CAT Off-Highway Truck 773E Parts Catalog M0071342-04
Brand: Caterpillar
Type of Machine: Off-Highway Truck
Model: CAT 773E Off-Highway Truck
PRB1-UP (Machine)
NTE1-UP (Engine)
4FY1-UP (Transmission)
T3K1-UP (Torque Converter)
Part Number: M0071342-04
Publication Date: 2017
Number of Pages: 801 Pages
GENERAL INFORMATION
REPAIR ALTERNATIVES
SUPPLEMENTAL COOLANT ADDITIVES
MAINTENANCE PARTS
INDEX
MACHINE ARRANGEMENT
Brand: Caterpillar
PRB1-UP (Machine)
NTE1-UP (Engine)
GENERAL INFORMATION
REPAIR ALTERNATIVES
MAINTENANCE PARTS
INDEX
MACHINE ARRANGEMENT
CHASSIS AR
COMMON AR
OPTION AR-COLD WEATHER
OPTION AR-REGIONAL
OPTION AR-SERVICE
ENGINE ARRANGEMENTENGINE AR-COMPLETE
ENGINE AR-CORE
INSTALLATION AR-ENGINE
BASIC ENGINEAIR COMPRESSOR GP
CAMSHAFT GP
COVER GP-CYLINDER BLOCK
COVER GP-FLYWHEEL HOUSING
COVER GP-FRONT HOUSING
COVER GP-OIL PAN
COVER GP-VALVE MECHANISM
CRANKSHAFT AS
CRANKSHAFT GP
CYLINDER BLOCK AS
CYLINDER BLOCK GP
CYLINDER HEAD AS
CYLINDER HEAD GP
DAMPER GP
DRIVE GP-ACCESSORY
DRIVE GP-FAN
FLYWHEEL GP
GEAR GP-FRONT
GEAR GP-REAR
HOUSING GP-FLYWHEEL
HOUSING GP-FRONT
LIFTING GP-ENGINE
LINES GP-AIR COMPRESSOR
PAN GP-OIL
PISTON & ROD GP
PLUG GP-CYLINDER BLOCK
PLUG GP-CYLINDER HEAD
ROCKER ARM GP
SEAL GP-CRANKSHAFT
SUPPORT GP-ENGINE
TRUNNION GP-ENGINE
VALVE MECHANISM GP
LUBRICATION SYSTEMBREATHER GP
EXTENSION GP-DRAIN
FASTENER GP-OIL PUMP MOUNTING
FILLER GP-ENGINE OIL
FILTER GP-ENGINE OIL
FUMES DISPOSAL GP
GAUGE GP-OIL LEVEL (DIPSTICK)
LINES GP-ENGINE OIL
LINES GP-ENGINE OIL FILTER
LINES GP-TURBOCHARGER OIL
MOUNTING GP-ENGINE OIL FILTER
OIL CHANGE GP-HIGH SPEED
PUMP GP-ENGINE OIL
COOLING SYSTEMCOOLING AR
CORE GP-OIL COOLER
FAN GP-SUCTION
LINES GP-COOLANT DRAIN
LINES GP-WATER
PUMP GP-WATER
RADIATOR GP
TANK GP-COOLANT
AIR INLET AND EXHAUST SYSTEMAFTERCOOLER GP-AIR
AIR CLEANER GP
CARTRIDGE GP-TURBOCHARGER
COVER GP-SHIPPING
EXHAUST AR-ENGINE
EXHAUST GP
GUARD GP-TURBOCHARGER
LINES GP-AIR
MANIFOLD GP-EXHAUST
MUFFLER GP
PIPE GP-EXHAUST
PRECLEANER GP
TURBOCHARGER GP
FUEL SYSTEMADAPTER GP-FAST FILL FUEL
DRIVE GP-UNIT INJ HYD PUMP
FILTER GP-FUEL
FILTER GP-PRIMARY FUEL
FILTER GP-WATER SEP & FUEL
INJECTOR GP-FUEL
KIT-SEAL
LINES GP-FUEL
LINES GP-INJECTOR HYD PUMP
PUMP & MTG GP-UNIT INJ HYD
PUMP GP-FUEL INJECTION
PUMP GP-FUEL PRM & WATER SEP
PUMP GP-UNIT INJECTOR HYD
SENDER GP-FUEL LEVEL
TANK GP-FUEL
VALVE GP-CHECK
VALVE GP-FUEL
VALVE GP-FUEL BYPASS
VALVE GP-PRESSURE CONTROL
VALVE GP-SOLENOID
ELECTRICAL AND STARTING SYSTEMALARM GP
ALTERNATOR GP-CHARGING
BATTERY & WIRING GP
CAMERA & MOUNTING GP
CAMERA GP
CONTROL & MTG GP-ENGINE ELEK
CONTROL & MTG GP-MONITOR
CONTROL & MTG GP-POWER TRAIN
CONTROL AR-COMMUNICATION
CONTROL GP-COMMUNICATION
CONTROL GP-ENGINE ELECTRONIC
CONTROL GP-UNPROGRAMMED
ELECTRICAL AR
ELECTRONICS GP-MACHINE
ELECTRONICS GP-MONITOR
HARNESS AS-BRAKE
HARNESS AS-CAB
HARNESS AS-CHASSIS
HARNESS AS-CONTROL
HARNESS AS-DASH
HARNESS AS-ENGINE
HARNESS AS-FRONT
HARNESS AS-FRONT CHASSIS
HARNESS AS-LIGHTING
HARNESS AS-REAR
HARNESS AS-REAR LIGHTING
HARNESS AS-SENSOR
HARNESS AS-TRANSMISSION
HARNESS AS-VALVE
HARNESS AS-WIRING
HEATER GP-FUEL
HEATER GP-JACKET WATER
INSTALLATION AR-OBJECT DETN
LAMP GP-DOME
LAMP GP-FLOOD
LAMP GP-HEAD
LAMP GP-MARKER
LAMP GP-PAYLOAD SIGNAL
LAMP GP-SIGNAL
LIGHTING GP-FLOOD
MOTOR GP-ELEC HYD PUMP
MOTOR GP-ELECTRIC
PLATE AS-BRUSH
SENSOR GP-ENGINE
SENSOR GP-OBJECT DETECTION
SENSOR GP-POSITION
SENSOR GP-PRESSURE
SENSOR GP-SPEED
SENSOR GP-TEMPERATURE
STARTING AID GP-ETHER
STARTING AR-COLD WEATHER
STARTING MOTOR GP-ELECTRIC
SWITCH GP-DISCONNECT
SWITCH GP-MAGNETIC
SWITCH GP-ROCKER
SWITCH GP-START
VALVE GP-ETHER STARTING
WIRING GP-AUTOMATIC RETARDER
WIRING GP-CAB
WIRING GP-CHASSIS
WIRING GP-COMMUNICATION
WIRING GP-CONTROL
WIRING GP-ELECTRONIC CONTROL
WIRING GP-ENGINE
WIRING GP-INTEGRATED BRAKE
WIRING GP-LIGHTING
WIRING GP-MIRROR
WIRING GP-MONITOR
WIRING GP-PAYLOAD SIGNAL
WIRING GP-POWER TRAIN
WIRING GP-SENSOR
WIRING GP-UNIT INJECTOR
POWER TRAINACTUATOR GP-ROTARY
AXLE GP-REAR
CASE & PARTS GP-PLANETARY
CONTROL GP-TRANSMISSION HYD
COVER GP-SHIPPING
DIFFERENTIAL & BEVEL GEAR GP
DIFFERENTIAL GP
DRIVE GP-FINAL
FILTER & LINES GP-TORQUE CONV
FILTER GP-OIL
GEAR GP-TRANSFER
HOUSING GP-REAR AXLE
INFLATION GP-AIR
LINES GP-POWER TRAIN COOLER
LINES GP-POWER TRAIN OIL
LINES GP-TRACTION CONTROL
MOUNTING GP-TORQUE CONVERTER
MOUNTING GP-WHEEL
PLANETARY GP-TRANSMISSION
POWER TRAIN AR
PUMP & DRIVE GP-GEAR
PUMP GP-GEAR
RIM GP-DEMOUNTABLE
SHAFT GP-DRIVE
SLIP JOINT GP
TORQUE CONVERTER AR
TORQUE CONVERTER GP
TRANSMISSION AR
VALVE GP-LOCKUP CLUTCH & SOL
VALVE GP-RELIEF
VALVE GP-SELECTOR & PRESS CONT
VALVE GP-SOLENOID
VALVE GP-TRACTION CONTROL
VALVE GP-TRANSMISSION CONTROL
WHEEL & BRAKE GP
WHEEL GP-REAR
FRAME AND BODYBAFFLE GP-RADIATOR
BODY GP-TRUCK
BOSS GP-FRAME
BRACKET GP-MOUNTING
COWLING GP
FENDER GP
FRAME GP
GUARD GP-BOTTOM
GUARD GP-DRIVE SHAFT
HANDRAIL GP
HOOD GP-TRUCK
LADDER GP
LINES GP-CENTRAL LUBRICATION
MIRROR & MTG GP-REAR VIEW
MIRROR GP
MIRROR GP-REAR VIEW
MOUNTING AR-TRUCK BODY
MOUNTING GP-SUSPENSION
MOUNTING GP-TRUCK BODY
PUMP & LINES GP-AUTOMATIC LUBE
PUMP GP-LUBRICATION
STEP GP
SUPPRESSION AR-SOUND
SUPPRESSION GP-SOUND
SUSPENSION AR
SUSPENSION GP-FRONT
SUSPENSION GP-REAR
TREAD GP-NON-SKID
VALVE GP-LUBE DISTRIBUTION
WALKWAY GP
BRAKING SYSTEMAIR DRYER GP
BRAKE GP-HYD CALIPER SERVICE
BRAKE GP-SERVICE
BRAKE GP-SERVICE & PARKING
CONTROL AR-SERVICE BRAKE
CONTROL GP-PARKING BRAKE
CONTROL GP-SERVICE BRAKE
CYLINDER GP-AIR/HYDRAULIC
FILTER GP-OIL
LINES GP-SERVICE BRAKE
SLACK ADJUSTER GP
TANK GP-AIR
TANK GP-BRAKE
VALVE & MTG GP-BRAKE
VALVE GP-AIR CONTROL
VALVE GP-BRAKE
VALVE GP-CHECK
VALVE GP-DIVERTER
VALVE GP-RELIEF
VALVE GP-SOLENOID
STEERING SYSTEMCYLINDER & MTG GP-STEERING
CYLINDER GP-STEERING
LINES GP-STEERING
LINK GP-STEERING
LOCK GP-STEERING CYLINDER
PUMP GP-METERING
STEERING COLUMN GP-ADJUSTABLE
STEERING GEAR GP
VALVE GP-CHECK & RELIEF
VALVE GP-PRESSURE REDUCING
VALVE GP-RELIEF
VALVE GP-SHUTTLE
WHEEL GP-FRONT
HYDRAULIC SYSTEMACTUATOR GP-PILOT CONTROL
COVER GP-CYLINDER
CYLINDER & MTG GP-HOIST
CYLINDER GP-HOIST
FILTER GP-OIL
HYDRAULIC AR
LINES GP-HOIST
LINES GP-HYDRAULIC OIL COOLER
MOUNTING GP-HYDRAULIC TANK
PUMP & MOTOR GP-HYDRAULIC
PUMP & MTG GP-HYDRAULIC
PUMP GP-GEAR
PUMP GP-HYDRAULIC
PUMP GP-PISTON
TANK GP-HYDRAULIC
VALVE & MTG GP-CONTROL
VALVE AS-RELIEF
VALVE GP-CONTROL
VALVE GP-PUMP CONTROL
VALVE GP-RELIEF
OPERATOR STATIONAIR CONDITIONER GP
ARMREST GP
CAB AR
COMPRESSOR GP-REFRIGERANT
CONDENSER & MTG GP-REFRIGERANT
CONTROL GP-HOIST
CONTROL GP-HOIST ELECTRONIC
CONTROL GP-RETARDER
CONTROL GP-UNPRGMED MONITOR
COVER GP-ACCESS
DISPLAY AR-MONITOR
DISPLAY GP-MONITOR
DOOR GP-CAB
FASTENER GP-HEATER LINES
FIRE EXTINGUISHER GP
HEATER GP-CAB
LINES GP-AIR CONDITIONER
MONITOR GP-PAYLOAD
MOTOR GP-WINDOW WIPER
MOUNTING GP-ANTENNA
MOUNTING GP-CAB
PANEL GP-CAB
PANEL GP-INSTRUMENT
PEDAL GP-GOVERNOR
PLATFORM GP
SEAT GP
SEAT GP-COMPANION
SEAT GP-SUSPENSION
SUSPENSION GP-SEAT
TRIM GP-CAB
VALVE GP-SHUTOFF
VISOR GP-CAB
WASHER GP-WINDOW
WINDOW GP
WINDOW GP-CAB
WIPER GP-WINDOW
SERVICE EQUIPMENT AND SUPPLIESCAP GP-PROTECTION
CHOCK GP-WHEEL
FILM GP
FILM GP-INTERNATIONAL
PLATE & FILM GP
SERVICE CENTER GP
PART NUMBER INDEX
- CAT 416D Parts Manual
- CAT 420D Parts Manual
