CAT Engine C10 C12 C15 C16 Electrical Application and Installation Guide LEBT9010-02
Brand: Caterpillar
Type of Manual: Electrical Application and Installation Guide
Model: CAT C10 C12 C15 C16 Engine
Part Number: LEBT9010-02
Number of Pages: 173 Pages
INTRODUCTION AND PURPOSE
1.0 Engine Functions
2.0 Engine Component Overview
3.0 Power and Grounding Requirements and Considerations
4.0 Voltage Requirements and Considerations
5.0 Connectors and Wiring Harness Requirements
6.0 Accelerator Pedal Position Sensors
7.0 Vehicle Speed Circuit
8.0 ECM Speedometer and Tachometer Outputs
9.0 Lamp Outputs
10.0 Engine Monitoring and OEM Requirements
11.0 Coolant Level Sensor
12.0 Idle Shutdown and Ambient Air Temperature Sensor Installation
13.0 OEM Installed Switch Inputs
14.0 Dedicated PTO Operation
15.0 Engine Retarder
16.0 Programmable Outputs
17.0 Cooling Fan
18.0 Transmissions
19.0 ABS and Traction Control
20.0 Data Links
21.0 SAE J1922/J1708 Data Link
22.0 SAE J1939 Data Link
23.0 SAE J1939 Data Link Supported Parameters
24.0 Customer Specified Parameters
25.0 ECM Date/Time Clock
26.0 ECM Diagnostic Clock
27.0 ECM Vehicle Harness Connector Terminal Assignments and Loads
28.0 Diagnostic Code Quick Reference
Brand: Caterpillar
9.0 Lamp Outputs
17.0 Cooling Fan
18.0 Transmissions
20.0 Data Links
- CAT 416D Parts Manual
- CAT 420D Parts Manual
