Martin Welker
104
230,792
CAT Engine 3064 3066 Disassembly and Assembly Manual SENR5553-10
Brand: Caterpillar
Type of Manual: Disassembly and Assembly Manual
Model: CAT 3064 3066 Engine
Part Number: SENR5553-10
Publication Date: 2012
Number of Pages: 275 Pages
Air Inlet Heater - Remove and Install
Alternator - Remove and Install
Bearing Clearance - Check
Camshaft - Install
Camshaft - Remove
Camshaft Bearings - Install
Camshaft Bearings - Remove
Camshaft Gear - Remove and Install
Connecting Rod Bearings - Install
Connecting Rod Bearings - Remove
Coolant Temperature Switch - Remove and Install
Crankcase Breather - Remove and Install
Crankshaft - Install
Crankshaft - Remove
Crankshaft Front Seal - Install
Crankshaft Front Seal - Remove
Crankshaft Gear - Remove and Install
Crankshaft Main Bearings - Install
Crankshaft Main Bearings - Remove
Crankshaft Pulley - Remove and Install
Crankshaft Rear Seal - Install
Crankshaft Rear Seal - Remove
Cylinder Head - Install
Cylinder Head - Remove
Cylinder Liner - Install
Cylinder Liner - Remove
Electric Starting Motor - Remove and Install
Engine Oil Bypass Valve - Remove and Install
Engine Oil Cooler - Assemble
Engine Oil Cooler - Disassemble
Engine Oil Cooler - Install
Engine Oil Cooler - Remove
Engine Oil Filter Base - Install
Engine Oil Filter Base - Remove
Engine Oil Pan - Remove and Install
Engine Oil Pressure Switch - Remove and Install
Engine Oil Pump - Install
Engine Oil Pump - Remove
Engine Oil Relief Valve - Remove and Install
Exhaust Manifold - Remove and Install
Flywheel - Install
Flywheel - Remove
Flywheel Housing - Remove and Install
Front Plate - Install
Front Plate - Remove
Fuel Filter Base - Remove and Install
Fuel Injection Lines - Remove and Install
Fuel Injection Nozzles - Install
Fuel Injection Nozzles - Remove
Fuel Injection Pump - Install
Fuel Injection Pump - Remove
Fuel Priming Pump - Remove and Install
Fuel Shutoff Solenoid - Remove and Install
Gear Group (Front) - Install - Idler Gear Only
Gear Group (Front) - Remove - Idler Gear Only
Housing (Front) - Install
Housing (Front) - Remove
Inlet and Exhaust Valve Guides - Remove and Install
Inlet and Exhaust Valve Seals - Remove and Install
Inlet and Exhaust Valve Seat Inserts - Remove and Install
Inlet and Exhaust Valve Springs - Remove and Install
Inlet and Exhaust Valves - Remove and Install
Inlet Manifold - Install
Inlet Manifold - Remove
Lifter Group - Remove and Install
Pistons and Connecting Rods - Assemble
Pistons and Connecting Rods - Disassemble
Pistons and Connecting Rods - Remove
Rocker Shaft - Assemble
Rocker Shaft - Disassemble
Rocker Shaft and Pushrod - Install
Rocker Shaft and Pushrod - Remove
Turbocharger - Assemble
Turbocharger - Disassemble
Turbocharger - Install
Turbocharger - Remove
Valve Mechanism Cover - Remove and Install
V-Belts - Remove and Install
Water Pump - Assemble
Water Pump - Disassemble
Water Pump - Install
Water Pump - Remove
Water Temperature Regulator - Remove and Install
