CAT Motor Grader 16M Parts Manual SEBP4108
Brand: Caterpillar
Type of Machine: Motor Grader
Model: CAT 16M Motor Grader
Serial Number: B9H1-Up (Machine), MHX1-Up (Engine), DZM1-Up (Transmission)
Part Number: SEBP4108
Publication Date: 2007
Number of Pages: 950 Pages
Back to Main Menu
Parts Manual
16M Motor Grader
TABLE OF CONTENTS
GENERAL INFORMATION
REPAIR ALTERNATIVES
SUPPLEMENTAL COOLANT ADDITIVES
MAINTENANCE PARTS
INDEX
INDEX (French)
INDICE (Spanish)
ÍNDICE (Portuguese)
STICHWORTVERZEICHNIS (German)
MACHINE ARRANGEMENT
COMMON AR
OPTION AR-EU
SNOW AR-MOTOR GRADER
ENGINE ARRANGEMENT
ENGINE AR-COMPLETE
ENGINE AR-CORE
BASIC ENGINE
ACTUATOR GP-VALVE
BASE GP-VALVE COVER & INJ HARN
CAMSHAFT GP
COVER GP-FLYWHEEL HOUSING
COVER GP-FRONT HOUSING
COVER GP-VALVE MECHANISM
CRANKSHAFT GP
CYLINDER BLOCK AS
CYLINDER BLOCK GP
CYLINDER HEAD AS
CYLINDER HEAD GP
DAMPER GP
DRIVE GP-ACCESSORY
FASTENER GP-CYLINDER HEAD
FASTENER GP-DAMPER & PULLEY
FASTENER GP-VALVE MECHANISM
FLYWHEEL GP
GEAR GP-FRONT
GEAR GP-REAR
HOUSING GP-FLYWHEEL
HOUSING GP-FRONT
KIT-CRANKSHAFT BEARING
LIFTER GP-VALVE
LIFTING GP-ENGINE
MOUNTING GP-ENGINE & TMSN
MOUNTING GP-FAN DRIVE
MOUNTING GP-VALVE MECHANISM
PAN GP-OIL
PISTON & ROD GP
PLUG GP-CYLINDER BLOCK
PLUG GP-ENGINE
PULLEY GP-CRANKSHAFT
ROCKER ARM GP
SEAL GP-CRANKSHAFT
SUPPORT GP-ENGINE
SUPPRESSION GP-SOUND
VALVE MECHANISM GP
LUBRICATION SYSTEM
BASE GP-OIL FILTER
BREATHER GP
COVER GP-OIL FILTER BASE
FILLER GP-ENGINE OIL
FUMES DISPOSAL GP
GAUGE GP-OIL LEVEL (DIPSTICK)
LINES GP-TURBOCHARGER OIL
OIL CHANGE GP-HIGH SPEED
PUMP GP-ENGINE OIL
COOLING SYSTEM
COOLER GP-ENGINE OIL
COOLING AR
FAN & MOTOR GP
GUARD GP-FAN
LINES GP-WATER
RADIATOR GP
TANK GP-COOLANT
AIR INLET AND EXHAUST SYSTEM
AFTERCOOLER GP-AIR
AIR CLEANER GP
LINES GP-AIR
MANIFOLD GP-EXHAUST
MANIFOLD GP-INLET
MUFFLER GP
PRECLEANER GP
TURBOCHARGER GP
FUEL SYSTEM
ADAPTER GP-FAST FILL FUEL
FILTER GP-FUEL
FILTER GP-WATER SEP & FUEL
INJECTOR GP-FUEL
LINES GP-FUEL
PUMP GP-FUEL INJECTION
PUMP GP-FUEL PRIMING
PUMP GP-FUEL TRANSFER
TANK GP-FUEL
VALVE GP-CHECK
VALVE GP-FLUID SAMPLING
VALVE GP-FUEL SHUTOFF
WATER SEP & FUEL PRM PUMP GP
ELECTRICAL AND STARTING SYSTEM
ALARM GP
BATTERY GP
CABLE GP-STARTING MOTOR
CAMERA AR
CONNECTION GP-ELECTRICAL
CONTROL & MTG GP-ENGINE ELEK
CONTROL & MTG GP-IMPLEMENT
CONTROL GP-ENGINE ELECTRONIC
CONTROL GP-IMPLEMENT
CONTROL GP-UNPROGRAMMED
CONVERTER GP-ELECTRICAL
ELECTRONICS GP-IMPLEMENT
ELECTRONICS GP-MONITOR
GRADE CONTROL AR
GRADE CONTROL GP
HEATER GP-JACKET WATER
INSTALLATION GP-LIGHTING
INSTALLATION GP-SECURITY
INSTALLATION GP-WARNING BEACON
LAMP GP-DOME
LAMP GP-FLOOD
LAMP GP-HEAD
LAMP GP-HEAD & SIGNAL
LAMP GP-SIGNAL
LAMP GP-WARNING BEACON
LIGHTING GP-BACKUP
LIGHTING GP-FLOOD
LIGHTING GP-ROADING
MOTOR GP-ELECTRIC
MOUNTING GP-LAMP
MOUNTING GP-LIGHTING
MOUNTING GP-RECEIVER
POWER SUPPLY GP
RADIO GP-COMMUNICATION
RECEIVER AR-LASER
RECEIVER AR- SATELLITE
RECEIVER GP-LASER
RECEIVER GP-SATELLITE
SENSOR & MTG GP-POSITION
SENSOR AR-GRADE
SENSOR GP-ENGINE
SENSOR GP-POSITION
SENSOR GP-PRESSURE
SENSOR GP-SONIC
SENSOR GP-SPEED
SENSOR GP-TEMPERATURE
STARTING AID GP-ETHER
STARTING MOTOR GP-ELECTRIC
SWITCH GP-BYPASS
SWITCH GP-DISCONNECT
SWITCH GP-LIGHT
SWITCH GP-LIMIT
SWITCH GP-MAGNETIC
SWITCH GP-PRESSURE
SWITCH GP-ROADING
SWITCH GP-ROCKER
SWITCH GP-WIPER
VALVE GP-ETHER STARTING
WARNING GP-BACKUP
WIRING GP-CAB
WIRING GP-CAMERA
WIRING GP-ELECTRONIC CONTROL
WIRING GP-FRONT
WIRING GP-GRADE CONTROL
WIRING GP-LIGHTING
WIRING GP-LUBRICATION
WIRING GP-MONITOR
WIRING GP-REAR
WIRING GP-REAR LIGHTING
WIRING GP-SECONDARY STEERING
WIRING GP-SENSOR
WIRING GP-UNIT INJECTOR
POWER TRAIN
AUTOSHIFT AR
AXLE GP-REAR
BASE GP-OIL FILTER
CARRIER GP-FINAL DRIVE
CASE & PARTS GP-PLANETARY
CHAIN GP-DRIVE
CLUTCH GP-TRANSMISSION
CONTROL GP-DIFFERENTIAL LOCK
CONTROL GP-TRANSMISSION HYD
COOLER GP-TRANSMISSION OIL
COUPLING GP-TORSIONAL
COVER GP-SHIPPING
DIFFERENTIAL GP
FILLER GP-POWER TRAIN OIL
FILTER & MTG GP-OIL
FILTER GP-OIL
FINAL DRIVE GP
GEAR GP-BEVEL & PINION
LINES GP-POWER TAKE-OFF
LINES GP-TRANSMISSION OIL
MOUNTING GP-WHEEL
PUMP GP-GEAR
SCREEN GP-MAGNETIC
SHAFT GP-DRIVE
SHAFT GP-INPUT
TANDEM & COVER GP
TIRE & RIM AR
TIRE GP
TRANSMISSION AR
VALVE & MTG GP-SOLENOID
VALVE GP-MODULATING
VALVE GP-RELIEF
WHEEL & TIRE AR
WHEEL & TIRE GP
WHEEL AR
WHEEL GP
FRAME AND BODY
AXLE AR-FRONT
AXLE AS-FRONT
AXLE GP-FRONT
COVER GP-CONTROL VALVE
ENCLOSURE GP-ENGINE
FENDER & SUPPORT GP
FRAME GP-FRONT
FRAME GP-REAR
GUARD GP-BOTTOM
GUARD GP-DEBRIS
HITCH GP-ARTICULATING
HITCH GP-TOWING
LINES GP-LUBRICATION
LINK GP-STEERING
LUBRICATION AR-AUTOMATIC
MOUNTING GP-AXLE
MOUNTING GP-VALVE
PUMP GP-LUBRICATION
REFLECTOR GP
SHIELD GP-ENGINE COMPARTMENT
STEP GP
SUPPORT AR-REAR CHASSIS
SUPPORT GP-FUEL TANK
WALKWAY GP
BRAKING SYSTEM
ACCUMULATOR GP-BRAKE
BRAKE GP-PARKING
CONTROL GP-SERVICE BRAKE
LINES GP-SERVICE BRAKE
HYDRAULIC SYSTEM
ACCUMULATOR GP-HYDRAULIC
CONTROL AR-HYDRAULIC
COOLER GP-HYDRAULIC OIL
CYLINDER & MTG GP-ARTICULATION
CYLINDER & MTG GP-BLADE LIFT
CYLINDER & MTG GP-BLADE TIP
CYLINDER & MTG GP-CENTERSHIFT
CYLINDER & MTG GP-SIDESHIFT
CYLINDER & MTG GP-STEERING
CYLINDER GP-ARTICULATION
CYLINDER GP-BLADE TIP
CYLINDER GP-CENTERSHIFT
CYLINDER GP-LIFT
CYLINDER GP-RIPPER
CYLINDER GP-SIDESHIFT
CYLINDER GP-STEERING
CYLINDER GP-WHEEL LEAN
DRIVE GP-CIRCLE
FILTER GP-OIL
FLOAT AR-BLADE
HYDRAULIC AR
LINES GP-ACCUMULATOR
LINES GP-CENTERSHIFT LOCK
LINES GP-HYDRAULIC
LINES GP-HYDRAULIC FAN
LINES GP-RIPPER
LINES GP-SECONDARY STEERING
LINES GP-STEERING
LOCK GP-CENTERSHIFT
MANIFOLD GP-CONTROL
MANIFOLD GP-VALVE
MOTOR GP-GEROTOR
PUMP & MOTOR GP
PUMP & MTG GP-HYDRAULIC FAN
PUMP & MTG GP-PISTON
PUMP GP-PISTON
ROTATING GP-PUMP
SWASHPLATE GP
SWIVEL GP
TANK & MTG GP-HYDRAULIC
TANK GP-HYDRAULIC
VALVE GP-BANK 3
VALVE GP-BANK 4
VALVE GP-BANK 5
VALVE GP-BANK 6
VALVE GP-BANK 7
VALVE GP-CHECK
VALVE GP-CONTROL
VALVE GP-DIVERTER
VALVE GP-PRESSURE REDUCING
VALVE GP-PUMP CONTROL
VALVE GP-RELIEF
VALVE GP-SHUTTLE
VALVE GP-SOLENOID
VALVE GP-SOLENOID & MANIFOLD
VALVE GP-STEERING
IMPLEMENTS
CIRCLE & BEAM AS
CIRCLE GP
DRAWBAR GP
PLATE GP-PUSH
WORK TOOLS
BIT GP
BIT GP-END
BLADE GP
EDGE GP-CUTTING
EXTENSION GP-BLADE
LIFT GP-BLADE
MAST GP
MOUNTING GP-MAST
MOUNTING GP-RIPPER
RIPPER AR
RIPPER GP
TOOTH GP-RIPPER
OPERATOR STATION
ADJUSTER GP-SEAT
AIR COMPRESSOR GP-SEAT
AIR CONDITIONER & MOUNTING GP
AIR CONDITIONER GP
ARMREST GP
BRACKET GP-MOUNTING
CAB AR
COIL GP-VALVE
COMPRESSOR GP-REFRIGERANT
CONTROL & MTG GP-JOYSTICK
CONTROL GP-AIR & TEMPERATURE
ELECTROHYDRAULIC
CONTROL GP-JOYSTICK
CONTROL GP-UNPRGMED MONITOR
COVER GP-CAB
CUSHION GP-ARM
DISPLAY AR-MONITOR
DISPLAY GP-MONITOR
DOOR GP-CAB
DUCT & FILTER GP-CAB AIR
FAN GP-DEFROSTER
HORN GP-AIR
HORN GP-ELECTRIC
HOUSING GP-SEAT SUSPENSION
LINER GP-CAB
LINES GP-AIR CONDITIONER
LINES GP-HEATER
MIRROR GP-REAR VIEW
MONITOR AS
MOTOR GP-WINDOW WIPER
MOUNTING GP-ANTENNA
MOUNTING GP-CAB
MOUNTING GP-CONTROL VALVE
MOUNTING GP-PLATFORM
PAN GP-BACKREST
PANEL GP-CAB
PANEL GP-CONTROL
PANEL GP-INSTRUMENT
PEDAL GP-BRAKE, TMSN & GOV
RADIO GP
RECLINER GP-SEAT
ROOF GP-CAB
SCREEN GP-SUN
SEAT & MOUNTING GP
SEAT GP
SEAT GP-SUSPENSION
SUPPORT GP-CONTROL
SUPPORT GP-LIGHT
SUSPENSION GP-SEAT
TANK GP-WINDOW WASHER
WINDOW GP-CAB
WIPER & WASHER GP-WINDOW
WIPER GP-WINDOW
SERVICE EQUIPMENT AND SUPPLIES
FILM GP
FILM-IDENTIFICATION
FILM GP
GREASE GUN GP
PLATE & FILM GP
TOOL GP-HAND
PART NUMBER INDEX
Brand: Caterpillar
Back to Main Menu
Parts Manual
16M Motor Grader
TABLE OF CONTENTS
GENERAL INFORMATION
REPAIR ALTERNATIVES
MAINTENANCE PARTS
INDEX
INDEX (French)
INDICE (Spanish)
ÍNDICE (Portuguese)
MACHINE ARRANGEMENT
COMMON AR
OPTION AR-EU
ENGINE ARRANGEMENT
ENGINE AR-COMPLETE
ENGINE AR-CORE
BASIC ENGINE
ACTUATOR GP-VALVE
CAMSHAFT GP
CRANKSHAFT GP
CYLINDER BLOCK AS
CYLINDER BLOCK GP
CYLINDER HEAD AS
CYLINDER HEAD GP
DAMPER GP
DRIVE GP-ACCESSORY
FLYWHEEL GP
GEAR GP-FRONT
GEAR GP-REAR
HOUSING GP-FLYWHEEL
HOUSING GP-FRONT
LIFTER GP-VALVE
LIFTING GP-ENGINE
PAN GP-OIL
PISTON & ROD GP
PLUG GP-ENGINE
ROCKER ARM GP
SEAL GP-CRANKSHAFT
SUPPORT GP-ENGINE
VALVE MECHANISM GP
LUBRICATION SYSTEM
BASE GP-OIL FILTER
BREATHER GP
FUMES DISPOSAL GP
PUMP GP-ENGINE OIL
COOLING SYSTEM
COOLING AR
FAN & MOTOR GP
GUARD GP-FAN
LINES GP-WATER
RADIATOR GP
TANK GP-COOLANT
AFTERCOOLER GP-AIR
AIR CLEANER GP
LINES GP-AIR
MANIFOLD GP-EXHAUST
MANIFOLD GP-INLET
MUFFLER GP
PRECLEANER GP
TURBOCHARGER GP
FUEL SYSTEM
FILTER GP-FUEL
INJECTOR GP-FUEL
LINES GP-FUEL
TANK GP-FUEL
VALVE GP-CHECK
ALARM GP
BATTERY GP
CAMERA AR
GRADE CONTROL AR
GRADE CONTROL GP
LAMP GP-DOME
LAMP GP-FLOOD
LAMP GP-HEAD
LAMP GP-SIGNAL
LIGHTING GP-BACKUP
LIGHTING GP-FLOOD
LIGHTING GP-ROADING
MOTOR GP-ELECTRIC
MOUNTING GP-LAMP
POWER SUPPLY GP
RECEIVER AR-LASER
RECEIVER GP-LASER
SENSOR AR-GRADE
SENSOR GP-ENGINE
SENSOR GP-POSITION
SENSOR GP-PRESSURE
SENSOR GP-SONIC
SENSOR GP-SPEED
SWITCH GP-BYPASS
SWITCH GP-LIGHT
SWITCH GP-LIMIT
SWITCH GP-MAGNETIC
SWITCH GP-PRESSURE
SWITCH GP-ROADING
SWITCH GP-ROCKER
SWITCH GP-WIPER
WARNING GP-BACKUP
WIRING GP-CAB
WIRING GP-CAMERA
WIRING GP-FRONT
WIRING GP-LIGHTING
WIRING GP-MONITOR
WIRING GP-REAR
WIRING GP-SENSOR
POWER TRAIN
AUTOSHIFT AR
AXLE GP-REAR
BASE GP-OIL FILTER
CHAIN GP-DRIVE
COVER GP-SHIPPING
DIFFERENTIAL GP
FILTER & MTG GP-OIL
FILTER GP-OIL
FINAL DRIVE GP
MOUNTING GP-WHEEL
PUMP GP-GEAR
SCREEN GP-MAGNETIC
SHAFT GP-DRIVE
SHAFT GP-INPUT
TANDEM & COVER GP
TIRE & RIM AR
TIRE GP
TRANSMISSION AR
VALVE GP-MODULATING
VALVE GP-RELIEF
WHEEL & TIRE AR
WHEEL & TIRE GP
WHEEL AR
WHEEL GP
FRAME AND BODY
AXLE AR-FRONT
AXLE AS-FRONT
AXLE GP-FRONT
ENCLOSURE GP-ENGINE
FENDER & SUPPORT GP
FRAME GP-FRONT
FRAME GP-REAR
GUARD GP-BOTTOM
GUARD GP-DEBRIS
HITCH GP-TOWING
LINK GP-STEERING
MOUNTING GP-AXLE
MOUNTING GP-VALVE
PUMP GP-LUBRICATION
REFLECTOR GP
STEP GP
WALKWAY GP
BRAKING SYSTEM
BRAKE GP-PARKING
HYDRAULIC SYSTEM
CYLINDER GP-LIFT
CYLINDER GP-RIPPER
DRIVE GP-CIRCLE
FILTER GP-OIL
FLOAT AR-BLADE
HYDRAULIC AR
LINES GP-HYDRAULIC
LINES GP-RIPPER
LINES GP-STEERING
LOCK GP-CENTERSHIFT
MANIFOLD GP-CONTROL
MANIFOLD GP-VALVE
MOTOR GP-GEROTOR
PUMP & MOTOR GP
PUMP GP-PISTON
ROTATING GP-PUMP
SWASHPLATE GP
SWIVEL GP
TANK GP-HYDRAULIC
VALVE GP-BANK 3
VALVE GP-BANK 4
VALVE GP-BANK 5
VALVE GP-BANK 6
VALVE GP-BANK 7
VALVE GP-CHECK
VALVE GP-CONTROL
VALVE GP-DIVERTER
VALVE GP-RELIEF
VALVE GP-SHUTTLE
VALVE GP-SOLENOID
VALVE GP-STEERING
IMPLEMENTS
CIRCLE & BEAM AS
CIRCLE GP
DRAWBAR GP
PLATE GP-PUSH
WORK TOOLS
BIT GP
BIT GP-END
BLADE GP
EDGE GP-CUTTING
EXTENSION GP-BLADE
LIFT GP-BLADE
MAST GP
MOUNTING GP-MAST
MOUNTING GP-RIPPER
RIPPER AR
RIPPER GP
TOOTH GP-RIPPER
OPERATOR STATION
ADJUSTER GP-SEAT
AIR CONDITIONER GP
ARMREST GP
BRACKET GP-MOUNTING
CAB AR
COIL GP-VALVE
ELECTROHYDRAULIC
CONTROL GP-JOYSTICK
COVER GP-CAB
CUSHION GP-ARM
DISPLAY AR-MONITOR
DISPLAY GP-MONITOR
DOOR GP-CAB
FAN GP-DEFROSTER
HORN GP-AIR
HORN GP-ELECTRIC
LINER GP-CAB
LINES GP-HEATER
MIRROR GP-REAR VIEW
MONITOR AS
MOUNTING GP-ANTENNA
MOUNTING GP-CAB
PAN GP-BACKREST
PANEL GP-CAB
PANEL GP-CONTROL
PANEL GP-INSTRUMENT
RADIO GP
RECLINER GP-SEAT
ROOF GP-CAB
SCREEN GP-SUN
SEAT & MOUNTING GP
SEAT GP
SEAT GP-SUSPENSION
SUPPORT GP-CONTROL
SUPPORT GP-LIGHT
SUSPENSION GP-SEAT
WINDOW GP-CAB
WIPER GP-WINDOW
FILM GP
FILM-IDENTIFICATION
FILM GP
GREASE GUN GP
PLATE & FILM GP
TOOL GP-HAND
PART NUMBER INDEX
- CAT 416D Parts Manual
- CAT 420D Parts Manual
