CAT Engine 3054C for 416D BFP Disassembly and Assembly Manual SENR5069-14
Brand: Caterpillar
Type of Manual: Disassembly and Assembly Manual
Model: CAT 3054C Engine
Part Number: SENR5069-14
Number of Pages: 247 Pages
Accessory Drive - Remove and Install
Alternator - Install
Alternator - Remove
Bearing Clearance - Check
Camshaft - Remove and Install
Camshaft Bearings - Remove and Install
Connecting Rod Bearings - Install
Connecting Rod Bearings - Remove
Coolant Temperature Sensor - Remove and Install
Crankcase Breather - Remove and Install
Crankshaft - Install
Crankshaft - Remove
Crankshaft Front Seal - Install
Crankshaft Front Seal - Remove
Crankshaft Gear - Remove and Install
Crankshaft Main Bearings - Install
Crankshaft Main Bearings - Remove
Crankshaft Pulley - Remove and Install
Crankshaft Rear Seal - Install
Crankshaft Wear Sleeve (Rear) - Install
Crankshaft Wear Sleeve (Rear) - Remove
Cylinder Head - Install
Cylinder Head - Remove
Electric Starting Motor - Remove and Install
Engine Oil Cooler - Install
Engine Oil Cooler - Remove
Engine Oil Filter Base - Remove and Install
Engine Oil Pan - Remove and Install
Engine Oil Pressure Sensor - Remove and Install
Engine Oil Pump - Install - Engines Without a Balancer
Engine Oil Pump - Remove - Engines Without a Balancer
Engine Oil Relief Valve - Remove and Install - Engine without Balancer Group
Exhaust Manifold - Remove and Install
Fan - Remove and Install
Fan Drive - Remove and Install
Flywheel - Install
Flywheel - Remove
Flywheel Housing - Remove and Install
Front Cover - Remove and Install
Fuel Injection Lines - Remove and Install
Fuel Injection Nozzles - Install
Fuel Injection Nozzles - Remove
Fuel Injection Pump - Install - Delphi DP210
Fuel Injection Pump - Remove - Delphi DP210
Fuel Priming Pump and Fuel Filter Base - Remove and Install
Glow Plugs - Remove and Install
Housing (Front) - Install
Housing (Front) - Remove
Idler Gear - Remove and Install - Delphi DP210 Fuel Injection Pump
Inlet and Exhaust Valve Guides - Remove and Install
Inlet and Exhaust Valve Seat Inserts - Remove and Install
Inlet and Exhaust Valve Springs - Remove and Install
Inlet and Exhaust Valves - Remove and Install
Lifter Group - Remove and Install
Piston Cooling Jets - Remove and Install
Pistons and Connecting Rods - Assemble
Pistons and Connecting Rods - Disassemble
Pistons and Connecting Rods - Install
Pistons and Connecting Rods - Remove
Rocker Shaft - Assemble
Rocker Shaft - Disassemble
Rocker Shaft and Pushrod - Install
Rocker Shaft and Pushrod - Remove
Turbocharger - Install
Turbocharger - Remove
Valve Mechanism Cover - Remove and Install
V-Belts - Remove and Install
Water Pump - Remove and Install
Water Temperature Regulator - Remove and Install
Brand: Caterpillar
Alternator - Remove
Crankshaft - Remove
Flywheel - Install
Flywheel - Remove
- CAT 416D Parts Manual
- CAT 420D Parts Manual
