CAT Uninterruptible Power Supplies UPS120 - UPS900 Systems Operation RENR9988-03
Brand: Caterpillar
Type of Machine: Uninterruptible Power Supplies
Type of Manual: Systems Operation
Model: CAT Uninterruptible Power Supplies
UPS 120, UPS 150, UPS 250, UPS 300, UPS 301, UPS 500, UPS 600, UPS 750 and UPS 900
Part Number: RENR9988-03
Number of Pages: 788 Pages
24V Power Supply (Flywheel Cabinet) 1
Troubleshooting 1
24V Power Supply (MMS System Cabinet)
AC Interface PWA (Flywheel Cabinet)
AC Interface PWA (MMS System Cabinet)
AC Output Current - Calibrate
AC Voltage - Calibrate
APS Controller PWA
Abbreviations and Acronyms
Additional UPS Concepts
Air Filter Element - Clean Replace
Basic Circuit Theory
Battery - Replace
Bearing (3.5 EVD or Greater) - Replace
Bearing (Earlier) - Replace
Bearing Retainer - Remove and Install
Bypass Static Switch (MMS System Cabinet)
Calibration Procedure for EVD Bearing
Calibration Procedure for Non-EVD Bearing
Changing Parameters
Circuit Breaker (K3)
Circuit Voltage
Controller Board Battery - Replace
Current Transformers (Primary, Secondary)
DC Bus Capacitor - Remove and Install
DC Bus Capacitor - Replace
DC Bus Voltage - Calibrate
Door
Door Latch
Door Pull and Retaining Ring
EPO Reset Switch (Flywheel Cabinet)
EPO Reset Switch (MMS System Cabinet)
Electrical Connections
Electrical Measurement
Electricity - How It Works
Emergency Power Off - Reset
Error Log - Access
Ethernet - Configure
External Source Sync Relay and Terminal Block
Fan (Flywheel Cabinet)
Fan (Input-Output Cabinet)
Fan (MMS System Cabinet)
Fan Monitor PWA (Flywheel Cabinet)
Fan Monitor PWA (MMS System Cabinet)
Fan Transformer
Field Coil Driver
Firmware - Update
Flywheel - Clean
Flywheel Assembly
Flywheel Bearing - Replace
Flywheel Contactor (K1, K2)
Flywheel Field Coil Current - Calibrate
Flywheel Interface PWA
Flywheel Inverter Assembly
Flywheel Load Cell - Calibrate
Flywheel Preheat Modes
Flywheel Telemetry - Calibrate
Flywheel Transformer
Foreword
Front Panel Display (Flywheel Cabinet)
Front Panel Display (MMS System Cabinet)
Front Panel Overview
Front Screen and Air Filter
Fuse (Flywheel Cabinet)
GENERAL INFORMATION
Gen Set Module Circuit Breaker
Gen Set Module Circuit Breaker (Input Output Cabinet)
General Information (Flywheel Cabinet)
General Purpose Interface PWA (Flywheel Cabinet)
General Purpose Interface PWA (MMS System Cabinet)
Getting Started
Hardware Revision - Version 3.0 Design
Initial Startup Procedure
Inspection and Cleaning Procedure For Certain Uninterruptible Power Supplies{4480}
Internal Component Preremoval Steps (Flywheel Cabinet)
Log File - Retrieve
MMU Messages
MOV Surge Protector
Magnetism
Maintenance Interval Schedule
Menus
Modbus Network - Setup
Modbus Register Map
Model View Illustrations - Illustrations of the Cabinets and Multiple Module Units
Modem (MMS System Cabinet)
Modem (SMS Bypass Cabinet)
Modem - Configure
Modes Of Operation
O-Ring Seals - Install - RADIAL, FITTING ASSEMBLY O-RINGS & OTHER O-RING APPLICATIONS
Ohms Law
Oil - Change
Oil Level - Check
Operating Environment - And Its Effect On SR4 Generators
Operating Parameters - Set
Operating Parameters Menu
Pager Configuration
Parallel Operation
Personal Computer to UPS Connection
Power Distribution PWA (Flywheel Cabinet)
Power Distribution PWA (MMS System Cabinet)
Receiving and Handling
Remote Input Output Dry Contact - Setup
Remote Notification - Setup
Rotor Position Sensor - Adjust
Rotor Position Sensor - Calibrate
Rotor Position Sensor Assembly
SKiiP Interface PWA
Safety Signs and Labels
Service Connections
Service tools
Short Blocks
Sight Gauge - Clean
Site Preparation
Software Installation
Specifications
Starting System
Static Drain - Install
Storage
System Bypass Operation
System Configuration
System Fuse (SMS Bypass Cabinet)
System Fuses (MMS System Cabinet)
System I-O Module
System IO Daughter PWA (Flywheel Cabinet)
System IO Daughter PWA (MMS System Cabinet)
System IO PWA (Flywheel Cabinet)
System IO PWA (MMS System Cabinet)
System Operational Modes
System Output Current - Calibrate
System Overview
System Shutdown
System Shutdown (SMS) - Single Module System
System Startup
System Startup (MMS) - Multiple Module System
System Startup (SMS) - Single Module System
System Voltage - Calibrate
Telemetry Parameters
Transfer to Bypass Mode (SMS)
Transformer (T1 to T3)
Transformer Voltage Setup
Troubleshooting
UPS Operating Parameters
UPS View Commands and Hot Keys
User Interface for Multiple Module Unit
User Interface for System Cabinet
Using Computer Software
Using the 149-4935 Measuring Group on A6, A7, and A8 Rexroth Hydraulic Pump and Motor Groups{0784}
Utility Inverter Assembly
Vacuum Gauge
Vacuum Pump
Vacuum Pump Oil - Change
Vacuum Pump Startup - Required Procedures After Extended Storage
Vibration Sensor - Calibrate
Wireway
Zig Zag Circuit Breaker (MMS System Cabinet)
Zig Zag Circuit Breaker (SMS Bypass Cabinet)
Zig Zag Contactor (MMS System Cabinet)
Zig Zag Contactor (SMS Bypass Cabinet)
Zig Zag Controller PWA (MMS System Cabinet)
Zig Zag Controller PWA (SMS Bypass Cabinet)
Zig Zag Overload Relay (MMS System Cabinet)
Zig Zag Overload Relay (SMS Bypass Cabinet)
Zig Zag Thyristor (MMS System Cabinet)
Zig Zag Transformer (MMS System Cabinet)
Zig Zag Transformer (SMS Bypass Cabinet)
Brand: Caterpillar
Troubleshooting 1
APS Controller PWA
Battery - Replace
Changing Parameters
Circuit Voltage
Door
Door Latch
Error Log - Access
Fan Transformer
Field Coil Driver
Firmware - Update
Flywheel - Clean
Flywheel Assembly
Foreword
GENERAL INFORMATION
Getting Started
Log File - Retrieve
MMU Messages
MOV Surge Protector
Magnetism
Menus
Modbus Register Map
Modem - Configure
Modes Of Operation
Ohms Law
Oil - Change
Oil Level - Check
Pager Configuration
Parallel Operation
SKiiP Interface PWA
Service Connections
Service tools
Short Blocks
Sight Gauge - Clean
Site Preparation
Specifications
Starting System
Storage
System I-O Module
System Overview
System Shutdown
System Startup
Troubleshooting
Vacuum Gauge
Vacuum Pump
Wireway
- CAT 416D Parts Manual
- CAT 420D Parts Manual
