Martin Welker
104
230,310
CAT Engine 3054B for 416D BGP Disassembly and Assembly Manual SENR5011-04
Brand: Caterpillar
Type of Manual: Disassembly and Assembly Manual
Model: CAT 3054B Engine
Part Number: SENR5011-04
Number of Pages: 243 Pages
Air Inlet Heater - Remove and Install
Alternator - Remove and Install
Bearing Clearance - Check
Camshaft - Install
Camshaft - Remove
Camshaft Bearings - Remove and Install
Camshaft Gear - Remove and Install
Connecting Rod Bearings - Install
Connecting Rod Bearings - Remove
Crankshaft - Install
Crankshaft - Remove - 3054 and 3054B Engines
Crankshaft Front Seal - Install
Crankshaft Front Seal - Remove
Crankshaft Gear - Remove and Install
Crankshaft Main Bearings - Install
Crankshaft Main Bearings - Remove
Crankshaft Pulley - Remove and Install
Crankshaft Rear Seal - Install
Crankshaft Rear Seal - Remove
Cylinder Head - Install
Cylinder Head - Remove
Electric Starting Motor - Remove and Install
Engine Oil Filter Base - Assemble
Engine Oil Filter Base - Disassemble
Engine Oil Filter Base - Install
Engine Oil Filter Base - Remove
Engine Oil Pan - Remove and Install
Engine Oil Pump - Assemble
Engine Oil Pump - Disassemble
Engine Oil Pump - Install
Engine Oil Pump - Remove
Exhaust Manifold - Remove and Install
Fan - Remove and Install
Fan Drive - Install
Fan Drive - Remove
Flywheel - Install
Flywheel - Remove
Flywheel Housing - Remove and Install
Front Cover - Install
Front Cover - Remove
Fuel Filter Base - Remove and Install
Fuel Injection Lines - Remove and Install
Fuel Injection Nozzles - Install
Fuel Injection Nozzles - Remove
Fuel Injection Pump - Install
Fuel Injection Pump - Remove
Fuel Transfer Pump - Assemble
Fuel Transfer Pump - Disassemble
Fuel Transfer Pump - Install
Fuel Transfer Pump - Remove
Gear Group (Front) - Install
Gear Group (Front) - Remove
Housing (Front) - Install
Housing (Front) - Remove
Inlet and Exhaust Valve Guides - Remove and Install
Inlet and Exhaust Valve Seat Inserts - Remove and Install
Inlet and Exhaust Valve Springs - Remove and Install
Inlet and Exhaust Valves - Remove and Install
Inlet Manifold - Install
Inlet Manifold - Remove
Lifter Group - Remove and Install
Piston Cooling Jets - Remove and Install
Pistons and Connecting Rods - Assemble
Pistons and Connecting Rods - Disassemble
Pistons and Connecting Rods - Install
Pistons and Connecting Rods - Remove
Rocker Arm and Shaft - Install
Rocker Arm and Shaft - Remove
Rocker Shaft - Assemble
Rocker Shaft - Disassemble
Valve Mechanism Cover - Remove and Install
V-Belts - Remove and Install
Water Pump - Install
Water Pump - Remove
Water Temperature Regulator - Remove and Install
Water Temperature Regulator Housing - Remove and Install
