Martin Welker
104
230,310
CAT Track Drill MD5075 Service Manual BI006823-00
Brand: Caterpillar
Type of Machine: Track Drill
Type of Manual: Service Manual, Electrical and Hydraulic Schematics
Model: CAT MD5075 Track Drill
Part Number: BI006823-00
Number of Pages: 512 Pages
PARTS ORDERING AND PRODUCT SUPPORT
Contents
Introduction
Machine Specifications
Component Locations
Section 1 - Safety
Hazard Classification
Safety Sign Symbols
Safety Information
Safety Sign List
Safety Sign Location
Safety Signs
Section 2 - Mainframe/Tracks
Track Oscillation Cylinders
Track Maintenance
Track Tension Adjustment
Metric Bolt Torque Specifications
Track Assembly
Crawler Carriage
Section 3 - Power Train
Fuel System
Engine Oil
Engine Radiator
Coolers
Hydraulic Pumps
Hydraulic Oil Change Procedure
Section 4 - Hydraulic and Electrical Systems
Valve Installation
Tram Valve Components
Auxiliary Manifold
Drill/Boom Valve
Drill Control Circuit
Transducer Manifold
Electrical Components Installation
Electrical Enclosure
Communication and Control Modules
Schematics
Section 5 - Air System
Air System Components
Compressor Assembly
Compressor Oil Piping
Air Receiver Tank
Thread Grease System
Detergent System
Section 6 - Boom and Feed Assemblies
Boom Assembly
Feed Assembly–Linear Rod Changer
Feed Assembly–Carousel Rod Changer
Boom Shim/Wear Pads
Feed Table Pivot Pin
HPR45/51 Hydraulic Rock Drill
Drill Mounting Slide
HPR1H-ATW Hydraulic Rock Drill
Feed Chain
Hose Reel
Section 7 - Pressure Settings and Adjustments
Pump Adjustments
Drill/Boom Valve Adjustments
Feed and Rotation Pressure Manifold
Compressor Adjustments
Compressor Drive Coupling
Dust Collector Assembly
Centralizer Assembly
Vertical Indicator
Backpressure Valve
Section 8 - Vendor Service Information
Index
HPR1H-ATW Drill Rotation Motor
HPR45/51 Drill Rotation Motor
Feed Drive Gear Reducer
Drill String Grease System
Dust Collector Filter/Regulator
Tandem Hydraulic Pumps - Oilgear
Feed Drive & Compressor Hydraulic Motor
Dust Collect Hydraulic Motor
Hydraulic Cylinder Repair
Section 9 - Hydraulic Rock Drill Repair Section
Section 10 - Lubrication and Maintenance
Hydraulic Oils for Percussion Drills
Lubrication and Inspection
Maintenance Schedule
R30C Grease Points
Engine Oil Filter
Engine Fuel Filter
Engine Air Cleaner Filter
Compressor Air Cleaner Filter
Compressor Oil Filter
Hydraulic Fluid Fill Pump and Filter
Hydraulic Return Filter Indicators
Coolant System
Maintenance Record
