CAT Excavator 320D - 340D2 Tool Control System Operation RENR7389-31
Brand: Caterpillar
Type of Machine: Excavator Tool Control
Type of Manual: System Operation
Model: CAT 320D, 320D2, 321D, 323D, 324D, 325D, 328D, 329D, 330D, 336D, 336D2, 340D and 340D2 Excavators Tool Control System
Part Number: RENR7389-31
Number of Pages: 836 Pages
Systems Operation
Medium Pressure Hydraulic System
Relays
Senders
Sensors
Solenoid Valves
Switches
System 1 One-Way,One Pump
System 2 Combined Function
System 3 One-Way,Two Pump
System 3 Prime One-Way,Two Pump
System 5 Two-Way,One Pump
System 11 Combined Function
System 13 Combined Function
System 14 Combined Function
System 16 One-Way,Two Pump
System 17 Combined Function 2
System 18 Combined Function
System 19 Combined Function
Testing and Adjusting
Control (Pedal) - Calibrate
Control (Thumb Wheel) - Calibrate
Medium Pressure Default Value of Work Tool Parameters
Medium Pressure Relief Valve (Main) - Test and Adjust
Process for Setting Up the Work Tool
Service Tools
Solenoid Valve (Proportional Reducing) - Calibrate 2
Solenoid Valve (Proportional Reducing) - Calibrate 3
System 1 Default Value of Work Tool Parameters
System 1 Relief Valve (Line) - Test and Adjust
System 2 Default Value of Work Tool Parameters
System 2 Relief Valve (Line) - Test and Adjust 2
System 3 Default Value of Work Tool Parameters
System 3 Prime Default Value of Work Tool Parameters
System 3 Prime Relief Valve (Line) 2
System 3 Relief Valve (Line) - Test and Adjust 2
System 5 Default Value of Work Tool Parameters
System 5 Relief Valve (Line) - Test and Adjust
System 11 Default Value of Work Tool Parameters
System 11 Relief Valve (Line) - Test and Adjust 2
System 13 Default Value of Work Tool Parameters
System 13 Relief Valve (Line) - Test and Adjust
System 14 Default Value of Work Tool Parameters
System 14 Relief Valve (Line)
System 14 Relief Valve (Main) - Test and Adjust
System 16 Default Value of Work Tool Parameters
System 16 Relief Valve (Line) - Test and Adjust
System 17 Default Value of Work Tool Parameters 2
System 17 Relief Valve (Line) - Test and Adjust
System 17 Relief Valve (Main) - Test and Adjust
System 18 Default Value of Work Tool Parameters
System 18 Relief Valve (Line) - Test and Adjust
System 19 Default Value of Work Tool Parameters
System 19 Relief Valve (Line) - Test and Adjust 2
System Identification
Work Tool - Select
Work Tool Parameter - Program
Brand: Caterpillar
Systems Operation
Relays
Senders
Sensors
Solenoid Valves
Switches
Service Tools
Work Tool - Select
- CAT 416D Parts Manual
- CAT 420D Parts Manual
