118
6,911
CAT Excavator 345C Electrical Hydraulic Schematic
Brand: Caterpillar
Type of Machine: Excavator
Type of Manual: Electrical Schematic, Hydraulic Schematic
Model: CAT 345C Excavator
List of Files:
KENR5699-00: 345C Material Handler Electrical System 291-4254-01
KENR5699-01: 345C Excavator With Hydraulic Cab Riser Electrical System, 291-4254-01(For Serial Number MTE1-UP)
KENR6103-01: 345C Material Handler With Cab Riser Hydraulic System (Interactive) 291-4253-00
KENR6289-01: 345C Excavator Electrical System - Attachment - Demolition
KENR6290-02: 323D, 324D, 325D, 330D, 345C, 365C, And 385C Excavator 336D MHPU And 345C MHPU Demolition Cab Electrical System 265-6487
KENR6290-03: 323D, 324D, 325D, 330D, 345C, 365C, And 385C Excavator, 336D MHPU And 345C MHPU Demolition Cab Electrical System 265-6487-00, (For Serial Numbers EJC1-UP SYM1-UP GPB1-UP PKE1-UP MCL1-UP GBR1-UP THJ1-UP SPC1-UP GPH1-UP GCL1-UP M3E1-UP M3F1-UP MEM1-UP MCY1-UP KGB1-UP T2E1-UP M3N1-UP M3M1-UP SDC1-UP)
KENR6569-00: 345C Excavator Hydraulic System - Attachment - Alternate Control Pattern - 2 Way (Interactive) 239-8859-01
KENR6573-00: 345C Excavator Hydraulic System - Attachment - Alternate Control Pattern - 4 Way (Interactive) 232-4139-01
KENR6664-01: 345C And W345C Material Handler - With Fixed Cab Riser Electrical System (For Serial Number M2R152-UP. All Other Serial Numbers 1-UP) 254-3291-05
KENR6664-02: 345C And W345C Material Handler Electrical System ,254-3291-05 (For Serial Numbers R5K1-UP M2R152-UP)
KENR7834-00: 345C Excavator Electrical System - Attachment - Ultra-High Demolition 261-5157-04
KENR7835-01: 345C Excavator Hydraulic System - Attachment - Ultra-High Demolition (Interactive) 261-5156-04
RENR6960-01: 345C Excavator Hydraulic System - Attachment - System 2: Combined Function (Interactive) 230-2698-01
RENR7074-02: 345C Excavator Hydraulic System - Attachment - Quick Coupler (Interactive) 282-5688-02
RENR7125-02: 345C Excavator Hydraulic System - Attachment - System 3: One-Way / Two Pump Flow / Foot Switch (Interactive) 230-2699-01
RENR7126-01: 345C Excavator Hydraulic System - Attachment - System 5: Two-Way / One Pump / Peda (Interactive) L 230-270-02
RENR7127-03: 345C Excavator Hydraulic System - Attachment - System 14: Combined Function / Joystick With Slide Control (Interactive) 230-2704-01
RENR7128-03: 345C Excavator Hydraulic System - Attachment - Boom Lowering Control Valve (Interactive) 230-2711
RENR7130-01: 345C Excavator Hydraulic - Attachment - Counterweight Removal (Interactive) 232-4123-01
RENR7130-02: 345C Excavator Hydraulic System - Counterweight Removal(Interactive)(Function ISOLATION),232-4123-01 (For Serial Numbers TBA1-UP BWY1-UP PJW1-UP GJR1-UP DHP1-UP TAJ1-UP TDG1-UP WDE1-UP ESD1-UP FPC1-UP)
RENR7218-00: 345C Excavator Hydraulic System - Attachment - System 16 Prime: One Way / Two Pump / Joystick Switch 239-8957-01
RENR7219-01: 345C Excavator Hydraulic System - Attachment - System 17: Combined Function / Joystick With Slide Control 239-8692-01
RENR7221-04: 345C Excavator Hydraulic System - Attachment - Stick Lowering Control Valve (Interactive) 230-2713-01
RENR7222-01: 345C Excavator Hydraulic System - Attachment 276-2846
RENR7248-00: 345C Excavator Hydraulic System - Attachment - System 11: Combined Function / Auxilliary Control Valve 230-2702-01
RENR7258-08: Air Conditioning Electrical System (324D,325D,326D,326D2,328D LCR,329D,329D2,330D,336D,336D2,340D,340D2,345C,345D,349D,349D2,365C,374D,385C,390D And M325D)
RENR7258-09: 324D, 325D, 326D, 326D2, 328D Lcr, 329D, 329D2, 330D, 336D, 336D2, 340D,340D2, 345C, 345D, 349D, 349D2, 365C, 374D, 385C, 390D And M325D Excavator Air Conditioning Electrical System (Interactive)(Function Isolation) ,336-6055-03 (For Serial Numbers BZN138-UP ZCA302-UP AYF245-UP KFM263-UP KRM220-UP RJP152-UP)
RENR7287-08: 345C Excavator Electrical System (Interactive), 213-0721-02 (For Serial Numbers PJW350-UP S5M1-UP TAJ1-UP TDG250-UP ESD168-UP)
RENR7287-09: 345C Excavator Electrical System (Interactive)(Function Isolation) 213-0721-02, (For Serial Numbers TDG250-UP TAJ1-UP S5M1-UP PJW350-UP ESD168-UP)
RENR7326-05: 345C Excavator Hydraulic System - With Heavy Lift And Fine Swing (Interactive) 255-5737-05
RENR7327-02: 345C Excavator Electrical System 213-0721-05
RENR7336-00: 345C Excavator Hydraulic System
RENR7337-05: 345C Excavator And 345C MHPU Electrical System 213-0721-06(CAB And Chassis) / 231-1979-06(ENGINE)
RENR7337-06: 345C Excavator And 345C MHPU Electrical System Cab And CHASSIS-213-0721-06, Engine CONTROL-231-1979-06, (For Serial Numbers SPC1-UP GPH1-UP GCL1-UP ELS1-UP LYS1-UP M3E1-UP M3F1-UP FPC1-UP)
RENR7356-02: 345C Excavator Hydraulic System Without Heavy Lift And Fine Swing (Interactive) 230-2696-05
RENR7357-00: 345C Excavator Hydraulic System - Attachment - System 12: Two Way / One Pump Flow / Pedal 239-8956-00
RENR7358-00: 345C Excavator Hydraulic System - Attachment - System 1: One-Way / One Pump / Pedal 230-2697-01
RENR7369-01: 345C Excavator Hydraulic System - Attachment - System 15: Two-Way / One Pump / Joystick (Interactive) 239-8691-02
RENR7378-01: 345C Excavator And 345C MHPU Hydraulic System - Attachment - Hydraulic Variable Gauge Undercarriage (Interactive) 258-2243-01
RENR7379-06: 345C And 345C MH Excavator 345C MHPU Hydraulic System - Attachment - Reversable Fan (Interactive) 239-8958-00
RENR7391-01: 345C Excavator Hydraulic System - Attachment - Fine Filtration 253-0013-00
RENR7397-02: 345C Excavator Hydraulic - Attachment - Boom Float 239-8690-02
RENR9169-02: 345C Material Handler Hydraulic System, Schematic Part Number 257-5818-05 (For Serial Numbers D3S1-UP)
RENR9175-01: 345C Material Handler With Fixed Cab Riser Hydraulic System 253-0313-01
RENR9175-02: 345C Material Handler Hydraulic System (Interactive)(Function Isolation) 253-0313-05, (For Serial Numbers M2R1-UP)
RENR9176-02: 345C Material Handler Electrical System 254-3291-03
RENR9176-03: 345C Material Handler Electrical System 254-3291-03, (For Serial Numbers M2R1-151)
RENR9859-01: 345C Material Handler Electrical System - With Hydraulic Cab Riser 264-6087-02
