705,263
CAT Forklift NR16NHS Parts Catalog 03.2021
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar NR16NHS Forklift
Publication Date: 03.2021
List of Files:
NR16NHS_Parts Catalog.pdf (626 Pages)
468428 A BATTERY CHANGING DEV BATTERY WIDTH -310
475736 C BASE FOR 1400kg MODEL
477582 B SLEEVE
479536 G ASSEMBLY BATTERY BRACKET 620Ah
482698 K MAST UNIT FOR 2000/2500kg CAPASITY
483099 C LIFTING CARRIAGE FOR 1400/1600kg CAPASITY
483211 G ASSEMBLY BATTERY BRACKET 465Ah
483589 F DISPLAY UNIT
484007 D LIFTING CARRIAGE FOR 2000/2500kg CAPASITY
484007-P C LIFTING CARRIAGE
484757 L ASSEMBLY MAIN ASSEMBLY
484915 A DRIVE WHEEL VULKOLLAN
484934 A LOAD SUPPORT HIGH PERFORMANCE CHASSIS
484952 B LIFTING FORK FOR 1400/1600kg CAPASITY,H.P.1150-100x40
485772 J MAST UNIT FOR 1400/1600kg CAPASITY
486127 E ACCESSORIES DISPLAY+ FORK CAMERA, L.H. 6301-7500
487543 D OPERATOR COMPARTMENT CAT
OPTIONS_Parts Catalog.pdf (152 Pages)
440510 0 BATTERY ROLLER BASIC
465065 A BATTERY ROLLER ASSEMBLY
468430 A BATTERY CHANGING DEV BATTERY WIDTH 390-542
482487 A ACCESSORIES
482493 A BRACKET COMPLETE, FOR OPTION
482495 E FIRE EXTINGUISHER COMPLETE
482827 B ARMREST
482840 B DRIVING SEAT MSG75
482840-P B DRIVING SEAT MSG75 WITH HEATING ELEMENT
482969 A ACCESSORIES
483255 A ACCESSORIES OVERHEAD GUARD SAFETY NET
483257 B ASSEMBLY QUICK-BATTERY CHANGING FROM RIGHT
483458 B CHARGING CONNECTOR
483559 B ACCESSORIES PC-BRACKET
483576 B PRESS KEY
483849 A RACK
483851 A BATTERY CHANGING DEV COMPLETE
483854 A BATTERY ROLLER
483935 B ACCESSORIES OVERHEAD GUARD SAFETY PLATE
484318 E ACCESSORIES DRIVE WARNING BUZZER, COMPLETE
484388 A VALVE
484647 I ACCESSORIES CENTERING FOR SIDE-SHIFT/TILT, L.H.9001-11500
484913 A CHAIN WHEEL FREE LIFT
484949 A HOSE ROLLER
485087 B LIGHT STANDARD CHASSIS
485088 C RADIO STANDARD CHASSIS
485089 D LIGHT WORKING LIGHT, STANDARD CHASSIS
485090 C WARNING LIGHT
485109 A ACCESSORIES LIST BRACKET
485110 A MIRROR
485123 C ACCESSORIES POWER OUTPUT
485146 B SWITCH
485194 D VALVE
485203 A KEY SWITCH IGNITION KEY
485206 B LIGHT COMPACT CHASSIS
485210 C RADIO COMPACT CHASSIS
485307 B ASSEMBLY QUICK-BATTERY CHANGING FROM LEFT
485396 B ASSEMBLY BATTERY CABLES
485397 B ASSEMBLY CHARGER CONTACT PLUG
485514 B ACCESSORIES LOWERING CUT-OFF
486134-9000 B ACCESSORIES ADDITIONAL HYDRAULIC, L.H. 9000
486137 B CHAIN YOKE ADDITIONAL HYDRAULIC
486153 A HOSE ROLLER
486237 B FORK ADJUSTING OPTION
486440 A ACCESSORIES SEAT BELT, MSG20
486462 A ACCESSORIES ARM REST, MSG75
486467 A ACCESSORIES EXTENSION BACK REST, MSG75
486468 A ACCESSORIES ARM REST, MSG20
486635 C FORK TELESCOPE
487832 B ASSEMBLY ADDITIONAL HYDRAULIC FASTENERS
487886 D ASSEMBLY
487919 C WARNING LIGHT WITH SWITCH
495945 A BUZZER
498978 B SWITCH WITH IGNITION LOCK
508131 0 ROLLER
600144 A ARM REST OPTION
606192 A ASSEMBLY CAMERA CABLE FASTENERS
