CAT Off-Highway Truck 794 AC Electrical Hydraulic Schematic
Brand: Caterpillar
Type of Machine: Off-Highway Truck
Type of Manual: Cooling System Schematic, Electrical Schematic, Hydraulic Schematic
Model: CAT 794 AC Off-Highway Truck
List of Files:
M0099817-02: 794 Ac Off-Highway Truck Electrical System (Interactive)(Function Isolation), Cab 550-8131-00, Chassis 525-0262-01, Inverter Cabinet (Low Voltage)- 539-5557-00, Inverter Cabinet (High Voltage) 313-4071-00, Engine 463-5300-08, Ecm Cabinet 435-3068-01, Platform 525-2062-01, Aftertreatment 444-0528-02 (For Serial Number HRT1-101)
M0099817-03: 794 Ac Off-Highway Truck Electrical System (Interactive)(Function Isolation), Cab 550-8131-00, Chassis 550-8131-00, Inverter Cabinet (Low Voltage) 539-5557-00, Inverter Cabinet (High Voltage) 313-4071-00, Engine 463-5300-08, ECM Cabinet 435-3068-01, Platform 550-8131-00, Aftertreatment 444-0528-01 (For Serial Number HRT1-101)
M0099817-04: 794 Ac Off-Highway Truck Electrical System (Interactive) (Function Isolation), Cab And Chassis - 550-8131-00, Inverter Cabinet (Low Voltage) - 539-5557-00, Inverter Cabinet (High Voltage) - 313-4071-00, Engine - 463-5300-08, ECM Cabinet - 435-3068-01, Platform - 550-8131-00, Aftertreatment - 444-0528-05 (For Serial Numbers HRT1-101)
M0103423-04: 794 Ac And 796 Ac Off-Highway Truck Hydraulic System(Interactive)(Function Isolation), 442-3333-05(FOR Serial Numbers HRZ1-507 HRT1-102 MT51-144 MN51-UP)
M0105964-02: 794 Ac, 796 Ac, And 798 Ac Off-Highway Truck Cooling System (Interactive)(Function Isolation), Schematic Part Number 578-6809-00 (For Serial Numbers ST31-UP HRY1-UP HRZ1-UP HRT1-UP MT51-UP MN51-UP ST71-UP)
M0106733-01: 794 Ac Off-Highway Truck Electrical System, Cab 555-0282-00, Chassis 555-0281-00,INVERTER Cabinet (Low Voltage) 539-5557-00,INVERTER Cabinet (High Voltage) 313-4071-00,ECM Cabinet 545-6168-00, Engine 463-5300-08,AFTERTREATMENT 444-0528-02 (For Serial Numbers HRT102-102)
M0106733-03: 794 Ac Off-Highway Truck Electrical System(Interactive)(Function Isolation), Cab 555-0282-00, Chassis 555-0281-00,INVERTER Cabinet (Low Voltage) 539-5557-00,INVERTER Cabinet (High Voltage) 313-4071-00,ECM Cabinet 545-6168-00, Engine 463-5300-08,AFTERTREATMENT 444-0528-02 (For Serial Numbers HRT102-102)
M0106733-04: 794 Ac Off-Highway Truck Electrical System, Cab And Chassis - 555-0282-00, Platform - 555-0281-00, Inverter Cabinet (Low Voltage) - 539-5557-00, Inverter Cabinet (High Voltage) - 313-4071-00, ECM Cabinet - 545-6168-00, Engine - 463-5300-08, Aftertreatment - 444-0528-05 (For Serial Numbers HRT102-102)
M0106867-00: 794 Ac Off-Highway Truck Electrical System, Cab 555-0282, Chassis, Platform & Engine 555-0281-01, Ecm Enclosure 545-6168, Inverter Cabinet (Low Voltage) 313-4073, Inverter Cabinet (High Voltage) 313-4071, Engine 423-0052-03 (For Serial Numbers MT5142-144)
M0106867-01: 794 Ac Off-Highway Truck Electrical System Cab 555-0282, Chassis, Platform And Engine 555-0281-01, ECM Enclosure 545-6168, Inverter Cabinet (Low Voltage) 313-4073, Inverter Cabinet (High Voltage) 313-4071, Engine 423-0052-03, (For Serial Numbers MT5142-144)
M0106867-03: 794 AC Off-Highway Truck Electrical System (Interactive) (Function Isolation), Cab - 555-0282-00, Chassis and Platform - 555-0281-00, ECM Cabinet - 545-6168-00, Inverter Cabinet (Low Voltage) - 539-5557-00, Inverter Cabinet (High Voltage) - 313-4071-00, Engine - 423-0052-03 (For Serial Numbers MT5142-144)
M0110583-00: 794 Ac Off-Highway Truck Command For Hauling (Cmd) (Cmd System Only) Electrical System, (Interactive) (Function Isolation) (For Serial Numbers MT51-UP MN51-UP HRT1-UP)
M0115911-02: 794 Ac, 796 Ac, And 798 Ac Off-Highway Truck Hydraulic System (Interactive)(Function Isolation), 582-4971-00 (For Serial Numbers HRT103-UP HRZ508-UP HRY1-UP ST31-UP ST71-UP MT5145-UP)
M0115911-03: 794 Ac, 796 Ac, And 798 Ac Off-Highway Truck Hydraulic System (Interactive)(Function Isolation), 582-4971-02 (For Serial Numbers ST71-UP ST31-UP HRY1-UP HRZ508-UP HRT103-UP MT5145-UP)
M0117467-01: 794 Ac Off-Highway Truck Electrical System, Cab 555-0282-01,CHASSIS 555-0281-01,PLATFORM 555-0281-01,ECM Box 545-6168-01,INVERTER Cabinet - Low Voltage 539-5557-00,INVERTER Cabinet - High Voltage 313-4071-00,ENGINE 463-5300-08,AFTERTREATMENT 444-0528-02 (For Serial Numbers HRT103-106)
M0117467-02: 794 Ac Off-Highway Truck Electrical System Cab 555-0282-01,CHASSIS 555-0281-01,PLATFORM 555-0281-01,ECM Box 545-6168-01,INVERTER Cabinet - Low Voltage 539-5557-00,INVERTER Cabinet - High Voltage 313-4071-00,ENGINE 463-5300-08,AFTERTREATMENT 444-0528-02, (For Serial Numbers HRT103-106)
M0117467-03: 794 Ac Off-Highway Truck Electrical System (Interactive) (Function Isolation), Cab - 555-0282-01, Chassis And Platform - 555-0281-01, ECM Box - 545-6168-01, Inverter Cabinet (Low Voltage) - 539-5557-00, Inverter Cabinet (High Voltage) - 313-4071-00, Engine - 463-5300-08, Aftertreatment - 444-0528-05 (For Serial Numbers HRT103-106)
M0118470-01: 794 Ac Off-Highway Truck Electrical System - 555-0282-01 (Cab), 555-0281-01 (Chassis And Platform), 545-6168-01 (Ecm Box), 539-5557-00 (Inverter Cabinet (Low Voltage)), 313-4071-00 (Inverter Cabinet (High Voltage)), 423-0052-03 (Engine)(For Serial Numbers MT5145-205)
M0118470-03: 794 Ac Off-Highway Truck Electrical System (Interactive) (Function Isolation), Cab - 555-0282-01, Chassis And Platform - 555-0281-01, ECM Box - 545-6168-01, Inverter Cabinet (Low Voltage) - 539-5557-00, Inverter Cabinet (High Voltage) - 313-4071-00, Engine - 423-0052-03 (For Serial Numbers MT5145-205)
M0118474-01: 796 Ac Off-Highway Truck Electrical System - 555-0282-01 (Cab), 555-0281-01 (Chassis And Platform), 545-6168-01 (Ecm Box), 539-5557-00 (Inverter Cabinet (Low Voltage)), 313-4071-00 (Inverter Cabinet (High Voltage)), 423-0052-03 (Engine) (For Serial Numbers HRZ508-524)
M0120601-01: 794 Ac Off-Highway Truck Command For Hauling (Cmd) (Cmd Steering System Only) Hydraulic System (Interactive)(Function Isolation), 582-4971-01(FOR Serial Numbers MT51-UP MN51-UP HRT1-UP)
M0124093-01: 794 Ac, 796 Ac And 798 Ac Off-Highway Truck Hydraulic Cabinet Removal And Brake Valve Retrofit Electrical System, 598-0542-00(FOR Serial Numbers MN51-56 ST3198-199 ST71-402 HRZ1-507 HRT1-102 MT51-144)
M0126235-00: 794 Ac Off-Highway Truck Electrical System
M0126235-01: 794 Ac Off-Highway Truck Electrical System , (For Serial Numbers MT5206-247)
M0126235-02: 794 Ac Off-Highway Truck Electrical System (For Serial Numbers MT5206-228)
M0126235-04: 794 AC Off-Highway Truck Electrical System (Interactive) (Function Isolation), Cab - 555-0282-02, Chassis and Platform - 555-0281-02, ECM Box - 601-4476-00, Inverter Cabinet (Low Voltage) - 539-5557-00, Inverter Cabinet (High Voltage) - 313-4071-00, Engine - 423-0052-03 (For Serial Numbers MT5206-228)
M0126239-00: 794 Ac Off-Highway Truck Electrical System
M0126239-01: 794 Ac Off-Highway Truck Electrical System , (For Serial Numbers HRT107-117)
M0126239-02: 794 Ac Off-Highway Truck Electrical System , (For Serial Numbers HRT107-114)
M0126239-03: 794 Ac Off-Highway Truck Electrical System (Interactive) (Function Isolation), Cab - 555-0282-02, Chassis And Platform - 555-0281-02, ECM Box - 601-4476-00, Inverter Cabinet (Low Voltage) - 539-5557-00, Inverter Cabinet (High Voltage) - 313-4071-00, Engine - 463-5300-08, Aftertreatment - 444-0528-05 (For Serial Numbers HRT107-114)
M0158335-00: 794 Ac Off-Highway Truck Electrical System , (For Serial Numbers MT5248-UP)
M0158335-01: 794 Ac Off-Highway Truck Electrical System(Interactive)(Function Isolation) , (For Serial Numbers MT5248-UP)
M0158335-04: 794 AC Off-Highway Truck Electrical System, Cab, Platform, and ECM Box - 610-1024-01, Chassis - 624-5031-01, PAS - 647-0048-00, Inverter Cabinet (Low Voltage) - 539-5557-00, Inverter Cabinet (High Voltage) - 313-4071-00, Engine (D4W1-169) - 423-0052-03, Engine (D4W170-UP) - 587-0000-01, CMD Layer - 596-5867-00, Trolley System - 619-6586-00 (For Serial Numbers MT5248-UP)
M0158335-06: 794 AC Off-Highway Truck Electrical System, Cab, Platform, and ECM Box - 610-1024-01, Chassis - 624-5031-01, PAS - 647-0048-00, Inverter Cabinet (Low Voltage) - 539-5557-00, Inverter Cabinet (High Voltage) - 313-4071-00, Engine (D4W1-169) - 423-0052-03, Engine (D4W170-UP) - 587-0000-01, CMD Layer - 596-5867-00, Trolley System - 619-6586-00 (For Serial Numbers MT5248-UP)
M0158503-00: 794 Ac Off-Highway Truck Electrical System(Interactive)(Function Isolation), (For Serial Numbers HRT118-UP)
M0158503-01: 794 Ac Off-Highway Truck Electrical System (Interactive) (Function Isolation), Cab, Platform, And ECM Box - 610-1024-00, Chassis Wiring - 624-5031-00, Inverter Cabinet (Low Voltage) - 539-5557-00, Inverter Cabinet (High Voltage) - 313-4071-00, Engine - 463-5300-08, Aftertreatment - 444-0528-05, CMD Layer - 596-5867-00 (For Serial Numbers HRT118-UP)
M0158503-03: 794 AC Off-Highway Truck Electrical System, Cab, Platform, and ECM Box - 610-1024-01, Chassis Wiring - 624-5031-01, PAS - 647-0048-00, Inverter Cabinet (Low Voltage) - 539-5557-00, Inverter Cabinet (High Voltage) - 313-4071-00, Engine - 463-5300-08, Aftertreatment - 444-0528-05, CMD Layer - 596-5867-00 (For Serial Numbers HRT118-UP)
M0158679-01: 794 Ac, 796 Ac, And 798 Ac Off-Highway Truck Chassis Retrofit Electrical System(Interactive)(Function Isolation), 615-4062-00(FOR Serial Numbers MT5142-247 HRZ503-544 HRT102-117 SKH1-632 ST71-408)
M0161281-01: 794 Ac Off-Highway Truck Electrical System(Interactive)(Function Isolation), (For Serial Numbers MT5229-247)
M0161281-02: 794 Ac Off-Highway Truck Electrical System (Interactive)(Function Isolation), Cab - 555-0282-03, ECM Box - 601-4476-01, Chassis And Platform - 555-0281-03, Inverter Cabinet (Low Voltage) - 539-5557-00, Inverter Cabinet (High Voltage) - 313-4071-00, Engine - 423-0052-03 (For Serial Numbers MT5229-247)
M0161973-00: 794 Ac Off-Highway Truck Electrical System(Interactive)(Function Isolation), (For Serial Numbers HRT115-117)
M0161973-01: 794 Ac Off-Highway Truck Electrical System, Cab - 555-0282-03, ECM Box - 601-4476-01, Chassis And Platform - 555-0281-03, Inverter Cabinet (Low Voltage) - 539-5557-00, Inverter Cabinet (High Voltage) - 313-4071-00, Engine - 463-5300-08, Aftertreatment - 444-0528-05 (For Serial Numbers HRT115-117)
UENR3700-06: 794 Ac Off-Highway Truck Electrical System,cab And Platform 551-6562-02, Chassis 525-2061-01, Inverter Cabinet 313-4073, Inverter Cabinet (High Voltage) 313-4071, Engine 423-0052-03, And ECM Cabinet 545-6168-01 (For Serial Numbers MT51-141 MN51-UP)
UENR3700-08: 794 Ac Off-Highway Truck Electrical System (Interactive) (Function Isolation), Cab And Platform - 551-6562-02, Chassis - 525-2061-01, Inverter Cabinet (Low Voltage) - 313-4073-00, Inverter Cabinet (High Voltage) - 313-4071-00, Engine - 423-0052-03, ECM Cabinet - 545-6168-01 (For Serial Numbers MN51-UP MT51-141)
Brand: Caterpillar
List of Files:
- CAT 416D Parts Manual
- CAT 420D Parts Manual
