Martin Welker
104
230,310
CAT Track-Type Tractor D6R III LGP Maintenance Service Manual and Schematics
Brand: Caterpillar
Type of Machine: Track-Type Tractor
Type of Manual: Service Manual, Maintenance Manual, Electrical Schematic, Hydraulic Schematic
Model: CAT D6R III LGP Track-Type Tractor
List of Files:
-Disassembly and Assembly
RENR2165 Comfort Series Seat For Caterpillar Machines.pdf
RENR8173 D6R Series 111 Track-Type Tractor Power Train.pdf
RENR8174 D6R Series III Track-Type Tractor Machine Systems.pdf
RENR8175 D6R Series III and D6T Track-Type Tractors Engine Supplement.pdf
SENR5664 Air Conditioning and Heating R134a for All Caterpillar Machines.pdf
SENR8456 561N 572R 572R Series II and 587T Pipelayers and D5M D5N D6M D6N D6R .pdf
-Maintenance Manual
SEBU7925 D6R Series III Track-Type Tractor.pdf
-Schematics
RENR7954 D6R Series III Track-Type Tractor Power Train System (Interactive).pdf
RENR7956 D6R Series III Track-Type Tractor Hydraulic System - Pilot Control and Accugrade Ready (Interactive).pdf
RENR8172 D6R III Track-Type Tractor with AccuGrade Electrical System.pdf
-Testing and Adjusting\D5M, D5N, D6M, D6N, D6R, Track-Type Tractors Caterpillar Monitoring System
Schematics 1.pdf
Schematics 2.pdf
Schematics 3.pdf
-Testing and Adjusting\D5M, D5N, D6M, D6N, D6R, Tractors Power Train Electronic Control System
Calibration.pdf
Electrical Connector - Inspect.pdf
Electronic Control Module (ECM) - Flash Program.pdf
Electronic Control Module (ECM) - Replace.pdf
Glossary of Electrical Terms.pdf
Schematics 1.pdf
Schematics 2.pdf
Speed Sensor - Adjust.pdf
System Schematic.pdf
Wiring Harness (Open Circuit) - Test.pdf
Wiring Harness (Short Circuit) - Test.pdf
-Testing and Adjusting\D6R Series III Track-Type Tractor
Accumulator - Test.pdf
Brake Pressure - Test.pdf
Brake Troubleshooting.pdf
Flywheel Lubrication Oil Pressure - Test.pdf
Hour Meter Troubleshooting.pdf
Machine Troubleshooting.pdf
Main Relief Valve - Adjust.pdf
Oil (Air in Oil) Troubleshooting.pdf
Oil Pressure Troubleshooting.pdf
Oil Temperature Troubleshooting.pdf
Pressure Charts.pdf
Pressure Taps.pdf
Relief Valve (Torque Converter Inlet) Pressure - Test and Adjust.pdf
Relief Valve (Torque Converter Outlet) Pressure - Test and Adjust.pdf
Software Troubleshooting.pdf
Speed Sensor - Adjust - Output Speed of the Torque Converter.pdf
Symptom List.pdf
Torque Converter Troubleshooting.pdf
Track - Adjust.pdf
Transmission Clutch Troubleshooting.pdf
Transmission Controls.pdf
Transmission Lubrication Oil Pressure - Test.pdf
Transmission Troubleshooting.pdf
Troubleshooting Procedures.pdf
-Testing and Adjusting\D6R Series III Track-Type Tractor Hydraulic System
Accumulator (Pilot) - Test and Charge.pdf
Hydraulic System Troubleshooting.pdf
Main Relief Valve and Crossover Relief Valve - Test.pdf
Operation Checks.pdf
Pilot Control Valve - Test and Adjust.pdf
Pressure Limiter Valve - Test.pdf
Pressure Reducing Valve - Test and Adjust.pdf
Pressure Taps.pdf
Pump Control Valve (Steering) - Adjust.pdf
Pump Discharge Pressure - Test.pdf
Steering Hydraulic Circuit - Test.pdf
Steering Motor - Adjust.pdf
-Testing and Adjusting\D6R Series III Track-Type Tractor Machine Systems
Fan Drive System Troubleshooting.pdf
