor GP-Window Wiper​
Mounting GP-Cab​
Pedal GP-Governor​
Roof GP-Cab​
Seat Belt GP​
Seat GP​
Seat GP-Suspension​
Suspension GP-Seat​
Trim GP-Cab​
Visor GP-Cab​
Window GP-Cab​
Window GP-Door​
Wiper GP-Window​
Service Equipment And Supplies
Film GP​
Film GP-International​
Film GP-U.S.​
Link GP-Shipping​
Lock GP-Vandalism​
Plate - Film GP​
Plate GP-Identification​
Protection GP-Vandalism​
Service GP-Filter​
Transport Ar-Machine​
Transport GP-Machine​
Part Number Index
