Hyundai
86
176,834
CAT Load Haul Dump R1300G Parts Manual SEBP3603-03
Brand: CAT
Type of Machine: Load Haul Dump
Model: CAT R1300G Load Haul Dump
Part Number: SEBP3603-03
Publication Date: 2003
Number of Pages: 800 Pages
Back to Main Menu
Parts Manual
PRODUCT INFORMATION
GENERAL INFORMATION
TABLE OF CONTENTS
INDEX
KIT GROUPS
ELECTRICAL CONNECTORS
MACHINE ARRANGEMENT
COMMON AR
ENGINE ARRANGEMENT
CONVERSION AR-ENGINE
ENGINE AR-BASIC
INSTALLATION AR-ENGINE
BASIC ENGINE
ADAPTER GP-SEAL
CAMSHAFT GP
COVER GP-CYLINDER BLOCK
COVER GP-FRONT HOUSING
COVER GP-VALVE MECHANISM
CRANKSHAFT GP
CYLINDER BLOCK AS
CYLINDER BLOCK GP
CYLINDER HEAD AS
CYLINDER HEAD GP
DAMPER GP
DRAIN GP-ENGINE OIL
DRIVE GP-AUXILIARY
FASTENER GP-CYLINDER HEAD
FASTENER GP-FRONT HOUSING
FASTENER GP-OIL PAN
FLYWHEEL GP
GEAR GP-FRONT
GEAR GP-REAR
HOUSING GP-FLYWHEEL
HOUSING GP-FRONT
LIFTING GP-ENGINE
MOUNTING GP-ENGINE (FRONT)
MOUNTING GP-ENGINE & TMSN
MOUNTING GP-FAN DRIVE
PAN GP-OIL
PISTON & ROD GP
PULLEY GP
PULLEY GP-CRANKSHAFT
SEAL GP-CRANKSHAFT
SUPPORT GP-ENGINE
VALVE MECHANISM GP
LUBRICATION SYSTEM
BASE GP-OIL FILTER
BREATHER GP
DRAIN GP-HIGH SPEED FLUID (ENGINE SUMP EVACUATION)
FILLER GP-ENGINE OIL
FUMES DISPOSAL GP
GAUGE GP-OIL LEVEL (DIPSTICK)
LINES GP-ENGINE OIL
LINES GP-TURBOCHARGER OIL
PUMP GP-ENGINE OIL
COOLING SYSTEM
COOLER GP-FLTR BASE & ENG OIL
COOLER GP-HYDRAULIC OIL
COOLER GP-TRANSMISSION OIL
DRAIN GP-HIGH SPEED FLUID (RADIATOR EVACUATION)
FAN & GUARD GP-BLOWER
HOUSING & REGULATOR GP
LINES GP-AFTERCOOLER WATER
LINES GP-HYDRAULIC OIL COOLER
LINES GP-TORQUE CONV COOLER
LINES GP-WATER
PUMP GP-WATER
RADIATOR GP
RADIATOR GP-BASIC
AIR INLET AND EXHAUST SYSTEM
ADAPTER GP-TURBOCHARGER
AFTERCOOLER GP-WATER
AIR CLEANER GP
EXHAUST GP-PURIFIER
LINES GP-AIR
MANIFOLD GP-EXHAUST
SHIELD AR-EXHAUST
SHIELD GP-EXHAUST
SHIELD GP-MANIFOLD
TURBOCHARGER GP
FUEL SYSTEM
ADAPTER GP-FAST FILL FUEL
ADAPTER GP-FUEL FILL
CONTROL GP-FUEL RATIO
CYLINDER & MTG GP-SLAVE
CYLINDER GP-SLAVE
FASTENER GP-FUEL INJ PUMP
FILTER AS-FUEL
FILTER GP-SECONDARY FUEL
GOVERNOR GP
LINES GP-DRAIN
LINES GP-FUEL
LINES GP-FUEL INJECTION
PUMP & MTG GP-FUEL TRANSFER
PUMP GP-FUEL INJECTION
PUMP GP-FUEL PRM & PRIM FILTER
PUMP GP-FUEL TRANSFER
TORQUE CONTROL GP
ELECTRICAL AND STARTING SYSTEM
ALTERNATOR GP-CHARGING
BATTERY & WIRING GP
CONNECTION GP-SERVICE TOOL
CONTROL & MTG GP-ELECTRONIC
CONTROL GP-INTERMITTENT WIPER
CONTROL GP-THROTTLE
ELECTRICAL AR
ELECTRONICS GP-MONITOR
ELECTRONICS GP-TRANSMISSION
LAMP GP-DOME
LAMP GP-FLOOD
LAMP GP-HEAD
LAMP GP-SIGNAL
LIGHTING GP-CAB
LIGHTING GP-FRONT
LIGHTING GP-REAR
LIGHTING GP-STOP
MOTOR GP-ELEC HYD PUMP (SECONDARY STEERING)
MOUNTING GP-PRESSURE SENSOR
PANEL GP-CIRCUIT BREAKER
RECEPTACLE GP-AUXILIARY START
RELAY GP
SENDER GP
SENSOR GP-PRESSURE
SENSOR GP-TEMPERATURE
SENSOR GP-TRANSMISSION
SHUTOFF GP-ELECTRICAL
STARTING MOTOR GP-ELECTRIC
SWITCH AS-DISCONNECT
SWITCH GP-BRAKE (PULL TO ENGAGE PARKING)
SWITCH GP-BRAKE (PUSH TO ENGAGE PARKING)
SWITCH GP-FLOW
SWITCH GP-LIFT ARM POSITIONER
SWITCH GP-MAGNETIC
SWITCH GP-RIDE CONTROL
SWITCH GP-SHUTDOWN (GROUND OPERATED)
SWITCH GP-TRANSMISSION CONTROL
WARNING GP-BACKUP
WIRING GP-ALTERNATOR
WIRING GP-CAB (INSULATOR)
WIRING GP-CAB (LOWER)
WIRING GP-CAB (UPPER)(OPEN ROPS)
WIRING GP-CAB (UPPER)(ENCLOSED ROPS)
WIRING GP-DOOR
WIRING GP-ENGINE
WIRING GP-FRONT
WIRING GP-REAR
WIRING GP-SHUTOFF (IDLE TIMER)
POWER TRAIN
AXLE & TRANSFER CASE AR (OSCILLATING)
AXLE AR-FIXED
AXLE AR-FIXED (COMPLETE)
AXLE AR-OSCILLATING
AXLE AR-OSCILLATING (COMPLETE)
AXLE GP-FIXED
AXLE GP-OSCILLATING
CASE & PARTS GP-PLANETARY
CASE & PARTS GP-TORQUE CONV
CONTROL GP-STIC
CONTROL GP-TRANSMISSION HYD
DIFFERENTIAL & BEVEL GEAR GP
DIFFERENTIAL GP (FRONT)
DIFFERENTIAL GP-NOSPIN
DRAIN GP-HIGH SPEED FLUID (TRANSMISSION EVACUATION)
DRIVE GP-OUTPUT
FILTER & LINES GP-TRANSMISSION
FILTER GP-TRANSMISSION
GAUGE GP-OIL LEVEL
GEAR & CASE GP-OUTPUT TRANSFER
GEAR GP-BEVEL
JOINT GP
LINES GP-AXLE VENT (FIXED)
LINES GP-AXLE VENT (OSCILLATING)
LINES GP-TRANSMISSION OIL
MOUNTING GP-BULKHEAD
MOUNTING GP-RIM
PLANETARY GP
POWER TRAIN AR
PUMP GP-GEAR (TRANSMISSION)
RIM AR (3-PIECE)
RIM AR (5-PIECE)
RIM GP-DEMOUNTABLE (3-PIECE)
RIM GP-DEMOUNTABLE (5-PIECE)
SENSOR GP-TRANSMISSION (ABA)
SHAFT GP-DRIVE
TIRE GP
TORQUE CONVERTER GP
TRANSMISSION AR
TRANSMISSION AR-COMPLETE
VALVE GP-DRAIN
VALVE GP-RELIEF (TRANSMISSION)
VALVE GP-SELECTOR
VALVE GP-SELECTOR & PRESS CONT
VALVE GP-SOLENOID (TRANSMISSION)
VALVE GP-TRANSMISSION CONTROL
WHEEL & FINAL DRIVE GP
FRAME AND BODY
BAR GP-WEAR
BLOCK GP-LUBRICATION (UPPER)
BLOCK GP-LUBRICATION (FRONT)
BOTTLE & MTG GP-FIRE
CHASSIS AR
COVER GP-BRAKE RELEASE
COVER GP-DECK
COVER GP-DECK (OPEN ROPS)
COVER GP-DECK (ENCLOSED ROPS)
COVER GP-DECK
COVER GP-DECK (FRONT)
DRAWBAR GP
FENDER GP-FRONT
FENDER GP-REAR (LH)
FENDER GP-REAR (RH)
FILTER GP-GREASE
FIRE EXTINGUISHER GP (4.5KG)
FIRE EXTINGUISHER GP (9.0KG)
FRAME GP-ENGINE END
FRAME GP-NONENGINE END
GRID GP-SAND BLAST
GRILL GP-RADIATOR
GUARD AR-EXHAUST
GUARD GP-BOTTOM
GUARD GP-DRIVE SHAFT
GUARD GP-DRIVE SHAFT (HITCH)
GUARD GP-DRIVE SHAFT (TRANSMISSION)
GUARD GP-EXHAUST
GUARD GP-LIGHT
HITCH GP-ARTICULATED
HOOD GP
LINES GP-CENTRAL LUBRICATION
LINES GP-FIRE SUPPRESSION (AUTO DETONATION)
LINES GP-FIRE SUPPRESSION (DETONATION)
LINES GP-FIRE SUPPRESSION (REMOTE DETONATION)
LINES GP-FIRE SUPPRESSION (RETARDANT)
LINES GP-GREASE (EJECTOR BUCKET)
LINES GP-GREASE (FAN HUB)
LINES GP-GREASE (FRONT)
LINES GP-GREASE (REAR)
LINES GP-LUBRICATION (BANK 1)
LINES GP-LUBRICATION (BANK 2)
LINES GP-LUBRICATION (BANK 3)
LINES GP-PAYLOAD
LINK GP-STEERING FRAME LOCK
LUBRICATION AR-AUTOMATIC
LUBRICATION AR-AUTOMATIC (HYDRAULIC)
LUBRICATION AR-CENTRAL
LUBRICATION AR-SEMI CENTRAL
MOUNTING GP-BATTERY
MOUNTING GP-CAB (ROPS)
PIN GP-DRAWBAR
PUMP GP-LUBRICATION
PUMP GP-LUBRICATION (HYDRAULIC)
SUPPRESSION AR-FIRE
TREAD GP-NONSKID
VALVE GP-LUBE DISTRIBUTION
VALVE GP-SOLENOID
BRAKING SYSTEM
ACCUMULATOR & MOUNTING GP
ACCUMULATOR GP
BRAKE AR
BRAKE GP-SERVICE & PARKING
BRAKE RELEASE AR (RECOVERY BAR)
BRAKE RELEASE AR (RECOVERY HOOK)
CONTROL GP-FOOT BRAKE
CYLINDER GP-BRAKE RELEASE
GAUGE & LINES GP-BRAKE PRESS (UPPER)
HOOK GP-BRAKE RELEASE
LINES GP-BRAKE (LOWER)
LINES GP-BRAKE (FRONT AXLE)
LINES GP-BRAKE (REAR AXLE)
LINES GP-BRAKE CONTROL VALVE
LINES GP-BRAKE RELEASE
LINES GP-PARKING BRAKE
LINES GP-SERVICE BRAKE (FRONT)
VALVE & MTG GP-ACCUM CHARGING
VALVE GP-PARKING BRAKE
VALVE GP-SEQUENCE
VALVE GP-SHUTTLE
VALVE GP-SOLENOID
STEERING SYSTEM
BODY GP-VALVE
CONTROL GP-STEERING
CONTROL GP-STEERING (STIC STEER)
CONTROL GP-STEERING
CYLINDER & MTG GP-STEERING
CYLINDER & SEAL GP-STEERING
CYLINDER GP-STEERING
LINES GP-SECONDARY STEERING
LINES GP-STEERING (STIC STEER)
LINES GP-STEERING CONTROL (STIC STEER)
LINES GP-STEERING NEUTRALIZER
LINES GP-STEERING RETURN
LINES GP-STEERING SUPPLY
PUMP & MTG GP-SECONDARY STEER
PUMP GP-SECONDARY STEERING
STEERING AR-SECONDARY
STEERING AR-STIC (STIC STEER)
VALVE & MTG GP-DIVERTER (SECONDARY STEERING)
VALVE & MTG GP-STEERING
VALVE & MTG GP-STEERING NEUT
VALVE GP-DIVERTER (SECONDARY STEERING)
VALVE GP-PILOT
VALVE GP-STEERING
VALVE GP-STEERING NEUTRALIZER
HYDRAULIC SYSTEM
ACCUMULATOR & MTG GP-RIDE CONT
ACCUMULATOR GP
BLOCK GP-HYDRAULIC (IMPLEMENT VALVE)
BLOCK GP-HYDRAULIC (PILOT RETURN)
CARTRIDGE GP-FRONT
CARTRIDGE GP-REAR
CONTROL AR-RIDE
CYLINDER & MTG GP-EJECTOR
CYLINDER & SEAL GP-EJECTOR
CYLINDER & SEAL GP-LIFT
CYLINDER & SEAL GP-TILT
CYLINDER GP-EJECTOR (TYPE 1)
CYLINDER GP-EJECTOR (TYPE 2)
CYLINDER GP-LIFT
CYLINDER GP-TILT
DRAIN GP-HIGH SPEED FLUID (HYD TANK EVACUATION)
HYDRAULIC AR
HYDRAULIC AR-2 VALVE
HYDRAULIC AR-3 VALVE
KICKOUT & POSITIONER GP
LINES GP-DRAIN
LINES GP-EJECTOR BUCKET
LINES GP-GOVERNOR HYDRAULIC
LINES GP-HYDRAULIC
LINES GP-IMPLEMENT
LINES GP-IMPLEMENT (3 VALVE)
LINES GP-LIFT ARM POSITIONER
LINES GP-LIFT CYLINDER
LINES GP-PILOT (IMPLEMENT VALVE)
LINES GP-PILOT (HITCH)
LINES GP-PILOT (REAR)
LINES GP-PILOT (2 VALVE)
LINES GP-PILOT (3 VALVE)
LINES GP-PILOT NEUTRALIZER
LINES GP-PILOT RETURN
LINES GP-PILOT SUPPLY
LINES GP-RIDE CONTROL
LINES GP-TILT CYLINDER
POSITIONER AR-LIFT ARM
PUMP & MOUNTING GP
PUMP GP-VANE
TANK & FILTER GP-HYDRAULIC
TANK & MTG GP-HYDRAULIC
VALVE & LINES GP-PILOT CONTROL
VALVE & MOUNTING GP (IMPLEMENT VALVE)
VALVE GP
VALVE GP-CONTROL
VALVE GP-CONTROL (3 VALVE)
VALVE GP-CONTROL (IMPLEMENT VALVE)
VALVE GP-PILOT
VALVE GP-PRESSURE CONTROL
VALVE GP-PRESSURE REDUCING
VALVE GP-RELIEF
VALVE GP-RELIEF (3 VALVE)
VALVE GP-RELIEF
VALVE GP-SHUTTLE
VALVE GP-SOLENOID
IMPLEMENTS
BRACE GP-LIFT ARM
CONTROL GP-BUCKET
WORK TOOLS
BUCKET AR-EJECTOR
BUCKET AS (2.4M3 SAE)
BUCKET AS (2.8M3 SAE)
BUCKET AS (3.1M3 SAE)
BUCKET AS (3.4M3 SAE)
BUCKET GP-EJECTOR
HARDWARE GP-WORK TOOL
OPERATOR STATION
AIR CONDITIONER & MOUNTING GP
AIR CONDITIONER AR
AIR CONDITIONER GP
ARMREST GP
BAR GP-WEAR (ENCLOSED ROPS)
BAR GP-WEAR (OPEN ROPS)
BOTTLE GP-WINDOW WASHER
CAB AR-ENCLOSED ROPS
CAB AR-OPEN ROPS
CAB GP-ENCLOSED ROPS
CAB GP-OPEN ROPS
CANOPY GP-ROPS
COMPARTMENT GP-LITERATURE
COMPRESSOR GP-CLUTCH & REFRIG
COMPRESSOR GP-REFRIGERANT
CONDENSER & MOUNTING GP
CONTROL GP-MONITOR (PAYLOAD CONTROL)
CONTROL GP-THROTTLE
COVER GP-ENCLOSED ROPS
COVER GP-OPEN ROPS
DOOR GP-ENCLOSED ROPS
DOOR GP-OPEN ROPS
HEATER AR-CAB
HEATER GP-CAB
LATCH GP (CAB)
LINER GP-CAB
LINES GP-AIR CONDITIONER
LINES GP-HEATER
LINES GP-WASHER
MODULE GP-QUAD GAUGE ELEK
MODULE GP-SPEED/TACH ELEK
MONITOR AR-PAYLOAD
MONITOR GP-PAYLOAD
MOUNTING GP-PRESSURIZER
OPERATOR AR-ENCLOSED ROPS
OPERATOR AR-OPEN ROPS (REMOVABLE)
PANEL GP-INSTRUMENT (OPEN ROPS)
PANEL GP-INSTRUMENT (ENCLOSED ROPS)
PANEL GP-SWITCH
PANEL GP-WARNING
PRESSURIZER GP
SEAT BELT GP
SEAT GP-SUSPENSION
SPRING GP-CAB DOOR
SUPPORT GP-SEAT
TOOL GP-ELECTRONIC (PAYLOAD CONTROL SYSTEM)
WINDOW GP
WIPER GP-DOOR
WIPER GP-WINDOW
WIPER GP-WINDOW (REAR)
WIPER GP-WINDSHIELD
REMOTE CONTROL SYSTEM
INTERFACE & MOUNTING GP (PROPORTIONAL REMOTES)
INTERFACE AR-REMOTE CONTROL (PROPORTIONAL)
LAMP GP-SIGNAL
LIGHTING GP-WARNING
LINES GP-REMOTE CONTROL
MOUNTING GP-RECEIVER
REMOTE CONTROL AR
SWITCH GP-REMOTE CONTROL
TRANSMITTER & RECEIVER AR (PROPORTIONAL)
VALVE & MTG GP-CONTROL (PROPORTIONAL)
VALVE GP-CONTROL (PROPORTIONAL)
WIRING GP-REMOTE CONTROL
SERVICE EQUIPMENT AND SUPPLIES
BAR GP-RECOVERY
BOLT GP-COLLET JACKING
FILM GP
FRAME-TIRE INSTALLATION
IDENTIFICATION-RIM
KIT-SERVICE (AIR CLEANER)
KIT-SERVICE (1000 HOUR)
KIT-SERVICE (2000 HOUR)
KIT-SERVICE (250 HOUR)
KIT-SERVICE (500 HOUR)
LIFTING GP-SEAT
PLATE & FILM GP (RIDE CONTROL)
PLATE & FILM GP
PUMP & LINES GP-HYDRAULIC (PORTABLE)
PUMP GP-ELECTRIC DRIVE
SERVICE GP-OIL SAMPLE
STAND GP-FRAME
TEMPLATE GP-WINDOW GLASS
TOOL-BRAKE WEAR
TOOL-DIAGNOSTIC SERVICE BOX
TOOL-IMPLEMENT VALVE LIFTING
TOOL-WHEEL NUT EXT SOCKET
TOOLS
PART NUMBER INDEX
Custom Product
PRODUCT INFORMATION
GENERAL INFORMATION
INDEX
MACHINE ARRANGEMENT
PROTECTION AR-CORROSION
COOLING SYSTEM
COOLANT CONDITIONER GP
FITTING GP-RADIATOR VENT
AIR CLEANER GP
EXHAUST AR-SCRUBBER
EXHAUST GP-SCRUBBER
FUEL SYSTEM
LINES GP-FUEL
POWER TRAIN
RIM AR
RIM AR (5-PIECE)
RIM GP-DEMOUNTABLE
TIRE GP
TUBE GP-TIRE
FRAME AND BODY
BAR GP-WEAR
COVER GP-DECK
FIRE EXTINGUISHER GP (DUAL 4.5KG EXTINGUISHERS)
FIRE EXTINGUISHER GP (9.0 LITRE FOAM)
GUARD GP-AXLE
GUARD GP-RADIATOR
INSTALLATION AR (FENDER)
PLATE GP-WEAR (HITCH)
BRAKING SYSTEM
CONTROL GP-PARKING BRAKE
STEERING SYSTEM
LINES GP-REVERSIBLE STEERING
HYDRAULIC SYSTEM
CYLINDER GP-TILT
GAUGE GP-LIQUID LEVEL
WORK TOOLS
EDGE-CUTTING
OPERATOR STATION
AIR CONDITIONER GP (SALT RESISTANT)
BEAD BREAKER GP
FILM GP
LIFTING GP-MACHINE (MINE TRANSFER)
PLATE & FILM GP
PLATE-MACHINE IDENTIFICATION
PART NUMBER INDEX
