CAT Mining Shovel 6015B Testing and Adjusting UENR5685
Brand: Caterpillar
Type of Machine: Mining Shovel
Type of Manual: Testing and Adjusting Manual
Model: CAT 6015B Mining Shovel
Serial Number: LWN 1-UP (Machine), WSN 1-UP (Machine)
Part Number: UENR5685
Publication Date: 2015
Number of Pages: 58 Pages
General Testing and Adjusting Information
Visual Inspection
System Pressure - Release
Hydraulic System Warm-Up
Main Hydraulic Pump Air - Purge
Performance Tests
Operational Checks
Engine Performance - Test (Engine Speed)
Travel on Level Ground - Test
Travel on Level Ground - Test (Optional Test)
Machine Drift on a Slope - Check
Swing Speed and Overswing on Level Ground -
Check
Swing Speed and Swing Drift on a Slope - Check
Cylinder Drift - Check (Loaded Bucket)
Cylinder Drift - Check (Empty Bucket)
Cylinder Speed - Check
Pilot System
Relief Valve (Pilot) - Test and Adjust
Pressure Reducing Valve (Pilot Oil) - Test and
Adjust
Accumulator (Pilot) - Test and Charge
Accumulator (Track Tension) - Test and Charge
Relief Valve (Track Tension) - Test and Adjust
Calibration
Main Control Valve - Calibrate (Implement Control
Valves)
Main Control Valve - Calibrate (Travel Control Valve
Calibrations)
Main Control Valve - Calibrate (Swing Control
Valves)
Main Pump - Calibrate (Main Hydraulic Pump
Displacement Control Valve)
Engine Cooling Fan - Calibrate
Machine Cooling Fan - Calibrate
Sensor - Calibrate (Main Hydraulic Pump
Displacement Sensor)
Sensor - Calibrate (Swing Hydraulic Pump
Main Control Valve
Relief Valve (Load Sensing Signal) - Test and
Adjust
Relief Valve (Line) - Test and Adjust
Swing System
Swing System Pressure - Check
Reference Specifications
Specifications
Brand: Caterpillar
Visual Inspection
Performance Tests
Operational Checks
Check
Pilot System
Adjust
Calibration
Valves)
Calibrations)
Valves)
Main Control Valve
Adjust
Swing System
Specifications
- CAT 416D Parts Manual
- CAT 420D Parts Manual
