CAT Telehandler TH336 TH336 TH337 TH407 Parts Manual 31200369
Brand: Caterpillar
Type of Machine: Telehandler
Model: CAT TH336 TH336 TH337 TH407 Telehandler
Serial Number:
S/N TDE00100 & After
S/N TDF00100 & After
S/N TBX00100 & After
S/N TBY00100 & After
Part Number: 31200369
Publication Date: 2010
Number of Pages: 386 Pages
Section 1 Frame & Attaching Parts
Part Number Index
Brand: Caterpillar
Serial Number:
Figure 1-1 Frame Shrouding & Trim
Figure 1-2 Frame Shrouding & Trim - Engine Pod Installation
Figure 1-3 Axle & Wheel Mounting
Figure 1-4 Retrieval Hitch
Figure 1-5 Pin Hitch, Auto Hitch & Piton Frame-Auto Hitch
Figure 1-6 Pin Hitch - Cuna C & Cuna D2
Figure 1-7 Hydraulic Hitch
Figure 1-8 Fixed Position Hitch
Section 2 BoomFigure 2-1 Boom Assembly Components
Figure 2-2 First Boom Section Assembly
Figure 2-3 Second Boom Section
Figure 2-4 Quick Coupler & Quick Disconnect Installation
Figure 2-5 JD Coupler Installation
Figure 2-6 Boom Prop Installation
Figure 2-7 JCB Coupler, Manual & Hydraulic
Figure 2-8 Manitou Coupler Installation, Manual & Hydraulic
Section 3 AttachmentsFigure 3-1 Carriage Assembly
Figure 3-2 Forks
Figure 3-3 Side Shift Carriage
Figure 3-4 Rotate/Side Tilt Carriage
Figure 3-5 General Purpose Bucket
Figure 3-6 Multi-Purpose Bucket
Figure 3-7 Material Handling Bucket
Figure 3-8 Grapple Bucket
Figure 3-9 Truss Boom
Figure 3-10 Lifting Hook
Figure 3-11 50 in & 72 in Rotate/Side Tilt Carriage Assembly
Figure 3-12 50 in & 72 in Carriage Assembly
Figure 3-13 100 Degree Swing Carriage
Section 4 Engine & Attaching PartsFigure 4-1 Engine & Transmission Installation
Figure 4-2 CAT Engine
Figure 4-3 Fuel Line Installation
Figure 4-4 Fuel Tank Installation
Figure 4-5 Radiator Installation
Figure 4-6 Air Cleaner Installation
Figure 4-7 Muffler Installation
Figure 4-8 Block Heater Installation
Figure 4-9 Reversing Fan - Hydraulic
Figure 4-10 Reversing Fan - Pneumatic
Section 5 Drive TrainFigure 5-1 Front Axle Assembly
Figure 5-2 Front Axle - Axle Housing
Figure 5-3 Front Axle - Swivel Housing & Steering Cylinder
Figure 5-4 Front Axle - Bevel Gear Set
Figure 5-5 Front Axle - Differential
Figure 5-6 Front Axle - Double U-Joint
Figure 5-7 Front Axle - Brakes
Figure 5-8 Front Axle - Wheel Hub
Figure 5-9 Front Axle - Final Reduction
Figure 5-10 Front Axle - Brake Caliper
Figure 5-11 Rear Axle Assembly
Figure 5-12 Rear Axle - Axle Housing
Figure 5-13 Rear Axle - Swivel Housing & Steering Cylinder
Figure 5-14 Rear Axle - Bevel Gear Set
Figure 5-15 Rear Axle - Differential
Figure 5-16 Rear Axle - Double U-Joint
Figure 5-17 Rear Axle - Wheel Hub
Figure 5-18 Rear Axle - Final Reduction
Figure 5-19 Drive Shaft Installation
Figure 5-20 Remote Grease System Installation
Figure 5-21 Tire & Wheel Installation
Section 6 CabFigure 6-1 Cab Installation
Figure 6-2 Cab Assembly
Figure 6-3 Open Cab Interior Installation
Figure 6-4 Enclosed Cab Interior Installation
Figure 6-5 Cab Door & Window Installation
Figure 6-6 Wiper System
Figure 6-7 Cab Covers & Cab Guards
Figure 6-8 Vinyl Mechanical Suspension Seat
Figure 6-9 Cloth Mechanical Suspension Seats
Figure 6-10 Cloth Pneumatic Suspension Seats
Figure 6-11 Cab Heater/AC Components
Figure 6-12 Engine Heater/AC Components
Figure 6-13 Heater/AC Unit & Heater/AC Unit Guard Shield
Section 7 ControlsFigure 7-1 Joystick
Figure 7-2 Steering Column
Figure 7-3 Accelerator Pedal
Figure 7-4 Mechanical Handbrake
Figure 7-5 Brake Installation
Section 8 Hydraulic CircuitsFigure 8-1 Supply Circuit
Figure 8-2 Dump Circuit
Figure 8-3 Steer Select Valve
Figure 8-4 Service Brake
Figure 8-5 Lift Cylinder
Figure 8-6 Extend/Retract
Figure 8-7 Tilt & Tilt Compensating Cylinder
Figure 8-8 Auxiliary Hydraulics
Figure 8-9 Rear Auxiliary Hydraulics w/Trailer Brakes
Section 9 Hydraulic ComponentsFigure 9-1 Lift Cylinder
Figure 9-2 Extend/Retract Cylinder
Figure 9-3 Tilt Cylinder
Figure 9-4 Compensation Cylinder
Figure 9-5 Quick Coupler Cylinder
Figure 9-6 Main Control Valve
Figure 9-7 Piston Pump
Figure 9-8 Steering Select Valve
Figure 9-9 Hydraulic Tank Installation
Figure 9-10 Diverter Valve
Figure 9-11 Combination Valve
Figure 9-12 Swing Carriage Cylinder
Section 10 ElectricalFigure 10-1 Engine & Transmission Electronic Installation
Figure 10-2 Cab Electronic Installation
Figure 10-3 Cab Switches
Figure 10-4 Boom & Frame Electronic Installation
Figure 10-5 Worklight & License Plate Light Installations
Figure 10-6 Driving Light Installation
Figure 10-7 Engine Harness
Figure 10-8 Cab Floor Harness
Figure 10-9 Cab Roof Harness
Figure 10-10 Transmission Harness
Figure 10-11 Front Frame Harness
Figure 10-12 Rear Frame Harness
Figure 10-13 Boom Harness
Figure 10-14 Boom Worklight Harness & Headlight Harness
Figure 10-15 Tow Hitch Harness
Figure 10-16 Boom Suspension Cab Components
Section 11 DecalsFigure 11-1 Cab & Frame Decals
Figure 11-2 Boom Decals
Maintenance parts listPart Number Index
- CAT 416D Parts Manual
- CAT 420D Parts Manual
