CAT Backhoe Loader 424D BGP Service Manual and Schematics
Brand: Caterpillar
Type of Manual: Service Manual, Electrical Schematic, Hydraulic Schematic
Model: CAT 424D BGP Backhoe Loader
List of Files:
-3054B Engine for Caterpillar Built Machines
Air Inlet Heater - Remove and Install.pdf
Alternator - Remove and Install.pdf
Bearing Clearance - Check.pdf
Camshaft - Install.pdf
Camshaft - Remove.pdf
Camshaft Bearings - Remove and Install.pdf
Camshaft Gear - Remove and Install.pdf
Connecting Rod Bearings - Install.pdf
Connecting Rod Bearings - Remove.pdf
Crankshaft - Install.pdf
Crankshaft - Remove - 3054 and 3054B Engines.pdf
Crankshaft Front Seal - Install.pdf
Crankshaft Front Seal - Remove.pdf
Crankshaft Gear - Remove and Install.pdf
Crankshaft Main Bearings - Install.pdf
Crankshaft Main Bearings - Remove.pdf
Crankshaft Pulley - Remove and Install.pdf
Crankshaft Rear Seal - Install.pdf
Crankshaft Rear Seal - Remove.pdf
Cylinder Head - Install.pdf
Cylinder Head - Remove.pdf
Electric Starting Motor - Remove and Install.pdf
Engine Oil Filter Base - Assemble.pdf
Engine Oil Filter Base - Disassemble.pdf
Engine Oil Filter Base - Install.pdf
Engine Oil Filter Base - Remove.pdf
Engine Oil Pan - Remove and Install.pdf
Engine Oil Pump - Assemble.pdf
Engine Oil Pump - Disassemble.pdf
Engine Oil Pump - Install.pdf
Engine Oil Pump - Remove.pdf
Exhaust Manifold - Remove and Install.pdf
Fan - Remove and Install.pdf
Fan Drive - Install.pdf
Fan Drive - Remove.pdf
Flywheel - Install.pdf
Flywheel - Remove.pdf
Flywheel Housing - Remove and Install.pdf
Front Cover - Install.pdf
Front Cover - Remove.pdf
Fuel Filter Base - Remove and Install.pdf
Fuel Injection Lines - Remove and Install.pdf
Fuel Injection Nozzles - Install.pdf
Fuel Injection Nozzles - Remove.pdf
Fuel Injection Pump - Install.pdf
Fuel Injection Pump - Remove.pdf
Fuel Transfer Pump - Assemble.pdf
Fuel Transfer Pump - Disassemble.pdf
Fuel Transfer Pump - Install.pdf
Fuel Transfer Pump - Remove.pdf
Gear Group (Front) - Install.pdf
Gear Group (Front) - Remove.pdf
Housing (Front) - Install.pdf
Housing (Front) - Remove.pdf
Inlet and Exhaust Valve Guides - Remove and Install.pdf
Inlet and Exhaust Valve Seat Inserts - Remove and Install.pdf
Inlet and Exhaust Valve Springs - Remove and Install.pdf
Inlet and Exhaust Valves - Remove and Install.pdf
Inlet Manifold - Install.pdf
Inlet Manifold - Remove.pdf
Lifter Group - Remove and Install.pdf
Piston Cooling Jets - Remove and Install.pdf
Pistons and Connecting Rods - Assemble.pdf
Pistons and Connecting Rods - Disassemble.pdf
Pistons and Connecting Rods - Install.pdf
Pistons and Connecting Rods - Remove.pdf
Rocker Arm and Shaft - Install.pdf
Rocker Arm and Shaft - Remove.pdf
Rocker Shaft - Assemble.pdf
Rocker Shaft - Disassemble.pdf
V-Belts - Remove and Install.pdf
Valve Mechanism Cover - Remove and Install.pdf
Water Pump - Install.pdf
Water Pump - Remove.pdf
Water Temperature Regulator - Remove and Install.pdf
Water Temperature Regulator Housing - Remove and Install.pdf
-424D Backhoe Loaders Engine Supplement
Air Cleaner - Remove and Install.pdf
Engine and Transmission - Install.pdf
Engine and Transmission - Remove.pdf
Engine Cover - Remove and Install.pdf
Engine Torque Converter and Transmission - Connect.pdf
Engine Torque Converter and Transmission - Separate.pdf
Fan Drive - Remove and Install.pdf
Fan Guard - Remove and Install.pdf
Fuel Filter - Remove and Install.pdf
Fuel Tank - Install.pdf
Fuel Tank - Remove.pdf
Hood - Remove and Install.pdf
Hydraulic Oil Cooler - Remove and Install.pdf
Hydraulic System Pressure - Release 1.pdf
Hydraulic System Pressure - Release.pdf
Muffler - Remove and Install.pdf
Radiator - Remove and Install.pdf
Refrigerant Compressor - Remove and Install.pdf
Refrigerant Condenser - Remove and Install.pdf
Turbocharger - Remove and Install.pdf
Water Pump - Remove and Install.pdf
Water Separator - Remove and Install.pdf
-424D Backhoe Loaders Machine Systems
Air Conditioner and Heater - Install.pdf
Air Conditioner and Heater - Remove.pdf
Backhoe Bucket Cylinder - Assemble.pdf
Backhoe Bucket Cylinder - Disassemble.pdf
Backhoe Bucket Cylinder - Install.pdf
Backhoe Bucket Cylinder - Remove.pdf
Backhoe Bucket Linkage - Remove and Install.pdf
Bank Valve (Backhoe) - Assemble 1.pdf
Bank Valve (Backhoe) - Assemble.pdf
Bank Valve (Backhoe) - Disassemble 1.pdf
Bank Valve (Backhoe) - Disassemble.pdf
Bank Valve (Loader) - Assemble.pdf
Bank Valve (Loader) - Disassemble.pdf
Bank Valve (Loader) - Install.pdf
Bank Valve (Loader) - Remove.pdf
Bank Valve (Stabilizer) - Assemble.pdf
Bank Valve (Stabilizer) - Disassemble.pdf
Bank Valve (Stabilizer) - Install.pdf
Bank Valve (Stabilizer) - Remove.pdf
Boom - Remove and Install.pdf
Boom Cylinder - Assemble.pdf
Boom Cylinder - Disassemble.pdf
Boom Cylinder - Install.pdf
Boom Cylinder - Remove.pdf
Bucket Positioner Control - Remove and Install.pdf
Cab - Install.pdf
Cab - Remove.pdf
Counterweight - Remove and Install.pdf
Extendable Stick - Remove and Install.pdf
Extendable Stick Cylinder - Assemble.pdf
Extendable Stick Cylinder - Disassemble.pdf
Extendable Stick Cylinder - Install.pdf
Extendable Stick Cylinder - Remove.pdf
Floorplate - Remove and Install.pdf
Hoe Bucket - Remove and Install.pdf
Hydraulic Tank - Assemble.pdf
Hydraulic Tank - Disassemble.pdf
Hydraulic Tank - Install.pdf
Hydraulic Tank - Remove.pdf
Lift Arms - Install.pdf
Lift Arms - Remove.pdf
Lift Cylinder - Assemble.pdf
Lift Cylinder - Disassemble.pdf
Lift Cylinder - Install.pdf
Lift Cylinder - Remove.pdf
Link Assemblies (Lower) - Remove and Install.pdf
Link Assemblies (Upper) - Remove and Install.pdf
Multipurpose Bucket - Remove and Install.pdf
Pilot Valve (Backhoe) - Assemble.pdf
Pilot Valve (Backhoe) - Disassemble.pdf
Pilot Valve (Backhoe) - Install.pdf
Pilot Valve (Backhoe) - Remove.pdf
Pilot Valve (Loader) - Assemble.pdf
Pilot Valve (Loader) - Disassemble.pdf
Pilot Valve (Loader) - Install.pdf
Pilot Valve (Loader) - Remove.pdf
Pilot Valve (Stabilizer) - Assemble.pdf
Pilot Valve (Stabilizer) - Disassemble.pdf
Pilot Valve (Stabilizer) - Install.pdf
Pilot Valve (Stabilizer) - Remove.pdf
Piston Pump - Assemble.pdf
Piston Pump - Disassemble.pdf
Piston Pump - Install - Implement.pdf
Piston Pump - Remove - Implement.pdf
Quick Coupler - Remove and Install.pdf
Seat - Assemble.pdf
Seat - Disassemble.pdf
Seat - Install.pdf
Seat - Remove.pdf
Service Brake Control - Assemble.pdf
Service Brake Control - Disassemble.pdf
Service Brake Control - Install.pdf
Service Brake Control - Remove.pdf
Stabilizer - Remove and Install.pdf
Stabilizer Cylinder - Assemble.pdf
Stabilizer Cylinder - Disassemble.pdf
Steering Metering Pump - Assemble.pdf
Steering Metering Pump - Disassemble.pdf
Steering Metering Pump - Install.pdf
Steering Metering Pump - Remove.pdf
Steering Wheel - Remove and Install.pdf
Swing Cylinder - Assemble.pdf
Swing Cylinder - Disassemble.pdf
Swing Cylinder - Install.pdf
Swing Cylinder - Remove.pdf
Swing Frame - Install.pdf
Swing Frame - Remove.pdf
Tilt Cylinder - Assemble.pdf
Tilt Cylinder - Disassemble.pdf
Tilt Cylinder - Install.pdf
Tilt Cylinder - Remove.pdf
Window Wiper and Wiper Motor (Front) - Install.pdf
Window Wiper and Wiper Motor (Front) - Remove.pdf
Window Wiper and Wiper Motor (Rear) - Install.pdf
Window Wiper and Wiper Motor (Rear) - Remove.pdf
-424D Backhoe Loaders Power Train
Axle Housing (Differential and Bevel Gear) (Front) - Assemble.pdf
Axle Housing (Differential and Bevel Gear) (Front) - Disassemble.pdf
Axle Housing (Differential and Bevel Gear) (Front) - Install.pdf
Axle Housing (Differential and Bevel Gear) (Front) - Remove.pdf
Differential and Pinion (Rear) - Assemble.pdf
Differential and Pinion (Rear) - Disassemble.pdf
Differential and Pinion (Rear) - Install.pdf
Differential and Pinion (Rear) - Remove.pdf
Drive and Steering Axle (Front) - Install.pdf
Drive and Steering Axle (Front) - Remove.pdf
Drive and Steering Axle (Rear) - Install.pdf
Drive and Steering Axle (Rear) - Remove.pdf
Drive and Steering Axle Housing (Front) - Assemble.pdf
Drive and Steering Axle Housing (Front) - Disassemble.pdf
Drive and Steering Axle Housing (Front) - Install.pdf
Drive and Steering Axle Housing (Front) - Remove.pdf
Drive and Steering Axle Housing (Rear) - Assemble.pdf
Drive and Steering Axle Housing (Rear) - Disassemble.pdf
Drive and Steering Axle Housing (Rear) - Install.pdf
Drive and Steering Axle Housing (Rear) - Remove.pdf
Drive Shaft (Front) - Remove and Install.pdf
Drive Shaft (Rear) - Remove and Install.pdf
Final Drive (Drive and Steering Axle)(Front) - Assemble.pdf
Final Drive (Drive and Steering Axle)(Front) - Disassemble.pdf
Final Drive (Drive and Steering Axle)(Front) - Install.pdf
Final Drive (Drive and Steering Axle)(Front) - Remove.pdf
Final Drive (Drive and Steering Axle)(Rear) - Assemble.pdf
Final Drive (Drive and Steering Axle)(Rear) - Disassemble.pdf
Final Drive (Drive and Steering Axle)(Rear) - Install.pdf
Final Drive (Drive and Steering Axle)(Rear) - Remove 1.pdf
Final Drive (Drive and Steering Axle)(Rear) - Remove.pdf
Front Axle - Assemble.pdf
Front Axle - Disassemble.pdf
Front Axle - Install.pdf
Front Axle - Remove.pdf
Parking Brake - Remove and Install.pdf
Rear Axle - Install.pdf
Rear Axle - Remove.pdf
Rear Axle Housing - Assemble.pdf
Rear Axle Housing - Disassemble.pdf
Rear Axle Housing - Install.pdf
Rear Axle Housing - Remove.pdf
Service Brake - Assemble.pdf
Service Brake - Disassemble.pdf
Service Brake - Install.pdf
Service Brake - Remove.pdf
Solenoid Valve (Transmission) - Assemble.pdf
Solenoid Valve (Transmission) - Disassemble.pdf
Solenoid Valve (Transmission) - Install 1.pdf
Solenoid Valve (Transmission) - Install.pdf
Solenoid Valve (Transmission) - Remove 1.pdf
Solenoid Valve (Transmission) - Remove.pdf
Steering Cylinder (Front) - Remove and Install.pdf
Tie Rod (Steering)(Front) - Remove and Install.pdf
Tie Rods (Steering)(Rear) - Remove and Install.pdf
Tire and Rim (Front) - Remove and Install 1.pdf
Tire and Rim (Front) - Remove and Install.pdf
Tire and Rim (Rear) - Remove and Install.pdf
Transmission (Direct Drive) - Assemble.pdf
Transmission (Direct Drive) - Disassemble.pdf
Transmission (Direct Drive) - Install.pdf
Transmission (Direct Drive) - Remove.pdf
Transmission (Power Shift) - Assemble.pdf
Transmission (Power Shift) - Disassemble.pdf
Transmission (Power Shift) - Install.pdf
Transmission (Power Shift) - Remove.pdf
-Maintenance Section
Axle Universal Joint (Front) - Lubricate.pdf
Backhoe Boom Stick Bucket and Cylinder Bearings - Lubricate.pdf
Backup Alarm - Test.pdf
Belts - Inspect Adjust Replace.pdf
Brake Reservoir Oil Level - Check.pdf
Braking System - Test.pdf
Bucket Cutting Edges - Inspect Replace.pdf
Bucket Tips - Inspect Replace.pdf
Cab Air Filter - Clean Replace.pdf
Capacities (Refill).pdf
Cooling System Coolant (ELC) - Change.pdf
Cooling System Coolant Extender (ELC) - Add.pdf
Cooling System Coolant Level - Check.pdf
Cooling System Water Temperature Regulator - Clean Replace.pdf
Differential Oil (Front) - Change.pdf
Differential Oil (Rear) - Change.pdf
Differential Oil Level (Front) - Check.pdf
Differential Oil Level (Rear) - Check.pdf
Drive Shaft Spline - Lubricate.pdf
Engine Air Filter Primary Element - Clean Replace.pdf
Engine Air Filter Secondary Element - Replace.pdf
Engine Air Filter Service Indicator - Inspect.pdf
Engine Oil and Filter - Change.pdf
Engine Oil Level - Check.pdf
Engine Valve Lash - Check.pdf
Extendable Stick Pads - Inspect Replace - If Equipped.pdf
Final Drive Oil (Front) - Change.pdf
Final Drive Oil (Rear) - Change - All Wheel Steer.pdf
Final Drive Oil Level (Front) - Check.pdf
Final Drive Oil Level (Rear) - Check - All Wheel Steer.pdf
Fuel System - Prime.pdf
Fuel System Filter and Water Separator - Replace.pdf
Fuel System Water Separator - Drain.pdf
Fuel Tank Water and Sediment - Drain 1.pdf
Fuel Tank Water and Sediment - Drain.pdf
Fuses - Replace 1.pdf
Fuses - Replace.pdf
Hydraulic System Oil - Change.pdf
Hydraulic System Oil Filter - Replace.pdf
Hydraulic System Oil Level - Check.pdf
Kingpin Bearings (Front) - Lubricate - Two-Wheel Drive Only.pdf
Loader Bucket Cylinder and Linkage Bearings - Lubricate.pdf
Lubricant Viscosities.pdf
Maintenance Interval Schedule.pdf
Oil Filter - Inspect.pdf
Parking Brake - Check Adjust.pdf
Radiator Core - Clean.pdf
Rollover Protective Structure (ROPS) - Inspect.pdf
Seat Belt - Inspect.pdf
Seat Belt - Replace.pdf
Sideshift Stabilizer Wear Pads - Inspect.pdf
S·O·S Information.pdf
Tire Check.pdf
Tire Inflation Pressure Adjustment.pdf
Tire Inflation with Air.pdf
Tire Installation.pdf
Tire Shipping Pressure.pdf
Transmission Magnetic Screen - Clean.pdf
Transmission Oil - Change.pdf
Transmission Oil Filter - Replace.pdf
Transmission Oil Level - Check.pdf
Welding on Machines and Engines with Electronic Controls.pdf
Wheel Bearings (Front) - Lubricate - Two-Wheel Drive.pdf
Window Washer Reservoir - Fill.pdf
-Schematic
RENR3586 416D and 424D Backhoe Loader Hydraulic System.pdf
RENR3587 416D 420D 424D 428D 430D 432D 438D and 442D Backhoe Loaders Electrical System.pdf
SENR3981 Fluid Power and Electrical Graphic Symbols (2).pdf
-Testing and Adjusting
Air in Fuel - Test.pdf
Air Inlet and Exhaust System - Inspect.pdf
Axle (Front) - Adjust.pdf
Axle Differential and Brake Troubleshooting.pdf
Brake System Air - Purge.pdf
Compression - Test.pdf
Connecting Rod - Inspect.pdf
Cooling System - Check - Overheating.pdf
Cooling System - Test.pdf
Cylinder Head - Inspect.pdf
Differential Lock - Adjust.pdf
Drive and Steering Axle (Front) - Adjust.pdf
Electric Starting System - Test.pdf
Engine Oil Pump - Inspect.pdf
Exhaust Temperature - Test.pdf
Finding Top Center Position for No. 1 Piston.pdf
Flywheel - Inspect.pdf
Flywheel Housing - Inspect.pdf
Fuel Injection Nozzle - Test.pdf
Fuel Injection Timing - Check.pdf
Fuel System Pressure - Test.pdf
Gear Group (Front) - Time.pdf
Gear Group - Inspect.pdf
Hydraulic Oil Contamination - Test.pdf
Hydraulic Pump - Test and Adjust.pdf
Hydraulic System Troubleshooting.pdf
Machine Preparation for Troubleshooting.pdf
Operational Checks.pdf
Parking Brake Control - Adjust.pdf
Pilot System Pressure - Test.pdf
Power Train Troubleshooting.pdf
Pressure Taps.pdf
Pump Flow - Test.pdf
Relief Valve (Line) - Test and Adjust.pdf
Relief Valve (Steering Priority) - Test and Adjust.pdf
Ride Control - Test.pdf
Ride Control Accumulator - Test and Charge.pdf
Service Brake Control - Adjust.pdf
Signal Resolver Network - Check.pdf
Steering System Troubleshooting.pdf
Transmission and Torque Converter - Test.pdf
Troubleshooting Engine.pdf
Worksheets - Troubleshoot.pdf
Brand: Caterpillar
List of Files:
Cab - Install.pdf
Cab - Remove.pdf
Seat - Assemble.pdf
Seat - Install.pdf
Seat - Remove.pdf
Fuses - Replace.pdf
Tire Check.pdf
-Schematic
Pressure Taps.pdf
- CAT 416D Parts Manual
- CAT 420D Parts Manual
