Hyundai
86
176,834
CAT Load Haul Dump R2900G Parts Manual SEBP3610-00
Brand: CAT
Type of Machine: Load Haul Dump
Model: CAT R2900G Load Haul Dump
Part Number: SEBP3610-00
Publication Date: 2004
Number of Pages: 776 Pages
KIT GROUPS
ELECTRICAL CONNECTORS
MACHINE ARRANGEMENT
CERTIFICATION AR-MACHINE
COMMON AR
ENGINE ARRANGEMENT
CONVERSION AR-ENGINE
ENGINE AR-COMPLETE
INSTALLATION AR-ENGINE
BASIC ENGINE
ADAPTER GP-AUXILIARY DRIVE
BASE GP-VALVE COVER & INJ HARN
BELT TIGHTENER GP
CAMSHAFT GP
COVER GP-AIR COMPRESSOR
COVER GP-CYLINDER BLOCK
COVER GP-FRONT HOUSING
COVER GP-VALVE MECHANISM
CRANKSHAFT GP
CYLINDER BLOCK GP
CYLINDER HEAD AS
CYLINDER HEAD GP
DAMPER GP
DRIVE GP-FAN
DRIVE GP-PUMP
FASTENER GP-FRONT HOUSING
FASTENER GP-OIL PAN
FASTENER GP-VALVE MECHANISM
FLYWHEEL GP
GEAR GP-FRONT
HOUSING GP-FLYWHEEL
HOUSING GP-FRONT
LIFTING GP-ENGINE (REAR)
LIFTING GP-ENGINE (FRONT)
MECHANISM GP-FUEL PUMP & VALVE
MOUNTING GP-ALTERNATOR
MOUNTING GP-ENGINE (FRONT)
MOUNTING GP-ENGINE (REAR)
PAN GP-OIL
PISTON & ROD GP
PLUG GP-CYLINDER BLOCK
PLUG GP-CYLINDER HEAD
PULLEY GP-AUXILIARY DRIVE
ROCKER ARM GP
SUPPORT GP-ENGINE
TRUNNION GP-ENGINE
LUBRICATION SYSTEM
DRAIN GP-HIGH SPEED FLUID
FASTENER GP-OIL PUMP MOUNTING
FILLER GP-ENGINE OIL
FUMES DISPOSAL GP
GUIDE GP-OIL LEVEL GAUGE
LINES GP-ENGINE OIL
LINES GP-ENGINE OIL DRAIN
LINES GP-TURBOCHARGER OIL
PUMP GP-ENGINE OIL
COOLING SYSTEM
COOLANT CONDITIONER GP
COOLER AR-AXLE OIL
DRAIN GP-HIGH SPEED FLUID (RADIATOR EVACUATION)
FAN GP-BLOWER
FITTING GP-RADIATOR VENT
LINES GP-AXLE OIL COOLER (FRONT AXLE)
LINES GP-AXLE OIL COOLER (REAR AXLE)
LINES GP-AXLE OIL COOLER (FRONT)
LINES GP-HYDRAULIC OIL COOLER
LINES GP-HYDRAULIC OIL COOLER (REAR)
LINES GP-OIL COOLER
LINES GP-TORQUE CONV COOLER
LINES GP-WATER
PUMP GP-WATER
RADIATOR GP
RADIATOR GP-BASIC
AIR INLET AND EXHAUST SYSTEM
AIR CLEANER GP
ELBOW GP-AIR INLET
EXHAUST AR-PARTICULATE FILTER
EXHAUST GP-PARTICULATE FILTER
EXHAUST GP-PURIFIER
LINES GP-AIR
LINES GP-EXHAUST BACK PRESSURE
MANIFOLD GP-EXHAUST
TURBOCHARGER GP
FUEL SYSTEM
ADAPTER GP-FAST FILL FUEL
ADAPTER GP-FUEL FILL
FILTER GP-FUEL
LINES GP-FUEL (ENGINE)
PUMP GP-FUEL INJECTION
PUMP GP-FUEL PRIMING
PUMP GP-FUEL TRANSFER
SHUTOFF GP-MANUAL (FUEL LINE)
VALVE GP-CHECK
ELECTRICAL AND STARTING SYSTEM
ALARM GP
ALTERNATOR GP-CHARGING
BATTERY & WIRING GP
CONNECTION GP-ELECTRICAL
CONTROL & MTG GP-COMMUNICATION
CONTROL & MTG GP-ELECTRONIC
CONTROL & MTG GP-ENGINE ELEK
CONTROL AR-COMMUNICATION (EAM)
CONTROL GP-COMMUNICATION
CONTROL GP-ROTARY POS SENSOR
ELECTRICAL AR
ELECTRONICS GP-MONITOR
ELECTRONICS GP-TRANSMISSION
LAMP GP-DOME
LAMP GP-FLOOD
LAMP GP-HEAD
LIGHTING GP-CAB
LIGHTING GP-FRONT
LIGHTING GP-REAR
LIGHTING GP-STOP
LIGHTING GP-WARNING
MOTOR GP-ELEC HYD PUMP
MOUNTING GP-SENSOR
PANEL GP-CIRCUIT BREAKER
RECEPTACLE GP-AUXILIARY START
SENDER GP
SENSOR GP-ENGINE
SENSOR GP-PRESSURE
SENSOR GP-ROTARY POSITION
SENSOR GP-TRANSMISSION
SOLENOID AS
STARTING MOTOR GP-ELECTRIC
SWITCH AS-DISCONNECT
SWITCH AS-TOGGLE
SWITCH GP-BRAKE
SWITCH GP-FLOW
SWITCH GP-LIFT ARM POSITIONER
SWITCH GP-MANUAL
SWITCH GP-RIDE CONTROL
SWITCH GP-SHUTDOWN
SWITCH GP-TEMPERATURE
WARNING GP-BACKUP
WIRING GP-CAB (INSULATOR)
WIRING GP-CAB (LOWER)
WIRING GP-CAB
WIRING GP-CAB (UPPER)
WIRING GP-COMMUNICATION
WIRING GP-ENGINE
9EQ5167 WIRING GP-FIRE SUPPRESSION
WIRING GP-FRONT
WIRING GP-REAR
POWER TRAIN
AXLE AR-FIXED
AXLE AR-FIXED (FRONT)(XTRA)
AXLE AR-OSCILLATING
AXLE GP-FIXED
AXLE GP-FIXED (FRONT)
AXLE GP-OSCILLATING
CASE & PARTS GP-PLANETARY
CONTROL GP-STIC
CONTROL GP-TRANSMISSION
CONTROL GP-TRANSMISSION HYD
COVER GP-FRONT
COVER GP-SHIPPING
DIFFERENTIAL & BEVEL GEAR GP
DIFFERENTIAL GP
DRAIN GP-HIGH SPEED FLUID (TRANSMISSION EVACUATION)
FILLER GP-POWER TRAIN OIL
FILTER GP-OIL
FINAL DRIVE & BRAKE GP
FINAL DRIVE & BRAKE GP (XTRA)
FINAL DRIVE GP
GAUGE GP-OIL LEVEL
GEAR & CASE GP-OUTPUT TRANSFER
LINES GP-AXLE VENT (FRONT)
LINES GP-AXLE VENT (REAR)
LINES GP-TORQUE CONV SUCTION
LINES GP-TRANSMISSION FILTER
LINES GP-TRANSMISSION OIL
LINES GP-TRANSMISSION OIL (LUBRICATION)
MOUNTING GP-DIFFERENTIAL
MOUNTING GP-RIM
PLANETARY GP-TRANSMISSION
POWER TRAIN AR
PUMP & MTG GP-CHARGE
PUMP & MTG GP-TRANSMISSION
PUMP GP-CHARGE
PUMP GP-GEAR
RIM AR AN ATTACHMENT
RIM AR (XTRA)
RIM GP-DEMOUNTABLE
RIM GP-DEMOUNTABLE (XTRA)
SHAFT GP-DRIVE
SLIP JOINT GP
SUPPORT GP-DIFFERENTIAL
SUPPORT GP-DIFFERENTIAL (FRONT)
SUPPORT GP-TRANSMISSION (FRONT)
SUPPORT GP-TRANSMISSION (REAR)
TIRE GP (XTRA)
TIRE GP
TORQUE CONVERTER & UPDRIVE AR
TORQUE CONVERTER & UPDRIVE GP
TORQUE CONVERTER GP
TRANSMISSION AR
UNIVERSAL JOINT GP
VALVE GP-DRAIN
VALVE GP-RELIEF
VALVE GP-SELECTOR
VALVE GP-SELECTOR & PRESS CONT
VALVE GP-SOLENOID
VALVE GP-TRANSMISSION CONTROL
FRAME AND BODY
CHASSIS AR PAGE:
COVER GP-BRAKE RELEASE
COVER GP-DECK
COVER GP-DECK (XTRA)
DRAWBAR GP
FENDER GP-FRONT
FENDER GP-FRONT (XTRA)
FENDER GP-REAR
FENDER GP-REAR (XTRA)
FILTER GP-GREASE
FIRE EXTINGUISHER GP
FIREWALL GP
FRAME GP-ENGINE END
FRAME GP-NONENGINE END
GRILL GP-RADIATOR
GUARD GP-BOTTOM
GUARD GP-BRAKE LINES
GUARD GP-DRIVE SHAFT
GUARD GP-LIGHT
GUARD GP-RADIATOR
HITCH GP-ARTICULATED
HOOD GP
LINES GP-CENTRAL LUBRICATION
LINES GP-FIRE SUPPRESSION (AUTO DETONATION)
LINES GP-LUBRICATION (BANK 1)
LINK GP-STEERING FRAME LOCK
LUBRICATION AR-AUTOMATIC (HYDRAULIC)
LUBRICATION AR-CENTRAL
LUBRICATION AR-SEMI CENTRAL
MOUNTING GP-CAB (XTRA)
PIN GP-DRAWBAR
PUMP GP-LUBRICATION
SUPPRESSION AR-FIRE AN ATTACHMENT
TREAD GP-NONSKID
VALVE GP-LUBE DISTRIBUTION
BRAKING SYSTEM
BRAKE GP
BRAKE RELEASE AR
CONTROL GP-FOOT BRAKE
CONTROL GP-SERVICE BRAKE
CYLINDER GP-BRAKE RELEASE
HOOK GP-BRAKE RELEASE
LINES GP-BRAKE (FRONT AXLE)
LINES GP-BRAKE (REAR AXLE)
LINES GP-BRAKE BLEEDER
LINES GP-BRAKE RELEASE
LINES GP-PARKING BRAKE
LINES GP-SERVICE BRAKE
STEERING SYSTEM
BODY GP-VALVE
CONTROL GP-STEERING (WHEEL STEER)
CONTROL GP-STEERING (STIC STEER)
CYLINDER & MTG GP-STEERING
CYLINDER & SEAL GP-STEERING
CYLINDER GP-STEERING
LINES GP-SECONDARY STEERING
LINES GP-STEERING (STIC STEER)
LINES GP-STEERING (WHEEL STEER)
LINES GP-STEERING CYLINDER
LINES GP-STEERING NEUTRALIZER (STIC STEER)
LINES GP-STEERING PILOT (WHEEL STEER)
PUMP & MTG GP-STEERING
PUMP GP-METERING
PUMP GP-SECONDARY STEERING
PUMP GP-STEERING
STEERING AR-SECONDARY
STEERING AR-STIC (XTRA)
STEERING AR-WHEEL
VALVE GP
VALVE GP-DIVERTER
VALVE GP-PILOT
VALVE GP-RELIEF
VALVE GP-STEERING
VALVE GP-STEERING NEUTRALIZER
HYDRAULIC SYSTEM
CONTROL AR-RIDE
CYLINDER & SEAL GP-LIFT
CYLINDER GP-LIFT
CYLINDER GP-TILT
DRAIN GP-HIGH SPEED FLUID (HYD TANK EVACUATION)
HYDRAULIC AR
LINES GP-HYDRAULIC (FRONT)
LINES GP-HYDRAULIC (REAR)
LINES GP-LIFT CYLINDER
LINES GP-PAYLOAD
LINES GP-PILOT
LINES GP-PILOT (REAR)
LINES GP-PILOT (FRONT)
LINES GP-PILOT NEUTRALIZER
LINES GP-PILOT RETURN
LINES GP-RIDE CONTROL
LINES GP-TILT CYLINDER
MOUNTING GP-HYDRAULIC TANK
PUMP GP-GEAR
TANK & FILTER GP-HYDRAULIC
VALVE & MTG GP-IMPLEMENT
VALVE GP
VALVE GP-CONTROL
VALVE GP-DIVERTER
VALVE GP-PILOT
VALVE GP-RELIEF
VALVE GP-SHUTTLE
VALVE GP-SOLENOID
IMPLEMENTS
CONTROL GP-BUCKET
STOP GP-BUCKET
WORK TOOLS
BUCKET AS
BUCKET AS-LIGHT MATERIAL
BUCKET AS-PENETRATION
HARDWARE GP-WORK TOOLS
OPERATOR STATION
AIR CONDITIONER AR
AIR CONDITIONER AR (XTRA)
AIR CONDITIONER GP
ARMREST GP
BOTTLE GP-WINDOW WASHER
CAB AR-ENCLOSED ROPS (WHEEL STEER)
CAB AR-OPEN ROPS (STIC STEER)
CAB GP-ENCLOSED ROPS
CAB GP-OPEN ROPS
COMPARTMENT GP-LITERATURE
COMPRESSOR GP-CLUTCH & REFRIG
COVER AS-PROTECTIVE
COVER GP-ENCLOSED ROPS (WHEEL STEER)
COVER GP-OPEN ROPS (WHEEL STEER)
COVER GP-SEAT
DOOR GP-ENCLOSED ROPS
DOOR GP-OPEN ROPS
HANDHOLD GP
HEATER AR-CAB
HORN GP-ELECTRIC
INSTALLATION GP-RADIO
LATCH GP
LINER GP-CAB 528
LINES GP-AIR CONDITIONER
LINES GP-HEATER
LINES GP-WASHER
MODULE GP-QUAD GAUGE ELEK
MODULE GP-SPEED/TACH ELEK
MONITOR AR-PAYLOAD (OPEN ROPS)
MONITOR GP-PAYLOAD (ENCLOSED ROPS)
MOUNTING GP-PRESSURIZER
OPERATOR AR-ENCLOSED ROPS (STIC STEER)
OPERATOR AR-OPEN ROPS (WHEEL STEER)
PANEL GP-INSTRUMENT
PANEL GP-SWITCH
PANEL GP-WARNING
PEDAL GP-THROTTLE
PRESSURIZER GP
PROTECTOR GP-SEAT
SEAT BELT GP
SEAT GP-SUSPENSION
SEAT GP-SUSPENSION (TEE SEAT)
WINDOW GP (ENCLOSED ROPS)
WIPER GP-DOOR (ENCLOSED ROPS)
WIPER GP-WINDOW
REMOTE CONTROL SYSTEM
HARNESS GP-INTERCONNECT
LAMP GP-SIGNAL
LIGHTING GP-WARNING
LINES GP-REMOTE CONTROL
MOUNTING GP-RECEIVER
REMOTE CONTROL AR (PROPORTIONAL)
SWITCH GP-REMOTE CONTROL
TRANSMITTER & RECEIVER AR (PROPORTIONAL)
VALVE GP-CONTROL (PROPORTIONAL)
VALVE GP-SOLENOID (BRAKE CONTROL)
WIRING GP-REMOTE CONTROL (PROPORTIONAL)
SERVICE EQUIPMENT AND SUPPLIES
BAR GP-RECOVERY
BOLT GP-COLLET JACKING
FILM GP
FRAME-TIRE INSTALLATION
IDENTIFICATION-RIM AN ATTACHMENT
KIT-SERVICE (AIR CLEANER)
LIFTING GP
LIFTING GP-SEAT
LIFTING GP-TILT CYLINDER
PLATE & FILM GP (ENGINE)
PUMP & LINES GP-HYDRAULIC (PORTABLE)
PUMP GP-ELECTRIC DRIVE
SERVICE GP-OIL SAMPLE
STAND GP-FRAME
TEMPLATE GP-WINDOW GLASS (ENCLOSED ROPS)
TOOL GP-BRAKE DISC ALIGNMENT
TOOL-DIAGNOSTIC SERVICE BOX
TOOL-LIFT ARM PIN LIFTING
TOOL-WHEEL NUT EXT SOCKET
TOOLS
PART NUMBER INDEX
GENERAL INFORMATION
INDEX
MACHINE ARRANGEMENT
CONVERSION AR-MACHINE (LARGE TIRE FITMENT)
LUBRICATION SYSTEM
FILTER GP-ENGINE OIL
COOLING SYSTEM
FUEL SYSTEM
SWITCH GP-SHUTDOWN (GROUND OPERATED-LH)
POWER TRAIN
TIRE GP
FRAME AND BODY
BAR GP-WEAR
BAR GP-WEAR (HYDRAULIC TANK)(XTRA)
BAR GP-WEAR
HOOD GP-SOLID
LINES GP-FIRE SUPPRESSION (DRY POWDER SYSTEM)
STEERING SYSTEM
LINES GP-REVERSIBLE STEERING (STIC STEER)
LINES GP-REVERSIBLE STEERING (WHEEL STEER)
WORK TOOLS
BUCKET AS (8.4M3 SAE)
BUCKET AS-LIGHT MATERIAL (11.6M3 SAE)
BUCKET AS-LIGHT MATERIAL (11.6M3 SAE)(FULL SPADE)
PROTECTION GP
OPERATOR STATION
AIR CONDITIONER AR (SALT RESISTANT)
AIR CONDITIONER GP (SALT RESISTANT)
BAR GP-WEAR
DUCT GP-AIR
GUARD GP-WINDOW WITH ENCLOSED
LINES GP-AIR CONDITIONER (SALT RESISTANT)
MONITOR AR-PAYLOAD AN ATTACHMENT
PANEL GP-INSTRUMENT
SPRING GP-CAB DOOR
TRANSMITTER & RECEIVER GP (PROPORTIONAL)
WIRING GP-REMOTE CONTROL (PROPORTIONAL) PROPORTIONAL REMOTES
BAR GP-RECOVERY
FILM GP (REFLECTIVE)
PLATE & FILM GP
PLATE-MACHINE IDENTIFICATION
PART NUMBER INDEX
