Hyundai
86
176,834
CAT Load Haul Dump R1300G Parts Catalog SEBP6407-09
Brand: Caterpillar
Type of Machine: Load Haul Dump
Model: CAT R1300G Load Haul Dump
NJB1-Up (Machine)
R6J1-Up (Engine)
3YY1-Up (Transmission)
4JT1-Up (Torque Converter)
Part Number: SEBP6407-09
Publication Date: 2015
Number of Pages: 845 Pages
GENERAL INFORMATION
REPAIR ALTERNATIVES
SUPPLEMENTAL COOLANT ADDITIVES
MAINTENANCE PARTS
INDEX
MACHINE ARRANGEMENT
CHASSIS AR​
COMMON AR​
INSTALLATION AR​
ENGINE ARRANGEMENT
CONVERSION AR-ENGINE​
ENGINE AR​
INSTALLATION AR-ENGINE​
BASIC ENGINE
ADAPTER GP-SEAL​
CAMSHAFT GP​
COVER GP-CYLINDER BLOCK​
COVER GP-FRONT HOUSING​
COVER GP-VALVE MECHANISM​
CRANKSHAFT GP​
CYLINDER BLOCK GP​
CYLINDER HEAD AS​
CYLINDER HEAD GP​
DAMPER GP​
DRAIN GP-ENGINE OIL​
DRIVE GP-AUXILIARY​
DRIVE GP-FAN​
FASTENER GP-CYLINDER HEAD​
FASTENER GP-FRONT HOUSING​
FASTENER GP-OIL PAN​
FLYWHEEL GP​
GEAR GP-FRONT​
GEAR GP-REAR​
HOUSING GP-FLYWHEEL​
HOUSING GP-FRONT​
LIFTING GP-ENGINE​
MOUNTING GP-ENGINE​
MOUNTING GP-ENGINE & XMSN​
MOUNTING GP-FAN DRIVE​
PAN GP-OIL​
PISTON & ROD GP​
PULLEY GP-CRANKSHAFT​
PULLEY GP-FAN DRIVE​
SEAL GP-CRANKSHAFT​
SUPPORT GP-ENGINE​
VALVE MECHANISM GP​
LUBRICATION SYSTEM
BASE GP-OIL FILTER​
BREATHER GP​
DRAIN GP-HIGH SPEED FLUID​
FILLER GP-ENGINE OIL​
FUMES DISPOSAL GP​
GAUGE GP-OIL LEVEL (DIPSTICK)​
LINES GP-ENGINE OIL​
LINES GP-TURBOCHARGER OIL​
PUMP GP-ENGINE OIL​
COOLING SYSTEM
COOLER GP-FLTR BASE & ENG OIL​
FAN & GUARD GP-BLOWER​
HOUSING & REGULATOR GP​
LINES GP-AFTERCOOLER WATER​
LINES GP-WATER​
PUMP GP-WATER​
RADIATOR & MOUNTING GP​
RADIATOR GP​
AIR INLET AND EXHAUST SYSTEM
ADAPTER GP-TURBOCHARGER​
AFTERCOOLER GP-WATER​
AIR CLEANER GP​
GUARD GP-EXHAUST​
LINES GP-AIR​
MANIFOLD GP-EXHAUST​
MUFFLER & CONVERTER GP​
MUFFLER & MOUNTING GP​
SHIELD GP-MANIFOLD​
TURBOCHARGER GP​
FUEL SYSTEM
ACTUATOR GP-GOVERNOR​
ADAPTER GP-FAST FILL FUEL​
ADAPTER GP-FUEL FILL​
BOWL GP-WATER COLLECTION​
CONTROL GP-FUEL RATIO​
CONTROL GP-GOVERNOR​
FASTENER GP-FUEL INJ PUMP​
FILTER GP-FUEL​
FITTING GP-FUEL LINES​
GOVERNOR GP​
LINES GP-DRAIN​
LINES GP-FUEL​
LINES GP-FUEL INJECTION​
LINES GP-GOVERNOR OIL​
PUMP & MTG GP-FUEL TRANSFER​
PUMP GP-FUEL INJECTION​
PUMP GP-FUEL PRM & PRIM FILTER​
PUMP GP-FUEL TRANSFER​
SEAL GP-PUMP​
SHUTOFF GP-MANUAL​
TORQUE CONTROL GP​
ELECTRICAL AND STARTING SYSTEM
ALARM GP​
ALTERNATOR GP-CHARGING​
BATTERY & WIRING GP​
BOX AS-CONTROL​
BOX GP-CONTROL​
CONTROL & MTG GP-POWER TRAIN​
CONTROL GP-UNPROGRAMMED​
ELECTRICAL AR​
ELECTRONICS GP-MONITOR​
ELECTRONICS GP-POWER TRAIN​
HARNESS AS-CAB​
HARNESS AS-CONSOLE​
HARNESS AS-CONTROL​
HARNESS AS-DASH​
HARNESS AS-ENGINE​
HARNESS AS-HEATER & AIR COND​
HARNESS AS-LIGHTING​
HARNESS AS-MONITOR​
HARNESS AS-MOTOR​
HARNESS AS-REAR​
HARNESS AS-SENSOR​
HARNESS AS-SWITCH​
HARNESS AS-TRANSMISSION​
HARNESS AS-WINDOW WIPER​
HARNESS AS-WIRING​
LAMP GP-DOME​
LAMP GP-FLOOD​
LAMP GP-HEAD​
LAMP GP-SIGNAL​
LIGHTING GP-CAB​
LIGHTING GP-FRONT​
LIGHTING GP-REAR​
LIGHTING GP-STOP​
MOTOR GP-ELEC HYD PUMP​
MOTOR GP-ELECTRIC​
MOUNTING GP-CONNECTOR​
PANEL GP-CIRCUIT BREAKER​
PANEL GP-SWITCH​
RECEPTACLE GP-AUXILIARY START​
RELAY GP​
SENDER GP-FUEL LEVEL​
SENSOR & MOUNTING GP​
SENSOR & MTG GP-LIFT POSITION​
SENSOR & MTG GP-PRESSURE​
SENSOR GP-POSITION​
SENSOR GP-PRESSURE​
SENSOR GP-SPEED​
SENSOR GP-TEMPERATURE​
SHUTOFF GP-ELECTRICAL​
SOLENOID GP-SHUTOFF​
STARTING MOTOR GP-ELECTRIC​
SUPPRESSOR AS-ARC​
SWITCH GP-BRAKE​
SWITCH GP-DISCONNECT​
SWITCH GP-MAGNETIC​
SWITCH GP-PUSH BUTTON​
SWITCH GP-ROTARY​
SWITCH GP-SHUTDOWN​
SWITCH GP-TOGGLE​
SWITCH AS-TOGGLE​
SWITCH GP-TOGGLE​
SWITCH GP-TRANSMISSION​
WARNING GP-BACKUP​
WIRING GP-ALTERNATOR​
WIRING GP-CAB​
WIRING GP-DOOR​
WIRING GP-ENGINE​
WIRING GP-FRONT​
WIRING GP-REAR​
WIRING GP-SHUTOFF​
WIRING GP-TRANSMISSION​
POWER TRAIN
AXLE & XFR CASE AR-OSCILLATING​
AXLE AR-FIXED​
AXLE AR-OSCILLATING​
AXLE GP-FIXED​
AXLE GP-OSCILLATING​
CASE & PARTS GP-PLANETARY​
CONTROL GP-TRANSMISSION HYD​
COOLER GP-TRANSMISSION OIL​
CORE GP-OIL COOLER​
DIFFERENTIAL & BEVEL GEAR GP​
DIFFERENTIAL GP​
DIFFERENTIAL GP-NOSPIN​
FILTER & LINES GP-TRANSMISSION​
FILTER GP-OIL​
GEAR & CASE GP-TRANSFER​
GEAR GP-BEVEL​
LINES GP-AXLE VENT​
LINES GP-SCAVENGE​
LINES GP-TORQUE CONV COOLER​
LINES GP-TRANSMISSION OIL​
MOUNTING GP-AXLE​
MOUNTING GP-FINAL DRIVE​
OUTPUT GP-TRANSMISSION​
PLANETARY GP-TRANSMISSION​
POWER TRAIN AR​
PUMP GP-TRANSMISSION​
RIM AR​
RIM GP-DEMOUNTABLE​
SHAFT GP-AXLE​
SHAFT GP-DRIVE​
TIRE GP​
TORQUE CONVERTER & HOUSING GP​
TORQUE CONVERTER GP​
TRANSMISSION AR​
TRANSMISSION AR-COMPLETE​
TUBE GP-TIRE​
UNIVERSAL JOINT GP​
VALVE GP-DRAIN​
VALVE GP-RELIEF​
VALVE GP-SELECTOR​
VALVE GP-SELECTOR & PRESS CONT​
VALVE GP-SOLENOID​
VALVE GP-TRANSMISSION CONTROL​
WHEEL & FINAL DRIVE GP​
FRAME AND BODY
BAR GP-WEAR​
BLOCK GP-LUBRICATION​
COVER GP-ACCESS​
COVER GP-DECK​
DRAWBAR GP​
FENDER GP-FRONT​
FENDER GP-REAR​
FILTER GP-GREASE​
FRAME GP-FRONT​
FRAME GP-REAR​
GRILL GP-RADIATOR​
GUARD GP-AXLE SEAL​
GUARD GP-BOTTOM​
GUARD GP-DRIVE SHAFT​
GUARD GP-LIGHTING​
GUARD GP-RADIATOR​
HITCH GP-ARTICULATING​
LINES GP-CENTRAL LUBRICATION​
LINES GP-FIRE SUPPRESSION​
LINES GP-GREASE​
LINES GP-LUBRICATION​
LINK GP-STEERING FRAME LOCK​
LUBRICATION AR-AUTOMATIC​
LUBRICATION AR-CENTRAL​
LUBRICATION AR-MANUAL​
MOUNTING GP-BATTERY​
PIN GP-DRAWBAR​
PLATE GP-WEAR​
PUMP GP-LUBRICATION​
TREAD GP-NON-SKID​
VALVE GP-LUBE DISTRIBUTION​
BRAKING SYSTEM
ACCUMULATOR & MTG GP-BRAKE​
ACCUMULATOR GP-BRAKE​
ACCUMULATOR GP-HYDRAULIC​
BRAKE AR​
BRAKE GP-SERVICE & PARKING​
BRAKE RELEASE AR​
CONTROL GP-PARKING BRAKE​
CONTROL GP-SERVICE BRAKE​
CYLINDER GP-BRAKE RELEASE​
GAUGE & LINES GP-BRAKE PRESS​
HOOK GP-BRAKE RELEASE​
LINES GP-BRAKE​
LINES GP-BRAKE RELEASE​
LINES GP-PARKING BRAKE​
LINES GP-SERVICE BRAKE​
VALVE & MTG GP-ACCUM CHARGING​
VALVE GP-PARKING BRAKE​
VALVE GP-PRESSURE REDUCING​
VALVE GP-SEQUENCE​
VALVE GP-SHUTTLE​
VALVE GP-SOLENOID​
STEERING SYSTEM
CONTROL GP-STEERING​
CYLINDER & MTG GP-STEERING​
CYLINDER & SEAL GP-STEERING​
CYLINDER GP-STEERING​
LINES GP-SECONDARY STEERING​
LINES GP-STEERING​
LINES GP-STEERING NEUTRALIZER​
PUMP & MOTOR GP​
PUMP & MTG GP-SECONDARY STEER​
PUMP GP-GEAR​
STEERING AR-SECONDARY​
STEERING AR-STIC​
VALVE & MTG GP-DIVERTER​
VALVE & MTG GP-STEERING​
VALVE & MTG GP-STEERING NEUT​
VALVE GP-DIVERTER​
VALVE GP-PILOT​
VALVE GP-STEERING​
VALVE GP-STEERING NEUTRALIZER​
HYDRAULIC SYSTEM
ACCUMULATOR & MTG GP-RIDE CONT​
ACCUMULATOR GP-RIDE CONTROL​
BLOCK GP-HYDRAULIC​
CARTRIDGE GP-VANE PUMP​
CONTROL AR-RIDE​
COOLER & MTG GP-HYDRAULIC OIL​
COOLER GP-HYDRAULIC OIL​
CYLINDER & MTG GP-EJECTOR​
CYLINDER & SEAL GP-EJECTOR​
CYLINDER & SEAL GP-LIFT​
CYLINDER & SEAL GP-TILT​
CYLINDER GP-HYDRAULIC​
CYLINDER GP-LIFT​
CYLINDER GP-TILT​
FITTING GP-HYDRAULIC​
GAUGE GP-SIGHT​
HYDRAULIC AR​
HYDRAULIC AR-2 VALVE​
HYDRAULIC AR-3 VALVE​
LINES GP-BUCKET​
LINES GP-DRAIN​
LINES GP-HYDRAULIC​
LINES GP-HYDRAULIC OIL COOLER​
LINES GP-IMPLEMENT​
LINES GP-LIFT CYLINDER​
LINES GP-PILOT​
LINES GP-TILT CYLINDER​
POSITIONER AR-WORK TOOL​
PUMP & MTG GP-HYDRAULIC​
PUMP GP-VANE​
TANK & FILTER GP-HYDRAULIC​
TANK & MTG GP-HYDRAULIC​
VALVE & MTG GP-CONTROL​
VALVE GP-AUXILIARY​
VALVE GP-CONTROL​
VALVE GP-PILOT​
VALVE GP-RELIEF​
VALVE GP-SHUTTLE​
VALVE GP-SOLENOID​
IMPLEMENTS
BRACE GP​
CONTROL GP-BUCKET​
WORK TOOLS
BUCKET AR-EJECTOR​
BUCKET AS​
BUCKET AS-EJECTOR​
BUCKET GP-EJECTOR​
EDGE GP-CUTTING​
PLATE GP-WEAR​
PROTECTOR GP-WEAR​
OPERATOR STATION
AIR CONDITIONER & MOUNTING GP​
AIR CONDITIONER AR​
AIR CONDITIONER GP​
ARMREST GP​
BASE GP-PEDAL​
CAB AR-ENCLOSED ROPS​
CAB AR-OPEN ROPS​
CAB GP-ENCLOSED ROPS​
CAB GP-OPEN ROPS​
COMPARTMENT GP-LITERATURE​
COMPRESSOR GP-REFRIGERANT​
CONDENSER & MTG GP-REFRIGERANT​
CONTROL GP-HANDLE​
CONTROL GP-MONITOR​
CONTROL GP-PILOT OPERATED HYD​
CONTROL GP-THROTTLE​
CONTROL GP-TRANSMISSION​
COVER GP-CAB​
DOOR GP-CAB​
HEATER AR-CAB​
HEATER GP-CAB​
LATCH GP-CAB DOOR​
LINES GP-AIR CONDITIONER​
LINES GP-HEATER​
MODULE GP-QUAD GAUGE​
MODULE GP-SPEEDOMETER & TACH​
MODULE GP-WARNING INDICATOR​
MONITOR AR-PAYLOAD​
MONITOR GP-PAYLOAD​
MOTOR GP-WINDOW WIPER​
MOUNTING GP-CAB​
OPERATOR AR-ENCLOSED ROPS​
PANEL GP-INSTRUMENT​
PRESSURIZER & MOUNTING GP​
PRESSURIZER GP-CAB​
SEAT BELT GP​
SEAT GP-SUSPENSION​
SPRING GP-CAB DOOR​
STRAP GP-MOUNTING​
SUPPORT GP-SEAT​
TANK GP-WINDOW WASHER​
TOOL GP-ELECTRONIC​
VALVE GP-CHECK​
WASHER GP-WINDOW​
WINDOW GP-CAB​
WIPER GP-WINDOW​
REMOTE CONTROL SYSTEM
CONTROL AR-REMOTE​
INTERFACE & MOUNTING GP​
INTERFACE AR-REMOTE CONTROL​
LAMP GP-SIGNAL​
LIGHTING GP-WARNING​
LINES GP-REMOTE CONTROL​
MANIFOLD & VALVE GP​
MOUNTING GP-RECEIVER​
REMOTE CONTROL AR​
SWITCH GP-PARKING BRAKE​
WIRING GP-REMOTE CONTROL​
SERVICE EQUIPMENT AND SUPPLIES
FILM GP​
FILM GP-INTERNATIONAL​
FILM GP-U.S.​
FILTER GP​
HOOK GP-RECOVERY​
KIT-SERVICE​
LIFTING GP-MACHINE​
PLATE & FILM GP​
PLATE GP-IDENTIFICATION​
PUMP GP-ELECTRIC DRIVE​
TOOL GP​
TOOL GP-DIAGNOSTIC​
PART NUMBER INDEX
