CAT Forklift GP30K Service, Operation & Maintenance Manual
Brand: CAT Caterpillar
Type of Machine: Forklift
Type of Manual: Service Manual, Operation & Maintenance Manual
Model: CAT GP30K Forklift
Date: 2016
Content:
Main Harness
99719-82130-00 Chassis and Mast: Foreward
99719-82130-01 Chassis and Mast: General Information
99719-82130-02 Chassis and Mast: Cooling
99719-82130-03 Chassis and Mast: Electrical System
99719-82130-03a Chassis and Mast: Wiring Schematic
99719-82130-04 Chassis and Mast: Power Train
99719-82130-05 Chassis and Mast: Powershift Transmission
99719-82130-06 Chassis and Mast: Front Axle & Differential
99719-82130-07 Chassis and Mast: Rear Axle
99719-82130-08 Chassis and Mast: Brake System
99719-82130-09 Chassis and Mast: Steering System
99719-82130-10 Chassis and Mast: Hydraulic System
99719-82130-11 Chassis and Mast: Mast and Forks
99719-82130-12 Chassis and Mast: LP-GAS System
99719-82130-13 Chassis and Mast: Service Data
99719-92100-00 Options Supplement: Foreword
99719-92100-01 Options Supplement: Plate Fin Type Radiator Kit
99719-92100-02 Options Supplement: Fan Speed Up Kit
99719-92100-03 Options Supplement: Radiator Coolant Level Warning Kit
99719-92100-04 Options Supplement: Torque Converter Oil Filter Kit
99719-92100-05 Options Supplement: Radiator Net Kit
99719-92100-06 Options Supplement: Combination Lamp Turn Signal Switch Kit
99719-92100-07 Options Supplement: Back Buzzer Kit
99719-92100-08 Options Supplement: Warning Lamp Kit
99719-92100-09 Options Supplement: Back Mirror Kit
99719-92100-10 Options Supplement: Working Lamp Kit
99719-92100-11 Options Supplement: Disconnect Switch Kit
99719-92100-12 Options Supplement: Hook Kit
99719-92100-13 Options Supplement: Enclosed Alternator Kit, Gasoline
99719-92100-14 Options Supplement: Enclosed Alternator Kit, Diesel
99719-92100-15 Options Supplement: Joint Cover Kit
99719-92100-16 Options Supplement: Special Dual Tire Kit, 1 Ton
99719-92100-17 Options Supplement: Special Dual Tire Kit, 2 and 3 Ton
99719-92100-18 Options Supplement: Special Dual Solid Tire Kit, 2 Ton
99719-92100-19 Options Supplement: Double Cyclone Air Cleaner Kit
99719-92100-20 Options Supplement: Dust Indicator Kit
99719-92100-21 Options Supplement: Cyclone Muffler Kit
99719-92100-22 Options Supplement: Catalyzer Muffler Kit
99719-92100-23 Options Supplement: Diffusion Muffler Kit
99719-92100-24 Options Supplement: Gear Pump Seal Kit
99719-92100-25 Options Supplement: Suction Filter Kit
99719-92100-26 Options Supplement: Dust Proof Breather Kit
99710-73160-00 Foreword
99710-73160-01 Safety Rules For Lift Truck Operators
99710-73160-02 Know Your Lift Truck
99710-73160-03 How To Avoid A Tipover; How To Survive One
99710-73160-04 Refueling
99710-73160-05 Operation
99710-73160-06 Operating Techniques
99710-73160-07 Storing The Lift Truck
99710-73160-08 Special Situations
99710-73160-09 Transportation Hints
99710-73160-10 Troubleshooting
99710-73160-11 Maintenance
99710-73160-12 Service Data
99710-73160-13 The Cat Lift Truck Owner
Cat Pub List Publication List (Service, Operator, & Parts Manuals)
Mast Tilting Angles Mast Tilting Angles
REF-18-0001C How To Determine Correct Mast Rails Lift Cylinders And Mast Hosing
REF-18-0001C How To Determine Correct Mast Rails Lift Cylinders And Mast Hosing (Spanish)
REF-18-0002C How To Locate Fluid Capacities
REF-18-0002C How To Locate Fluid Capacities (Spanish)
REF-18-0003C How To Use A Pick List
REF-18-0003C How To Use A Pick List (Spanish)
REF-18-0007C Abbreviations And Acronyms List
REF-18-0008C Diagnostic Trouble (Error) Codes
Date: 2016
Content:
Main Harness
- CAT Lifttruck GP,DP15-35 Service Manual
- CAT Forklift Trucks Error Codes list
- Caterpillar Lift Trucks MCFS [05.2018] Spare Parts Catalogue
- CAT Forklift Truck P5000 Service Manual
- CAT Lift Trucks NSP Series Manual and Electric Schematic
- Caterpillar Lift Truck DP30NT Operation & Maintenance Manuals
- CAT Forklift Truck P6000 Service Manual
- Cat Forklifts Warehouse NPV20N2 Manual
- CAT Forklifts Electric Counterweight EP25K Manual
- CAT Forklifts Diesel Counterweight DP30N Manual
- CAT Forklifts Electric Counterweight EP25CA Manual
- Caterpillar Lift Truck E5000 Service Manuals
- Cat Forklifts Warehouse NSP12N Manual
- CAT Forklifts Electric Counterweight EP16TCB(J) Manual
- Cat Forklifts Warehouse NSP10N2R Manual
