705,578
CAT Forklift GC20K Schematic, Service, Operation & Maintenance Manual
Brand: CAT Caterpillar
Type of Machine: Forklift
Type of Manual: Schematic, Service Manual, Operation & Maintenance Manual
Model: CAT GC20K Forklift
Date: 2010
Content:
Main Harness S15G Fuel System Schematic
4G63 Tier II SCH Chassis and Mast: Tier II Wiring Schematic
99719-80150-00 Chassis and Mast: Foreword
99719-80150-01 Chassis and Mast: General Information
99719-80150-02 Chassis and Mast: Cooling System
99719-80150-03 Chassis and Mast: Electrical System
99719-80150-04 Chassis and Mast: Power Train
99719-80150-05 Chassis and Mast: Powershift Transmission
99719-80150-06 Chassis and Mast: Front Axle and Reduction Differential
99719-80150-07 Chassis and Mast: Rear Axle
99719-80150-08 Chassis and Mast: Brake System
99719-80150-09 Chassis and Mast: Steering System
99719-80150-10 Chassis and Mast: Fuel System
99719-80150-11 Chassis and Mast: Hydraulic System
99719-80150-12 Chassis and Mast: Mast and Forks
99719-80150-13 Chassis and Mast: Service Data
99739-92100-00 Options Supplement: Foreword
99739-92100-01 Options Supplement: Rear Combination Lamp Kit
99739-92100-02 Options Supplement: Working Lamp Kit
99739-92100-03 Options Supplement: Warning Lamp Kit
99739-92100-04 Options Supplement: Back Buzzer Piezo Kit
99739-92100-05 Options Supplement: Back Mirror Kit
99739-92100-06 Options Supplement: Oil Filter Kit (1-Ton Model)
99739-92100-07 Options Supplement: Oil Filter Kit (2-, 3-Ton Models)
99739-92100-08 Options Supplement: Enclosed Alternator Kit
99739-92100-09 Options Supplement: Spark Plug Kit
99739-92100-10 Options Supplement: Fastener Kit
99739-92100-11 Options Supplement: Front Axle Breather Kit
99739-92100-12 Options Supplement: Wide Axle Kit (2-. 3-Ton Models)
99739-92100-13 Options Supplement: Semi Wide Axle Kit (1-Ton Model)
99739-92100-14 Options Supplement: Semi Wide Axle Kit (2-, 3-Ton Models)
99739-92100-15 Options Supplement: Dual Element Kit
99739-92100-16 Options Supplement: Dust Indicator Kit
99710-80140-00 00_FOREWARD
99710-80140-01 01_SAFETY RULES FOR LIFT TRUCK OPERATORS
99710-80140-02 02_KNOW YOUR LIFT TRUCK
99710-80140-03 03_HOW TO AVOID A TIPOVER; HOW TO SURVIVE ONE
99710-80140-04 04_REFUELING
99710-80140-05 05_OPERATION
99710-80140-06 06_OPERATING TECHNIQUES
99710-80140-07 07_STORING THE LIFT TRUCK
99710-80140-08 08_TRANSPORTATION HINTS
99710-80140-09 09_SPECIAL SITUATIONS
99710-80140-10 10_IF ANY TROUBLE SHOULD OCCUR
99710-80140-11 11_MAINTENANCE
99710-80140-12 12_SERVICE DATA
99710-80140-13 13_TO THE CAT LIFT TRUCK OWNER
Cat Pub List Publication List (Service, Operator, & Parts Manuals)
Mast Tilting Angles Mast Tilting Angles
REF-18-0001C How To Determine Correct Mast Rails Lift Cylinders And Mast Hosing
REF-18-0001C How To Determine Correct Mast Rails Lift Cylinders And Mast Hosing (Spanish)
REF-18-0002C How To Locate Fluid Capacities
REF-18-0002C How To Locate Fluid Capacities (Spanish)
REF-18-0003C How To Use A Pick List
REF-18-0003C How To Use A Pick List (Spanish)
REF-18-0007C Abbreviations And Acronyms List
REF-18-0008C Diagnostic Trouble (Error) Codes
