CAT Track-Type Tractor D9R Parts Manual SEBP4196
Brand: Caterpillar
Type of Machine: Track-Type Tractor
Model: CAT D9R Track-Type Tractor
Serial Number: WDM1-Up (Machine)
48W42331 -Up (Engine)
6KX1-Up (Transmission)
9MP1-Up (Bulldozer)
9RP1- Up (Bulldozer)
T9H1- Up (Bulldozer)
T9J1- Up (Bulldozer)
5RP1- Up (Ripper)
7HP1- Up (Ripper)
6ZT1- Up (Torque Converter)
Part Number: SEBP4196
Publication Date: 2005
Number of Pages: 846 Pages
Back to Main Menu
Parts Manual
GENERAL INFORMATION
REPAIR ALTERNATIVES
SUPPLEMENTAL COOLANT ADDITIVES
MAINTENANCE PARTS
INDEX
INDEX (French)
INDICE (Spanish)
ÍNDICE (Portuguese)
STICHWORTVERZEICHNIS (German)
MACHINE ARRANGEMENT
CHASSIS AR
COLD WEATHER AR
GENERAL AR
MACHINE AR-COLD WEATHER
MACHINE AR- HIGH AMBIENT TEMP
ENGINE ARRANGEMENT
ENGINE AR
INSTALLATION AR- ENGINE
BASIC ENGINE
BELT TIGHTENER GP
CAMSHAFT GP
COVER GP- CYLINDER BLOCK
COVER GP- FLYWHEEL HOUSING
COVER GP- FRONT HOUSING
COVER GP- VALVE MECHANISM
CRANKSHAFT AS
CRANKSHAFT GP
CYLINDER BLOCK AS
CYLINDER BLOCK GP
CYLINDER HEAD AS
CYLINDER HEAD GP
DAMPER & PULLEY GP
DRIVE GP- FAN
FLYWHEEL GP
GEAR GP- FRONT
GEAR GP- REAR
HOUSING GP- FLYWHEEL
HOUSING GP- FRONT
LIFTING GP- ENGINE
PAN GP- OIL
PISTON & ROD GP
PULLEY- ALTERNATOR
ROCKER ARM GP
SUPPORT GP- ENGINE
TRUNNION GP- ENGINE
VALVE MECHANISM GP
YOKE GP
LUBRICATION SYSTEM
BREATHER GP
FASTENER GP- OIL PUMP MOUNTING
FILLER GP- ENGINE OIL
FILTER GP- ENGINE OIL
FUMES DISPOSAL GP
GAUGE GP- OIL LEVEL (DIPSTICK)
LINES GP- ENGINE OIL
LINES GP- TURBOCHARGER OIL
OIL CHANGE GP- HIGH SPEED
PRELUBRICATION AR- ENGINE
PUMP GP- ENGINE OIL
COOLING SYSTEM
FAN & GRID AR
FAN GP- BLOWER
FAN GP- REVERSIBLE
LINES GP- AFTERCOOLER WATER
LINES GP- WATER
PUMP GP- WATER
RADIATOR AR
RADIATOR GP
TANK GP- COOLANT
TANK GP- WATER
AIR INLET AND EXHAUST SYSTEM
AFTERCOOLER GP- WATER
AIR CLEANER GP
CARTRIDGE GP- TURBOCHARGER
DUST EJECTOR GP
INDICATOR GP- AIR FILTER CHANGE
LINES GP- AIR
MANIFOLD GP- EXHAUST
MUFFLER GP
PRECLEANER AR
SHIELD GP- MANIFOLD
TURBOCHARGER GP
FUEL SYSTEM
ADAPTER GP- FAST FILL FUEL
CONTROL GP- FUEL RATIO
CONTROL GP- GOVERNOR
DRIVE GP- GOVERNOR & FUEL PUMP
DRIVE GP- TACHOMETER
FASTENER GP- FUEL INJ PUMP
FILTER & LINES GP- FUEL
FILTER GP- FUEL
FILTER GP- WATER SEP & FUEL
GOVERNOR GP
HOUSING GP- FUEL PUMP
LINES GP- FUEL DRAIN
LINES GP- FUEL FILTER
LINES GP- FUEL INJECTION
PLATE GP- GOVERNOR ADAPTER
PUMP GP- FUEL INJECTION
PUMP GP- FUEL TRANSFER
PUMP GP- GOV, FUEL INJ & TFR
TANK GP- FUEL
TORQUE CONTROL GP
ELECTRICAL AND STARTING SYSTEM
ALARM GP
ALTERNATOR GP- CHARGING
BATTERY & WIRING GP
BATTERY GP
BLOCK GP- JUNCTION
BLOCK GP- POWER
CONNECTION GP- ELECTRICAL
CONVERTER GP- ELECTRICAL
FASTENER AS
HEATER GP- FUEL
HEATER GP- JACKET WATER
LAMP GP- DOME
LAMP GP- FLOOD
LIGHTING GP- FLOOD
SENSOR GP- FUEL LEVEL
SENSOR GP- PRESSURE
SENSOR GP- SPEED
SENSOR GP-TEMPERATURE
STARTING AID GP- ETHER
STARTING AR- COLD WEATHER
STARTING MOTOR GP- ELECTRIC
SWITCH GP- BYPASS
SWITCH GP- DISCONNECT
SWITCH GP- FLOW
SWITCH GP- HANDLE
SWITCH GP- MAGNETIC
SWITCH GP- PUSH BUTTON
SWITCH GP- START
WIRING GP- CONSOLE
WIRING GP- PLATFORM
POWER TRAIN
AXLE GP- POWER TRAIN
CASE & PARTS GP- PLANETARY
CONTROL GP- TRANSMISSION
CONTROL GP- TRANSMISSION HYD
COOLER GP- TRANSMISSION OIL
COUPLING GP- PUMP
DRAIN GP-ECOLOGY
FILTER GP- OIL
FINAL DRIVE GP
GEAR GP- BEVEL & TRANSFER
GUARD GP- DRIVE SHAFT
LINES GP- POWER TRAIN OIL
MOUNTING GP- TRANSMISSION
PLANETARY GP- TRANSMISSION
POWER TRAIN AR
PUMP GP- GEAR
SEGMENT GP- SPROCKET
SHAFT GP- DRIVE
TORQUE CONVERTER GP
TRANSMISSION AR
UNIVERSAL JOINT GP
VALVE GP- PRIORITY
VALVE GP- RELIEF
VALVE GP- SELECTOR & PRESS CONT
FRAME AND BODY
CASE & FRAME GP
COUNTERWEIGHT GP
COVER GP- TRUNNION
DOOR GP- ACCESS
DRAWBAR GP
ENCLOSURE GP- ENGINE
ENCLOSURE GP- LH
ENCLOSURE GP- RH
FENDER GP
FLOORPLATE AR
GRID GP- SAND BLAST ERODING
GUARD GP- BOTTOM
GUARD GP- IDLER
GUARD GP- PIVOT SHAFT
GUARD GP- RADIATOR
GUARD GP- ROCK
GUARD GP- VANDALISM
HOOD & GUARD GP
LATCH GP
UNDERCARRIAGE
BAR AS- EQUALIZER
BAR GP- EQUALIZER
CAP GP- TRACK IDLER
CAP GP- TRACK ROLLER
FRAME GP- TELESCOPING RECOIL
IDLER GP- TRACK
LINK AS- TRACK
LUBRICATION GP- PIVOT SHAFT
ROLLER & IDLER AR
ROLLER AR- TRACK CARRIER
ROLLER GP- TRACK- DOUBLE FLANGE
ROLLER GP- TRACK- SINGLE FLANGE
SHOE- TRACK
SUSPENSION GP- BOGIE
TRACK ADJUSTER & RECOIL GP
TRACK GP
UNDERCARRIAGE AR
STEERING AND BRAKING SYSTEM
CLUTCH & BRAKE GP- STEERING
CONTROL GP- STEER CLUTCH & BRK
VALVE GP- STEERING & BRAKE CONT
HYDRAULIC SYSTEM
CONTROL AR- HYD PIN PULLER
CONTROL AR- HYDRAULIC
CONTROL AR-HYDRAULIC IMPLEMENT
COVER GP- HYDRAULIC TANK CAP
CYLINDER & LINES GP- LIFT
CYLINDER & LINES GP-RIPPER
CYLINDER AR- TILT
CYLINDER GP- LIFT
CYLINDER GP- RIPPER
CYLINDER GP- RIPPER PIN PULLER
CYLINDER GP- RIPPER TIP
CYLINDER GP- TILT
LEVER GP- CONTROL VALVE
LINES GP- LIFT CYLINDER
LINES GP- PIN PULLER
LINES GP-PIN PULLER CYLINDER
LINES GP- PUMP
LINES GP- RIPPER
LINES GP- TILT CYLINDER
MANIFOLD GP- VALVE
MOUNTING GP- CYLINDER
PUMP GP- PISTON
ROTATING GP- PUMP
TANK & FILTER GP- HYDRAULIC
VALVE & MTG GP- CONTROL
VALVE GP- BANK 4
VALVE GP- CHECK
VALVE GP- CONTROL
VALVE GP- PUMP CONTROL
VALVE GP- QUICK- DROP
VALVE GP- RELIEF
VALVE GP- SHUTTLE
VALVE GP- SOLENOID
VALVE GP- TILT CONTROL
IMPLEMENTS
BULLDOZER AR
BULLDOZER AR-SEMI- UNIVERSAL
BULLDOZER AR- UNIVERSAL
LINK GP- STABILIZER
LINKAGE GP- IMPLEMENT
MODIFICATION AR- BULLDOZER
PUSH ARM GP
PUSH ARM GP- STABILIZER
TRUNNION GP- BULLDOZER
WORK TOOLS
BLADE & EDGE GP- SEMI- UNIVERSAL
BLADE & EDGE GP-UNIVERSAL
BLADE AS- SEMI- UNIVERSAL
BLADE AS- UNIVERSAL
BLADE GP- UNIVERSAL
EDGE GP- BIT & CUTTING
FRAME GP- RIPPER
MOUNTING GP- RIPPER
PLATE GP- WEAR
PULLER AR-PIN
PULLER GP- PIN
RIPPER AR
RIPPER GP
TOOTH GP- RIPPER
TOOTH GP- RIPPER
OPERATOR STATION
ADJUSTER GP- SEAT
AIR CONDITIONER AR
AIR CONDITIONER GP
CAB AR
CAB GP
COMPRESSOR GP- REFRIGERANT
CONDENSER & MTG GP- REFRIGERANT
CONDENSER GP- REFRIGERANT
CONTROL GP- MONITOR
CONVERSION AR
CONVERSION AR-NON-ROPS
FAN GP- DEFROSTER
HEATER GP- CAB
HOUSING GP- SEAT SUSPENSION
INSTALLATION GP- RADIO
LINER GP- CAB
LINES GP- AIR CONDITIONER
LINES GP- HEATER
MIRROR GP
MIRROR GP- REAR VIEW
MODULE GP- QUAD GAUGE
MODULE GP- SPEEDOMETER & TACH
MOTOR GP- WINDOW WIPER
MOUNTING GP- CAB
MOUNTING GP- ROPS
PAN GP- BACKREST
PANEL GP- INSTRUMENT
PLATFORM GP
RECLINER GP- SEAT
ROPS GP
SCREEN GP- PROTECTION
SEAT AR
SEAT GP
SEAT GP- SUSPENSION
SUSPENSION GP- SEAT
TANK GP- WINDOW WASHER
WASHER GP- WINDOW
WINDOW AS- SLIDING
WINDOW GP- CAB
WIPER GP- WINDOW
WIPER PIVOT GP
SERVICE EQUIPMENT AND SUPPLIES
FILM GP
PAINT GP
PLATE & FILM GP
PART NUMBER INDEX
Brand: Caterpillar
9MP1-Up (Bulldozer)
5RP1- Up (Ripper)
7HP1- Up (Ripper)
Back to Main Menu
Parts Manual
GENERAL INFORMATION
REPAIR ALTERNATIVES
MAINTENANCE PARTS
INDEX
INDEX (French)
INDICE (Spanish)
ÍNDICE (Portuguese)
MACHINE ARRANGEMENT
CHASSIS AR
COLD WEATHER AR
GENERAL AR
ENGINE ARRANGEMENT
ENGINE AR
BASIC ENGINE
BELT TIGHTENER GP
CAMSHAFT GP
CRANKSHAFT AS
CRANKSHAFT GP
CYLINDER BLOCK AS
CYLINDER BLOCK GP
CYLINDER HEAD AS
CYLINDER HEAD GP
DAMPER & PULLEY GP
DRIVE GP- FAN
FLYWHEEL GP
GEAR GP- FRONT
GEAR GP- REAR
HOUSING GP- FRONT
LIFTING GP- ENGINE
PAN GP- OIL
PISTON & ROD GP
PULLEY- ALTERNATOR
ROCKER ARM GP
SUPPORT GP- ENGINE
TRUNNION GP- ENGINE
VALVE MECHANISM GP
YOKE GP
LUBRICATION SYSTEM
BREATHER GP
FUMES DISPOSAL GP
PUMP GP- ENGINE OIL
COOLING SYSTEM
FAN & GRID AR
FAN GP- BLOWER
FAN GP- REVERSIBLE
LINES GP- WATER
PUMP GP- WATER
RADIATOR AR
RADIATOR GP
TANK GP- COOLANT
TANK GP- WATER
AIR CLEANER GP
DUST EJECTOR GP
LINES GP- AIR
MUFFLER GP
PRECLEANER AR
SHIELD GP- MANIFOLD
TURBOCHARGER GP
FUEL SYSTEM
FILTER GP- FUEL
GOVERNOR GP
TANK GP- FUEL
TORQUE CONTROL GP
ALARM GP
BATTERY & WIRING GP
BATTERY GP
BLOCK GP- JUNCTION
BLOCK GP- POWER
FASTENER AS
HEATER GP- FUEL
LAMP GP- DOME
LAMP GP- FLOOD
LIGHTING GP- FLOOD
SENSOR GP- PRESSURE
SENSOR GP- SPEED
SWITCH GP- BYPASS
SWITCH GP- FLOW
SWITCH GP- HANDLE
SWITCH GP- MAGNETIC
SWITCH GP- START
WIRING GP- CONSOLE
WIRING GP- PLATFORM
POWER TRAIN
COUPLING GP- PUMP
DRAIN GP-ECOLOGY
FILTER GP- OIL
FINAL DRIVE GP
POWER TRAIN AR
PUMP GP- GEAR
SHAFT GP- DRIVE
TORQUE CONVERTER GP
TRANSMISSION AR
UNIVERSAL JOINT GP
VALVE GP- PRIORITY
VALVE GP- RELIEF
FRAME AND BODY
CASE & FRAME GP
COUNTERWEIGHT GP
COVER GP- TRUNNION
DOOR GP- ACCESS
DRAWBAR GP
ENCLOSURE GP- LH
ENCLOSURE GP- RH
FENDER GP
FLOORPLATE AR
GUARD GP- BOTTOM
GUARD GP- IDLER
GUARD GP- RADIATOR
GUARD GP- ROCK
GUARD GP- VANDALISM
HOOD & GUARD GP
LATCH GP
UNDERCARRIAGE
BAR AS- EQUALIZER
BAR GP- EQUALIZER
CAP GP- TRACK IDLER
IDLER GP- TRACK
LINK AS- TRACK
ROLLER & IDLER AR
SHOE- TRACK
TRACK GP
UNDERCARRIAGE AR
HYDRAULIC SYSTEM
CYLINDER AR- TILT
CYLINDER GP- LIFT
CYLINDER GP- RIPPER
CYLINDER GP- TILT
LINES GP- PUMP
LINES GP- RIPPER
MANIFOLD GP- VALVE
PUMP GP- PISTON
ROTATING GP- PUMP
VALVE GP- BANK 4
VALVE GP- CHECK
VALVE GP- CONTROL
VALVE GP- RELIEF
VALVE GP- SHUTTLE
VALVE GP- SOLENOID
IMPLEMENTS
BULLDOZER AR
LINK GP- STABILIZER
PUSH ARM GP
WORK TOOLS
BLADE AS- UNIVERSAL
BLADE GP- UNIVERSAL
FRAME GP- RIPPER
MOUNTING GP- RIPPER
PLATE GP- WEAR
PULLER AR-PIN
PULLER GP- PIN
RIPPER AR
RIPPER GP
TOOTH GP- RIPPER
TOOTH GP- RIPPER
OPERATOR STATION
ADJUSTER GP- SEAT
AIR CONDITIONER AR
AIR CONDITIONER GP
CAB AR
CAB GP
CONTROL GP- MONITOR
CONVERSION AR
FAN GP- DEFROSTER
HEATER GP- CAB
LINER GP- CAB
LINES GP- HEATER
MIRROR GP
MOUNTING GP- CAB
MOUNTING GP- ROPS
PAN GP- BACKREST
PLATFORM GP
RECLINER GP- SEAT
ROPS GP
SEAT AR
SEAT GP
SEAT GP- SUSPENSION
SUSPENSION GP- SEAT
WASHER GP- WINDOW
WINDOW AS- SLIDING
WINDOW GP- CAB
WIPER GP- WINDOW
WIPER PIVOT GP
FILM GP
PAINT GP
PLATE & FILM GP
PART NUMBER INDEX
- CAT 416D Parts Manual
- CAT 420D Parts Manual
