705,578
CAT Forklift GC45K Schematic, Service, Operation & Maintenance Manual
Brand: CAT Caterpillar
Type of Machine: Forklift
Type of Manual: Schematic, Service Manual, Operation & Maintenance Manual
Model: CAT GC45K Forklift
Date: 2021
Content:
Operation & Maintenance Manual GC35K GC40K GC45K GC55K GC60K GC70K 99730-8D120 (187 Pages)
Service Manual GC40K GC45K GC55K GC60K GC70K 99739-8D110 (598 Pages)
99739-82100-00 Chassis and Mast: Foreword
99739-82100-01 Chassis and Mast: General Information
99739-82100-02 Chassis and Mast: Cooling System
99739-82100-03 Chassis and Mast: Electrical System
99739-82100-04 Chassis and Mast: Power Train
99739-82100-05 Chassis and Mast: Powershift Transmission
99739-82100-06 Chassis and Mast: Front Axle and Reduction Differential
99739-82100-07 Chassis and Mast: Rear Axle
99739-82100-08 Chassis and Mast: Brake System
99739-82100-09 Chassis and Mast: Steering System
99739-82100-10 Chassis and Mast: Hydraulic System
99739-82100-11 Chassis and Mast: Masts and Forks
99739-82100-12 Chassis and Mast: Service Data
99739-94100-00 Options Supplement: Foreword
99739-94100-01 Options Supplement: Rear Combination Lamp Kit
99739-94100-02 Options Supplement: Warning Lamp Kit
99739-94100-03 Options Supplement: Working Lamp Kit
99739-94100-04 Options Supplement: Creep Speed Kit
99739-94100-05 Options Supplement: Foot Directional Control Group
99739-94100-06 Options Supplement: Engine Shutdown Kit (LPG Models Only)
99739-94100-07 Options Supplement: Enclosed Alternator Field Kit
99739-94100-08 Options Supplement: Disconnect Switch Kit
99739-94100-09 Options Supplement: UL Fuel Cap Kit (Gasoline Models Only)
99739-94100-10 Options Supplement: Key Kit
99739-94100-11 Options Supplement: Back Buzzer Kit
99739-94100-12 Options Supplement: Dual Element Air Cleaner
99739-94100-13 Options Supplement: Dust and Foundry Kit
99739-94100-14 Options Supplement: Back Mirror Kit
99789-84122-01 Engine: GM 4.3L (G6) LPG Fuel System Supplement: General Information
99789-84122-02 Engine: GM 4.3L (G6) LPG Fuel System Supplement: Maintenance
99789-84122-04 Engine: GM 4.3L (G6) LPG Fuel System Supplement: LPG System Diagnosis
99789-84122-05 Engine: GM 4.3L (G6) LPG Fuel System Supplement: LPG Symptom Diagnostics
99789-84122-06 Engine: GM 4.3L (G6) LPG Fuel System Supplement: Diagnostic Scan Tool
99789-84122-07 Engine: GM 4.3L (G6) LPG Fuel System Supplement: Wiring Schematic
99789-84122-07a Engine: GM 4.3L (G6) LPG Fuel System Supplement: Electrical Schematic
99789-84122-08 Engine: GM 4.3L (G6) LPG Fuel System Supplement: Wiring Harness Repair
99789-84122-09 Engine: GM 4.3L (G6) LPG Fuel System Supplement: Diagnostic Trouble Codes
99789-84122-10 Engine: GM 4.3L (G6) LPG Fuel System Supplement: Servicing the Fuel System
99789-84122-11 Engine: GM 4.3L (G6) LPG Fuel System Supplement: LPG Parts Diagram
99789-84122-12 Engine: GM 4.3L (G6) LPG Fuel System Supplement: Appendix
99789-84221-06 Engine: GM 4.3LPG: DIAGNOSTIC ANALYSIS TOOL
99730-86101-00 Foreword
99730-86101-01 How to Avoid a Tipover; How to Survive One
99730-86101-02 Know Your Lift Truck
99730-86101-03 Maintenance
99730-86101-04 Operating Techniques
99730-86101-05 Operation
99730-86101-06 Refueling
99730-86101-07 Safety Rules for Lift Truck Operators
99730-86101-08 Service Data
99730-86101-09 Special Situations
99730-86101-10 Storing the Lift Truck
99730-86101-11 Transportation Hints
99730-86101-12 Troubleshooting
99730-86101-13 To the Cat Lift Truck Owner
Cat Pub List Publication List (Service, Operator, & Parts Manuals)
Mast Tilting Angles Mast Tilting Angles
REF-18-0001C How To Determine Correct Mast Rails Lift Cylinders And Mast Hosing
REF-18-0001C How To Determine Correct Mast Rails Lift Cylinders And Mast Hosing (Spanish)
REF-18-0002C How To Locate Fluid Capacities
REF-18-0002C How To Locate Fluid Capacities (Spanish)
REF-18-0003C How To Use A Pick List
REF-18-0003C How To Use A Pick List (Spanish)
REF-18-0007C Abbreviations And Acronyms List
REF-18-0008C Diagnostic Trouble (Error) Codes
Schematic
12V IGN POWER SUPPLY
12V POWER SUPPLY
CHARGING
CONNECTOR 2
CONNECTOR 3
CONNECTOR 4
CONNECTOR 5
CONNECTOR 6
CONNECTOR
ENGINE HARNESS
FOOT DIRECTION
FUSE BOX
GND 2
GND
HORN & WARNING BUZZER
LAMP 2
LAMP
METER PANEL
STARTER
TURN SIGNAL
VEHICLE CONTROL 2
VEHICLE CONTROL 3
VEHICLE CONTROL
WARNING LAMP
