Hyundai
86
176,834
CAT Forklift 2C3500 USA Spare Parts Catalog
Brand: Caterpillar
Region: USA
Type of Machine: Forklift
Model: CAT 2C3500 MCFA Forklift
List of Files:
98725-45400 CAT ENGINE (1) (K21 / K25) (UPTO MARCH 2018) (89 Pages)
ENGINE​
ENGINE MECHANICAL​
101-01 BARE AND SHORT ENGINE​
102-01 ENGINE GASKET KIT​
110-01 CYLINDER BLOCK AND OIL PAN​
111-01 CYLINDER HEAD AND ROCKER COVER​
118-01 FAN BELT​
118-02 CRANKCASE VENTILATION​
120-01 PISTON, CRANKSHAFT, AND FLYWHEEL​
130-01 CAMSHAFT AND VALVE MECHANISM​
135-01 FRONT COVER AND FITTING​
140-01 MANIFOLD​
150-01 LUBRICATING SYSTEM​
FUEL SYSTEM​
163-01 THROTTLE CHAMBER​
164-01 FUEL SYSTEM (GASOLINE)​
164-02 FUEL SYSTEM (LPG)​
164-03 FUEL SYSTEM (DUAL)​
165-01 AIR CLEANER​
170-01 FUEL PUMP​
195-01 VAPORIZER​
INTAKE AND EXHAUST SYSTEM​
208-01 CATALYST CONVERTER​
210-01 WATER PUMP, COOLING FAN, AND THERMOSTAT​
ENGINE ELECTRICAL​
220-01 IGNITION SYSTEM​
221-01 CRANK AND CAM HARNESS​
223-01 VACUUM PIPING​
226-01 ENGINE CONTROL MODULE (ECM)​
230-01 ALTERNATOR FITTING​
231-01 ALTERNATOR​
233-01 STARTER MOTOR​
98725-40000 CAT ENGINE (2) (GK21/25) (AFTER APRIL 2018) (245 Pages)
ENGINE​
FIG.102AA ENGINE GASKET KIT​
FIG.110AA CYLINDER BLOCK AND OIL PAN​
FIG.111AA CYLINDER HEAD AND ROCKER COVER​
FIG.117AA FAN BELT​
FIG.118AA CRANK CASE VENTILATION​
FIG.120AA PISTON, CRANKSHAFT, AND FLYWHEEL​
FIG.130AA CAMSHAFT AND VALVE MECHANISM​
FIG.135AA FRONT COVER AND FITTING​
FIG.140AA MANIFOLD​
FIG.150AA OIL PUMP AND OIL FILTER​
FIG.163AA THROTTLE CHAMBER​
FIG.164AA INJECTOR (GAS)​
FIG.164BA INJECTOR (LPG)​
FIG.164CA INJECTOR AND FUEL PIPING (DUAL)​
FIG.164CB INJECTOR (DUAL)​
FIG.165AA AIR HORN​
FIG.170AA FUEL PUMP SPACER​
FIG.195AA VAPORIZER (LPG AND DUAL)​
FIG.196AA CATALTST CONVERTER​
FIG.208AA WATER PUMP, COOLING FAN, AND THERMOSTAT​
FIG.210AA IGNITION SYSTEM (1/2)​
FIG.220AA IGNITION SYSTEM (2/2)​
FIG.221AA VACUUM PIPING (LPG AND DUAL)​
FIG.223AA ENGINE CONTROL MODULE (ECM)​
FIG.226AA ALTERNATOR FITTING​
FIG.230AA ALTERNATOR (UL)​
FIG.231AA ALTERNATOR (UL-S)​
FIG.231BA STARTER MOTOR​
8715-62310 CAT CHASSIS, MAST AND OPTIONS (149 Pages)
CHASSIS AND OPTION​
COOLING SYSTEM​
01-01-01 COOLING SYSTEM​
01-01-02 RADIATOR​
01-01-03 RESERVOIR TANK​
01-01-04 TORQUE-CONVERTER COOLER​
01-01-05 RADIATOR NET KIT - OPTION​
01-01-06 INDICATOR KIT - OPTION​
ELECTRICAL SYSTEM​
01-04-01 ELECTRIC SYSTEM​
01-04-02 CHASSIS CIRCUIT​
01-04-03 HEAD GUARD CIRCUIT​
01-04-04 BATTERY​
01-04-05 BATTERY CABLE​
01-04-06 COMBINATION SWITCH​
01-04-07 REAR WORKING LAMP KIT - OPTION​
01-04-08 WARNING LAMP TOP KIT - OPTION​
01-04-09 WARNING LAMP SIDE KIT - OPTION​
01-04-10 FIRE EXTINGUISHER KIT - OPTION​
01-04-11 REAR COMBINATION LAMP KIT - OPTION​
01-04-12 TURN SIGNAL KIT - OPTION​
01-04-13 DISCONNECT SWITCH KIT - OPTION​
01-04-14 BACKUP HANDLE KIT - OPTION​
01-04-15 STROBE LAMP KIT ABOVE - OPTION​
01-04-16 STROBE LAMP KIT BELOW - OPTION​
01-04-17 KIT,M12 TELEM ENG - OPTION​
01-04-18 KIT,M12 TELEM FRE - OPTION​
01-04-19 THIRD-PARTY TELEMATICS HARNESS (MC MODEL) (PART-1)​
01-04-20 THIRD-PARTY TELEMATICS HARNESS - SCHEMATIC (MC MODEL) (PART-2)​
01-04-21 THIRD-PARTY TELEMATICS HARNESS (FC MODEL) (PART-1)​
01-04-22 THIRD-PARTY TELEMATICS HARNESS - SCHEMATIC (FC MODEL) (PART-2)​
FRAME AND BODY​
01-11-01 FRAME SYSTEM​
01-11-02 FRAME​
01-12-01 UPPER FRAME SYSTEM​
01-12-02 RADIATOR COVER​
01-12-03 ENGINE COVER​
01-12-04 SIDE COVER​
01-12-05 DASHBOARD COVER​
01-12-06 FLOOR MAT​
01-13-01 COUNTER WEIGHT​
01-13-02 COUNTER WEIGHT (JACKING ADAPTER)​
01-13-03 WEIGHT HOOK KIT - OPTION​
01-13-04 DRAW PIN KIT - OPTION​
01-14-01 SEAT (OLD)​
01-14-02 SEAT,SUSP. VINYL NET (NEW)​
01-14-03 SEAT,SUSP. CLOTH NET (NEW)​
01-14-04 SEAT,STATIC,VINYL,NET (NEW)​
01-14-05 SEAT,STATIC,CLOTH,NET (NEW)​
01-15-01 HEAD GUARD SYSTEM​
01-15-02 HEAD GUARD​
01-15-03 SIDE REAR VIEW MIRROR KIT - OPTION​
01-20-01 ENGINE BRACKET​
01-20-02 ENGINE CONTROLLER​
01-20-03 SPEED LIMITER KIT - OPTION​
01-20-04 POWER SELECT KIT - OPTION​
01-20-05 ENGINE CONTROLLER (AIR CLEANER DOUBLE ELEMENT) - OPTION​
01-20-06 ENCLOSED ALTERNATOR KIT - OPTION​
POWER LINE​
01-23-01 TORQUE-CONVERTER ASSY​
01-24-01 TRANSMISSION (PART-1)​
01-24-02 TRANSMISSION (PART-2)​
01-28-01 CONTROL VALVE​
AXLE​
01-31-01 REDUCTION & DIFFERENTIAL (PART-1)​
01-31-02 REDUCTION & DIFFERENTIAL (PART-2)​
01-32-01 POWER LINE​
01-33-01 FRONT AXLE​
01-34-01 FRONT AXLE SYSTEM​
01-34-02 FRONT TIRE ASSY​
01-34-03 FRONT AXLE DUST PROOF BREATHER KIT - OPTION​
01-43-01 REAR AXLE SYSTEM (PART-1)​
01-43-02 REAR AXLE SYSTEM (PART-2)​
01-43-03 STEERING CYLINDER (OLD TYPE)​
01-43-04 STEERING CYLINDER (NEW TYPE)​
01-43-05 REAR TIRE ASSY​
01-46-01 BRAKE SYSTEM​
01-46-02 WHEEL BRAKE L.H.​
01-46-03 WHEEL BRAKE R.H.​
OcultarDRIVING CONTROL​
01-51-01 DRIVING SYSTEM (PART-1)​
01-51-02 DRIVING SYSTEM (PART-2)​
01-51-03 ACCEL CONTROL SYSTEM​
01-51-04 BRAKE RESERVOIR (OLD)​
01-51-05 BRAKE RESERVOIR (NEW)​
01-54-01 STEERING SYSTEM​
01-54-02 STEERING VALVE​
01-54-03 STEERING WHEEL​
01-54-04 STEERING WHEEL KNOB KIT - OPTION​
OcultarINTAKE AND EXHAUST SYSTEM​
01-61-01 INTAKE SYSTEM​
01-61-02 AIR CLEANER​
01-61-03 PRE-AIR-CLEANER KIT - OPTION​
01-62-01 EXHAUST SYSTEM​
01-62-02 MUFFLER​
FUEL SYSTEM​
01-65-01 LPG SYSTEM​
01-65-02 LPG TANK BRACKET​
01-65-03 LPG TANK​
HYDRAULIC SYSTEM​
01-71-01 HYDRAULIC DELIVERY CIRCUIT​
01-71-02 SUCTION CIRCUIT​
01-72-01 HYD CONTROL SYSTEM (MC MODEL) (PART-1) (3 VALVES)​
01-72-02 HYD CONTROL SYSTEM (MC MODEL) (PART-1) (4 VALVES)​
01-72-03 HYD CONTROL SYSTEM (MC MODEL) (PART-2)​
01-72-04 CONTROL VALVE (3 VALVES) (PART-1) (MC MODEL)​
01-72-05 CONTROL VALVE (3 VALVES) (PART-2) (MC MODEL)​
01-72-06 CONTROL VALVE (4 VALVES) (FOR MC MODEL)​
01-72-07 4V CONTROL VALVE KIT - OPTION​
01-72-08 HYDRAULIC LEVER KNOBS AND DECALS (MC MODEL)​
01-73-01 TILT CYL. BOOT KIT - OPTION​
01-73-02 EXTRA TILT CYL. KIT - OPTION​
01-73-03 FC3V,4V - OPTION​
01-73-04 FC ARMREST 3V,4V - OPTION​
01-73-05 FNR 3V,4V - OPTION​
01-73-06 HYD ATT CIRCUIT - OPTION​
01-73-07 LEVER - OPTION​
01-75-01 HYD POWER STEERING CIRCUIT​
01-75-02 HYDRAULIC TILT CIRCUIT​
01-75-03 HYDRAULIC LIFT CIRCUIT​
01-75-04 HYDRAULIC TANK CIRCUIT​
01-75-05 HYDRAULIC ATTACHMENT CIRCUIT​
NAMEPLATE​
01-81-01 NAME-PLATE​
01-81-02 WARNING LABEL​
01-81-03 FUEL LABEL​
OPTION​
01-05-01 TCHD1000 - OPTION START DISCONNECT​
01-05-02 TCHD1160 - OPTION TIME DELAYED TRAVEL ALARM​
01-05-03 TCHD1000 - OPTION START DISCONNECT (ICC 1 TON TO 3 TON) (MU MODELS)​
01-05-04 TC2020 - OPTION IGNITION INTERLOCK, SEAT & SEATBELT W/PARK BRAKE OVERRIDE 9040112884​
01-11-01 TC3360 - OPTION 60" HIGH LOAD BACKREST EXTENSION​
01-26-01 TCHD1150 - OPTION TRANSMISSION INTERLOCK​
01-75-01 TC1060 - OPTION ACCUMULATOR GROUP 1T 9040108485​
03-04-01 BLUE SPOT LIGHT - REAR ACTIVATED 1-TON​
03-04-02 BLUE SPOT LIGHT - FWD ACTIVATED 1-2-3-TON​
03-04-03 TELA - OPTION POWERFLEET TELEMATICS​
03-05-01 TC2090 POWER SUPPLY FOR LXE SCANNER 12 VOLT 9040113167​
03-20-01 TC6720 BLOCK HEATER ASSEMBLY - LP AND GAS - NO CAB/FRAME MODIFICATION 9040112162 - 9040113192 - 9040114186​
03-20-02 TC6720 BLOCK HEATER ASSEMBLY - LP AND GAS WITH CAB/FRAME MODIFICATION 9040113193 - 9040113192 - 9040114186​
MAST​
LIFT BRACKET​
02-01-01 LIFT BRACKET COMMON PARTS​
02-01-02 LIFT BRACKET​
02-01-03 BACKREST​
TILT CYLINDER​
02-04-01 TILT CYLINDER (L.H.) (5 DEGREES-10 DEGREES,5 DEGREES-6 DEGREES)​
02-04-02 TILT CYLINDER (R.H.) (5 DEGREES-10 DEGREES,5 DEGREES-6 DEGREES)​
02-04-03 TILT CYLINDER (L.H.) (9 DEGREES-6 DEGREES)​
02-04-04 TILT CYLINDER (R.H.) (9 DEGREES-6 DEGREES)​
FORK​
02-06-01 FORK (5A15C,5B15C,5C15C)​
02-06-02 FORK (5A20C,5B20C,5C20C)​
MAST COMMON PARTS​
02-10-01 MAST COMMON PARTS (PART-1) (5A15C,20C20-60)​
02-10-02 MAST COMMON PARTS (PART-2) (5A15C,20C20-60)​
02-10-03 MAST COMMON PARTS (PART-1) (5C15C,20C37-70)​
02-10-04 MAST COMMON PARTS (PART-2) (5C15C,20C37-70)​
02-10-05 MAST COMMON PARTS (PART-3) (5C15C,20C37-70)​
02-10-06 MAST COMMON PARTS (PART-4) (5C15C,20C37-70)​
02-10-07 MAST COMMON PARTS (PART-1) (5B15C,20C28-40)​
02-10-08 MAST COMMON PARTS (PART-2) (5B15C,20C28-40)​
02-10-09 MAST COMMON PARTS (PART-3) (5B15C,20C28-40)​
DUPLEX MAST​
02-18-01 DUPLEX MAST MODEL 5B15C,20C28-40​
02-18-02 LIFT CYLINDER (1ST) (5B15C,20C28-40)​
02-18-03 LIFT CYLINDER (2ND) (5B15C,20C28-40)​
TRIPLEX MAST​
02-20-01 TRIPLEX MAST MODEL 5C15C,20C37-70​
02-20-02 LIFT CYLINDER (1ST) (5C15C,20C37-70)​
02-20-03 LIFT CYLINDER (2ND) (5C15C,20C37-70)​
SIMPLEX MAST​
02-60-01 SIMPLEX MAST MODEL 5A15C,20C20-60​
02-60-02 LIFT CYLINDER (5A15C,20C20-60)​
INTERNAL HOSING​
DUPLEX MAST​
04-21-01 CONNECTOR GROUP (3 VALVES) (5B15C,5B20C28-40)​
04-21-02 HOSING COMMON PARTS (3 VALVES) (5B15C,5B20C28-40)​
04-21-03 INTERNAL HOSING (3 VALVES) (5B15C,5B20C28-40)​
04-22-01 CONNECTOR GROUP (4 VALVES) (5B15C,5B20C28-40)​
04-22-02 HOSING COMMON PARTS (4 VALVES) (5B15C,5B20C28-40)​
04-22-03 INTERNAL HOSING (4 VALVES) (5B15C,5B20C28-40)​
04-22-04 INTEGRAL SIDESHIFTER (5B15C, 20C28-40) (UPTO 2013-11)​
04-22-05 INTEGRAL SIDESHIFTER (5B15C) (PART-1) (FROM 2013-12)​
04-22-06 INTEGRAL SIDESHIFTER (5B15C) (PART-2) (FROM 2013-12)​
04-22-07 STEEL SUPPLY LINES (5B15C, 20C28-40 & INTEGRAL SIDESHIFTER)​
04-22-08 STEEL SUPPLY LINES (5B15C, 20C28-40, 5C15C, 20C37-70)​
04-22-09 QUICK DISCONNECT KIT​
TRIPLEX MAST​
04-61-01 CONNECTOR GROUP (3 VALVES) (5C15C,5C20C37-70)​
04-61-02 HOSING COMMON PARTS (3 VALVES) (5C15C,5C20C37-70)​
04-61-03 INTERNAL HOSING (3 VALVES) (5C15C,5C20C37-70)​
04-62-01 CONNECTOR GROUP (4 VALVES) (5C15C,5C20C37-70)​
04-62-02 HOSING COMMON PARTS (4 VALVES) (5C15C,5C20C37-70)​
04-62-03 INTERNAL HOSING (4 VALVES) (5C15C,5C20C37-70)​
04-62-04 3 VALVES TO 4 VALVES CONVERSION (MC MODEL) (PART-1) (5C15C, 5C20C37-70)​
04-62-05 3 VALVES TO 4 VALVES CONVERSION (PART-2) (5C15C, 5C20C37-70)​
04-62-06 INTEGRAL SIDESHIFTER (5C15C, 20C20-60) (UPTO 2013-01)​
04-62-07 INTEGRAL SIDESHIFTER (5C15C) (PART-1) (FROM 2013-02)​
04-62-08 INTEGRAL SIDESHIFTER (5C15C) (PART-2) (FROM 2013-02)​
04-62-09 STEEL SUPPLY LINES (5C15C, 20C37-70 & INTEGRAL SIDESHIFTER)​
04-62-10 STEEL SUPPLY LINES (5B15C,20C28-40 & 5C15C,20C37-70)​
04-62-11 QUICK DISCONNECT KIT​
SIMPLEX MAST​
04-41-01 CONNECTOR GROUP (3 VALVES) (5A15C,5A20C20-60)​
04-41-02 HOSING COMMON PARTS (3 VALVES) (5A15C,5A20C20-60)​
04-41-03 INTERNAL HOSING (3 VALVES) (5A15C,5A20C20-60)​
04-42-01 CONNECTOR GROUP (4 VALVES) (5A15C,5A20C20-60)​
04-42-02 HOSING COMMON PARTS (4 VALVES) (5A15C,5A20C20-60)​
04-42-03 INTERNAL HOSING (4 VALVES) (5A15C,5A20C20-60)​
04-42-04 INTEGRAL SIDESHIFTER (5A15C) (PART-1) (UPTO 2013-11)​
04-42-05 INTEGRAL SIDESHIFTER (5A20C20-60) (PART-2) (UPTO 2013-11)​
04-42-06 INTEGRAL SIDESHIFTER (5A15C, 5A20C) (PART-1) (FROM 2013-12)​
04-42-07 INTEGRAL SIDESHIFTER (5A15C, 5A20C) (PART-2) (FROM 2013-12)​
04-42-08 STEEL SUPPLY LINES (5A15C, 20C20-60 & INTEGRAL SIDESHIFTER)​
04-42-09 STEEL SUPPLY LINES (5A15C, 20C20-60)​
04-42-10 QUICK DISCONNECT KIT​
Expandir​
