Caterpillar Articulated Truck 745C Parts Manual SEBP6806-08
Brand: Caterpillar
Type of Machine: Articulated Truck
Model: Caterpillar 745C Articulated Truck
LFK1-UP (Machine)
TXW1-UP (Engine)
M4Y1-UP (Transmission)
Part Number: SEBP6806-08
Publication Date: 2016
Number of Pages: 1014 Pages
GENERAL INFORMATION
REPAIR ALTERNATIVES
SUPPLEMENTAL COOLANT ADDITIVES
MAINTENANCE PARTS
INDEX
MACHINE ARRANGEMENT
Brand: Caterpillar
LFK1-UP (Machine)
TXW1-UP (Engine)
GENERAL INFORMATION
REPAIR ALTERNATIVES
MAINTENANCE PARTS
INDEX
MACHINE ARRANGEMENT
CHASSIS AR
CHASSIS AR-REAR
COMMON AR
DISTRIBUTION AR
STANDARD AR
ENGINE ARRANGEMENTENGINE AR
ENGINE AR-COMPLETE
ENGINE AR-CORE
BASIC ENGINEADAPTER GP-AUXILIARY DRIVE
BASE GP-VALVE COVER
BELT GP-SERPENTINE
CAMSHAFT GP
COVER GP-CYLINDER BLOCK
COVER GP-FLYWHEEL HOUSING
COVER GP-FRONT HOUSING
COVER GP-VALVE MECHANISM
CRANKSHAFT GP
CYLINDER BLOCK AS
CYLINDER BLOCK GP
CYLINDER HEAD AS
CYLINDER HEAD GP
DAMPER GP
DRIVE GP-PUMP
ENGINE BRAKE GP
FASTENER GP-FRONT HOUSING
FLYWHEEL GP
GEAR GP-FRONT
GEAR GP-REAR
GUARD GP-BELT
HOUSING GP-FLYWHEEL
HOUSING GP-FRONT
KIT-CRANKSHAFT BEARING
KIT-ENGINE GASKET
KIT-REAR COVER GASKET
LIFTING GP-ENGINE
MECHANISM GP-FUEL PUMP & VALVE
MOUNTING GP-ALTERNATOR & COMPR
MOUNTING GP-ENGINE & XMSN
PAN GP-OIL
PANEL GP-SOUND SUPPRESSION
PISTON & ROD GP
PLUG GP-CYLINDER BLOCK
PLUG GP-CYLINDER HEAD
PULLEY GP-CRANKSHAFT
ROCKER ARM GP
SEAL GP-CRANKSHAFT
SUPPORT GP-ENGINE
LUBRICATION SYSTEMBREATHER GP
COVER GP-OIL FILLER
FASTENER GP-OIL PUMP MOUNTING
FILTER & LINES GP-ENGINE OIL
FILTER GP-ENGINE OIL
FUMES DISPOSAL GP
GAUGE GP-OIL LEVEL (DIPSTICK)
LINES GP-ENGINE OIL
LINES GP-ENGINE OIL DRAIN
LINES GP-TURBOCHARGER OIL
PUMP GP-ENGINE OIL
COOLING SYSTEMBASE GP-OIL COOLER & FILTER
BONNET GP-OIL COOLER
COOLER GP-ENGINE OIL
COVER GP-WATER PUMP
ENCLOSURE GP-RADIATOR
FAN GP-SUCTION
HOUSING & REGULATOR GP
LINES GP-COOLANT
LINES GP-WATER
MOTOR & MTG GP-HYDRAULIC FAN
PLUG GP-WATER LINES
PUMP GP-WATER
RADIATOR AR
RADIATOR GP
SHROUD GP-RADIATOR
TANK GP-COOLANT
AIR INLET AND EXHAUST SYSTEMAFTERCOOLER GP-AIR
AIR CLEANER GP
BRACKET GP-MOUNTING
BRACKET GP-SUPPORT
ELBOW GP-AIR INLET
EXHAUST AR
EXHAUST AR-BODY
EXHAUST GP
KIT-TURBOCHARGER GASKET
LINES GP-AIR
MANIFOLD GP-EXHAUST
MUFFLER GP
PLATE GP-MOUNTING
SUPPORT GP-AFTERCOOLER
TURBOCHARGER GP
VALVE GP-SOLENOID
FUEL SYSTEMBASE GP-FUEL FILTER
FILTER GP-FUEL
FILTER GP-WATER SEP & FUEL
INJECTOR GP-FUEL
KIT-INJECTOR
LINES GP-FUEL
MOUNTING GP-CONTROL
MOUNTING GP-FUEL FILTER
MOUNTING GP-PUMP
PUMP GP-FUEL INJECTION
PUMP GP-FUEL PRIMING
PUMP GP-FUEL PRM & WATER SEP
PUMP GP-FUEL TRANSFER
REGULATOR GP-FUEL PRESSURE
TANK & MTG GP-FUEL
TANK AR-FUEL
TANK GP-FUEL
VALVE GP-CHECK
VALVE GP-FLUID SAMPLING
ELECTRICAL AND STARTING SYSTEMALARM GP
ALTERNATOR GP-CHARGING
APPLICATION GP-MONITOR
BATTERY & WIRING GP
BATTERY GP
BLOCK GP-JUNCTION
CAMERA GP
CONNECTION GP-ELECTRICAL
CONTROL & MTG GP-ENGINE ELEK
CONTROL GP-COMMUNICATION
CONTROL GP-ELECTRONIC
CONTROL GP-UNPROGRAMMED
ELECTRICAL AR
ELECTRONICS GP-COMMUNICATION
ELECTRONICS GP-MONITOR
HARNESS AS-CAB
HARNESS AS-CHASSIS
HARNESS AS-CONTROL
HARNESS AS-ENGINE
HARNESS AS-FRONT
HARNESS AS-FRONT CHASSIS
HARNESS AS-LIGHTING
HARNESS AS-MONITOR
HARNESS AS-MOTOR
HARNESS AS-PANEL
HARNESS AS-RADIO
HARNESS AS-REAR
HARNESS AS-REAR LIGHTING
HARNESS AS-SENSOR
HARNESS AS-SWITCH
HARNESS AS-TRANSMISSION
HARNESS AS-WINDOW WIPER
HARNESS AS-WIRING
HEATER GP-JACKET WATER
INSTALLATION AR-COMMUNICATION
INSTALLATION GP-SECURITY
LAMP GP-FLOOD
LAMP GP-HEAD & SIGNAL
LAMP GP-PAYLOAD SIGNAL
LAMP GP-SIGNAL
LAMP GP-WARNING BEACON
LIGHTING GP-CAB
LIGHTING GP-WARNING BEACON
MOUNTING GP-SENSOR
MOUNTING GP-WIRING
PANEL GP-CIRCUIT BREAKER
PLATE AS-BRUSH
RADIO GP-COMMUNICATION
SENDER GP-FUEL LEVEL
SENSOR GP-COOLANT LEVEL
SENSOR GP-ENGINE
SENSOR GP-LIQUID LEVEL
SENSOR GP-PRESSURE
SENSOR GP-SPEED
SENSOR GP-TEMPERATURE
STARTING AID GP-ETHER
STARTING AR
STARTING MOTOR GP-ELECTRIC
SWITCH GP-DISCONNECT
SWITCH GP-MAGNETIC
SWITCH GP-PRESSURE
SWITCH GP-START
VALVE GP-ETHER STARTING
WARNING GP-BACKUP
WIRING GP-ALTERNATOR
WIRING GP-CAB
WIRING GP-CONTROL
WIRING GP-ELECTRONIC CONTROL
WIRING GP-FRONT
WIRING GP-HITCH
WIRING GP-LIGHTING
WIRING GP-PAYLOAD
WIRING GP-PAYLOAD CONTROL
WIRING GP-PAYLOAD SENSOR
WIRING GP-REAR
WIRING GP-REAR AXLE
WIRING GP-SENSOR
WIRING GP-UNIT INJECTOR
POWER TRAINACCUMULATOR GP
ADAPTER GP-MOUNTING
AXLE AR-CENTER
AXLE AR-FRONT
AXLE AR-REAR
AXLE GP-CENTER
AXLE GP-FRONT
AXLE GP-REAR
BREATHER GP-POWER TRAIN
CASE & PARTS GP-PLANETARY
CASE GP-TRANSFER
CONTROL GP-DIFFERENTIAL LOCK
CONTROL GP-TRANSMISSION HYD
DIFFERENTIAL & BEVEL GEAR GP
DIFFERENTIAL GP
FILLER GP-POWER TRAIN OIL
FILTER GP-OIL
GEAR GP-OUTPUT TRANSFER
HOUSING GP-TORQUE CONVERTER
LINES GP-POWER TRAIN COOLER
LINES GP-TRANSMISSION OIL
MOUNTING GP-FILTER
MOUNTING GP-TRANSFER GEAR
MOUNTING GP-TRANSMISSION
PAN GP-TRANSMISSION OIL
PLANETARY GP-TRANSFER GEAR
PLANETARY GP-TRANSMISSION
POWER TRAIN AR
PUMP & MTG GP-TRANSFER GEAR
PUMP GP-GEAR
RIM GP-DEMOUNTABLE
SHAFT GP-DRIVE
SHAFT GP-REAR DRIVE
TIRE & RIM AR
TIRE & RIM GP
TORQUE CONVERTER GP
TRANSMISSION AR
UNIVERSAL JOINT GP
VALVE GP-SOLENOID
VALVE GP-TIRE
WHEEL GP-FINAL DRIVE & BRAKE
YOKE GP
FRAME AND BODYBAFFLE GP-RADIATOR
BODY AR-TRUCK
BODY GP-TRUCK
BRACKET GP-MOUNTING
BUFFER GP-DUMP BODY
COVER GP-ACCESS
COVER GP-RADIATOR
ENCLOSURE AR
EXTENSION GP-FENDER
FENDER & SUPPORT GP
FENDER GP
FRAME AR-REAR
FRAME GP-FRONT
FRAME GP-REAR
GUARD GP-AXLE
GUARD GP-CRANKCASE
GUARD GP-HYDRAULIC TANK
GUARD GP-MUD
GUARD GP-PLATFORM
GUARD GP-RADIATOR
HITCH GP
HITCH GP-OSCILLATING
HOOD GP-ENGINE
KIT-FRAME
LINER GP-BODY
LINES GP-AUTOMATIC LUBRICATION
LINES GP-GREASE
LUBRICATION AR-AUTOMATIC
LUBRICATION AR-MANUAL
MOUNTING GP-SUSPENSION
MOUNTING GP-TRUCK BODY
PANEL GP-FENDER
PUMP & MTG GP-LUBRICATION
PUMP GP-LUBRICATION
SHIELD AR-FENDER
SHIELD GP-FENDER
STEP GP
STOP GP-STEERING
SUPPORT GP-HITCH LINES
SUPPRESSION AR-SOUND
SUPPRESSION GP-SOUND
SUSPENSION AR
TAILGATE AR
TILT GP-HOOD
VALVE GP-LUBE DISTRIBUTION
WALKWAY GP
BRAKING SYSTEMACCUMULATOR GP-BRAKE
ACCUMULATOR GP-HYDRAULIC
BRAKE GP-PARKING
BRAKE GP-SERVICE
CONTROL GP-PARKING BRAKE
CONTROL GP-SERVICE BRAKE
LINES GP-BRAKE
LINES GP-BRAKE COOLING
LINES GP-PUMP
LINES GP-SERVICE BRAKE
VALVE GP-SOLENOID
STEERING SYSTEMCONTROL GP-STEERING
CYLINDER GP-STEERING
LINES GP-STEERING
PUMP & MOTOR GP-SEC STEERING
PUMP & MTG GP-SECONDARY STEER
PUMP GP-METERING
STEERING COLUMN GP-ADJUSTABLE
HYDRAULIC SYSTEMCONTROL GP-HOIST
COVER GP-HYDRAULIC TANK
CYLINDER & MTG GP-HOIST
CYLINDER GP-HOIST
CYLINDER GP-HYDRAULIC
HYDRAULIC AR
LINES GP-DRAIN
LINES GP-HOIST
LINES GP-HYDRAULIC FAN
LINES GP-PILOT
LINES GP-PRESSURE TEST
LINES GP-PUMP
LINES GP-RETURN
MANIFOLD GP-CONTROL
MOTOR & MOUNTING GP
PIN GP-CYLINDER
PUMP & MTG GP-HYDRAULIC FAN
PUMP & MTG GP-PISTON
PUMP GP-GEAR
PUMP GP-PISTON
ROTATING GP-PUMP
TANK & MTG GP-HYDRAULIC
TANK GP-HYDRAULIC
VALVE & MTG GP-HOIST CONTROL
VALVE & MTG GP-MAIN CONTROL
VALVE GP-CONTROL
VALVE GP-MAIN CONTROL
VALVE GP-PRESSURE REDUCING
VALVE GP-PUMP CONTROL
VALVE GP-SOLENOID
SUSPENSION SYSTEMCYLINDER GP-SUSPENSION
FRAME GP-CENTER SUSPENSION
FRAME GP-FRONT SUSPENSION
FRAME GP-REAR SUSPENSION
SUSPENSION GP-REAR EQUALIZER
OPERATOR STATIONADJUSTER GP-SEAT
AIR CONDITIONER & MOUNTING GP
AIR CONDITIONER GP
ARMREST GP
CAB AR
CAB GP
COIL GP-HEATER
COMPRESSOR GP-REFRIGERANT
CONTROL GP-XMSN & HOIST
CYLINDER GP-CAB TILT
DISPLAY GP-CAMERA
DOOR GP-CAB
GUARD GP-WINDOW
INSTALLATION GP-RADIO
KIT-SEAT CUSHION
LINER GP-CAB
LINES GP-AIR CONDITIONER
LINES GP-HEATER
MIRROR GP-REAR VIEW
MONITOR AR-PAYLOAD
MOTOR GP-WINDOW WIPER
MOUNTING GP-CAB
MOUNTING GP-CAB PANEL
MOUNTING GP-RADIO
MOUNTING GP-ROPS
PAN GP-DRAIN
PANEL GP-CAB
PEDAL GP-BRAKE
PEDAL GP-GOVERNOR
PLUG GP
PUMP GP-CAB TILT
RADIO GP
ROPS GP
SEAT & MOUNTING GP
SEAT BELT GP
SEAT GP
SEAT GP-COMPANION
SEAT GP-SUSPENSION
SUSPENSION GP-SEAT
TILT GP-PLATFORM
VISOR GP-CAB
WINDOW GP
WINDOW GP-CAB
WIPER & WASHER GP-WINDOW
SERVICE EQUIPMENT AND SUPPLIESCOVER GP-SHIPPING
FILM GP
KIT-GASKET
PLATE & FILM GP
PART NUMBER INDEX
- CAT 416D Parts Manual
- CAT 420D Parts Manual
